path: root/drivers/char/hvc_vio.c
2011-01-13tty: move hvc drivers to drivers/tty/hvc/Greg Kroah-Hartman
As requested by Arnd Bergmann, the hvc drivers are now moved to the drivers/tty/hvc/ directory. The virtio_console.c driver was also moved, as it required the hvc_console.h file to be able to be built, and it really is a hvc driver. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-29drivers/char/hvc_vio: Use static const char arraysJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-24hvc_console: make the ops pointer const.Rusty Russell
This is nicer for modern R/O protection. And noone needs it non-const, so constify the callers as well. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Amit Shah <amit.shah@redhat.com> To: Christian Borntraeger <borntraeger@de.ibm.com> Cc: linuxppc-dev@ozlabs.org
2009-08-28hvc_console: Add __init and __exit to hvc_vioPeter Huewe
Trivial patch which adds the __init/__exit macros to the module_init/ module_exit functions of char/hvc_vio.c Please have a look at the small patch and either pull it through your tree, or please ack' it so Jiri can pull it through the trivial tree. linux version 2.6.31-rc6 - linus git tree, Do 20. Aug 22:26:06 CEST 2009 Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-16drivers/hvc: Add missing __devexit_p()Mike Frysinger
The remove function uses __devexit, so the .remove assignment needs __devexit_p() to fix a build error with hotplug disabled. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-03drivers/hvc: Add missing of_node_putNicolas Palix
of_node_put is needed before discarding a value received from of_find_node_by_name, e.g., in error handling code or when the device node is no longer used. The semantic match that catches the bug is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression struct device_node *n; position p1, p2; statement S1,S2; expression E,E1; expression *ptr != NULL; @@ ( if (!(n@p1 = of_find_node_by_name(...))) S1 | n@p1 = of_find_node_by_name(...) ) <... when != of_node_put(n) when != if (...) { <+... of_node_put(n) ...+> } when != true !n || ... when != n = E when != E = n if (!n || ...) S2 ...> ( return \(0\|<+...n...+>\|ptr\); | return@p2 ...; | n = E1 | E1 = n ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-22hvc_console: Add a hangup notifier for backendsHendrik Brueckner
I have added a hangup notifier that can be used by hvc console backends to handle a tty hangup. The default irq hangup notifier calls the notifier_del_irq() for compatibility. Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-25hvc_console: rework setup to replace irq functions with callbacksChristian Borntraeger
This patch tries to change hvc_console to not use request_irq/free_irq if the backend does not use irqs. This allows virtio_console to use hvc_console without having a linker reference to request_irq/free_irq. In addition, together with patch 2/3 it improves the performance for virtio console input. (an earlier version of this patch was tested by Yajin on lguest) The irq specific code is moved to hvc_irq.c and selected by the drivers that use irqs (System p, System i, XEN). I replaced "int irq" with the opaque "int data". The request_irq and free_irq calls are replaced with notifier_add and notifier_del. I have also changed the code a bit to call the notifier_add and notifier_del inside the spinlock area as the callbacks are found via hp->ops. Changes since last version: o remove ifdef o reintroduce "irq_requested" as "notified" o cleanups, sparse.. I did not move the timer based polling into a separate polling scheme. I played with several variants, but it seems we need to sleep/schedule in a thread even for irq based consoles, as there are throttleing and buffer size constraints. I also kept hvc_struct defined in hvc_console.h so that hvc_irq.c can access the irq_requested element. Feedback is appreciated. virtio_console is currently the only available console for kvm on s390. I plan to push this change as soon as all affected parties agree on it. I would love to get test results from System p, Xen etc. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-27[POWERPC] Rename get_property to of_get_property: partial driversStephen Rothwell
This does drivers/machintosh and the hvc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-25[POWERPC] The two vio HVC backends clashStephen Rothwell
Make sure only one of them actually registers as a driver. Also, remove cast from get_property(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-07-31[POWERPC] pseries: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. pseries platform changes. Built for pseries_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-13[POWERPC] Make the hvc_console output buffer size settableStephen Rothwell
So the iSeries console will be faster since it can send up to 200 bytes at a time to the Hypervisor. This only affects the tty part of the console, the console writes are still in 16 byte lots. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-03-28[PATCH] powerpc: hvc_console updatesRyan S. Arnold
These are some updates from both Ryan and Arnd for the hvc_console driver: The main point is to enable the inclusion of a console driver for rtas, which is currrently needed for the cell platform. Also shuffle around some data-type declarations and moves some functions out of include/asm-ppc64/hvconsole.h and into a new drivers/char/hvc_console.h file. Signed-off-by: "Ryan S. Arnold" <rsa@us.ibm.com> Signed-off-by: Arnd Bergmann <abergman@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-24powerpc: don't duplicate name between vio_driver and device_driverStephen Rothwell
Just set the name field directly in the device_driver structure contained in the vio_driver struct. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-08-30[PATCH] Make MODULE_DEVICE_TABLE work for vio devicesStephen Rothwell
Make MODULE_DEVICE_TABLE work for vio devices. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-07-07[PATCH] hvc_console: Separate the NUL character filtering from get_hvc_charsMilton Miller
Separate the NUL character filtering from get_hvc_chars. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] hvc_console: Register ops when setting up hvc_consoleMilton Miller
When registering the hvc console port, register a list of ops (read and write) to go with it, instead of calling fixed function names. This allows different ports to encode the data differently. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] hvc_console: Separate hvc_console and vio code 2Milton Miller
Remove all the vio device driver code from hvc_console.c This will allow us to separate hvsi, hvc, and allow hvc_console to be used without the ppc64 vio layer. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
