path: root/drivers/cdrom/Makefile
2008-01-28cdrom: Add support for Sega Dreamcast GD-ROM.Adrian McMenamin
This patch adds support for the GD-Rom drive, SEGA's proprietary implementation of an IDE CD Rom for the SEGA Dreamcast. This driver implements Sega's Packet Interface (SPI) - at least partially. It will also read disks in SEGA's propreitary GD format. Unlike previous drivers (which were never in mainline) this uses DMA and not PIO to read disks. It is a new driver, not a refactoring of old drivers. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-10Remove legacy CDROM driversJens Axboe
They are all broken beyond repair. Given that nobody has complained about them (most haven't worked in 2.6 AT ALL), remove them from the tree. A new mitsumi driver that actually works is in progress, it'll get added when completed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
