-enable warnings as errors compilation flag
bug 949219
Change-Id: I47e2df835985f341ebccdad95f53b4e6f7763e39
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118017
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent
with the other IOMMU options.
Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the
irq subsystem name.
And define the CONFIG_DMAR_TABLE for the common ACPI DMAR
routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: youquan.song@intel.com
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com
arch/x86/include/asm/irq_remapping.h
arch/x86/kernel/apic/io_apic.c
drivers/iommu/Makefile
Change-Id: I3f09baf327e59d94f38801d107268f4e20c1da8e
Konstantin Belousov found an error in the define of G4x_GMCH_SIZE_VT_2M
relative to the GMCH specs, and confirmed that indeed one of his users
with a Q45 reports 0xb not 0xc for a 2/2MiB GATT.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Konstantin Belousov <kostikbel@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This was based on a description by Ben Herrenschmidt:
> I've removed that SBA reset from the normal TLB invalidation path and
> left it only once after turning AGP on.
About six months ago, he said:
> I did it a bit differently, but yeah, you get the idea. I'm doing a
> patch series so don't bother pushing things too hard yet.
But I haven't seen anything from him about this since then, and people are
regularly hitting these lockups, so here we are...
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Dave Airlie <airlied@gmail.com>
Just use the Sandy Bridge routines.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Reviewed-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl
cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the
comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND,
and it is not checked at all in case of AGPIOC_UNBIND. As a result, user
with sufficient privileges (usually "video" group) may generate either
local DoS or privilege escalation.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
page_count is copied from userspace. agp_allocate_memory() tries to
check whether this number is too big, but doesn't take into account the
wrap case. Also agp_create_user_memory() doesn't check whether
alloc_size is calculated from num_agp_pages variable without overflow.
This may lead to allocation of too small buffer with following buffer
overflow.
Another problem in agp code is not addressed in the patch - kernel memory
exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked
whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()).
Each allocation is limited to 16KB, though, there is no per-process limit.
This might lead to OOM situation, which is not even solved in case of the
caller death by OOM killer - the memory is allocated for another (faked) process.
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel into drm-fixes
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel:
drm/i915: fix corruptions on i8xx due to relaxed fencing
drm/i915: skip FDI & PCH enabling for DP_A
agp/intel: Experiment with a 855GM GWB bit
drm/i915: don't enable FDI & transcoder interrupts after all
drm/i915: Ignore a hung GPU when flushing the framebuffer prior to a switch
The module forgot to sometimes unregister some resources.
This fixes Bug #22882.
[Patch updated to 2.6.38-rc3 by Randy Dunlap.]
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Florian Mickler <florian@mickler.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=27187
Tested-by: Thorsten Vollmer <thorsten@thvo.de> (DFI-ACP G5M150-N w/852GME)
Tested-by: Moritz Brunner <2points@gmx.org> (Asus M2400N/i855GM)
Tested-by: Indan Zupancic <indan@nul.nu> (Thinkpad X40/855GM rev 02)
Tested-by: Eric Anholt <eric@anholt.net> (865G)
Some BIOSs (eg. the AMI BIOS on the Asus P4P800 motherboard) don't
initialise the GART address, and pcibios_assign_resources() can ignore it
because it can be marked as a host bridge (see
https://bugzilla.kernel.org/show_bug.cgi?id=24392#c5 for details). This
was handled correctly up to 2.6.35, but the pci_enable_device() cleanup in
2.6.36 96576a9e1a0cdb8 ("agp: intel-agp: do not use PCI resources before
pci_enable_device()") means that the kernel tries to enable the GART
before assigning it an address; in such cases the GART overlaps with other
device assignments and ends up being disabled.
This patch fixes https://bugzilla.kernel.org/show_bug.cgi?id=24392
Note that I imagine efficeon-agp.c probably has the same problem, but
I can't test that and I'd like to make sure this patch is suitable for
-stable (since 2.6.36 and 2.6.37 are affected).
Signed-off-by: Stephen Kitt <steve@sk2.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Kulikov Vasiliy <segooon@gmail.com>
Cc: Florian Mickler <florian@mickler.org>
Cc: <stable@kernel.org>
This reverts commit f191f144079b0083c6fa7d01a4acbd7263fb5032.
The AMD 751 and 761 chipsets are used on the UP1000, UP1100, and UP1500
OEM motherboards, but they neglect to do anything to make AGP work.
According to Ivan Kokshaysky:
There is quite fundamental conflict between the Alpha architecture and
x86 AGP implementation - Alpha is entirely cache coherent by design,
while x86 AGP is not (I mean native AGP DMA transactions, not a PCI over
AGP). There are no such things as non-cacheable mappings or software
support for cache flushing/invalidation on Alpha, so x86 AGP code won't
work on Nautilus.
So there's no point in allowing this driver to be configured on Alpha.
Signed-off-by: Matt Turner <mattst88@gmail.com>
amd-k7-agp can't be built on Alpha anymore, so remove now unnecessary
code.
We can only utilize the stolen portion of the GTT if we are in sole
charge of the hardware. This is only true if using GEM and KMS,
otherwise VESA continues to access stolen memory.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Tested-by: Frederic Weisbecker <fweisbec@gmail.com>
They got mixed up when the switch was converted to a table in 2007.
Signed-off-by: Oswald Buddenhagen <ossi@kde.org>
[ickle: minor changes for 2.6.37+]
Previous to the last GTT rework we always rewrote the GTT then unmapped the
object, somehow this got reversed in the rework in 2.6.37-rc5 timeframe.
This fix needs to go to stable in an alternate form since the code changed.
This fixes DMAR reports on my Ironlake HP2540p.
This code was setting up the status page before setting the DMAR-is-on-bit,
so we were getting DMAR errors on the status page. Reverse the two bits
of init code to the correct result.
Flush the chipset write buffers before and after adjusting the GTT base
register, just in case. We only modify this value upon initialisation
(boot and resume) so there should be no outstanding writes, however
there are always those persistent PGTBL_ER that keep getting reported
upon resume.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (390 commits)
drm/radeon/kms: disable underscan by default
drm/radeon/kms: only enable hdmi features if the monitor supports audio
drm: Restore the old_fb upon modeset failure
drm/nouveau: fix hwmon device binding
radeon: consolidate asic-specific function decls for pre-r600
vga_switcheroo: comparing too few characters in strncmp()
drm/radeon/kms: add NI pci ids
drm/radeon/kms: don't enable pcie gen2 on NI yet
drm/radeon/kms: add radeon_asic struct for NI asics
drm/radeon/kms/ni: load default sclk/mclk/vddc at pm init
drm/radeon/kms: add ucode loader for NI
drm/radeon/kms: add support for DCE5 display LUTs
drm/radeon/kms: add ni_reg.h
drm/radeon/kms: add bo blit support for NI
drm/radeon/kms: always use writeback/events for fences on NI
drm/radeon/kms: adjust default clock/vddc tracking for pm on DCE5
drm/radeon/kms: add backend map workaround for barts
drm/radeon/kms: fill gpu init for NI asics
drm/radeon/kms: add disabled vbios accessor for NI asics
drm/radeon/kms: handle NI thermal controller
* 'x86-amd-nb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, cacheinfo: Cleanup L3 cache index disable support
x86, amd-nb: Cleanup AMD northbridge caching code
x86, amd-nb: Complete the rename of AMD NB and related code
This fixes regression from a6963596a13e62f8e65b1cf3403a330ff2db407c,
that missed to set cached memory type in GTT entry.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Immediate merge for the conflicting introduction of HAS_COHERENT_RINGS.
drivers/gpu/drm/i915/i915_dma.c
include/drm/i915_drm.h
Add a missing NULL check and fix the wrong address passed to kunmap()
in i830_cleanup().
Cc: stable@kernel.org
[danvet: added cc stable]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
drivers/char/agp/intel-gtt.c:340:48: warning: duplicate const
Just some minor shuffling to get rid of any agp traces in the
exported functions.
Its only user, intel-gtt.c is now gone.
Cc: Dave Airlie <airlied@gmail.com>
This still uses the agp functions to actually reinstate the mappings
(with a gross hack to make agp cooperate), but it wires everything
up correctly for the switchover.
The call to agp_rebind_memory can be dropped because all non-kms drivers
do all their rebinding on EnterVT.
v2: Be more paranoid and flush the chipset cache after restoring gtt
mappings.
The intel drm calls the chipset functions now directly. Userspace
never called the corresponding ioctl, hence it can be killed, too.
... and a few other defines.
Now the intel-gtt.c rewrite is complete!
Still a separate agp_bridge_driver because of the i81x-only
dedicated vram support.
Initialization is still done with the old code with a few
added things sprinkled in to make the intel_fake_agp helper
functions work.
Used for the now dead agp type_to_mask stuff.
i830_check_flags already disallows it, so no need to implement it
in the write_entry function. Seems to be a remnant from i810 support.
Now that the stolen memory does not also steal entries from the GTT, we
can use all the memory the BIOS set aside for the GPU.
drivers/gpu/drm/i915/i915_gem.c
Support more than just the "Misc Control" part of the northbridges.
Support more flags by turning "gart_supported" into a single bit flag
that is stored in a flags member. Clean up related code by using a set
of functions (amd_nb_num(), amd_nb_has_feature() and node_to_amd_nb())
instead of accessing the NB data structures directly. Reorder the
initialization code and put the GART flush words caching in a separate
function.
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Not only the naming of the files was confusing, it was even more so for
the function and variable names.
Renamed the K8 NB and NUMA stuff that is also used on other AMD
platforms. This also renames the CONFIG_K8_NUMA option to
CONFIG_AMD_NUMA and the related file k8topology_64.c to
amdtopology_64.c. No functional changes intended.
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
drivers/gpu/drm/i915/intel_ringbuffer.c
drm/i915: Fix LVDS fixed-mode regression from 219adae1
drm/i915/ringbuffer: Use the HEAD auto-reporting mechanism
drm/i915: Avoid might_fault during pwrite whilst holding our mutex
agp/intel: fix cache control for sandybridge
agp/intel: restore cache behavior on sandybridge
drm/i915; Don't apply Ironlake FDI clock workaround to Sandybridge
drm/i915: Fix KMS regression on Sandybridge/CPT
i915: reprogram power monitoring registers on resume
drm/i915: SNB BLT workaround
drm/i915: Fix the graphics frequency clamping at init and when IPS is active.
drm/i915: Allow powersave modparam to be adjusted at runtime.
drm/i915: Apply big hammer to serialise buffer access between rings
drm/i915: opregion_setup: iounmap correct address
drm/i915: Flush read-only buffers from the active list upon idle as well
i915: signedness bug in check_overlay_src()
drm/i915: Fix typo from "Enable DisplayPort Audio"
This is broken from 97ef1bdd0bc75bce7b2058e9c432b6c277dcf4d3.
Let's set the correct bit for LLC+MLC and LLC only.
This restores cache behavior for default AGP_USER_MEMORY as
uncached, and leave default AGP_USER_CACHED_MEMORY as LLC only.
I've seen different cache behavior on one sandybridge desktop CPU vs.
another mobile CPU. Until we figure out how to detect the real cache
config, restore back to the original behavior now.
... and trying to set the bit is ineffectual.
Fixes the regression from e380f60 which detected that we were trying to
do undefined operations on the I830_GMCH_CTRL.
Reported-by: Alexey Fisher <bug-track@fisher-privat.net>
