path: root/drivers/char/agp
2012-01-23iommu: Rename the DMAR and INTR_REMAP config optionsSuresh Siddha
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent with the other IOMMU options. Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the irq subsystem name. And define the CONFIG_DMAR_TABLE for the common ACPI DMAR routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: yinghai@kernel.org Cc: youquan.song@intel.com Cc: joerg.roedel@amd.com Cc: tony.luck@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Conflicts: arch/x86/include/asm/irq_remapping.h arch/x86/kernel/apic/io_apic.c drivers/iommu/Makefile Change-Id: I3f09baf327e59d94f38801d107268f4e20c1da8e
2011-07-13agp/intel: Fix typo in G4x_GMCH_SIZE_VT_2MChris Wilson
Konstantin Belousov found an error in the define of G4x_GMCH_SIZE_VT_2M relative to the GMCH specs, and confirmed that indeed one of his users with a Q45 reports 0xb not 0xc for a 2/2MiB GATT. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Konstantin Belousov <kostikbel@gmail.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-22agp/uninorth: Fix lockups with radeon KMS and >1x.Michel Dänzer
This was based on a description by Ben Herrenschmidt: > I've removed that SBA reset from the normal TLB invalidation path and > left it only once after turning AGP on. About six months ago, he said: > I did it a bit differently, but yeah, you get the idea. I'm doing a > patch series so don't bother pushing things too hard yet. But I haven't seen anything from him about this since then, and people are regularly hitting these lockups, so here we are... Signed-off-by: Michel Dänzer <daenzer@vmware.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@gmail.com>
2011-05-13agp/intel: add Ivy Bridge supportJesse Barnes
Just use the Sandy Bridge routines. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-04-21agp: fix arbitrary kernel memory writesVasiliy Kulikov
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND, and it is not checked at all in case of AGPIOC_UNBIND. As a result, user with sufficient privileges (usually "video" group) may generate either local DoS or privilege escalation. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix OOM and buffer overflowVasiliy Kulikov
page_count is copied from userspace. agp_allocate_memory() tries to check whether this number is too big, but doesn't take into account the wrap case. Also agp_create_user_memory() doesn't check whether alloc_size is calculated from num_agp_pages variable without overflow. This may lead to allocation of too small buffer with following buffer overflow. Another problem in agp code is not addressed in the patch - kernel memory exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()). Each allocation is limited to 16KB, though, there is no per-process limit. This might lead to OOM situation, which is not even solved in case of the caller death by OOM killer - the memory is allocated for another (faked) process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-24Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel into drm-fixes * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: fix corruptions on i8xx due to relaxed fencing drm/i915: skip FDI & PCH enabling for DP_A agp/intel: Experiment with a 855GM GWB bit drm/i915: don't enable FDI & transcoder interrupts after all drm/i915: Ignore a hung GPU when flushing the framebuffer prior to a switch
2011-02-23amd64-agp: fix crash at second module loadFlorian Mickler
The module forgot to sometimes unregister some resources. This fixes Bug #22882. [Patch updated to 2.6.38-rc3 by Randy Dunlap.] Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-22agp/intel: Experiment with a 855GM GWB bitChris Wilson
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=27187 Tested-by: Thorsten Vollmer <thorsten@thvo.de> (DFI-ACP G5M150-N w/852GME) Tested-by: Moritz Brunner <2points@gmx.org> (Asus M2400N/i855GM) Tested-by: Indan Zupancic <indan@nul.nu> (Thinkpad X40/855GM rev 02) Tested-by: Eric Anholt <eric@anholt.net> (865G) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-02-04agp: ensure GART has an address before enabling itStephen Kitt
Some BIOSs (eg. the AMI BIOS on the Asus P4P800 motherboard) don't initialise the GART address, and pcibios_assign_resources() can ignore it because it can be marked as a host bridge (see https://bugzilla.kernel.org/show_bug.cgi?id=24392#c5 for details). This was handled correctly up to 2.6.35, but the pci_enable_device() cleanup in 2.6.36 96576a9e1a0cdb8 ("agp: intel-agp: do not use PCI resources before pci_enable_device()") means that the kernel tries to enable the GART before assigning it an address; in such cases the GART overlaps with other device assignments and ends up being disabled. This patch fixes https://bugzilla.kernel.org/show_bug.cgi?id=24392 Note that I imagine efficeon-agp.c probably has the same problem, but I can't test that and I'd like to make sure this patch is suitable for -stable (since 2.6.36 and 2.6.37 are affected). Signed-off-by: Stephen Kitt <steve@sk2.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Maciej Rutecki <maciej.rutecki@gmail.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kulikov Vasiliy <segooon@gmail.com> Cc: Florian Mickler <florian@mickler.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-04Revert "agp: AMD AGP is used on UP1100 & UP1500 alpha boxen"Matt Turner
This reverts commit f191f144079b0083c6fa7d01a4acbd7263fb5032. The AMD 751 and 761 chipsets are used on the UP1000, UP1100, and UP1500 OEM motherboards, but they neglect to do anything to make AGP work. According to Ivan Kokshaysky: There is quite fundamental conflict between the Alpha architecture and x86 AGP implementation - Alpha is entirely cache coherent by design, while x86 AGP is not (I mean native AGP DMA transactions, not a PCI over AGP). There are no such things as non-cacheable mappings or software support for cache flushing/invalidation on Alpha, so x86 AGP code won't work on Nautilus. So there's no point in allowing this driver to be configured on Alpha. Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-04amd-k7-agp: remove non-x86 codeMatt Turner
amd-k7-agp can't be built on Alpha anymore, so remove now unnecessary code. Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-24drm/i915,agp/intel: Do not clear stolen entriesChris Wilson
We can only utilize the stolen portion of the GTT if we are in sole charge of the hardware. This is only true if using GEM and KMS, otherwise VESA continues to access stolen memory. Reported-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Tested-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-14agp/intel: Fix device names of i845 and 845GOswald Buddenhagen
They got mixed up when the switch was converted to a table in 2007. Signed-off-by: Oswald Buddenhagen <ossi@kde.org> [ickle: minor changes for 2.6.37+] Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-12i915/gtt: fix ordering causing DMAR errors on object teardown.Dave Airlie
Previous to the last GTT rework we always rewrote the GTT then unmapped the object, somehow this got reversed in the rework in 2.6.37-rc5 timeframe. This fix needs to go to stable in an alternate form since the code changed. This fixes DMAR reports on my Ironlake HP2540p. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-12i915/gtt: fix ordering issues with status setup and DMARDave Airlie
This code was setting up the status page before setting the DMAR-is-on-bit, so we were getting DMAR errors on the status page. Reverse the two bits of init code to the correct result. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-11agp/intel: Flush the chipset write buffers when changing GTT baseChris Wilson
Flush the chipset write buffers before and after adjusting the GTT base register, just in case. We only modify this value upon initialisation (boot and resume) so there should be no outstanding writes, however there are always those persistent PGTBL_ER that keep getting reported upon resume. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-10Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (390 commits) drm/radeon/kms: disable underscan by default drm/radeon/kms: only enable hdmi features if the monitor supports audio drm: Restore the old_fb upon modeset failure drm/nouveau: fix hwmon device binding radeon: consolidate asic-specific function decls for pre-r600 vga_switcheroo: comparing too few characters in strncmp() drm/radeon/kms: add NI pci ids drm/radeon/kms: don't enable pcie gen2 on NI yet drm/radeon/kms: add radeon_asic struct for NI asics drm/radeon/kms/ni: load default sclk/mclk/vddc at pm init drm/radeon/kms: add ucode loader for NI drm/radeon/kms: add support for DCE5 display LUTs drm/radeon/kms: add ni_reg.h drm/radeon/kms: add bo blit support for NI drm/radeon/kms: always use writeback/events for fences on NI drm/radeon/kms: adjust default clock/vddc tracking for pm on DCE5 drm/radeon/kms: add backend map workaround for barts drm/radeon/kms: fill gpu init for NI asics drm/radeon/kms: add disabled vbios accessor for NI asics drm/radeon/kms: handle NI thermal controller ...
2011-01-06Merge branch 'x86-amd-nb-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-amd-nb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, cacheinfo: Cleanup L3 cache index disable support x86, amd-nb: Cleanup AMD northbridge caching code x86, amd-nb: Complete the rename of AMD NB and related code
2010-12-14Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
2010-12-14agp/intel: Fix missed cached memory flags setting in i965_write_entry()Chris Wilson
This fixes regression from a6963596a13e62f8e65b1cf3403a330ff2db407c, that missed to set cached memory type in GTT entry. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-12-05Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
Immediate merge for the conflicting introduction of HAS_COHERENT_RINGS. Conflicts: drivers/gpu/drm/i915/i915_dma.c include/drm/i915_drm.h
2010-12-05agp/intel: Fix wrong kunmap in i830_cleanup()Takashi Iwai
Add a missing NULL check and fix the wrong address passed to kunmap() in i830_cleanup(). Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de> [danvet: added cc stable] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23agp/intel: Remove duplicate constChris Wilson
drivers/char/agp/intel-gtt.c:340:48: warning: duplicate const Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: export api for drm/i915Daniel Vetter
Just some minor shuffling to get rid of any agp traces in the exported functions. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23agp: kill agp_rebind_memoryDaniel Vetter
Its only user, intel-gtt.c is now gone. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23drm/i915: restore gtt on resume in the drm instead of in intel-gtt.koDaniel Vetter
This still uses the agp functions to actually reinstate the mappings (with a gross hack to make agp cooperate), but it wires everything up correctly for the switchover. The call to agp_rebind_memory can be dropped because all non-kms drivers do all their rebinding on EnterVT. v2: Be more paranoid and flush the chipset cache after restoring gtt mappings. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23agp: kill agp_flush_chipset and corresponding ioctlDaniel Vetter
The intel drm calls the chipset functions now directly. Userspace never called the corresponding ioctl, hence it can be killed, too. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23drm/i915/gtt: call chipset flush directlyDaniel Vetter
2010-11-23drm/i915|intel-gtt: consolidate intel-gtt.h headersDaniel Vetter
... and a few other defines. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: fold i81x-only dcache support into the generic driverDaniel Vetter
Now the intel-gtt.c rewrite is complete! Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: switch i81x to the common initialization helpersDaniel Vetter
Still a separate agp_bridge_driver because of the i81x-only dedicated vram support. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: switch i81x to the write_entry helpersDaniel Vetter
Initialization is still done with the old code with a few added things sprinkled in to make the intel_fake_agp helper functions work. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: kill unneeded sandybridge memory typesDaniel Vetter
Used for the now dead agp type_to_mask stuff. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23intel-gtt: drop dcache support for i830 and laterDaniel Vetter
i830_check_flags already disallows it, so no need to implement it in the write_entry function. Seems to be a remnant from i810 support. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23agp/intel: Remove confusion of stolen entries not stolen memoryChris Wilson
2010-11-23agp/intel: Remove the artificial cap on stolen sizeChris Wilson
Now that the stolen memory does not also steal entries from the GTT, we can use all the memory the BIOS set aside for the GPU. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-22Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
Conflicts: drivers/gpu/drm/i915/i915_gem.c
2010-11-18x86, amd-nb: Cleanup AMD northbridge caching codeHans Rosenfeld
Support more than just the "Misc Control" part of the northbridges. Support more flags by turning "gart_supported" into a single bit flag that is stored in a flags member. Clean up related code by using a set of functions (amd_nb_num(), amd_nb_has_feature() and node_to_amd_nb()) instead of accessing the NB data structures directly. Reorder the initialization code and put the GART flush words caching in a separate function. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-11-18x86, amd-nb: Complete the rename of AMD NB and related codeHans Rosenfeld
Not only the naming of the files was confusing, it was even more so for the function and variable names. Renamed the K8 NB and NUMA stuff that is also used on other AMD platforms. This also renames the CONFIG_K8_NUMA option to CONFIG_AMD_NUMA and the related file k8topology_64.c to amdtopology_64.c. No functional changes intended. Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
Conflicts: drivers/gpu/drm/i915/i915_gem.c drivers/gpu/drm/i915/intel_ringbuffer.c
2010-11-09Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: Fix LVDS fixed-mode regression from 219adae1 drm/i915/ringbuffer: Use the HEAD auto-reporting mechanism drm/i915: Avoid might_fault during pwrite whilst holding our mutex agp/intel: fix cache control for sandybridge agp/intel: restore cache behavior on sandybridge drm/i915; Don't apply Ironlake FDI clock workaround to Sandybridge drm/i915: Fix KMS regression on Sandybridge/CPT i915: reprogram power monitoring registers on resume drm/i915: SNB BLT workaround drm/i915: Fix the graphics frequency clamping at init and when IPS is active. drm/i915: Allow powersave modparam to be adjusted at runtime. drm/i915: Apply big hammer to serialise buffer access between rings drm/i915: opregion_setup: iounmap correct address drm/i915: Flush read-only buffers from the active list upon idle as well i915: signedness bug in check_overlay_src() drm/i915: Fix typo from "Enable DisplayPort Audio"
2010-11-04agp/intel: fix cache control for sandybridgeZhenyu Wang
This is broken from 97ef1bdd0bc75bce7b2058e9c432b6c277dcf4d3. Let's set the correct bit for LLC+MLC and LLC only. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-04agp/intel: restore cache behavior on sandybridgeZhenyu Wang
This restores cache behavior for default AGP_USER_MEMORY as uncached, and leave default AGP_USER_CACHED_MEMORY as LLC only. I've seen different cache behavior on one sandybridge desktop CPU vs. another mobile CPU. Until we figure out how to detect the real cache config, restore back to the original behavior now. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-02agp/intel: restore cache behavior on sandybridgeZhenyu Wang
This restores cache behavior for default AGP_USER_MEMORY as uncached, and leave default AGP_USER_CACHED_MEMORY as LLC only. I've seen different cache behavior on one sandybridge desktop CPU vs. another mobile CPU. Until we figure out how to detect the real cache config, restore back to the original behavior now. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-02agp/intel: fix cache control for sandybridgeZhenyu Wang
This is broken from 97ef1bdd0bc75bce7b2058e9c432b6c277dcf4d3. Let's set the correct bit for LLC+MLC and LLC only. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-10-31agp/intel: the GMCH is always enabled for integrated processor graphicsChris Wilson
... and trying to set the bit is ineffectual. Fixes the regression from e380f60 which detected that we were trying to do undefined operations on the I830_GMCH_CTRL. Reported-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-10-29agp/intel: Sandybridge doesn't require GMCH enablingChris Wilson
