path: root/drivers/char/cs5535_gpio.c
2008-04-28drivers: fix integer as NULL pointer warningsHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05gpio_cs5535: disable AUX on outputBen Gardner
The AMD CS5535/CS5536 GPIO has two alternate output modes: AUX-1 and AUX-2. When either AUX is enabled, the cs5535_gpio driver cannot control the output. Some BIOS code for the Geode processor enables AUX-1 for GPIO-1, which configures it as the PC BEEP output. This patch will disable AUX-1 and AUX-2 when the user enables output. Signed-of-by: Ben Gardner <gardner.ben@gmail.com> Cc: Richard Knutsson <ricknu-0@student.ltu.se> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cs5535_gpio, add MODULE_DEVICE_TABLEJiri Slaby
cs5535_gpio, add MODULE_DEVICE_TABLE Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ben Gardner <bgardner@wabtec.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert char-driversJosef Sipek
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] cs5535_gpio.c: call cdev_del() during module_exit to unmap kobject ↵Thayumanavar Sachithanantham
references and other cleanups During module unloading, cdev_del() must be called to unmap cdev related kobject references and other cleanups(such as inode->i_cdev being set to NULL) which prevents the OOPS upon subsequent loading, usage and unloading of modules(as seen in the mail thread http://marc.theaimsgroup.com/?l=linux-kernel&m=114533640609018&w=2). Also, remove unneeded test of gpio_base. Signed-off-by: Thayumanavar Sachithanantham <thayumk@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] i386: GPIO driver for AMD CS5535/CS5536Ben Gardner
A simple driver for the CS5535 and CS5536 that allows a user-space program to manipulate GPIO pins. The CS5535/CS5536 chips are Geode processor companion devices. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
