path: root/drivers/char/drm/Kconfig
2008-02-07drm: run cleanfile across drm treeDave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-16video gfx: merge kconfig menusRandy Dunlap
Move AGP and DRM menus into the video graphics support menu. They use 'menuconfig' so that they can all be disabled with one selection. Make the console menu use 'menuconfig' so that it can all be disabled with one selection. Make the frame buffer menu use 'menuconfig' so that it can all be disabled with one selection. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-29[SPARC]: Mark as emulating cmpxchg, add appropriate depends for DRM.Martin Habets
The DRM code depends on an atomic version of cmpxchg(), which is not available on sparc32. Since other platforms besides sparc32 have this issue a KCONFIG option is added for it. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22drm: add better explanation for i830/i915Dave Airlie
2006-03-20remove dead Radeon URLAdrian Bunk
This patch removes a dead Radeon URL from two Kconfig files. This isue was noted by Reto Gantenbein <ganto82@gmx.ch> in Kernel Bugzilla #4446. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-08-07drm: add savage driverDave Airlie
Add driver for savage chipsets. From: Felix Kuehling Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-08-05drm: remove the gamma driverDave Airlie
The gamma driver has been broken for quite a while, it doesn't build, we don't have a userspace, mine is in Ireland etc... Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10Add support for PCI MGA cards to MGA DRM.Dave Airlie
This patch adds serveral new ioctls and a new query to get_param query to support PCI MGA cards. Two ioctls were added to implement interrupt based waiting. With this change, the client-side driver no longer needs to map the primary DMA region or the MMIO region. Previously, end-of-frame waiting was done by busy waiting in the client-side driver until one of the MMIO registers (the current DMA pointer) matched a pointer to the end of primary DMA space. By using interrupts, the busy waiting and the extra mappings are removed. A third ioctl was added to bootstrap DMA. This ioctl, which is used by the X-server, moves a *LOT* of code from the X-server into the kernel. This allows the kernel to do whatever needs to be done to setup DMA buffers. The entire process and the locations of the buffers are hidden from user-mode. Additionally, a get_param query was added to differentiate between G4x0 cards and G550 cards. A gap was left in the numbering sequence so that, if needed, G450 cards could be distinguished from G400 cards. According to Ville Syrjälä, the G4x0 cards and the G550 cards handle anisotropic filtering differently. This seems the most compatible way to let the client-side driver know which card it's own. Doing this very small change now eliminates the need to bump the DRM minor version twice. http://marc.theaimsgroup.com/?l=dri-devel&m=106625815319773&w=2 (airlied - this may not work at this point, I think the follow on buffer cleanup patches will be needed) From: Ian Romanick <idr@us.ibm.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-28drm: Add via unichrome supportDave Airlie
Add DRM device driver for VIA Unichrome chipsets From: Unichrome Project http://unichrome.sf.net, Erdi Chen, Thomas Hellstrom Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-23Currently DRM depends on PCI this will need to change for ffb on Sparc toDave Airlie
be fixed but at the moment it is true. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
