Signed-off-by: Brian Swetland <swetland@google.com>
Signed-off-by: Arve Hjønnevåg <arve@android.com>
The first version of this patch proposed an arch/tile/drivers/ directory,
but the consensus was that this was probably a poor choice for a place to
group Tilera-specific drivers, and that in any case grouping by platform
was discouraged, and grouping by function was preferred.
This version of the patch addresses various issues raised in the
community, primarily the absence of sysfs integration. The sysfs
integration now handles passing information on sector size, page size,
and total partition size to userspace as well. In addition, we now
use a single "struct cdev" to manage all the partition minor devices,
and dynamically discover the correct number of partitions from the
hypervisor rather than using a module_param with a default value.
This driver has no particular "peer" drivers it can be grouped with.
It is sort of like an MTD driver for SPI ROM, but it doesn't group well
with the other MTD devices since it relies on hypervisor virtualization
to handle many of the irritating aspects of flash ROM management: sector
awareness, background read for sub-sector writes, bit examination to
determine whether a sector erase needs to be issued, etc. It is in fact
more like an EEPROM driver, but the hypervisor virtualization does require
a "flush" command if you wish to commit a sector write prior to writing
to a different sector, and this is sufficiently different from generic
I2C/SPI EEPROMs that as a result it doesn't group well with them either.
The simple character device is already in use by a range of Tilera
SPI ROM management tools, as well as by customers. In addition, using
the simple character device actually simplifies the userspace tools,
since they don't need to manage sector erase, background read, etc.
This both simplifies the code (since we can uniformly manage plain files
and the SPI ROM) as well as makes the user code portable to non-Linux
platforms that don't offer the same MTD ioctls.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Allow setting of maximal number of raw devices as a module parameter. This
requires changing of static array into a vmalloced one (the array is going to
be too large for kmalloc).
Add smd_pkt driver which provides device interface to smd packet ports.
Signed-off-by: Niranjana Vishwanathapura <nvishwan@codeaurora.org>
Cc: Brian Swetland <swetland@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: David Brown <davidb@codeaurora.org>
drivers/staging/generic_serial/
As planned by Arnd Bergmann, this moves the following drivers to the
drivers/staging/generic_serial directory where they will be removed
after 2.6.41 if no one steps up to claim them.
generic_serial
rio
ser_a2232
sx
vme_scc
Cc: Jiri Slaby <jslaby@suse.cz>
drivers/staging/tty/ directory where they will be removed after 2.6.41
epca
epca
ip2
istallion
riscom8
serial167
specialix
stallion
As planned by Arnd Bergmann, this moves the following drivers from
drivers/char/ to drivers/tty/ as that's where they really belong:
amiserial
nozomi
synclink
rocket
cyclades
moxa
mxser
isicom
bfin_jtag_comm
The Kconfig options for the drivers/tty/ files still were hanging around
in the "big" drivers/char/Kconfig file, so move them to the proper
location under drivers/tty and drivers/tty/hvc/
This converts the existing bfin_jtag_comm TTY driver to the HVC layer so
that the common HVC code can worry about all of the TTY/polling crap and
leave the Blackfin code to worry about the Blackfin bits.
* akpm:
kernel/smp.c: consolidate writes in smp_call_function_interrupt()
kernel/smp.c: fix smp_call_function_many() SMP race
memcg: correctly order reading PCG_USED and pc->mem_cgroup
backlight: fix 88pm860x_bl macro collision
drivers/leds/ledtrig-gpio.c: make output match input, tighten input checking
MAINTAINERS: update Atmel AT91 entry
mm: fix truncate_setsize() comment
memcg: fix rmdir, force_empty with THP
memcg: fix LRU accounting with THP
memcg: fix USED bit handling at uncharge in THP
memcg: modify accounting function for supporting THP better
fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bio
mm: compaction: prevent division-by-zero during user-requested compaction
mm/vmscan.c: remove duplicate include of compaction.h
memblock: fix memblock_is_region_memory()
thp: keep highpte mapped until it is no longer needed
kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERT
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
The newer drivers/gpio/cs5535-gpio.c replaces drivers/misc/cs5535_gpio.c.
The new driver has been in the tree for a little while, and has received
some testing; it's time to mark the old one as deprecated. I'm thinking
removal around 2.6.40 would be good, provided we're not missing critical
functionality in the newer driver.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Cc: Daniel Drake <dsd@laptop.org>
Acked-by: Ben Gardner <bgardner@wabtec.com>
Cc: Greg KH <greg@kroah.com>
This driver adds a basic console that uses the arm JTAG
DCC to transfer data back and forth. It has support for
ARMv6 and ARMv7.
This console is created under the HVC driver, and should be named
/dev/hvcX (or /dev/hvc0 for example).
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
Ttyprintk is a pseudo TTY driver, which allows users to make printk
messages, via output to ttyprintk device. It is possible to store
"console" messages inline with kernel messages for better analyses of
the boot process, for example.
Signed-off-by: Samo Pogacnik <samo_pogacnik@t-2.net>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Fix kconfig dependency warning for PC8736x_GPIO by restricting it to
X86_32.
warning: (SCx200_GPIO && SCx200 || PC8736x_GPIO && X86) selects NSC_GPIO which has unmet direct dependencies (X86_32)
NSC_GPIO is X86_32 only. The other driver (SCx200_GPIO) that selects
NSC_GPIO is X86_32 only (indirectly, since SCx200 depends on X86_32), so
limit this driver also.
Cc: Jordan Crouse <jordan.crouse@amd.com>
Cc: Jim Cromie <jim.cromie@gmail.com>
The driver fails to compile on s390:
drivers/char/ramoops.c: In function 'ramoops_init':
drivers/char/ramoops.c:122: error: implicit declaration of function 'ioremap'
Since we won't make use of the driver anyway on s390 just let it depend on
HAS_IOMEM.
Cc: Marco Stornelli <marco.stornelli@gmail.com>
Ramoops, like mtdoops, can log oops/panic information but in RAM. It can
be used with persistent RAM for systems without flash support. In
addition, for this systems, with this driver, it's no more needed add to
the kernel the mtd subsystem with advantage in footprint.
It can be used in a very easy way with persistent RAM for systems without
flash support. For these systems, with this driver, it is no longer
required to cinlude mtd subsystem with an advantage in footprint. In
addition, you can save flash space and store this information only in RAM.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Cc: Simon Kagstrom <simon.kagstrom@netinsight.net>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Cc; Anders Grafstrom <anders.grafstrom@netinsight.net>
Cc: Yuasa Yoichi <yuasa@linux-mips.org>
Cc: Jamie Lokier <jamie@shareable.org>
n_gsm uses skb functions, so it should depend on NET.
n_gsm.c:(.text+0x123d49): undefined reference to `skb_dequeue'
n_gsm.c:(.text+0x123d98): undefined reference to `kfree_skb'
n_gsm.c:(.text+0x123e1e): undefined reference to `skb_pull'
Add an implementation of GSM 0710 MUX. The implementation currently supports
- Basic and advanced framing (as either end of the link)
- UI or UIH data frames
- Adaption layer 1-4 (1 and 2 via tty, 3 and 4 as skbuff lists)
- Modem and control messages including the correct retry process
- Flow control
and exposes the MUX channels as a set of virtual tty devices including modem
signals. This is an experimental driver.
Signed-off-by: Alan Cox <alan@linux.intel.com>
The char device will be used as an interface by applications on the
guest to communicate with apps on the host.
The devices created are placed in /dev/vportNpn where N is the
virtio-console device number and n is the port number for that device.
One dynamic major device number is allocated for each device and minor
numbers are allocated for the ports contained within that device.
The file operation for the char devs will be added in the following
commits.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Hi Stephen,
next-20090925 randconfig build breaks on hvcs driver on powerpc,
with HVC_CONSOLE=n.
ERROR: ".hvc_put_chars" [drivers/char/hvcs.ko] undefined!
ERROR: ".hvc_get_chars" [drivers/char/hvcs.ko] undefined!
adding the dependency of HVC_CONSOLE helped
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
The ESP driver has been marked broken for years. It's an old ISA device
that clearly nobody cares about any more. Remove it
There isn't much else I can do with these. I can find no hardware for any
of them and no users. The code is broken.
Cc: stable <stable@kernel.org>
This driver memory maps the UV Hub RTC.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Signed-off-by: Yoichi Yuasa <yyuasa@linux.com>
Blackfin platforms do not support the hardware which this driver drives.
Cc: David Brownell <david-b@pacbell.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits)
trivial: remove the trivial patch monkey's name from SubmittingPatches
trivial: Fix a typo in comment of addrconf_dad_start()
trivial: usb: fix missing space typo in doc
trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug
trivial: Remove the hyphen from git commands
trivial: fix ETIMEOUT -> ETIMEDOUT typos
trivial: Kconfig: .ko is normally not included in module names
trivial: SubmittingPatches: fix typo
trivial: Documentation/dell_rbu.txt: fix typos
trivial: Fix Pavel's address in MAINTAINERS
trivial: ftrace:fix description of trace directory
trivial: unnecessary (void*) cast removal in sound/oss/msnd.c
trivial: input/misc: Fix typo in Kconfig
trivial: fix grammo in bus_for_each_dev() kerneldoc
trivial: rbtree.txt: fix rb_entry() parameters in sample code
trivial: spelling fix in ppc code comments
trivial: fix typo in bio_alloc kernel doc
trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt
trivial: Miscellaneous documentation typo fixes
trivial: fix typo milisecond/millisecond for documentation and source comments.
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (55 commits)
microblaze: Don't use access_ok for unaligned
microblaze: remove unused flat_stack_align() definition
microblaze: Fix problem with early_printk in startup
microblaze_mmu_v2: Makefiles
microblaze_mmu_v2: Kconfig update
microblaze_mmu_v2: stat.h MMU update
microblaze_mmu_v2: Elf update
microblaze_mmu_v2: Update dma.h for MMU
microblaze_mmu_v2: Update cacheflush.h
microblaze_mmu_v2: Update signal returning address
microblaze_mmu_v2: Traps MMU update
microblaze_mmu_v2: Enable fork syscall for MMU and add fork as vfork for noMMU
microblaze_mmu_v2: Update linker script for MMU
microblaze_mmu_v2: Add MMU related exceptions handling
microblaze_mmu_v2: uaccess MMU update
microblaze_mmu_v2: Update exception handling - MMU exception
microblaze_mmu_v2: entry.S, entry.h
microblaze_mmu_v2: Add CURRENT_TASK for entry.S
microblaze_mmu_v2: MMU asm offset update
microblaze_mmu_v2: Update tlb.h and tlbflush.h
.ko is normally not included in Kconfig help, make it consistent.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
The Blackfin JTAG interface has a 4 byte generic data field (EMUDAT). With
a little creative thinking, we can turn this into a TTY device.
Signed-off-by: Bryan Wu <cooloney@kernel.org>
drivers/char/nvram.c uses rtc_lock, that (on ARM) is only defined if
RTC_DRV_CMOS is enabled.
iSeries dependent drivers fail to build, when CONFIG_VIOPATH is disabled.
Fix the problem by making those drivers select it.
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Mark it broken
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (144 commits)
powerpc/44x: Support 16K/64K base page sizes on 44x
powerpc: Force memory size to be a multiple of PAGE_SIZE
powerpc/32: Wire up the trampoline code for kdump
powerpc/32: Add the ability for a classic ppc kernel to be loaded at 32M
powerpc/32: Allow __ioremap on RAM addresses for kdump kernel
powerpc/32: Setup OF properties for kdump
powerpc/32/kdump: Implement crash_setup_regs() using ppc_save_regs()
powerpc: Prepare xmon_save_regs for use with kdump
powerpc: Remove default kexec/crash_kernel ops assignments
powerpc: Make default kexec/crash_kernel ops implicit
powerpc: Setup OF properties for ppc32 kexec
powerpc/pseries: Fix cpu hotplug
powerpc: Fix KVM build on ppc440
powerpc/cell: add QPACE as a separate Cell platform
powerpc/cell: fix build breakage with CONFIG_SPUFS disabled
powerpc/mpc5200: fix error paths in PSC UART probe function
powerpc/mpc5200: add rts/cts handling in PSC UART driver
powerpc/mpc5200: Make PSC UART driver update serial errors counters
powerpc/mpc5200: Remove obsolete code from mpc5200 MDIO driver
powerpc/mpc5200: Add MDMA/UDMA support to MPC5200 ATA driver
Fix trivial conflict in drivers/char/Makefile as per Paul's directions
This patch introduces a new hypervisor console (HVC) back-end that provides
terminal access over the z/VM inter-user communication vehicle (IUCV).
The z/VM IUCV communication is independent of the regular tcp/ip network
and allows access even if there is no network connection between two
z/VM guest virtual machines.
The z/VM IUCV hypervisor console back-end helps the user to access a
z/VM guest virtual machine that lacks of network connectivity; and thus,
provides a "full-screen" terminal alternative to 3215/3270 terminal sessions.
Use the hvc_iucv=[0..8] kernel boot parameter to specify the number of
HVC terminals using a z/VM IUCV back-end.
A recent version of the s390-tools package is required to establish a
terminal connection to a z/VM IUCV hypervisor console back-end.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
This adds a new backend for the hvc console based on the low-level
udbg callbacks. This effectively implements a working runtime console
in terms of the simple udbg primitives. This is kind of a hack -
since udbg isn't something you really want to be using routinely - but
it's really useful during bringup.
This can be used to quickly implement a userspace-usable console while
you're working on a proper driver for whatever console I/O device the
hardware has. Or, it can be used to avoid writing a full blown
tty/console driver entirely for quick-and-dirty I/O hardware that will
later be replaced by something else.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Create Documentation/blockdev/ sub-directory and populate it.
Populate the Documentation/serial/ sub-directory.
Move MSI-HOWTO.txt to Documentation/PCI/.
Move ioctl-number.txt to Documentation/ioctl/.
Update all relevant 00-INDEX files.
Update all relevant Kconfig files and source files.
It was only used by this one SGI platform which recently was converted to
RTC_LIB and with RTC_LIB enabled the legacy drivers are no more selectable.
It was only used by two SGI platforms which recently were converted to
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
HPET_RTC_IRQ is no longer needed; HPET_EMULATE_RTC suffices and is more
correct. (http://bugzilla.kernel.org/show_bug.cgi?id=11111)
Note that when using the legacy RTC driver, platforms don't really do a
dynamic switch between HPET and non-HPET modes based on whether HPET
hardware actually exists ... only rtc-cmos (using the new RTC framework)
currently switches that way.
So this reflects bitrot in that legacy code, for x86/ia64: kernels with
HPET support configured (e.g. for a clocksource) can't get IRQs from the
legacy RTC driver unless they really have HPET hardware. (The obvious
workaround is to not use the legacy RTC driver on those platforms when you
configure HPET ... unless you know the target really has a HPET.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Use tty_port_init and krefs in the stallion drivers to protect us from devices
going away underneath us. As with the other drives some rearranging is done to
pass the tty structure down properly on the user side.
This driver was declared obsolete over 2 years ago, the alternative
console driver for legacy iSeries (hvc_iseries) was made the default
over 1 year ago and this driver has been build broken for over 3
months, so remove it.
* git://git.infradead.org/embedded-2.6:
Make console charset translation optional
