path: root/drivers/char/i8k.c
2011-05-25i8k: Integrate with the hwmon subsystemJean Delvare
Let i8k create an hwmon class device so that libsensors will expose the CPU temperature and fan speeds to monitoring applications. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Massimo Dal Zotto <dz@debian.org>
2011-05-25i8k: Avoid lahf in 64-bit codeLuca Tettamanti
i8k uses lahf to read the flag register in 64-bit code; early x86-64 CPUs, however, lack this instruction and we get an invalid opcode exception at runtime. Use pushf to load the flag register into the stack instead. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Reported-by: Jeff Rickman <jrickman@myamigos.us> Tested-by: Jeff Rickman <jrickman@myamigos.us> Tested-by: Harry G McGavran Jr <w5pny@arrl.net> Cc: stable@kernel.org Cc: Massimo Dal Zotto <dz@debian.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-11-15Fix gcc 4.5.1 miscompiling drivers/char/i8k.c (again)Jim Bos
The fix in commit 6b4e81db2552 ("i8k: Tell gcc that *regs gets clobbered") to work around the gcc miscompiling i8k.c to add "+m (*regs)" caused register pressure problems and a build failure. Changing the 'asm' statement to 'asm volatile' instead should prevent that and works around the gcc bug as well, so we can remove the "+m". [ Background on the gcc bug: a memory clobber fails to mark the function the asm resides in as non-pure (aka "__attribute__((const))"), so if the function does nothing else that triggers the non-pure logic, gcc will think that that function has no side effects at all. As a result, callers will be mis-compiled. Adding the "+m" made gcc see that it's not a pure function, and so does "asm volatile". The problem was never really the need to mark "*regs" as changed, since the memory clobber did that part - the problem was just a bug in the gcc "pure" function analysis - Linus ] Signed-off-by: Jim Bos <jim876@xs4all.nl> Acked-by: Jakub Jelinek <jakub@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-13i8k: Tell gcc that *regs gets clobberedJim Bos
More recent GCC caused the i8k driver to stop working, on Slackware compiler was upgraded from gcc-4.4.4 to gcc-4.5.1 after which it didn't work anymore, meaning the driver didn't load or gave total nonsensical output. As it turned out the asm(..) statement forgot to mention it modifies the *regs variable. Credits to Andi Kleen and Andreas Schwab for providing the fix. Signed-off-by: Jim Bos <jim876@xs4all.nl> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05drivers: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. These drivers do not seem to be under active maintainance from my brief investigation. Apologies to those maintainers that I have missed. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-05-17procfs: Push down the bkl from ioctlFrederic Weisbecker
Push down the bkl from procfs's ioctl main handler to its users. Only three procfs users implement an ioctl (non unlocked) handler. Turn them into unlocked_ioctl and push down the Devil inside. v2: PDE(inode)->data doesn't need to be under bkl v3: And don't forget to git-add the result v4: Use wrappers to pushdown instead of an invasive and error prone handlers surgery. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: John Kacur <jkacur@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com>
2009-01-02i8k: Add Dell Vostro systemsFederico Heinz
This trivial patch adds support for i8k on the new Dell Vostro models. I tested it on my Vostro 1400, and it works. It does print a warning when loading the module: i8k: unable to get SMM BIOS version But I couldn't figure out how to fix that. The module seems to work fine, anyway... Signed-off-by: Federico Heinz <fheinz@vialibre.org.ar> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02i8k: Enable i8k on Dell Precision SystemsAndy Spencer
Patch to enable i8k on Dell Precisions. Signed-off-by: Andy Spencer <spenceal@rose-hulman.edu> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01i8k: make fan multiplier tunable with a module parameterJochen Eisinger
The i8k driver multiplies the fan speed reported by the BIOS with a factor of 30. On my Dell Latitude D800, this factor is not required. I'd suggest to make this configurable. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07i8k: Inspiron E1705 fixFrank Sorenson
Needs the following in order to work correctly on my Inspiron E1705: Add DMI Product name to i8k for Dell MP061 hardware (Inspiron 9400/E1705) Signed-off-by: Frank Sorenson <frank@tuxrocks.com> Cc: Bradley Smith <bradjsmith@btinternet.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07I8K: allow i8k driver to be built on x86_64 systemsBradley Smith
Adds #if clause and additional inline assembly so that the driver builds on x86_64 systems. Signed-off-by: Bradley Smith <bradjsmith@btinternet.com> Cc: Frank Sorenson <frank@tuxrocks.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ik8: add Dell UK 6400 Inspiron model (MM061)Nick Warne
Add the Dell UK 6400 Inspiron model (MM061) to allow the i8k module to load correctly without using 'force=1' Signed-off-by: "Nick Warne" <nick@ukfsn.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-09drivers/firmware: const-ify DMI API and internalsJeff Garzik
Three main sets of changes: 1) dmi_get_system_info() return value should have been marked const, since callers should not be changing that data. 2) const-ify DMI internals, since DMI firmware tables should, whenever possible, be marked const to ensure we never ever write to that data area. 3) const-ify DMI API, to enable marking tables const where possible in low-level drivers. And if we're really lucky, this might enable some additional optimizations on the part of the compiler. The bulk of the changes are #2 and #3, which are interrelated. #1 could have been a separate patch, but it was so small compared to the others, it was easier to roll it into this changeset. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-08i386: sched.h inclusion from module.h is baackAlexey Dobriyan
linux/module.h -> linux/elf.h -> asm-i386/elf.h -> linux/utsname.h -> linux/sched.h Noticeably cut the number of files which are rebuild upon touching sched.h and cut down pulled junk from every module.h inclusion. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-12[PATCH] I8K: fix /proc reporting of blank service tagsDmitry Torokhov
Make /proc/i8k display '?' when service tag is blank in BIOS. This fixes segfault in i8k gkrellm plugin. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: add new BIOS signaturesDmitry Torokhov
I8K: add BIOS signatures of a newer Dell laptops, also there can be more than one temperature sensor reported by BIOS. Lifted from driver 1.25 on Massimo Dal Zotto's site. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: initialization code cleanup; formattingDmitry Torokhov
I8K: use module_{init|exit} instead of old style #ifdef MODULE code, some formatting changes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: convert to seqfileDmitry Torokhov
I8K: Change proc code to use seq_file. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: use standard DMI interfaceDmitry Torokhov
I8K: Change to use stock dmi infrastructure instead of homegrown parsing code. The driver now requires box's DMI data to match list of supported models so driver can be safely compiled-in by default without fear of it poking into random SMM BIOS code. DMI checks can be ignored with i8k.ignore_dmi option. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: pass through lindentDmitry Torokhov
I8K: pass through Lindent to change 4 spaces identation to TABs Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
