path: root/drivers/cdrom
2011-02-09cdrom: support devices that have check_events but not media_changedSimon Arlott
Commit 93aae17af1172c40c6f74b7294e93a90c3cfaa5d ("sr: implement sr_check_events()") replaced the media_changed op with the check_events op in drivers/scsi/sr.c All users that check for the CDC_MEDIA_CHANGED capbility try both the check_events op and the media_changed op, but register_cdrom() was requiring media_changed. This patch fixes the capability checking. The cdrom_select_disc ioctl is also using the two operations, so they should be required for CDC_SELECT_DISC too. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Cc: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Tested-by: Chris Clayton <chris2553@googlemail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2010-12-24gdrom: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush work on removal instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk>
2010-12-16cdrom: export cdrom_check_events()Jens Axboe
It's used by sr, so we need to export it. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16cdrom: add ->check_events() supportTejun Heo
In principle, cdrom just needs to pass through ->check_events() but CDROM_MEDIA_CHANGED ioctl makes things a bit more complex. Just as with ->media_changed() support, cdrom code needs to buffer the events and serve them to ioctl and vfs as requested. As the code has to deal with both ->check_events() and ->media_changed(), and vfs and ioctl event buffering, this patch adds check_events caching on top of the existing cdi->mc_flags buffering. It may be a good idea to deprecate CDROM_MEDIA_CHANGED ioctl and remove all this mess. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-27cdrom: gdrom: ctrl_in/outX to __raw_read/writeX conversion.Paul Mundt
The ctrl_xxx routines are deprecated, switch over to the __raw_xxx versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07drivers/cdrom: use pr_<level>Joe Perches
- add pr_fmt. - convert printks to pr_<level> - add if (0) and printf argument checking to cdinfo - coalesce consecutive printks to single pr_ - fix a typo "back ground" to "background" - convert printks without level to pr_info - remove VIOCD_ prefixes and use pr_fmt/pr_<level> - add a missing newline to an OS/400 message Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Folded in tab indentation fix from Andrew. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (137 commits) sh: include empty zero page in romImage sh: Make associative cache writes fatal on all SH-4A parts. sh: Drop associative writes for SH-4 cache flushes. sh: Partial revert of copy/clear_user_highpage() optimizations. sh: Add default uImage rule for se7724, ap325rxa, and migor. sh: allow runtime pm without suspend/resume callbacks sh: mach-ecovec24: Remove un-defined settings for VPU sh: mach-ecovec24: LCDC drive ability become high sh: fix sh7724 VEU3F resource size serial: sh-sci: Fix too early port disabling. sh: pfc: pr_info() -> pr_debug() cleanups. sh: pfc: Convert from ctrl_xxx() to __raw_xxx() I/O routines. sh: Improve kfr2r09 serial port setup code sh: Break out SuperH PFC code sh: Move KEYSC header file sh: convert /proc/cpu/aligmnent, /proc/cpu/kernel_alignment to seq_file sh: Add CPG save/restore code for sh7724 R-standby sh: Add SDHI power control support to Ecovec mfd: Add power control platform data to SDHI driver sh: mach-ecovec24: modify address map ...
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl drivers: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a wrapper around /proc/sys all of the binary sysctl support elsewhere in the tree is dead code. Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Brown <neilb@suse.de> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> for drivers/char/hpet.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-13cdrom: gdrom: Kill off PHYSADDR use.Paul Mundt
PHYSADDR() is gone, and completely unecessary in all of the cases the gdrom driver was using it. Kill off all references to it, and change the one legitimate use over to virt_to_phys() instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/ide/ide-io.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-20cdrom: beyond ARRAY_SIZE of viocd_diskinfoRoel Kluin
Do not go beyond ARRAY_SIZE of viocd_diskinfo Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11gdrom: dequeue in-flight requestTejun Heo
gdrom already dequeues and fully completes requests on normal path and the error paths can be easily converted to do so too. Clean it up and dequeue requests on error paths too. While at it remove superflous blk_fs_request() && !blk_rq_sectors() condition check. [ Impact: dequeue in-flight request, cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to dequeueing model (easy ones)Tejun Heo
plat-omap/mailbox, floppy, viocd, mspro_block, i2o_block and mmc/card/queue are already pretty close to dequeueing model and can be converted with simple changes. Convert them. While at it, * xen-blkfront: !fs check moved downwards to share dequeue call with normal path. * mspro_block: __blk_end_request(..., blk_rq_cur_byte()) converted to __blk_end_request_cur() * mmc/card/queue: loop of __blk_end_request() converted to __blk_end_request_all() [ Impact: dequeue in-flight request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: replace end_request() with [__]blk_end_request_cur()Tejun Heo
end_request() has been kept around for backward compatibility; however, it's about time for it to go away. * There aren't too many users left. * Its use of @updtodate is pretty confusing. * In some cases, newer code ends up using mixture of end_request() and [__]blk_end_request[_all](), which is way too confusing. So, add [__]blk_end_request_cur() and replace end_request() with it. Most conversions are straightforward. Noteworthy ones are... * paride/pcd: next_request() updated to take 0/-errno instead of 1/0. * paride/pf: pf_end_request() and next_request() updated to take 0/-errno instead of 1/0. * xd: xd_readwrite() updated to return 0/-errno instead of 1/0. * mtd/mtd_blkdevs: blktrans_discard_request() updated to return 0/-errno instead of 1/0. Unnecessary local variable res initialization removed from mtd_blktrans_thread(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Laurent Vivier <Laurent@lvivier.info> Cc: Tim Waugh <tim@cyberelk.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: unsik Kim <donari75@gmail.com>
2009-04-28block: implement and use [__]blk_end_request_all()Tejun Heo
There are many [__]blk_end_request() call sites which call it with full request length and expect full completion. Many of them ensure that the request actually completes by doing BUG_ON() the return value, which is awkward and error-prone. This patch adds [__]blk_end_request_all() which takes @rq and @error and fully completes the request. BUG_ON() is added to to ensure that this actually happens. Most conversions are simple but there are a few noteworthy ones. * cdrom/viocd: viocd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/block/dasd: dasd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/char/tape_block: tapeblock_end_request() replaced with direct calls to blk_end_request_all(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mike Miller <mike.miller@hp.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29cdrom: reduce stack usage of mmc_ioctl_dvd_read_structMarcin Slusarz
1. kmalloc 192 bytes in dvd_read_bca (which is inlined into dvd_read_struct) 2. Pass struct packet_command to all dvd_read_* functions. Checkstack output: Before: mmc_ioctl_dvd_read_struct: 280 After: mmc_ioctl_dvd_read_struct: 56 Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29cdrom: split mmc_ioctl to lower stack usageMarcin Slusarz
Checkstack output: Before: mmc_ioctl: 584 After: mmc_ioctl_dvd_read_struct: 280 mmc_ioctl_cdrom_subchannel: 152 mmc_ioctl_cdrom_read_data: 120 mmc_ioctl_cdrom_volume: 104 mmc_ioctl_cdrom_read_audio: 104 (mmc_ioctl is inlined into cdrom_ioctl - 104 bytes) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-12Commands needing to be retried require a complete re-initialization.Alan D. Brunelle
The test-unit-ready portion of this patch was causing boots to fail on my test machine (as in http://lkml.org/lkml/2008/12/5/161). With this patch in place, the system is booting reliably. Mike Anderson found the same problem in the hp_hw_start_stop code, and I applied the same solution in cdrom_read_cdda_bpc. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-28gdrom: Fix compile errorNobuhiro Iwamatsu
Return value and argument of block_device_operations.release of gdrom was changed. This patch fix this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-21[PATCH] switch viocdAl Viro
2008-10-21[PATCH] switch gdromAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] switch cdrom_{open,release,ioctl} to sane APIsAl Viro
... convert to it in callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] eliminate use of ->f_flags in block methodsAl Viro
store needed information in f_mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-09gdrom: change to use __blk_end_request()Kiyoshi Ueda
This patch converts gdrom to use __blk_end_request() directly so that end_{queued|dequeued}_request() can be removed. gd.transfer is '1' in error cases and '0' in non-error cases, so gdrom hasn't been propagating any error code to the block layer. We can just convert error cases to '-EIO'. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-18cdrom: handle TOCAlexander Inyukhin
This patch should fix TOC handling for cdroms that can not play audio. It extends commit af744e3294d09d706c4eae26cffaaa68a8d40337 ("cdrom: don't check CDC_PLAY_AUDIO in cdrom_count_tracks()") with a safety check and non-audio ioctls support. Since CDC_PLAY_AUDIO flag was used not only to check ability to play audio but also to ensure that audio_ioctl was not NULL, all TOC-related operations had to use it. As far as I understand, now audio_ioctl is never NULL, so a sanity check during device registration should be sufficient. It was tested on Optiarc AD7203A device, that has no ability to play audio. Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [bart: remove now unneeded ->audio_ioctl check (noticed by Borislav)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18gdrom: add dummy audio_ioctl handlerBorislav Petkov
Make sure audio_ioctl is always defined even if being a dummy function since the cdrom_ioctl interface assumes its existence and we don't want to BUG on null ptr on some ioctls like, e.g. CDROMREADTOCENTRY, CDROMREADTOCHDR etc. when we fix CDC_PLAY_AUDIO checking in cdrom.c. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18viocd: add dummy audio ioctl handlerBorislav Petkov
Make sure audio_ioctl is always defined even if being a dummy function since the cdrom_ioctl interface assumes its existence and we don't want to BUG on null ptr on some ioctls like, e.g. CDROMREADTOCENTRY, CDROMREADTOCHDR etc. when we fix CDC_PLAY_AUDIO checking in cdrom.c. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05cdrom: don't check CDC_PLAY_AUDIO in cdrom_count_tracks()Tejun Heo
According to MMC-3 (or any later versions) READ TOCs are mandatory commands and have nothing to do with CDC_PLAY_AUDIO. I have no idea why the check was put there in the first place but it now only breaks automatic actions on certain drives. Note that this test was only effective when ide-cdrom was being used as sr didn't mask CDC_PLAY_AUDIO according to the capabilities. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-29sh: More header path fixups for mach dir refactoring.Paul Mundt
2008-07-04cdrom: revert commit 22a9189 (cdrom: use kmalloced buffers instead of ↵FUJITA Tomonori
buffers on stack) The commit 22a9189fd073db3d03a4cf8b8c098aa207602de1 (cdrom: use kmalloced buffers instead of buffers on stack) is introduced to use kmalloced buffers for packet commands to avoid stack corruption on non coherent platforms. SCSI cdrom uses blk_rq_map_kern, which properly avoids DMA on the stack by using the bounce buffers. IDE cdrom also has the mechnism to avoids DMA on the stack. So we don't need this extra complexitiy in cdrom.c, such as allocating just 8 bytes. The lower layers can handle it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-23[POWERPC] iSeries: Remove unused mail addressStephen Rothwell
I don't use my IBM email address normally and people can find me in CREDITS. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
