path: root/drivers/char/drm/mga_drv.h
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-05-07Revert "drm/vbl rework: rework how the drm deals with vblank."Dave Airlie
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4. Okay this looks like wasn't as fully baked as I'd led myself to believe. Revert for now for further baking. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26drm/vbl rework: rework how the drm deals with vblank.Jesse Barnes
Other Authors: Michel Dänzer <michel@tungstengraphics.com> mga: Ian Romanick <idr@us.ibm.com> via: Thomas Hellstrom <thomas-at-tungstengraphics-dot-com> This re-works the DRM internals to provide a better interface for drivers to expose vblank on multiple crtcs. It also includes work done by Michel on making i915 triple buffering and pageflipping work properly. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07drm: cleanup DRM_DEBUG() parametersMárton Németh
As DRM_DEBUG macro already prints out the __FUNCTION__ string (see drivers/char/drm/drmP.h), it is not worth doing this again. At some other places the ending "\n" was added. airlied:- I cleaned up a few that this patch missed also Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: run cleanfile across drm treeDave Airlie
2007-10-15drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.Eric Anholt
The data is now in kernel space, copied in/out as appropriate according to t This results in DRM_COPY_{TO,FROM}_USER going away, and error paths to deal with those failures. This also means that XFree86 4.2.0 support for i810 DR is lost. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Remove DRM_ERR OS macro.Eric Anholt
This was used to make all ioctl handlers return -errno on linux and errno on *BSD. Instead, just return -errno in shared code, and flip sign on return f shared code to *BSD code. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: drop drm_buf_t typedefDave Airlie
2007-07-11drm: fixup other drivers for typedef removalsDave Airlie
2005-11-11drm: update mga driver for new bootstrap codeDave Airlie
The MGA driver needs to use the full AGP interface. From: Ian Romanick <idr@us.ibm.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-10drm: rename driver hooks more understandablyDave Airlie
Rename the driver hooks in the DRM to something a little more understandable: preinit -> load postinit -> (removed) presetup -> firstopen postsetup -> (removed) open_helper -> open prerelease -> preclose free_filp_priv -> postclose pretakedown -> lastclose postcleanup -> unload release -> reclaim_buffers_locked version -> (removed) postinit and version were replaced with generic code in the Linux DRM (drivers now set their version numbers and description in the driver structure, like on BSD). postsetup wasn't used at all. Fixes the savage hooks for initializing and tearing down mappings at the right times. Testing involved at least starting X, running glxgears, killing glxgears, exiting X, and repeating. Tested on: FreeBSD (g200, g400, r200, r128) Linux (r200, savage4) From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-10-22merge linus head to drm-mm branchDave Airlie
2005-10-21[PATCH] drm: another mga bugDave Airlie
The wrong state emission routines were being called for G550, and consistent maps weren't correctly mapped... Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30drm: fix all sparse warning on 32-bit x86Dave Airlie
Finally cleaned up the sparse warnings for the drm. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10Add support for PCI MGA cards to MGA DRM.Dave Airlie
This patch adds serveral new ioctls and a new query to get_param query to support PCI MGA cards. Two ioctls were added to implement interrupt based waiting. With this change, the client-side driver no longer needs to map the primary DMA region or the MMIO region. Previously, end-of-frame waiting was done by busy waiting in the client-side driver until one of the MMIO registers (the current DMA pointer) matched a pointer to the end of primary DMA space. By using interrupts, the busy waiting and the extra mappings are removed. A third ioctl was added to bootstrap DMA. This ioctl, which is used by the X-server, moves a *LOT* of code from the X-server into the kernel. This allows the kernel to do whatever needs to be done to setup DMA buffers. The entire process and the locations of the buffers are hidden from user-mode. Additionally, a get_param query was added to differentiate between G4x0 cards and G550 cards. A gap was left in the numbering sequence so that, if needed, G450 cards could be distinguished from G400 cards. According to Ville Syrjälä, the G4x0 cards and the G550 cards handle anisotropic filtering differently. This seems the most compatible way to let the client-side driver know which card it's own. Doing this very small change now eliminates the need to bump the DRM minor version twice. http://marc.theaimsgroup.com/?l=dri-devel&m=106625815319773&w=2 (airlied - this may not work at this point, I think the follow on buffer cleanup patches will be needed) From: Ian Romanick <idr@us.ibm.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: add test for AGP devices and driver override for it.Dave Airlie
Added device_is_agp callback to drm_driver. This function is called by the platform-specific drm_device_is_agp function. Added implementation of this function the the Linux-specific portion of the MGA driver to detect PCI G450 cards. Added code to the Linux-specific portion of the generic DRM layer to not initialize AGP infrastructure if the card is not AGP (this matches what already existed in BSD). Fix up i810/i830 and i915 drivers to always return AGP as they don't always report the capability. Fix the MGA to not report AGP for a card that has an AGP chip behind a PCI bridge. From: Ian Romanick, Dave Airlie, Alan Hourihane Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-07drm: add 32/64 support for MGA/R128/i915Dave Airlie
This adds compatiblity ioctls for mga/r128 and i915 DRM drivers. From: Paul Mackerras, David Airlie, Alan Hourihane, Egbert Eich. Signed-off-by: David Airlie <airlied@linux.ie>
