commit 48e8ac2979920ffa39117e2d725afa3a749bfe8d upstream.
With recent changes it is possible for the timer handler to detect an
idle interface and not start the timer, but the thread to start an
operation at the same time. The thread will not start the timer in that
instance, resulting in the timer not running.
Instead, move all timer operations under the lock and start the timer in
the thread if it detect non-idle and the timer is not already running.
Moving under locks allows the last timeout to be set in both the thread
and the timer. 'Timer is not running' means that the timer is not
pending and smi_timeout() is not running. So we need a flag to detect
this correctly.
Also fix a few other timeout bugs: setting the last timeout when the
interrupt has to be disabled and the timer started, and setting the last
timeout in check_start_timer_thread possibly racing with the timer
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Signed-off-by: Bodo Stroesser <bstroesser@ts.fujitsu.com>
Fix
drivers/char/ipmi/ipmi_si_intf.c: In function 'ipmi_parisc_probe':
drivers/char/ipmi/ipmi_si_intf.c:2752:2: error: 'rv' undeclared (first use in this function)
drivers/char/ipmi/ipmi_si_intf.c:2752:2: note: each undeclared identifier is reported only once for each function it appears in
Introduced by commit d02b3709ff8e ("ipmi: Cleanup error return")
Acked-by: Corey Minyard <cminyard@mvista.com>
Return proper errors for a lot of IPMI failure cases. Also call
pci_disable_device when IPMI PCI devices are removed.
Loading ipmi_si module while bmc is disconnected, we found the timeout
is longer than 5 secs. Actually it takes about 3 mins and 20
secs.(HZ=250)
error message as below:
Dec 12 19:08:59 linux kernel: IPMI BT: timeout in RD_WAIT [ ] 1 retries left
Dec 12 19:08:59 linux kernel: BT: write 4 bytes seq=0x01 03 18 00 01
Dec 12 19:12:19 linux kernel: IPMI BT: timeout in RD_WAIT [ ]
Dec 12 19:12:19 linux kernel: failed 2 retries, sending error response
Dec 12 19:12:19 linux kernel: IPMI: BT reset (takes 5 secs)
Dec 12 19:12:19 linux kernel: IPMI BT: flag reset [ ]
Function wait_for_msg_done() use schedule_timeout_uninterruptible(1) to
sleep 1 tick, so we should subtract jiffies_to_usecs(1) instead of 100
usecs from timeout.
Reported-by: Hu Shiyuan <hushiyuan@huawei.com>
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com>
This patch proposes to remove the use of the IRQF_DISABLED flag
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
The last line of PARISC machines (C8000, RP34x0, etc.) have a BMC for
controlling temperature, fan speed and other stuff. The BMC is
connected via a special bus and listed in the firmware device tree.
This change adds support for these BMCs to the IPMI driver.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
I'd submitted this about a year ago but it never made it upstream.
The latest versions of the kernel drivers for ipmi can use ACPI to
determine the type of BMC device used in the system. The following
patch adds a module alias so that udev will autoload the ipmi_si driver.
Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com>
When the interrupt enable message returns an error, the messages are
not entirely accurate nor helpful. So improve them.
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
Add try... parameters to disable pci and platform (openfirmware) device
scanning for IPMI. Also add docs for all the try... parameters.
The configuration change building ipmi_si into the kernel precludes the
use of a custom driver that can utilize more than one KCS interface,
multiple IPMBs, and more than one BMC. This capability is important for
fault-tolerant systems.
Even if the kernel option ipmi_si.trydefaults=0 is specified, ipmi_si
discovers and claims one of the KCS interfaces on a Stratus server. The
inability to now prevent the kernel from managing this device is a
regression from previous kernels. The regression breaks a capability
fault-tolerant vendors have relied upon.
To support both ACPI opregion access and the need to avoid activation of
ipmi_si on some platforms, we've added two new kernel options,
ipmi_si.tryacpi and ipmi_si.trydmi be added to prevent ipmi_si from
initializing when these options are set to 0 on the kernel command line.
With these options at the default value of 1, ipmi_si init proceeds
according to the kernel default.
Tested-by: Jim Paradis <jparadis@redhat.com>
Signed-off-by: Robert Evans <Robert.Evans@stratus.com>
Signed-off-by: Jim Paradis <jparadis@redhat.com>
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: David Airlie <airlied@linux.ie>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Olof Johansson <olof@lixom.net>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: Rajiv Andrade <mail@srajiv.net>
Cc: Marcel Selhorst <tpmdd@selhorst.net>
Cc: Sirrix AG <tpmdd@sirrix.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: openipmi-developer@lists.sourceforge.net
Cc: platform-driver-x86@vger.kernel.org
Cc: tpmdd-devel@lists.sourceforge.net
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Cc: Geoff Levand <geoff@infradead.org>
Cc: Amit Shah <amit.shah@redhat.com>
Cc: cbe-oss-dev@lists.ozlabs.org
Cc: virtualization@lists.linux-foundation.org
"Asynchronous" is misspelled in some comments. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
The IPMI spec defines a way to detect register spacing for PCI interfaces,
so implement it.
Signed-off-by: Steven Hsieh <sshsieh@broadcom.com>
The legacy PM callbacks provided by the IPMI PCI driver are
empty routines returning 0, so they can be safely dropped.
Merge third batch of patches from Andrew Morton:
- Some MM stragglers
- core SMP library cleanups (on_each_cpu_mask)
- Some IPI optimisations
- kexec
- kdump
- IPMI
- the radix-tree iterator work
- various other misc bits.
"That'll do for -rc1. I still have ~10 patches for 3.4, will send
those along when they've baked a little more."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
backlight: fix typo in tosa_lcd.c
crc32: add help text for the algorithm select option
mm: move hugepage test examples to tools/testing/selftests/vm
mm: move slabinfo.c to tools/vm
mm: move page-types.c from Documentation to tools/vm
selftests/Makefile: make `run_tests' depend on `all'
selftests: launch individual selftests from the main Makefile
radix-tree: use iterators in find_get_pages* functions
radix-tree: rewrite gang lookup using iterator
radix-tree: introduce bit-optimized iterator
fs/proc/namespaces.c: prevent crash when ns_entries[] is empty
nbd: rename the nbd_device variable from lo to nbd
pidns: add reboot_pid_ns() to handle the reboot syscall
sysctl: use bitmap library functions
ipmi: use locks on watchdog timeout set on reboot
ipmi: simplify locking
ipmi: fix message handling during panics
ipmi: use a tasklet for handling received messages
ipmi: increase KCS timeouts
ipmi: decrease the IPMI message transaction time in interrupt mode
Now that the the IPMI driver is using a tasklet, we can simplify the
locking in the driver and get rid of the message lock.
The IPMI driver would release a lock, deliver a message, then relock.
This is obviously ugly, and this patch converts the message handler
interface to use a tasklet to schedule work. This lets the receive
handler be called from an interrupt handler with interrupts enabled.
Call the event handler immediately after starting the next message.
This change considerably decreases the IPMI transaction time (cuts off
~9ms for a single ipmitool transaction).
Signed-off-by: Srinivas_Gowda <srinivas_g_gowda@dell.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
The ->read_proc interface is going away, convert to seq_file.
Cc:Corey Minyard <minyard@acm.org>
Commit b826291c, "drivercore/dt: add a match table pointer to struct
device" added an of_match pointer to struct device to cache the
of_match_table entry discovered at driver match time. This was unsafe
because matching is not an atomic operation with probing a driver. If
two or more drivers are attempted to be matched to a driver at the
same time, then the cached matching entry pointer could get
overwritten.
This patch reverts the of_match cache pointer and reworks all users to
call of_match_device() directly instead.
commit d2478521afc2022 ("char/ipmi: fix OOPS caused by
pnp_unregister_driver on unregistered driver") introduced a section
mismatch by calling __exit cleanup_ipmi_si from __devinit init_ipmi_si.
Remove __exit annotation from cleanup_ipmi_si.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt: Eliminate of_platform_{,un}register_driver
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
This patch fixes an issue in OpenIPMI module where sometimes an ABORT command
is sent after sending an IPMI request to BMC causing the IPMI request to fail.
Signed-off-by: YiCheng Doe <yicheng.doe@hp.com>
Acked-by: Tom Mingarelli <thomas.mingarelli@hp.com>
Tested-by: Andy Cress <andy.cress@us.kontron.com>
Tested-by: Mika Lansirine <Mika.Lansirinne@stonesoft.com>
Tested-by: Brian De Wolf <bldewolf@csupomona.edu>
Cc: Jean Michel Audet <Jean-Michel.Audet@ca.Kontron.com>
Cc: Jozef Sudelsky <jozef.sudolsky@elbiahosting.sk>
Acked-by: Matthew Garrett <mjg@redhat.com>
of_bus is deprecated in favor of the plain platform bus. This patch
merges the ipmi OF driver with the existing platform driver.
CONFIG_PPC_OF occurrances are removed or replaced with CONFIG_OF.
Compile tested with and without CONFIG_OF. Tested OF probe and
default probe cases.
This patch fixes an OOPS triggered when calling modprobe ipmi_si a
second time after the first modprobe returned without finding any ipmi
devices. This can happen if you reload the module after having the
first module load fail. The driver was not deregistering from PNP in
that case.
Peter Huewe originally reported this patch and supplied a fix, I have a
different patch based on Linus' suggestion that cleans things up a bit
more.
Cc: stable@kernel.org
Reviewed-by: Peter Huewe <peterhuewe@gmx.de>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits)
ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework
ACPI: fix resource check message
ACPI / Battery: Update information on info notification and resume
ACPI: Drop device flag wake_capable
ACPI: Always check if _PRW is present before trying to evaluate it
ACPI / PM: Check status of power resources under mutexes
ACPI / PM: Rename acpi_power_off_device()
ACPI / PM: Drop acpi_power_nocheck
ACPI / PM: Drop acpi_bus_get_power()
Platform / x86: Make fujitsu_laptop use acpi_bus_update_power()
ACPI / Fan: Rework the handling of power resources
ACPI / PM: Register power resource devices as soon as they are needed
ACPI / PM: Register acpi_power_driver early
ACPI / PM: Add function for updating device power state consistently
ACPI / PM: Add function for device power state initialization
ACPI / PM: Introduce __acpi_bus_get_power()
ACPI / PM: Introduce function for refcounting device power resources
ACPI / PM: Add functions for manipulating lists of power resources
ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes
ACPICA: Update version to 20101209
The new GPE handler callback has 2 additional parameters, gpe_device and
gpe_number.
typedef
u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context);
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
of_address.h and of_irq.h are implicitly included on powerpc. Adding
them fixes builds on non-powerpc platforms.
Fixes for sdhci-of and ipmi drivers.
Auditing all drivers using of_get_property did not find other
occurrences likely to be used on LE platforms.
The IPMI smi_watcher will be used to catch the IPMI interface as they
come or go. In order to communicate with the correct IPMI device, it
should be confirmed whether it is what we wanted especially on the
system with multiple IPMI devices. But the new_smi callback function
of smi_watcher provides very limited info(only the interface number
and dev pointer) and there is no detailed info about the low level
interface. For example: which mechansim registers the IPMI
interface(ACPI, PCI, DMI and so on).
This is to add one interface that can get more info of low-level IPMI
device. For example: the ACPI device handle will be returned for the
pnp_acpi IPMI device.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
__init and __exit belong after the return type on functions, not
before.
Unloading ipmi module can trigger following error. (if
CONFIG_DEBUG_SPINLOCK=y)
[ 9633.779590] BUG: spinlock bad magic on CPU#1, rmmod/7170
[ 9633.779606] lock: f41f5414, .magic: 00000000, .owner:
<none>/-1, .owner_cpu: 0
[ 9633.779626] Pid: 7170, comm: rmmod Not tainted
2.6.36-rc7-11474-gb71eb1e-dirty #328
[ 9633.779644] Call Trace:
[ 9633.779657] [<c13921cc>] ? printk+0x18/0x1c
[ 9633.779672] [<c11a1f33>] spin_bug+0xa3/0xf0
[ 9633.779685] [<c11a1ffd>] do_raw_spin_lock+0x7d/0x160
[ 9633.779702] [<c1131537>] ? release_sysfs_dirent+0x47/0xb0
[ 9633.779718] [<c1131b78>] ? sysfs_addrm_finish+0xa8/0xd0
[ 9633.779734] [<c1394bac>] _raw_spin_lock_irqsave+0xc/0x20
[ 9633.779752] [<f99d93da>] cleanup_one_si+0x6a/0x200 [ipmi_si]
[ 9633.779768] [<c11305b2>] ? sysfs_hash_and_remove+0x72/0x80
[ 9633.779786] [<f99dcf26>] ipmi_pnp_remove+0xd/0xf [ipmi_si]
[ 9633.779802] [<c11f622b>] pnp_device_remove+0x1b/0x40
Fix this by initializing spinlocks in a smi_info_alloc() helper function,
right after memory allocation and clearing.
Acked-by: David Miller <davem@davemloft.net>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: <stable@kernel.org>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
When modprobe.conf has
options ipmi_si type="kcs" ports=0xCA2 regspacings="4"
ipmi_si can be loaded properly, but when try to unload it get:
Sep 20 15:00:27 xx abrt: Kerneloops: Reported 1 kernel oopses to Abrt
Sep 20 15:00:27 xx abrtd: Directory 'kerneloops-1285020027-1' creation detected
Sep 20 15:00:27 xx abrtd: New crash /var/spool/abrt/kerneloops-1285020027-1, processing
Sep 20 15:01:09 xx kernel: ------------[ cut here ]------------
Sep 20 15:01:09 xx kernel: WARNING: at drivers/base/driver.c:262 driver_unregister+0x8a/0xa0()
Sep 20 15:01:09 xx kernel: Hardware name: Sun Fire x4800
Sep 20 15:01:09 xx kernel: Unexpected driver unregister!
Sep 20 15:01:09 xx kernel: Modules linked in: ipmi_si(-) ipmi_msghandler ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf xt_physdev be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb3i iw_cxgb3 cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun kvm_intel kvm uinput sg ses enclosure ahci libahci pcspkr i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support igb dca i7core_edac edac_core ext3 jbd mbcache sd_mod crc_t10dif megaraid_sas [last unloaded: ipmi_devintf]
Sep 20 15:01:09 xx kernel: Pid: 10625, comm: modprobe Tainted: G W 2.6.36-rc5-tip+ #6
Sep 20 15:01:09 xx kernel: Call Trace:
Sep 20 15:01:09 xx kernel: [<ffffffff810600df>] warn_slowpath_common+0x7f/0xc0
Sep 20 15:01:09 xx kernel: [<ffffffff810601d6>] warn_slowpath_fmt+0x46/0x50
Sep 20 15:01:09 xx kernel: [<ffffffff812ff60a>] driver_unregister+0x8a/0xa0
Sep 20 15:01:09 xx kernel: [<ffffffff812ae112>] pnp_unregister_driver+0x12/0x20
Sep 20 15:01:09 xx kernel: [<ffffffffa01d0327>] cleanup_ipmi_si+0x3c/0xa7 [ipmi_si]
Sep 20 15:01:09 xx kernel: [<ffffffff81099a60>] sys_delete_module+0x1a0/0x270
Sep 20 15:01:09 xx kernel: [<ffffffff814b7070>] ? do_page_fault+0x150/0x320
Sep 20 15:01:09 xx kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b
Sep 20 15:01:09 xx kernel: ---[ end trace 0d1967161adcee0d ]---
We need to check if ipmi_pnp_driver is loaded before we try to unload it.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Corey Minyard <minyard@acm.org>
After d9e1b6c45059ccf ("ipmi: fix ACPI detection with regspacing") we get
[ 11.026326] ipmi_si: probing via ACPI
[ 11.030019] ipmi_si 00:09: (null) regsize 1 spacing 1 irq 0
[ 11.035594] ipmi_si: Adding ACPI-specified kcs state machine
on an old system with only one range for ipmi kcs range.
Try to fix it by adding another res pointer.
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
Print out the reg spacing and size for spmi and smbios so BIOS developers
can make them consistent.
Also remove extra PFX on the duplicating path.
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Myron Stowe <myron.stowe@hp.com>
Free the temporary info struct when we have duplicated ones.
not used
Fix a warning message generated by GCC, and also updates a web address
pointing to a pdf containing information.
CC [M] drivers/char/ipmi/ipmi_si_intf.o
drivers/char/ipmi/ipmi_si_intf.c: In function 'try_init_spmi':
drivers/char/ipmi/ipmi_si_intf.c:2016:8: warning: variable 'addr_space' set but not used
Signed-off-by: Sergey V. <sftp.mtuci@gmail.com>
Acked-by: Corey Minyard <minyard@acm.org>
After the commit that changed ipmi_si detecting sequence from SMBIOS/ACPI
to ACPI/SMBIOS,
| commit 754d453185275951d39792865927ec494fa1ebd8
| Author: Matthew Garrett <mjg@redhat.com>
| Date: Wed May 26 14:43:47 2010 -0700
| ipmi: change device discovery order
| The ipmi spec provides an ordering for si discovery. Change the driver to
| match, with the exception of preferring smbios to SPMI as HPs (at least)
| contain accurate information in the former but not the latter.
ipmi_si can not be initialized.
[ 138.799739] calling init_ipmi_devintf+0x0/0x109 @ 1
[ 138.805050] ipmi device interface
[ 138.818131] initcall init_ipmi_devintf+0x0/0x109 returned 0 after 12797 usecs
[ 138.822998] calling init_ipmi_si+0x0/0xa90 @ 1
[ 138.840276] IPMI System Interface driver.
[ 138.846137] ipmi_si: probing via ACPI
[ 138.849225] ipmi_si 00:09: [io 0x0ca2] regsize 1 spacing 1 irq 0
[ 138.864438] ipmi_si: Adding ACPI-specified kcs state machine
[ 138.870893] ipmi_si: probing via SMBIOS
[ 138.880945] ipmi_si: Adding SMBIOS-specified kcs state machineipmi_si: duplicate interface
[ 138.896511] ipmi_si: probing via SPMI
[ 138.899861] ipmi_si: Adding SPMI-specified kcs state machineipmi_si: duplicate interface
[ 138.917095] ipmi_si: Trying ACPI-specified kcs state machine at i/o address 0xca2, slave address 0x0, irq 0
[ 138.928658] ipmi_si: Interface detection failed
[ 138.953411] initcall init_ipmi_si+0x0/0xa90 returned 0 after 110847 usecs
in smbios has
DMI/SMBIOS
Handle 0x00C5, DMI type 38, 18 bytes
IPMI Device Information
Interface Type: KCS (Keyboard Control Style)
Specification Version: 2.0
I2C Slave Address: 0x00
NV Storage Device: Not Present
Base Address: 0x0000000000000CA2 (I/O)
Register Spacing: 32-bit Boundaries
in DSDT has
Device (BMC)
Name (_HID, EisaId ("IPI0001"))
Method (_STA, 0, NotSerialized)
If (LEqual (OSN, Zero))
Return (Zero)
Return (0x0F)
Name (_STR, Unicode ("IPMI_KCS"))
Name (_UID, Zero)
Name (_CRS, ResourceTemplate ()
IO (Decode16,
0x0CA2, // Range Minimum
0x0CA2, // Range Maximum
0x00, // Alignment
0x01, // Length
IO (Decode16,
0x0CA6, // Range Minimum
0x0CA6, // Range Maximum
0x00, // Alignment
0x01, // Length
Method (_IFT, 0, NotSerialized)
Return (One)
Method (_SRV, 0, NotSerialized)
Return (0x0200)
so the reg spacing should be 4 instead of 1.
Try to calculate regspacing for this kind of system.
Observed on a Sun Fire X4800. Other OSes work and pass certification.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
