path: root/drivers/char/ds1302.c
2007-02-12[PATCH] DS1302: local_irq_disable() is redundant after local_irq_save()Jiri Kosina
drivers/char/ds1302.c::get_rtc_time() contains local_irq_disable() call after local_irq_save(). This looks redundant. drivers/char/ds1302.c::rtc_ioctl() contains local_irq_disable() call after local_irq_save(). This looks redundant. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
