(commit 10d8713429d345867fc8998d6193b233c0cab28c upstream)
Mixing asm and C code is not recommended in a naked function by
gcc and leads to an error when using clang:
drivers/bus/arm-cci.c:2107:2: error: non-ASM statement in naked
function is not supported
unreachable();
While the function is marked __naked it actually properly return
in asm. There is no need for the unreachable() call.
GCC 7.2 generates identical object files before and after, other
than (for obvious reasons) the line numbers generated by
WANT_WARN_ON_SLOWPATH for all the WARN()s appearing later in the
file.
Suggested-by: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit 1898eb61fbc9703efee886d3abec27a388cf28c3 ]
The ARM CCN PMU driver uses dev_warn() to complain about parameters in
the user-provided perf_event_attr. This means that under normal
operation (e.g. a single invocation of the perf tool), a number of
messages warnings may be logged to dmesg.
Tools may issue multiple syscalls to probe for feature support, and
multiple applications (from multiple users) can attempt to open events
simultaneously, so this is not very helpful, even if a user happens to
have access to dmesg. Worse, this can push important information out of
the dmesg ring buffer, and can significantly slow down syscall fuzzers,
vastly increasing the time it takes to find critical bugs.
Demote the dev_warn() instances to dev_dbg(), as is the case for all
other PMU drivers under drivers/perf/. Users who wish to debug PMU event
initialisation can enable dynamic debug to receive these messages.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
commit e2bf801ecd4e62222a46d1ba9e57e710171d29c1 upstream.
Include the OF-based modalias in the uevent sent when registering devices
on the sunxi RSB bus, so that user space has a chance to autoload the
kernel module for the device.
Fixes a regression caused by commit 3f241bfa60bd ("arm64: allwinner: a64:
pine64: Use dcdc1 regulator for mmc0"). When the axp20x-rsb module for
the AXP803 PMIC is built as a module, it is not loaded and the system
ends up with an disfunctional MMC controller.
Fixes: d787dcdb9c8f ("bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus")
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit c7f5828bf77dcbd61d51f4736c1d5aa35663fbb4 ]
When the PMU driver is built as a module, the perf expects the
pmu->module to be valid, so that the driver is prevented from
being unloaded while it is in use. Fix the CCN pmu driver to
fill in this field.
Fixes: a33b0daab73a0 ("bus: ARM CCN PMU driver")
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
instances left.
commit b69f63ebf553504739cc8534cbed31bd530c6f0b upstream.
Unregistering the driver before calling cpuhp_remove_multi_state() removes
any remaining hotplug cpu instances so __cpuhp_remove_state_cpuslocked()
doesn't emit this warning:
[ 268.748362] Error: Removing state 147 which has instances left.
[ 268.748373] ------------[ cut here ]------------
[ 268.748386] WARNING: CPU: 2 PID: 5476 at kernel/cpu.c:1734 __cpuhp_remove_state_cpuslocked+0x454/0x4f0
[ 268.748389] Modules linked in: arm_ccn(-) [last unloaded: arm_ccn]
[ 268.748403] CPU: 2 PID: 5476 Comm: rmmod Tainted: G W 4.14.0-rc4+ #3
[ 268.748406] Hardware name: AMD Seattle/Seattle, BIOS 10:18:39 Dec 8 2016
[ 268.748410] task: ffff8001a18ca000 task.stack: ffff80019c120000
[ 268.748416] PC is at __cpuhp_remove_state_cpuslocked+0x454/0x4f0
[ 268.748421] LR is at __cpuhp_remove_state_cpuslocked+0x448/0x4f0
[ 268.748425] pc : [<ffff2000081729ec>] lr : [<ffff2000081729e0>] pstate: 60000145
[ 268.748427] sp : ffff80019c127d30
[ 268.748430] x29: ffff80019c127d30 x28: ffff8001a18ca000
[ 268.748437] x27: ffff20000c2cb000 x26: 1fffe4000042d490
[ 268.748443] x25: ffff20000216a480 x24: 0000000000000000
[ 268.748449] x23: ffff20000b08e000 x22: 0000000000000001
[ 268.748455] x21: 0000000000000093 x20: 00000000000016f8
[ 268.748460] x19: ffff20000c2cbb80 x18: 0000ffffb5fe7c58
[ 268.748466] x17: 00000000004402d0 x16: 1fffe40001864f01
[ 268.748472] x15: ffff20000c4bf8b0 x14: 0000000000000000
[ 268.748477] x13: 0000000000007032 x12: ffff20000829ae48
[ 268.748483] x11: ffff20000c4bf000 x10: 0000000000000004
[ 268.748488] x9 : 0000000000006fbc x8 : ffff20000c318a40
[ 268.748494] x7 : 0000000000000000 x6 : ffff040001864f02
[ 268.748500] x5 : 0000000000000000 x4 : 0000000000000000
[ 268.748505] x3 : 0000000000000007 x2 : dfff200000000000
[ 268.748510] x1 : 000000000000ad3d x0 : 00000000000001f0
[ 268.748516] Call trace:
[ 268.748521] Exception stack(0xffff80019c127bf0 to 0xffff80019c127d30)
[ 268.748526] 7be0: 00000000000001f0 000000000000ad3d
[ 268.748531] 7c00: dfff200000000000 0000000000000007 0000000000000000 0000000000000000
[ 268.748535] 7c20: ffff040001864f02 0000000000000000 ffff20000c318a40 0000000000006fbc
[ 268.748539] 7c40: 0000000000000004 ffff20000c4bf000 ffff20000829ae48 0000000000007032
[ 268.748544] 7c60: 0000000000000000 ffff20000c4bf8b0 1fffe40001864f01 00000000004402d0
[ 268.748548] 7c80: 0000ffffb5fe7c58 ffff20000c2cbb80 00000000000016f8 0000000000000093
[ 268.748553] 7ca0: 0000000000000001 ffff20000b08e000 0000000000000000 ffff20000216a480
[ 268.748557] 7cc0: 1fffe4000042d490 ffff20000c2cb000 ffff8001a18ca000 ffff80019c127d30
[ 268.748562] 7ce0: ffff2000081729e0 ffff80019c127d30 ffff2000081729ec 0000000060000145
[ 268.748566] 7d00: 00000000000001f0 0000000000000000 0001000000000000 0000000000000000
[ 268.748569] 7d20: ffff80019c127d30 ffff2000081729ec
[ 268.748575] [<ffff2000081729ec>] __cpuhp_remove_state_cpuslocked+0x454/0x4f0
[ 268.748580] [<ffff200008172adc>] __cpuhp_remove_state+0x54/0x80
[ 268.748597] [<ffff20000215dd84>] arm_ccn_exit+0x2c/0x70 [arm_ccn]
[ 268.748604] [<ffff20000834cfbc>] SyS_delete_module+0x5a4/0x708
[ 268.748607] Exception stack(0xffff80019c127ec0 to 0xffff80019c128000)
[ 268.748612] 7ec0: 0000000019bb7258 0000000000000800 ba64d0fb3d26a800 00000000000000da
[ 268.748616] 7ee0: 0000ffffb6144e28 0000ffffcd95b409 fefefefefefefeff 7f7f7f7f7f7f7f7f
[ 268.748621] 7f00: 000000000000006a 1999999999999999 0000ffffb6179000 0000000000bbcc6d
[ 268.748625] 7f20: 0000ffffb6176b98 0000ffffcd95c2d0 0000ffffb5fe7b58 0000ffffb6163000
[ 268.748630] 7f40: 0000ffffb60ad3e0 00000000004402d0 0000ffffb5fe7c58 0000000019bb71f0
[ 268.748634] 7f60: 0000ffffcd95c740 0000000000000000 0000000019bb71f0 0000000000416700
[ 268.748639] 7f80: 0000000000000000 00000000004402e8 0000000019bb6010 0000ffffcd95c748
[ 268.748643] 7fa0: 0000000000000000 0000ffffcd95c460 00000000004113a8 0000ffffcd95c460
[ 268.748648] 7fc0: 0000ffffb60ad3e8 0000000080000000 0000000019bb7258 000000000000006a
[ 268.748652] 7fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 268.748657] [<ffff200008084f9c>] __sys_trace_return+0x0/0x4
[ 268.748661] ---[ end trace a996d358dcaa7f9c ]---
Fixes: 8df038725ad5 ("bus/arm-ccn: Use cpu-hp's multi instance support instead custom list")
Signed-off-by: Kim Phillips <kim.phillips@arm.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
commit b18c2b9487d8e797fc0a757e57ac3645348c5fba upstream.
Booting a DEBUG_PREEMPT enabled kernel on a CCN-based system
results in the following splat:
arm-ccn e8000000.ccn: No access to interrupts, using timer.
BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1
caller is debug_smp_processor_id+0x1c/0x28
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.13.0 #6111
Hardware name: AMD Seattle/Seattle, BIOS 17:08:23 Jun 26 2017
Call trace:
[<ffff000008089e78>] dump_backtrace+0x0/0x278
[<ffff00000808a22c>] show_stack+0x24/0x30
[<ffff000008bc3bc4>] dump_stack+0x8c/0xb0
[<ffff00000852b534>] check_preemption_disabled+0xfc/0x100
[<ffff00000852b554>] debug_smp_processor_id+0x1c/0x28
[<ffff000008551bd8>] arm_ccn_probe+0x358/0x4f0
as we use smp_processor_id() in the wrong context.
Turn this into a get_cpu()/put_cpu() that extends over the CPU hotplug
registration, making sure that we don't race against a CPU down operation.
commit 24771179c5c138f0ea3ef88b7972979f62f2d5db upstream.
Check memory allocation failures and return -ENOMEM in such cases
This avoids a potential NULL pointer dereference.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Scott Branden <scott.branden@broadcom.com>
commit 4608af8aa53e7f3922ddee695d023b7bcd5cb35b upstream.
The ARM CCI driver seem to be using smp_processor_id() in a
preemptible context, which is likely to make a DEBUG_PREMPT
kernel scream at boot time.
hotplug registration, making sure that we don't race against
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
At least the Armada XP SoC supports 4GB on a single DRAM window. Because
the size register values contain the actual size - 1, the MSB is set in
that case. For example, the SDRAM window's control register's value is
0xffffffe1 for 4GB (bits 31 to 24 contain the size).
The MBUS driver reads back each window's size from registers and
calculates the actual size as (control_reg | ~DDR_SIZE_MASK) + 1, which
overflows for 32 bit values, resulting in other miscalculations further
on (a bad RAM window for the CESA crypto engine calculated by
mvebu_mbus_setup_cpu_target_nooverlap() in my case).
This patch changes the type in 'struct mbus_dram_window' from u32 to
u64, which allows us to keep using the same register calculation code in
most MBUS-using drivers (which calculate ->size - 1 again).
Fixes: fddddb52a6c4 ("bus: introduce an Marvell EBU MBus driver")
CC: stable@vger.kernel.org
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Pull ARM SoC driver updates from Olof Johansson:
"This branch contains platform-related driver updates for ARM and ARM64.
Among them:
- Reset driver updates:
+ New API for dealing with arrays of resets
+ Make unimplemented {de,}assert return success on shared resets
+ MSDKv1 driver
+ Removal of obsolete Gemini reset driver
+ Misc updates for sunxi and Uniphier
- SoC drivers:
+ Platform SoC driver registration on Tegra
+ Shuffle of Qualcomm drivers into a submenu
+ Allwinner A64 support for SRAM
+ Renesas R-Car R3 support
+ Power domains for Rockchip RK3366
- Misc updates and smaller fixes for TEE and memory driver
subsystems"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
firmware: arm_scpi: fix endianness of dev_id in struct dev_pstate_set
soc/tegra: fuse: Add missing semi-colon
soc/tegra: Restrict SoC device registration to Tegra
drivers: soc: sunxi: add support for A64 and its SRAM C
drivers: soc: sunxi: add support for remapping func value to reg value
drivers: soc: sunxi: fix error processing on base address when claiming
dt-bindings: add binding for Allwinner A64 SRAM controller and SRAM C
bus: sunxi-rsb: Enable by default for ARM64
soc/tegra: Register SoC device
firmware: tegra: set drvdata earlier
memory: Convert to using %pOF instead of full_name
soc: Convert to using %pOF instead of full_name
bus: Convert to using %pOF instead of full_name
firmware: Convert to using %pOF instead of full_name
soc: mediatek: add SCPSYS power domain driver for MediaTek MT7622 SoC
soc: mediatek: add header files required for MT7622 SCPSYS dt-binding
soc: mediatek: reduce code duplication of scpsys_probe across all SoCs
dt-bindings: soc: update the binding document for SCPSYS on MediaTek MT7622 SoC
reset: uniphier: add analog amplifiers reset control
reset: uniphier: add video input subsystem reset control
https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into next/drivers
Pull "Allwinner driver changes for 4.14" from Chen-Yu Tsai:
Usual driver changes:
- SUNXI_RSB bus driver enabled by default for ARM64
- Support for SRAM controller and SRAM C block on the A64 added
* tag 'sunxi-drivers-for-4.14' of https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
Pull "non-urgent fixes for omaps for v4.14" from Tony Lindgren:
Non-urgent fixes for omaps for v4.14 merge window. These all
can wait for the merge window as we have not seemed to hit
any of these so far:
- Fix error handling in omap_ocp2scp_probe affecting runtime
PM error path
- Drop broken RPM status update for omap_device
- Two fixes for of_irq_get() usage that can return 0
* tag 'omap-for-v4.14/fixes-not-urgent-v2-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP4+: PRM: fix of_irq_get() result checks
ARM: OMAP3+: PRM: fix of_irq_get() result check
ARM: OMAP2+: omap_device: drop broken RPM status update from suspend_noirq
bus: omap-ocp2scp: Fix error handling in omap_ocp2scp_probe
Allwinner's A64 SoC uses the "Reduced Serial Bus" to communicate with
its companion PMIC.
Since arm64 does not have separate defconfigs for each platform or
processor family, enable this driver by default for ARM64 as well.
Note that the Kconfig symbol already depends on ARCH_SUNXI.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
[wens@csie.org: Refined commit message]
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Chen-Yu Tsai <wens@csie.org>
When resuming, set up registers that have been lost in the sleep state.
The error handling code in omap_ocp2scp_probe fails to invoke
pm_runtime_disable and fails to initialize return value in
certain cases. Fix it here.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Pull drm updates from Dave Airlie:
"This is the main pull request for the drm, I think I've got one later
driver pull for mediatek SoC driver, I'm undecided on if it needs to
go to you yet.
Otherwise summary below:
Core drm:
- Atomic add driver private objects
- Deprecate preclose hook in modern drivers
- MST bandwidth tracking
- Use kvmalloc in more places
- Add mode_valid hook for crtc/encoder/bridge
- Reduce sync_file construction time
- Documentation updates
- New DRM synchronisation object support
New drivers:
- pl111 - pl111 CLCD display controller
Panel:
- Innolux P079ZCA panel driver
- Add NL12880B20-05, NL192108AC18-02D, P320HVN03 panels
- panel-samsung-s6e3ha2: Add s6e3hf2 panel support
i915:
- SKL+ watermark fixes
- G4x/G33 reset improvements
- DP AUX backlight improvements
- Buffer based GuC/host communication
- New getparam for (sub)slice infomation
- Cannonlake and Coffeelake initial patches
- Execbuf optimisations
radeon/amdgpu:
- Lots of Vega10 bug fixes
- Preliminary raven support
- KIQ support for compute rings
- MEC queue management rework
- DCE6 Audio support
- SR-IOV improvements
- Better radeon/amdgpu selection support
nouveau:
- HDMI stereoscopic support
- Display code rework for >= GM20x GPUs
msm:
- GEM rework for fine-grained locking
- Per-process pagetable work
- HDMI fixes for Snapdragon 820.
vc4:
- Remove 256MB CMA limit from vc4
- Add out-fence support
- Add support for cygnus
- Get/set tiling ioctls support
- Add T-format tiling support for scanout
zte:
- add VGA support.
etnaviv:
- Thermal throttle support for newer GPUs
- Restore userspace buffer cache performance
- dma-buf sync fix
stm:
- add stm32f429 display support
exynos:
- Rework vblank handling
- Fixup sw-trigger code
sun4i:
- V3s display engine support
- HDMI support for older SoCs
- Preliminary work on dual-pipeline SoCs.
rcar-du:
- VSP work
imx-drm:
- Remove counter load enable from PRE
- Double read/write reduction flag support
tegra:
- Documentation for the host1x and drm driver.
- Lots of staging ioctl fixes due to grate project work.
omapdrm:
- dma-buf fence support
- TILER rotation fixes"
* tag 'drm-for-v4.13' of git://people.freedesktop.org/~airlied/linux: (1270 commits)
drm: Remove unused drm_file parameter to drm_syncobj_replace_fence()
drm/amd/powerplay: fix bug fail to remove sysfs when rmmod amdgpu.
amdgpu: Set cik/si_support to 1 by default if radeon isn't built
drm/amdgpu/gfx9: fix driver reload with KIQ
drm/amdgpu/gfx8: fix driver reload with KIQ
drm/amdgpu: Don't call amd_powerplay_destroy() if we don't have powerplay
drm/ttm: Fix use-after-free in ttm_bo_clean_mm
drm/amd/amdgpu: move get memory type function from early init to sw init
drm/amdgpu/cgs: always set reference clock in mode_info
drm/amdgpu: fix vblank_time when displays are off
drm/amd/powerplay: power value format change for Vega10
drm/amdgpu/gfx9: support the amdgpu.disable_cu option
drm/amd/powerplay: change PPSMC_MSG_GetCurrPkgPwr for Vega10
drm/amdgpu: Make amdgpu_cs_parser_init static (v2)
drm/amdgpu/cs: fix a typo in a comment
drm/amdgpu: Fix the exported always on CU bitmap
drm/amdgpu/gfx9: gfx_v9_0_enable_gfx_static_mg_power_gating() can be static
drm/amdgpu/psp: upper_32_bits/lower_32_bits for address setup
drm/amd/powerplay/cz: print message if smc message fails
drm/amdgpu: fix typo in amdgpu_debugfs_test_ib_init
Pull ARM SoC driver updates from Arnd Bergmann:
"New SoC specific drivers:
- NVIDIA Tegra PM Domain support for newer SoCs (Tegra186 and later)
based on the "BPMP" firmware
- Clocksource and system controller drivers for the newly added
Action Semi platforms (both arm and arm64).
Reset subsystem, merged through arm-soc by tradition:
- New drivers for Altera Stratix10, TI Keystone and Cortina Gemini
SoCs
- Various subsystem-wide cleanups
Updates for existing SoC-specific drivers
- TI GPMC (General Purpose Memory Controller)
- Mediatek "scpsys" system controller support for MT6797
- Broadcom "brcmstb_gisb" bus arbitrer
- ARM SCPI firmware
- Renesas "SYSC" system controller
One more driver update was submitted for the Freescale/NXP DPAA data
path acceleration that has previously been used on PowerPC chips. I
ended up postponing the merge until some API questions for its unusual
MMIO access are resolved"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
clocksource: owl: Add S900 support
clocksource: Add Owl timer
soc: renesas: rcar-sysc: Use GENPD_FLAG_ALWAYS_ON
firmware: tegra: Fix locking bugs in BPMP
soc/tegra: flowctrl: Fix error handling
soc/tegra: bpmp: Implement generic PM domains
soc/tegra: bpmp: Update ABI header
PM / Domains: Allow overriding the ->xlate() callback
soc: brcmstb: enable drivers for ARM64 and BMIPS
soc: renesas: Rework Kconfig and Makefile logic
reset: Add the TI SCI reset driver
dt-bindings: reset: Add TI SCI reset binding
reset: use kref for reference counting
soc: qcom: smsm: Improve error handling, quiesce probe deferral
cpufreq: scpi: use new scpi_ops functions to remove duplicate code
firmware: arm_scpi: add support to populate OPPs and get transition latency
dt-bindings: reset: Add reset manager offsets for Stratix10
memory: omap-gpmc: add error message if bank-width property is absent
memory: omap-gpmc: make dts snippet include semicolon
reset: Add a Gemini reset controller
Add compatible string for the ARM CCN-502 interconnect
Signed-off-by: Velibor Markovski <velibor.markovski@broadcom.com>
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Multiplications for the size determination of memory allocations
indicated that array data structures should be processed.
Thus use the corresponding function "devm_kcalloc".
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
If the driver is built as a module, autoload won't work because the module
alias information is not filled. So user-space can't match the registered
device with the corresponding module.
Export the module alias information using the MODULE_DEVICE_TABLE() macro.
Before this patch:
$ modinfo drivers/bus/arm-ccn.ko | grep alias
After this patch:
alias: of:N*T*Carm,ccn-504C*
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
In fact, it is needed for PCI to work on msm8996 (and probably other
things). No idea why it was depending on renesas but that doesn't make
any sense. So drop the dependency.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
The 7278 introduces a new version of this core. This
commit adds support for that revision.
Signed-off-by: Doug Berger <opendmb@gmail.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The ARM64 architecture can provide meaningful diagnostic
output from the GISB arbiter solely from interrupts and
notifiers without the need to hook the low level fault
handlers.
The ARM architecture can provide meaningful diagnostic
handlers.
Check for GISB arbitration errors through a chained notifier
when a process dies or a kernel panic occurs. This allows a
meaningful GISB diagnostic message to occur along with other
diagnostic information from the event.
The GISB bus can support addresses beyond 32-bits. So this commit
corrects support for reading a captured 64-bit address into a 64-bit
variable by obtaining the high bits from the ARB_ERR_CAP_HI_ADDR
register (when present) and then outputting the full 64-bit value.
It also removes unused definitions.
Fixes: 44127b771d9c ("bus: add Broadcom GISB bus arbiter timeout/error handler")
Acked-by: Gregory Fong <gregory.0xf0@gmail.com>
This commit corrects the bug introduced in commit f80835875d3d
("bus: brcmstb_gisb: Look up register offsets in a table") such
that gisb_write() translates the register enumeration into an
offset from the base address for writes as well as reads.
Fixes: f80835875d3d ("bus: brcmstb_gisb: Look up register offsets in a table")
"Driver updates for ARM SoCs.
A handful of driver changes this time around. The larger changes are:
- Reset drivers for hi3660 and zx2967
- AHCI driver for Davinci, acked by Tejun and brought in here due to
platform dependencies
- Cleanups of atmel-ebi (External Bus Interface)
- Tweaks for Rockchip GRF (General Register File) usage (kitchensink
misc register range on the SoCs)
- PM domains changes for support of two new ZTE SoCs (zx296718 and
zx2967)"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
soc: samsung: pmu: Add register defines for pad retention control
reset: make zx2967 explicitly non-modular
reset: core: fix reset_control_put
soc: samsung: pm_domains: Read domain name from the new label property
soc: samsung: pm_domains: Remove message about failed memory allocation
soc: samsung: pm_domains: Remove unused name field
soc: samsung: pm_domains: Use full names in subdomains registration log
sata: ahci-da850: un-hardcode the MPY bits
sata: ahci-da850: add a workaround for controller instability
sata: ahci: export ahci_do_hardreset() locally
sata: ahci-da850: implement a workaround for the softreset quirk
sata: ahci-da850: add device tree match table
sata: ahci-da850: get the sata clock using a connection id
soc: samsung: pmu: Remove duplicated define for ARM_L2_OPTION register
memory: atmel-ebi: Enable the SMC clock if specified
soc: samsung: pmu: Remove unused and duplicated defines
memory: atmel-ebi: Properly handle multiple reference to the same CS
memory: atmel-ebi: Fix the test to enable generic SMC logic
soc: samsung: pm_domains: Add new Exynos5433 compatible
soc: samsung: pmu: Add dummy support for Exynos5433 SoC
Since we want this external bus to be available on multi_v7 builds,
set to default ARCH_QCOM so we get it selected whenever QCOM is
enabled.
Suggested-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
I noticed my e-mail address is wrong in this one. This patch fixes it.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
When the state names got added a script was used to add the extra argument
to the calls. The script basically converted the state constant to a
string, but the cleanup to convert these strings into meaningful ones did
not happen.
Replace all the useless strings with 'subsys/xxx/yyy:state' strings which
are used in all the other places already.
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/20161221192112.085444152@linutronix.de
In case the driver registration fails, the hotplug callback is leaked.
Not fatal, because it's never invoked as there are no instances registered,
but wrong nevertheless.
Fixes: fdc15a36d84e ("bus/arm-ccn: Convert to hotplug statemachine")
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- A new driver for the power management controller on TI Keystone
- Support for the prerelease "SCPI" firmware protocol that ended up
being shipped by Amlogic in their GXBB SoC.
- A soc_device can now be matched using a glob from inside the
kernel, when another driver wants to know the specific chip it is
running on and cannot find out from DT, firmware or hardware.
- Renesas SoCs now support identification through the soc_device
interface, both in user space and kernel.
- Renesas r8a7743 and r8a7745 gain support for their system
controller
- A new checking module for the ARM "PSCI" (not to be confused with
"SCPI" mentioned above) firmware interface.
- A new driver for the Tegra GMI memory interface
- Support for the Tegra firmware interfaces with their power
management controllers
As usual, the updates for the reset controller framework are merged
here, as they tend to touch multiple SoCs as well, including a new
driver for the Oxford (now Broadcom) OX820 chip and the Tegra bpmp
interface.
The existing drivers for Atmel, Qualcomm, NVIDIA, TI Davinci, and
Rockchips SoCs see some further updates"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
misc: sram: remove useless #ifdef
drivers: psci: Allow PSCI node to be disabled
drivers: psci: PSCI checker module
soc: renesas: Identify SoC and register with the SoC bus
firmware: qcom: scm: Return PTR_ERR when devm_clk_get fails
firmware: qcom: scm: Remove core, iface and bus clocks dependency
dt-bindings: firmware: scm: Add MSM8996 DT bindings
memory: da8xx-ddrctl: drop the call to of_flat_dt_get_machine_name()
bus: da8xx-mstpri: drop the call to of_flat_dt_get_machine_name()
ARM: shmobile: Document DT bindings for Product Register
soc: renesas: rcar-sysc: add R8A7745 support
reset: Add Tegra BPMP reset driver
dt-bindings: firmware: Allow child nodes inside the Tegra BPMP
dt-bindings: Add power domains to Tegra BPMP firmware
firmware: tegra: Add BPMP support
firmware: tegra: Add IVC library
dt-bindings: firmware: Add bindings for Tegra BPMP
mailbox: tegra-hsp: Use after free in tegra_hsp_remove_doorbells()
mailbox: Add Tegra HSP driver
firmware: arm_scpi: add support for pre-v1.0 SCPI compatible
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- Added support for the TI DRA71x family of SoCs in mach-omap2, this
is an new variant of the the DRA72x/DRA74x automotive infotainment
chips we already supported for a while.
- Added support for the ST STM32F746 SoC, the first Cortex-M7 based
microcontroller we support, related to the smaller STM32F4 family.
- Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see
http://elinux.org/RZ-G
- SMP is now supported on the OX820 platform
- A lot of code in mach-omap2 gets removed as a follow-up to removing
support for board files in the previous release
- Davinci has some new work to improve USB support
- For i.MX, the performance monitor now supports profiling the memory
controller using 'perf'"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits)
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: da850-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6
ARM: davinci: da8xx: Fix ohci device name
ARM: oxnas: Add OX820 config and makefile entry
ARM: oxnas: Add OX820 SMP support
ARM: davinci: PM: fix build when da850 not compiled in
ARM: orion5x: remove legacy support of ls-chl
ARM: integrator: drop EBI access use syscon
ARM: BCM5301X: Add back handler ignoring external imprecise aborts
ARM: davinci: PM: support da8xx DT platforms
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
ARM: Kconfig: Introduce MACH_STM32F746 flag
ARM: mach-stm32: Add a new SOC - STM32F746
ARM: shmobile: document SK-RZG1E board
ARM: shmobile: r8a7745: basic SoC support
ARM: imx: mach-imx6ul: add imx6ull support
ARM: zynq: Reserve correct amount of non-DMA RAM
Make sure to drop the reference to the parent device taken by
class_find_device() after populating the bus.
Fixes: 3b9334ac835b ("mfd: vexpress: Convert custom func API to regmap")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers
Pull "DaVinci driver updates for v4.10 (part 2)" from Sekhar Nori:
Fixes for drivers already queued to prevent
section mismatch warnings introduced by them.
* tag 'davinci-for-v4.10/drivers-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
In order to avoid a section mismatch drop the call to
of_flat_dt_get_machine_name() when printing the error message.
While we're at it: fix a typo.
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/drivers
bus: Add Tegra GMI support
This provides a driver to enable the use of the Generic Memory Interface
found on Tegra SoCs that can host various types of high-speed devices.
* tag 'tegra-for-4.10-bus' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
bus: Add support for Tegra Generic Memory Interface
dt/bindings: Add bindings for Tegra GMI controller
The Generic Memory Interface bus can be used to connect high-speed
devices such as NOR flash, FPGAs, DSPs...
Signed-off-by: Mirza Krak <mirza.krak@gmail.com>
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Tested-on: Colibri T20/T30 on EvalBoard V3.x and GMI-Memory Board
Acked-by: Jon Hunter <jonathanh@nvidia.com>
[treding@nvidia.com: symmetry and coding style OCD]
Signed-off-by: Thierry Reding <treding@nvidia.com>
Create the driver for the da8xx master peripheral priority
configuration and implement support for writing to the three
Master Priority registers on da850 SoCs.
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
Acked-by: Rob Herring <robh@kernel.org>
[nsekhar@ti.com: subject line adjustment]
This hides the option for people who do not want their Kconfig
vision cluttered (i.e. x86) and enables compile testing apart
from the supported main arch.
Cc: Stephen Boyd <sboyd@codeaurora.org>
The CCI ports programming interface is available to the kernel
only when booted in secure mode (or when firmware enables
non-secure access to override CCI ports control). In both cases,
firmware reports the CCI ports availability through the device
tree CCI ports nodes, which must be parsed and their status checked
by the kernel probing path.
This check is currently missing and may cause the kernel to
erroneously believe it is free to take control of CCI ports
where in practice CCI ports control is forbidden.
Add the missing CCI port availability check to the CCI driver
in order to guarantee sane CCI usage.
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
Pull CPU hotplug updates from Thomas Gleixner:
"Yet another batch of cpu hotplug core updates and conversions:
- Provide core infrastructure for multi instance drivers so the
drivers do not have to keep custom lists.
- Convert custom lists to the new infrastructure. The block-mq custom
list conversion comes through the block tree and makes the diffstat
tip over to more lines removed than added.
- Handle unbalanced hotplug enable/disable calls more gracefully.
- Remove the obsolete CPU_STARTING/DYING notifier support.
- Convert another batch of notifier users.
The relayfs changes which conflicted with the conversion have been
shipped to me by Andrew.
The remaining lot is targeted for 4.10 so that we finally can remove
the rest of the notifiers"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits)
cpufreq: Fix up conversion to hotplug state machine
blk/mq: Reserve hotplug states for block multiqueue
x86/apic/uv: Convert to hotplug state machine
s390/mm/pfault: Convert to hotplug state machine
mips/loongson/smp: Convert to hotplug state machine
mips/octeon/smp: Convert to hotplug state machine
fault-injection/cpu: Convert to hotplug state machine
padata: Convert to hotplug state machine
cpufreq: Convert to hotplug state machine
ACPI/processor: Convert to hotplug state machine
virtio scsi: Convert to hotplug state machine
oprofile/timer: Convert to hotplug state machine
block/softirq: Convert to hotplug state machine
lib/irq_poll: Convert to hotplug state machine
x86/microcode: Convert to hotplug state machine
sh/SH-X3 SMP: Convert to hotplug state machine
ia64/mca: Convert to hotplug state machine
ARM/OMAP/wakeupgen: Convert to hotplug state machine
ARM/shmobile: Convert to hotplug state machine
arm64/FP/SIMD: Convert to hotplug state machine
After being asked to not depend on ARCH_QCOM* or similar,
unsurprisingly compilation fails on UM as it has no I/O
memory:
drivers/built-in.o: In function `qcom_ebi2_probe':
>> drivers/bus/qcom-ebi2.c:333: undefined reference to
`devm_ioremap_resource'
Fix this by letting the Kconfig atleast depend on HAS_IOMEM.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Andy Gross <andy.gross@linaro.org>
Cc: linux-arm-msm@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/drivers
Pull "Qualcomm EBI2 bindings and bus driver" from Linus Walleij
* tag 'qcom-ebi2-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator:
Acked-by: Andy Gross <andy.gross@linaro.org>
This adds a driver for the Qualcomm External Bus Interface EBI2
found in the MSM8660 and APQ8060 SoCs (at least).
This was tested with the SMSC9112 ethernet on the APQ8060
Dragonboard sitting on top of the SLOW CS2.
Some of my understanding if very vague and based on guesses and
extrapolations: the documentation in APQ8060 Qualcomm Application
Processor User Guide 80-N7150-14 Rev. A describes select features but
does not document the register bit fields.
For one of the CCI events exposed under sysfs, "snoop" was typo'd as
"snopp". Correct this such that users see the expected event name when
enumerating events via sysfs.
Cc: arm@kernel.org
