path: root/drivers/char/drm/via_drv.h
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-05-07Revert "drm/vbl rework: rework how the drm deals with vblank."Dave Airlie
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4. Okay this looks like wasn't as fully baked as I'd led myself to believe. Revert for now for further baking. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26drm/vbl rework: rework how the drm deals with vblank.Jesse Barnes
Other Authors: Michel Dänzer <michel@tungstengraphics.com> mga: Ian Romanick <idr@us.ibm.com> via: Thomas Hellstrom <thomas-at-tungstengraphics-dot-com> This re-works the DRM internals to provide a better interface for drivers to expose vblank on multiple crtcs. It also includes work done by Michel on making i915 triple buffering and pageflipping work properly. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-10-15drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.Eric Anholt
The data is now in kernel space, copied in/out as appropriate according to t This results in DRM_COPY_{TO,FROM}_USER going away, and error paths to deal with those failures. This also means that XFree86 4.2.0 support for i810 DR is lost. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Replace filp in ioctl arguments with drm_file *file_priv.Eric Anholt
As a fallout, replace filp storage with file_priv storage for "unique identifier of a client" all over the DRM. There is a 1:1 mapping, so this should be a noop. This could be a minor performance improvement, as everyth on Linux dereferenced filp to get file_priv anyway, while only the mmap ioct went the other direction. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-12drm: de-typedef smanDave Airlie
2007-07-11drm: remove drm_file_t, drm_device_t and drm_head_t typedefsDave Airlie
some drivers still todo. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-05-08via: Try to improve command-buffer chaining.Thomas Hellstrom
Bump driver date and patchlevel. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-02-08via: allow for npot texture pitch alignmentThomas Hellstrom
2007-02-08via: add some new chipsetsThomas Hellstrom
Disable 3D functionality and AGP DMA for chipsets with the DX9 3D engine. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: add drm simple memory manager support for SiS and VIA driversThomas Hellstrom
This add support to the SiS and VIA drivers for the simple memory manager. This fixes a lot of problems with the current simple code these drivers used, including locking and SMP issues. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-02-02drm: drivers/char/drm/: make some functions staticDave Airlie
From: Adrian Bunk <bunk@stusta.de> This patch makes some needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: via driver update to CVS versionDave Airlie
This updates the DRM via driver to the latest CVS version, which contains support for DMA blitting. It also contains some whitespace and other minor fixes From: Thomas Hellstrom <unichrome@shipmail.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-12drm: update VIA driver to 2.7.2Dave Airlie
Add PCI DMA blitengine to VIA DRM Add portability code for porting VIA to FreeBSD. Sync via_drm.h with 3d driver From: Thomas Hellstrom <unichrome@shipmail.org>, Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-30drm: fix all sparse warning on 32-bit x86Dave Airlie
Finally cleaned up the sparse warnings for the drm. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-28drm: Add via unichrome supportDave Airlie
Add DRM device driver for VIA Unichrome chipsets From: Unichrome Project http://unichrome.sf.net, Erdi Chen, Thomas Hellstrom Signed-off-by: Dave Airlie <airlied@linux.ie>
