Switch virtio-rng to new virtqueue_xxx wrappers.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Fix fixes the following warnings by renaming the driver structures to be
suffixed with _driver.
WARNING: drivers/virtio/virtio_balloon.o(.data+0x88): Section mismatch in reference from the variable virtio_balloon to the function .devexit.text:virtballoon_remove()
WARNING: drivers/char/hw_random/virtio-rng.o(.data+0x88): Section mismatch in reference from the variable virtio_rng to the function .devexit.text:virtrng_remove()
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
This patch converts virtio-rng to the new hw_rng API.
In the process it fixes a previously untriggered buffering bug where the
buffer is not drained correctly if it has a non-multiple-of-4 length.
Performance has improved under qemu-kvm testing also.
Signed-off-by: Ian Molton <ian.molton@collabora.co.uk>
Acked-by: Matt Mackall <mpm@selenic.com>
The function virtrng_remove is used only wrapped by __devexit_p so define
it using __devexit.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Rusty,
commit 3ca4f5ca73057a617f9444a91022d7127041970a
virtio: add virtio IDs file
moved all device IDs into a single file. While the change itself is
a very good one, it can break userspace applications. For example
if a userspace tool wanted to get the ID of virtio_net it used to
include virtio_net.h. This does no longer work, since virtio_net.h
does not include virtio_ids.h.
This patch moves all "#include <linux/virtio_ids.h>" from the C
files into the header files, making the header files compatible with
the old ones.
In addition, this patch exports virtio_ids.h to userspace.
CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Virtio IDs are spread all over the tree which makes assigning new IDs
bothersome. Putting them together should make the process less error-prone.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
This API change means that virtio_net can tell how much capacity
remains for buffers. It's necessarily fuzzy, since
VIRTIO_RING_F_INDIRECT_DESC means we can fit any number of descriptors
in one, *if* we can kmalloc.
Cc: Dinesh Subhraveti <dineshs@us.ibm.com>
If the device fills less than 4 bytes of our random buffer, we'll
BUG_ON. It's nicer to handle the case where it partially fills the
buffer (the protocol doesn't explicitly bad that).
This replaces find_vq/del_vq with find_vqs/del_vqs virtio operations,
and updates all drivers. This is needed for MSI support, because MSI
needs to know the total number of vectors upfront.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ lguest/9p compile fixes)
Add a linked list of all virtqueues for a virtio device: this helps for
debugging and is also needed for upcoming interface change.
Also, add a "name" field for clearer debug messages.
The virtio-rng drivers checks for spurious callbacks. Since
callbacks can be implemented via shared interrupts (e.g. PCI) this
could lead to guest kernel oopses with lots of virtio devices.
Cc: stable@kernel.org
Note that by itself, having a "hardware" random generator does very
little: you should probably run "rngd" in your guest to feed this into
the kernel entropy pool.
Included:
virtio_rng: dont use vmalloced addresses for virtio
If virtio_rng is build as a module, random_data is an address
in vmalloc space. As virtio expects guest real addresses, this
can cause any kind of funny behaviour, so lets allocate
random_data dynamically with kmalloc.
