This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
sound/soc/fsl/imx-sgtl5000.c
[ Upstream commit eaecce12f5f0d2c35d278e41e1bc4522393861ab ]
When unloading omap3-rom-rng, we'll get the following:
WARNING: CPU: 0 PID: 100 at drivers/clk/clk.c:948 clk_core_disable
This is because the clock may be already disabled by omap3_rom_rng_idle().
Let's fix the issue by checking for rng_idle on exit.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Adam Ford <aford173@gmail.com>
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Sebastian Reichel <sre@kernel.org>
Cc: Tero Kristo <t-kristo@ti.com>
Fixes: 1c6b7c2108bd ("hwrng: OMAP3 ROM Random Number Generator support")
commit af0d4442dd6813de6e77309063beb064fa8e89ae upstream.
No remove function implemented yet in the driver.
Without remove function, the pm_runtime implementation
complains when removing and probing again the driver.
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
commit 78887832e76541f77169a24ac238fccb51059b63 upstream.
add_early_randomness() is called by hwrng_register() when the
hardware is added. If this hardware and its module are present
at boot, and if there is no data available the boot hangs until
data are available and can't be interrupted.
For instance, in the case of virtio-rng, in some cases the host can be
not able to provide enough entropy for all the guests.
We can have two easy ways to reproduce the problem but they rely on
misconfiguration of the hypervisor or the egd daemon:
- if virtio-rng device is configured to connect to the egd daemon of the
host but when the virtio-rng driver asks for data the daemon is not
connected,
host but the egd daemon doesn't provide data.
The guest kernel will hang at boot until the virtio-rng driver provides
enough data.
To avoid that, call rng_get_data() in non-blocking mode (wait=0)
from add_early_randomness().
Signed-off-by: Laurent Vivier <lvivier@redhat.com>
Fixes: d9e797261933 ("hwrng: add randomness to system from rng...")
Cc: <stable@vger.kernel.org>
Reviewed-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit aef027db48da56b6f25d0e54c07c8401ada6ce21 ]
The virtio-rng driver uses a completion called have_data to wait for a
virtio read to be fulfilled by the hypervisor. The completion is reset
before placing a buffer on the virtio queue and completed by the virtio
callback once data has been written into the buffer.
Prior to this commit, the driver called init_completion on this
completion both during probe as well as when registering virtio buffers
as part of a hwrng read operation. The second of these init_completion
calls should instead be reinit_completion because the have_data
completion has already been inited by probe. As described in
Documentation/scheduler/completion.txt, "Calling init_completion() twice
on the same completion object is most likely a bug".
This bug was present in the initial implementation of virtio-rng in
f7f510ec1957 ("virtio: An entropy device, as suggested by hpa"). Back
then the have_data completion was a single static completion rather than
a member of one of potentially multiple virtrng_info structs as
implemented later by 08e53fbdb85c ("virtio-rng: support multiple
virtio-rng devices"). The original driver incorrectly used
init_completion rather than INIT_COMPLETION to reset have_data during
read.
Tested by running `head -c48 /dev/random | hexdump` within crosvm, the
Chrome OS virtual machine monitor, and confirming that the virtio-rng
driver successfully produces random bytes from the host.
Signed-off-by: David Tolnay <dtolnay@gmail.com>
Tested-by: David Tolnay <dtolnay@gmail.com>
ENGR00292341 imx6sl hwrng
Add hwrng support for i.MX6SL.
1. Add RNG driver. This driver originated as fsl-rngc.c. It
has been modified to support device tree. The name has been
changed since it supports both b and c variants of RNG.
2. Added clock and compatible info to the device tree data.
3. Added the entry in the options in the Kconfig for hwrng.
(cherry picked from commit 1f3f2c0647b7319c4e23293a61512e4191593513)
[<vicki.milhoan@freescale.com>: Edited to apply to 3.14]
Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
[ Upstream commit 326ed382256475aa4b8b7eae8a2f60689fd25e78 ]
Avoid issue when probing the RNG without
reset if bad status has been detected previously
commit b399151cb48db30ad1e0e93dd40d68c6d007b637 upstream.
x86_mask is a confusing name which is hard to associate with the
processor's stepping.
Additionally, correct an indent issue in lib/cpu.c.
Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com>
[ Updated it to more recent kernels. ]
Cc: bp@alien8.de
Cc: tony.luck@intel.com
Link: http://lkml.kernel.org/r/1514771530-70829-1-git-send-email-qianyue.zj@alibaba-inc.com
commit 8c75704ebcac2ffa31ee7bcc359baf701b52bf00 upstream.
After commit e9afc746299d ("hwrng: geode - Use linux/io.h instead of
asm/io.h") the geode-rng driver uses devres with pci_dev->dev to keep
track of resources, but does not actually register a PCI driver. This
results in the following issues:
1. The driver leaks memory because the driver does not attach to a
device. The driver only uses the PCI device as a reference. devm_*()
functions will release resources on driver detach, which the geode-rng
driver will never do. As a result,
2. The driver cannot be reloaded because there is always a use of the
ioport and region after the first load of the driver.
Revert the changes made by e9afc746299d ("hwrng: geode - Use linux/io.h
instead of asm/io.h").
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Fixes: 6e9b5e76882c ("hwrng: geode - Migrate to managed API")
Cc: Matt Mackall <mpm@selenic.com>
Cc: Corentin LABBE <clabbe.montjoie@gmail.com>
Cc: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
Cc: Wei Yongjun <weiyongjun1@huawei.com>
Cc: linux-crypto@vger.kernel.org
Cc: linux-geode@lists.infradead.org
commit 69db7009318758769d625b023402161c750f7876 upstream.
After commit 31b2a73c9c5f ("hwrng: amd - Migrate to managed API"), the
amd-rng driver uses devres with pci_dev->dev to keep track of resources,
but does not actually register a PCI driver. This results in the
following issues:
1. The message
WARNING: CPU: 2 PID: 621 at drivers/base/dd.c:349 driver_probe_device+0x38c
is output when the i2c_amd756 driver loads and attempts to register a PCI
driver. The PCI & device subsystems assume that no resources have been
registered for the device, and the WARN_ON() triggers since amd-rng has
already do so.
2. The driver leaks memory because the driver does not attach to a
functions will release resources on driver detach, which the amd-rng
3. The driver cannot be reloaded because there is always a use of the
Revert the changes made by 31b2a73c9c5f ("hwrng: amd - Migrate to managed
API").
Fixes: 31b2a73c9c5f ("hwrng: amd - Migrate to managed API").
hw_random carefully avoids using a stack buffer except in
add_early_randomness(). This causes a crash in virtio_rng if
CONFIG_VMAP_STACK=y.
Reported-by: Matt Mullins <mmullins@mmlx.us>
Tested-by: Matt Mullins <mmullins@mmlx.us>
Fixes: d3cc7996473a ("hwrng: fetch randomness only after device init")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Merge the crypto tree to pull in vmx ghash fix.
Currently omap-rng checks the return value of pm_runtime_get_sync and
reports failure if anything is returned, however it should be checking
if ret < 0 as pm_runtime_get_sync return 0 on success but also can return
1 if the device was already active which is not a failure case. Only
values < 0 are actual failures.
Fixes: 61dc0a446e5d ("hwrng: omap - Fix assumption that runtime_get_sync will always succeed")
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
In case of error, the function devm_ioremap() returns NULL pointer
not ERR_PTR(). The IS_ERR() test in the return value check should
be replaced with NULL test.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
In case of error, the function devm_kzalloc() or devm_ioport_map()
return NULL pointer not ERR_PTR(). The IS_ERR() test in the return
value check should be replaced with NULL test.
Fix checkpatch.pl warning by changing from asm/io.h to linux/io.h. In
the mean time arrange the includes in alphabetical order.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
Use devm_ioremap and devm_hwrng_register instead of ioremap and
hwrng_register. This removes error handling code. Also moved code around
by removing goto statements. This improves code readability.
Fix the missing clk_disable_unprepare() before return
from st_rng_probe() in the error handling case.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Peter Griffin <peter.griffin@linaro.org>
Managed API eliminates error handling code, thus reduces several lines
of code.
In core rng_buffer and rng_fillbuf is allocated in hwrng_register only
once and it is freed during module exit. This patch moves allocating
rng_buffer and rng_fillbuf from hwrng_register to rng core's init. This
avoids checking whether rng_buffer and rng_fillbuf was allocated from
every hwrng_register call. Also moving them to module init makes it
explicit that it is freed in module exit.
Change in v2:
Fix memory leak when register_miscdev fails.
Checkpatch.pl warns about usage of asm/io.h. Use linux/io.h instead.
hwrng_register. This removes unregistering and error handling code.
Changes in v2:
Remove hardcoded resource size in ioremap, use resource struct obtained
by calling platform_get_resource.
Removing hardcoded resource size was suggested by LABBE Corentin.
CC: Darren Stevens <darren@stevens-zone.net>
Suggested-by: LABBE Corentin <clabbe.montjoie@gmail.com>
Check return value of of_iomap and handle errors correctly.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Acked-by: Eric Anholt <eric@anholt.net>
By using devm_hwrng_register instead of hwrng_register the .remove
callback in platform_driver can be removed. This reduces a few lines in
code.
HW RNG core never asks for data less than 4 bytes. The check whether max
is less than 4 bytes is unnecessary. Remove the check.
This patch convert the hwrng interface used by amd768-rng to its new API
by replacing data_read()/data_present() by read().
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
Instead of accessing hw directly via pmbase, it's better to
access after ioport_map() via ioread32/iowrite32.
Instead of having two global variable, it's better to use a
private struct. This will permit to remove amd_pdev variable
The driver release the memory region before being sure that nobody use
it.
This patch made hwrng_unregister ran before any release was done.
checkpatch complains about <asm/io.h> used instead of linux/io.h.
In fact it is not needed.
This patch remove it, and in the process, alphabetize the other headers.
The driver name is displayed each time differently.
This patch make use of the same name everywhere.
This patch add usage of the BIT() macro
Some blank line are unncessary, and one is missing after declaration.
This patch fix thoses style problems.
The Cavium ThunderX SoC has a hardware random number generator.
This driver provides support using the HWRNG framework.
Signed-off-by: Omer Khaliq <okhaliq@caviumnetworks.com>
Signed-off-by: Ananth Jasty <Ananth.Jasty@cavium.com>
Acked-by: David Daney <david.daney@cavium.com>
Remove omap3_rom_rng_data_present method as it was returning 1 always.
Use .read callback instead of .data_read callback. This avoids use of
obsolete callbacks.
This patch is not tested with hardware as I don't have access to it.
We can directly depend on SOC_IMX31 since commit c9ee94965dce
("ARM: imx: deconstruct mxc_rnga initialization")
Since that commit, CONFIG_HW_RANDOM_MXC_RNGA could not be switched on
with unknown symbol ARCH_HAS_RNGA and mxc-rnga.o can't be generated with
ARCH=arm make M=drivers/char/hw_random
Previously, HW_RANDOM_MXC_RNGA required ARCH_HAS_RNGA
which was based on IMX_HAVE_PLATFORM_MXC_RNGA && ARCH_MXC.
IMX_HAVE_PLATFORM_MXC_RNGA was based on SOC_IMX31.
Fixes: c9ee94965dce ("ARM: imx: deconstruct mxc_rnga initialization")
Signed-off-by: Fabian Frederick <fabf@skynet.be>
The field "owner" is set by the core.
Thus delete an unneeded initialisation.
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
pm_runtime_get_sync does return a error value that must be checked for
error conditions, else, due to various reasons, the device maynot be
enabled and the system will crash due to lack of clock to the hardware
module.
Before:
12.562784] [00000000] *pgd=fe193835
12.562792] Internal error: : 1406 [#1] SMP ARM
12.562864] CPU: 1 PID: 241 Comm: modprobe Not tainted 4.7.0-rc4-next-20160624 #2
12.562867] Hardware name: Generic DRA74X (Flattened Device Tree)
12.562872] task: ed51f140 ti: ed44c000 task.ti: ed44c000
12.562886] PC is at omap4_rng_init+0x20/0x84 [omap_rng]
12.562899] LR is at set_current_rng+0xc0/0x154 [rng_core]
After the proper checks:
[ 94.366705] omap_rng 48090000.rng: _od_fail_runtime_resume: FIXME:
missing hwmod/omap_dev info
[ 94.375767] omap_rng 48090000.rng: Failed to runtime_get device -19
[ 94.382351] omap_rng 48090000.rng: initialization failed.
Fixes: 665d92fa85b5 ("hwrng: OMAP: convert to use runtime PM")
Cc: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
The Broadcom BCM5301x SoCs (Northstar) utilize the same random number
generator peripheral as Northstar Plus and BCM2835, but just like the
NSP SoC, we need to enable the interrupt.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Add support for the Amlogic Meson SoCs hardware random generator.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The __raw IO functions are not endian safe, so use the readl_relaxed
and writel_relaxed versions of these.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Read the requested number of data from the fifo
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com>
Reviewed-by: Eric Anholt <eric@anholt.net>
This supports the random number generator available in NSP SoC.
Masks the rng interrupt for NSP.
This patch fixes the following warning:
drivers/char/hw_random/stm32-rng.c: In function 'stm32_rng_read':
drivers/char/hw_random/stm32-rng.c:82:19: warning: 'sr' may be used
uninitialized in this function
Reported-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org>
This patch integrates the ppc4xx-rng driver into the existing
crypto4xx. This is because the true random number generator
is controlled and part of the security core.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This adds the Hisilicon Random Number Generator(RNG) support,
which is found in Hip04 and Hip05 soc.
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Correct smasung.com into samsung.com.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Get some build coverage of Exynos H/W random number generator
driver. Driver uses devm_ioremap_resource() so add IOMEM dependency for
the compile testing.
Driver enabled runtime PM but did not revert this on removal. Re-binding
of a device triggered warning:
exynos-rng 10830400.rng: Unbalanced pm_runtime_enable!
Fixes: b329669ea0b5 ("hwrng: exynos - Add support for Exynos random number generator")
Add proper error path (for disabling runtime PM) when registering of
hwrng fails.
