Intel definitions have spilled into agp.h. Create a header file for
them and also include it in efficion-agp.c 'cause it needs a few of
them.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Eric Anholt <eric@anholt.net>
There seems to be no reason for these -- they're a 1:1 mapping on all
platforms.
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
The pageattr-array patch that you currently have in tip/master only
enables it for intel-agp, not the others. The attached enables it for
all drivers currently directly using agp_generic_alloc_page() and
agp_generic_destroy_page() (ocal driver is amd-k7-agp).
The new agp_generic_alloc_pages() interface uses the also new
pageattr array interface API. This makes all AGP drivers that
up to now used generic_{alloc,destroy}_page() use it.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Use boolean in AGP instead of having own TRUE/FALSE
Create an inline function for clflush(), with the proper arguments,
and use it instead of hard-coding the instruction.
This also removes one instance of hard-coded wbinvd, based on a patch
by Bauder de Oliveira Costa.
[ tglx: arch/x86 adaptation ]
Cc: Glauber de Oliveira Costa <gcosta@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Andi Kleen <ak@suse.de>
agp_efficeon_probe()
(This is a resend of a patch originally submitted on 24-Jul-2007 00:14)
Ok, this is something the coverity checker found (CID: 1813).
I'm not at all intimate with this code, so I'm not sure if this
attempt at a fix is correct (but at least it compiles).
Please look it over and NACK if bad or merge if good ;-)
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
Make agp_bridge_driver->aperture_sizes and ->masks const.
Also agp_bridge_data->driver
Signed-off-by: Dave Jones <davej@redhat.com>
This patch allows drm to populate an agpgart structure with pages of its own.
It's needed for the new drm memory manager which dynamically flips pages in and out of AGP.
The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is
currently the only one supporting the new memory manager.
Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver.
AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected
to do that, as well as taking care of cache- and tlb flushing when needed.
It's not possible to request these types from user space using agpgart ioctls.
The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT.
Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com>
acquired (aquired)
contiguous (contigious)
successful (succesful, succesfull)
surprise (suprise)
whether (weather)
some other misspellings
Signed-off-by: Andreas Mohr <andi@lisas.de>
Original patch by Benjamin Herrenschmidt after debugging by Brian Hinz.
Cc: Brian Hinz <bphinz@hotmail.com>
Eliminate trailing whitespace.
s/if(/if (/
s/for(/for (/
efficeon-agp.c:222: warning: passing arg 1 of `virt_to_phys' makes pointer from integer without a cast
This updates .owner field of struct pci_driver.
This allows SYSFS to create the symlink from the driver to the module which
provides it.
$ tree /sys/bus/pci/drivers/agpgart-via/
|-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0
|-- bind
|-- module -> ../../../../module/via_agp
|-- new_id
`-- unbind
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
When Linux is running on the Xen virtual machine monitor, physical
addresses are virtualised and cannot be directly referenced by the AGP
GART. This patch fixes the GART driver for Xen by adding a layer of
abstraction between physical addresses and 'GART addresses'.
Architecture-specific functions are also defined for allocating and freeing
the GATT. Xen requires this to ensure that table really is contiguous from
the point of view of the GART.
These extra interface functions are defined as 'no-ops' for all existing
architectures that use the GART driver.
Signed-off-by: Keir Fraser <keir@xensource.com>
Another large rollup of various patches from Adrian which make things static
where they were needlessly exported.
Here are fixes for drivers/char.
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
