path: root/drivers/char/agp/via-agp.c
2008-10-20Update email addresses.Dave Jones
Update assorted email addresses and related info to point to a single current, valid address. additionally - trivial CREDITS entry updates. (Not that this file means much any more) - remove arjans dead redhat.com address from powernow driver Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19agp/via: fixup pci idsGreg KH
add a new PCI ID and remove an old dodgy one, include the explaination in the commented code so nobody readds later. (davej also sent the pci id addition). Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-08-25agp: Add device id for P4M900 to via-agp moduleXavier Bachelot
Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-05-13[AGPGART] Fix wrong ID in via-agp.cGabriel Mansi
there is a wrong id in drivers/char/agp/via-agp.c #define PCI_DEVICE_ID_VIA_CX700 0x8324 It must be 0x0324 Notice that PCI_DEVICE_ID_VIA_CX700 is also used in drivers/i2c/busses/i2c-viapro.c and drivers/ide/pci/via82cxxx.c So, I think that constant must be renamed to avoid conflicting. I attached a proposed patch. Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-28[AGPGART] Add new IDs to VIA AGP.Dave Jones
Culled from the VIA codedrop. Also fixes up one ID used in amd64-agp to use the VIA part number instead of the board name in its ID. Signed-off-by: Dave Jones <davej@redhat.com>
2006-08-11[AGPGART] const'ify VIA AGP PCI table.Dave Jones
2006-05-22[AGPGART] VIA PT880 Ultra support.Magnus Kessler
This patch enables agpgart on a Via "PT880 Ultra" based motherboard (Asus P4V800D-X). The PCI ID of the PT880 Ultra is 0x0308 instead of 0x0258 of the PT880. The patched via-agp passes testgart. Signed-off-by: Magnus Kessler <Magnus.Kessler@gmx.net> Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-21[AGPGART] Support VIA P4M800CE bridge.Dave Jones
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
