path: root/drivers/char/agp/agp.h
2015-01-29agp: change agp_free_page_array to use kvfreeWang, Yalin
Change agp_free_page_array to use kvfree function, remove the duplicated code. Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-01-06agp: Support 64-bit APBASEBjorn Helgaas
Per the AGP 3.0 spec, APBASE is a standard PCI BAR and may be either 32 bits or 64 bits wide. Many drivers read APBASE directly, but they only handled 32-bit BARs. The PCI core reads APBASE at enumeration-time. Use pci_bus_address() instead of reading it again in the driver. This works correctly for both 32-bit and 64-bit BARs. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2010-11-23agp: kill agp_flush_chipset and corresponding ioctlDaniel Vetter
The intel drm calls the chipset functions now directly. Userspace never called the corresponding ioctl, hence it can be killed, too. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-21agp: kill agp_(unmap|map)_memoryDaniel Vetter
DMA remapping was only used by the intel-gtt driver. With that code now folded into the driver, kill the agp generic support for it. Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-21agp: kill agp_(map|unmap)_pageDaniel Vetter
Only used to remap the scratch page. Now that intel-gtt does this itself, kill the support code. Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-04-18agp/intel: introduce intel-agp.h header fileDaniel Vetter
Intel definitions have spilled into agp.h. Create a header file for them and also include it in efficion-agp.c 'cause it needs a few of them. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch agp_{un,}map_page() to take struct page * argumentDavid Woodhouse
2009-08-03agp: Add generic support for graphics dma remappingZhenyu Wang
New driver hooks for support graphics memory dma remapping are introduced in this patch. It makes generic code can tell if current device needs dma remapping, then call driver provided interfaces for mapping and unmapping. Change has also been made to handle scratch_page in remapping case. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22Merge branch 'x86/urgent' into x86/patIngo Molnar
Conflicts: arch/x86/mm/pageattr.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21agp: add agp_generic_destroy_pages()Shaohua Li
Add agp_generic_destroy_pages(), it uses new pageattr array interface API. Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21agp: generic_alloc_pages()Shaohua Li
Add agp_generic_alloc_pages(), it uses new pageattr array interface API. Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21Revert "reduce tlb/cache flush times of agpgart memory allocation"Ingo Molnar
This reverts commit 466ae837424dcc538b1af2a0eaf53be32edcdbe7.
2008-08-15reduce tlb/cache flush times of agpgart memory allocationShaohua Li
To reduce tlb/cache flush, makes agp memory allocation do one flush after all pages in a region are changed to uc. All agp drivers except agp-sgi uses agp_generic_alloc_page() for .agp_alloc_page, so the patch should work for them. agp-sgi is only for ia64, so not a problem too. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: airlied@linux.ie Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-12intel/agp: rewrite GTT on resumeKeith Packard
On my Intel chipset (965GM), the GTT is entirely erased across suspend/resume. This patch simply re-plays the current mapping at resume time to restore the table.=20 I noticed this once I started relying on persistent GTT mappings across VT switch in our GEM work -- the old X server and DRM code carefully unbind all memory from the GTT on VT switch, but GEM does not bother. I placed the list management and rewrite code in the generic layer on the assumption that it will be needed on other hardware, but I did not add the rewrite call to anything other than the Intel resume function. Keep a list of current GATT mappings. At resume time, rewrite them into the GATT. This is needed on Intel (at least) as the entire GATT is cleared across suspend/resume. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Keith Packard <keithp@keithp.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-30drivers/char: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-02-05intel-agp: add new chipset IDZhenyu Wang
This one adds new pci ids for Intel intergrated graphics chipset, with gtt table access change on it and new gtt table size definition. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: add chipset flushing support to AGP interfaceDave Airlie
This bumps the AGP interface to 0.103. Certain Intel chipsets contains a global write buffer, and this can require flushing from the drm or X.org to make sure all data has hit RAM before initiating a GPU transfer, due to a lack of coherency with the integrated graphics device and this buffer. This just adds generic support to the AGP interfaces, a follow-on patch will add support to the Intel driver to use this interface. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-10-15AGP fix race condition between unmapping and freeing pagesDave Airlie
With Andi's clflush fixup, we were getting hangs on server exit, flushing the mappings after freeing each page helped. This showed up a race condition where the pages after being freed could be reused before the agp mappings had been flushed. Flushing after each single page is a bad thing for future drm work, so make the page destroy a two pass unmapping all the pages, flushing the mappings, and then destroying the pages. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-09-19intel-agp: Fix i830 mask variable that changed with G33 supportDave Airlie
The mask on i830 should be 0x70 always, later chips 0xF0 should be okay. Signed-off-by: Dave Airlie <airlied@linux.ie> Acked-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Cc: Michael Haas <laga@laga.ath.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-06[AGPGART] intel_agp: Add support for G33, Q33 and Q35 chipsetsWang Zhenyu
This patch adds pci ids for G33, Q33 and Q35 chips, and update with new GTT size and stolen mem size detect method on these chips. Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] compat ioctlZwane Mwaikambo
The following video card requires the agpgart driver ioctl interface in order to detect video memory. 00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03) Tested on a Thinkpad Z61t, Xorg.0.log from a 32bit debian Xorg is at; http://montezuma.homeunix.net/Xorg.0.log Signed-off-by: Zwane Mwaikambo <zwane@infradead.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22[AGPGART] fix detection of aperture size versus GTT size on G965Eric Anholt
On the G965, the GTT size may be larger than is required to cover the aperture. (In fact, on all hardware we've seen, the GTT is 512KB to the aperture's 256MB). A previous commit forced the aperture size to 512MB on G965 to match GTT, which would likely result in hangs at best if users tried to rely on agpgart's aperture size information. Instead, we use the resource length for the aperture size and the system's reported GTT size when available for the GTT size. Because the MSAC registers which had been read for aperture size detection on i9xx chips just cause a change in the resource size, we can use generic code for aperture detection on all i9xx. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-05[AGPGART] agp.h: constify struct agp_bridge_data::versionAlexey Dobriyan
drivers/char/agp/backend.c: In function `agp_backend_initialize': drivers/char/agp/backend.c:141: warning: assignment discards qualifiers from pointer target type Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-07-29[PATCH] agp: restore APBASE after setting APSIZEMatthew Garrett
When leaving S3 state, the AGP bridge may not have all PCI configuration registers set in the same way as they were at boot. This should be fixed by pci_restore_state - however, the APBASE register cannot be set to conflict with the APSIZE register. If APSIZE is larger than it was before suspend, pci_restore_state will not restore APBASE correctly. The attached patch adds an extra item to the agp_bridge_data structure and uses it to store the value of APBASE. On resume, this is then written after APSIZE has been set. This patch only touches the path used for Intel chipsets without integrated graphics, and may need to be extended to work with the others. Without this patch, I get the symptoms described in bug 4921 - APBASE ends up overlapping various PCI devices, and as a result they fail to work after resume. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
