path: root/drivers/char/ip2/Makefile
2011-02-22tty: move obsolete and broken tty drivers to drivers/staging/tty/Greg Kroah-Hartman
As planned by Arnd Bergmann, this moves the following drivers to the drivers/staging/tty/ directory where they will be removed after 2.6.41 if no one steps up to claim them. epca epca ip2 istallion riscom8 serial167 specialix stallion Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-27drivers/char/ip2/Makefile: replace the use of <module>-objs with <module>-yTracey Dent
Changed <module>-objs to <module>-y in Makefile. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Char: merge ip2main and ip2baseJiri Slaby
It's pretty useless to have one setup() function separated along with module_init() which only calls a function from ip2main anyway. Get rid of ip2base. Remove also checks of always-true now. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ip2: fix crashes on load/unloadAlan Cox
This doesn't need to be two modules, and making it one cleans up the problem Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-19Move ip2.c and ip2main.c to drivers/char/ip2/ where the other filesAdrian Bunk
used by this driver reside. Renamed ip2.c to ip2base.c to allow ip2.o to be built from multiple objects. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Michael H. Warfield <mhw@WittsEnd.com>
