Signed-off-by: Dave Jones <davej@redhat.com>
Add suspend/resume support for the ati-agp module
Signed-off-by: Jaco Kroon <jaco@kroon.co.za>
Acked-by: Pavel Machek <pavel@suse.cz>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This updates .owner field of struct pci_driver.
This allows SYSFS to create the symlink from the driver to the module which
provides it.
$ tree /sys/bus/pci/drivers/agpgart-via/
|-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0
|-- bind
|-- module -> ../../../../module/via_agp
|-- new_id
`-- unbind
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
When Linux is running on the Xen virtual machine monitor, physical
addresses are virtualised and cannot be directly referenced by the AGP
GART. This patch fixes the GART driver for Xen by adding a layer of
abstraction between physical addresses and 'GART addresses'.
Architecture-specific functions are also defined for allocating and freeing
the GATT. Xen requires this to ensure that table really is contiguous from
the point of view of the GART.
These extra interface functions are defined as 'no-ops' for all existing
architectures that use the GART driver.
Signed-off-by: Keir Fraser <keir@xensource.com>
Another large rollup of various patches from Adrian which make things static
where they were needlessly exported.
infrastructure for it.
Let it rip!
