path: root/drivers/char/ipmi
2012-03-28Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge third batch of patches from Andrew Morton: - Some MM stragglers - core SMP library cleanups (on_each_cpu_mask) - Some IPI optimisations - kexec - kdump - IPMI - the radix-tree iterator work - various other misc bits. "That'll do for -rc1. I still have ~10 patches for 3.4, will send those along when they've baked a little more." * emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits) backlight: fix typo in tosa_lcd.c crc32: add help text for the algorithm select option mm: move hugepage test examples to tools/testing/selftests/vm mm: move slabinfo.c to tools/vm mm: move page-types.c from Documentation to tools/vm selftests/Makefile: make `run_tests' depend on `all' selftests: launch individual selftests from the main Makefile radix-tree: use iterators in find_get_pages* functions radix-tree: rewrite gang lookup using iterator radix-tree: introduce bit-optimized iterator fs/proc/namespaces.c: prevent crash when ns_entries[] is empty nbd: rename the nbd_device variable from lo to nbd pidns: add reboot_pid_ns() to handle the reboot syscall sysctl: use bitmap library functions ipmi: use locks on watchdog timeout set on reboot ipmi: simplify locking ipmi: fix message handling during panics ipmi: use a tasklet for handling received messages ipmi: increase KCS timeouts ipmi: decrease the IPMI message transaction time in interrupt mode ...
2012-03-28ipmi: use locks on watchdog timeout set on rebootCorey Minyard
The IPMI watchdog timer clears or extends the timer on reboot/shutdown. It was using the non-locking routine for setting the watchdog timer, but this was causing race conditions. Instead, use the locking version to avoid the races. It seems to work fine. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: simplify lockingCorey Minyard
Now that the the IPMI driver is using a tasklet, we can simplify the locking in the driver and get rid of the message lock. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: fix message handling during panicsCorey Minyard
The part of the IPMI driver that delivered panic information to the event log and extended the watchdog timeout during a panic was not properly handling the messages. It used static messages to avoid allocation, but wasn't properly waiting for these, or wasn't properly handling the refcounts. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: use a tasklet for handling received messagesCorey Minyard
The IPMI driver would release a lock, deliver a message, then relock. This is obviously ugly, and this patch converts the message handler interface to use a tasklet to schedule work. This lets the receive handler be called from an interrupt handler with interrupts enabled. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: increase KCS timeoutsMatthew Garrett
We currently time out and retry KCS transactions after 1 second of waiting for IBF or OBF. This appears to be too short for some hardware. The IPMI spec says "All system software wait loops should include error timeouts. For simplicity, such timeouts are not shown explicitly in the flow diagrams. A five-second timeout or greater is recommended". Change the timeout to five seconds to satisfy the slow hardware. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: decrease the IPMI message transaction time in interrupt modeSrinivas_Gowda
Call the event handler immediately after starting the next message. This change considerably decreases the IPMI transaction time (cuts off ~9ms for a single ipmitool transaction). Signed-off-by: Srinivas_Gowda <srinivas_g_gowda@dell.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-20ipmi_watchdog: restore settings when BMC resetCorey Minyard
If the BMC gets reset, it will return 0x80 response errors. In less than a week # grep "Error 80 on cmd 22" /var/log/kernel |wc -l 378681 In this case, it is probably a good idea to restore the IPMI settings. Signed-off-by: Corey Minyard <cminyard@mvista.com> Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-10x86, nmi: Wire up NMI handlers to new routinesDon Zickus
Just convert all the files that have an nmi handler to the new routines. Most of it is straight forward conversion. A couple of places needed some tweaking like kgdb which separates the debug notifier from the nmi handler and mce removes a call to notify_die. [Thanks to Ying for finding out the history behind that mce call https://lkml.org/lkml/2010/5/27/114 And Boris responding that he would like to remove that call because of it https://lkml.org/lkml/2011/9/21/163] The things that get converted are the registeration/unregistration routines and the nmi handler itself has its args changed along with code removal to check which list it is on (most are on one NMI list except for kgdb which has both an NMI routine and an NMI Unknown routine). Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Corey Minyard <minyard@acm.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Corey Minyard <minyard@acm.org> Cc: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/1317409584-23662-4-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26ipmi: convert to seq_file interfaceAlexey Dobriyan
The ->read_proc interface is going away, convert to seq_file. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc:Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23drivers/char/ipmi/ipmi_si_intf.c: fix cleanup_one_si section mismatchSergey Senozhatsky
commit d2478521afc2022 ("char/ipmi: fix OOPS caused by pnp_unregister_driver on unregistered driver") introduced a section mismatch by calling __exit cleanup_ipmi_si from __devinit init_ipmi_si. Remove __exit annotation from cleanup_ipmi_si. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-10ipmi: Fix IPMI errors due to timing problemsDoe, YiCheng
This patch fixes an issue in OpenIPMI module where sometimes an ABORT command is sent after sending an IPMI request to BMC causing the IPMI request to fail. Signed-off-by: YiCheng Doe <yicheng.doe@hp.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Acked-by: Tom Mingarelli <thomas.mingarelli@hp.com> Tested-by: Andy Cress <andy.cress@us.kontron.com> Tested-by: Mika Lansirine <Mika.Lansirinne@stonesoft.com> Tested-by: Brian De Wolf <bldewolf@csupomona.edu> Cc: Jean Michel Audet <Jean-Michel.Audet@ca.Kontron.com> Cc: Jozef Sudelsky <jozef.sudolsky@elbiahosting.sk> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28ipmi: convert OF driver to platform driverRob Herring
of_bus is deprecated in favor of the plain platform bus. This patch merges the ipmi OF driver with the existing platform driver. CONFIG_PPC_OF occurrances are removed or replaced with CONFIG_OF. Compile tested with and without CONFIG_OF. Tested OF probe and default probe cases. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-10char/ipmi: fix OOPS caused by pnp_unregister_driver on unregistered driverCorey Minyard
This patch fixes an OOPS triggered when calling modprobe ipmi_si a second time after the first modprobe returned without finding any ipmi devices. This can happen if you reload the module after having the first module load fail. The driver was not deregistering from PNP in that case. Peter Huewe originally reported this patch and supplied a fix, I have a different patch based on Linus' suggestion that cleans things up a bit more. Cc: stable@kernel.org Cc: openipmi-developer@lists.sourceforge.net Reviewed-by: Peter Huewe <peterhuewe@gmx.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-12Merge branch 'ipmi' into releaseLen Brown
2011-01-12ACPICA: New GPE handler callback definitionLin Ming
The new GPE handler callback has 2 additional parameters, gpe_device and gpe_number. typedef u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context); Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-07x86: Convert some devices to use DIE_NMIUNKNOWNDon Zickus
They are a handful of places in the code that register a die_notifier as a catch all in case no claims the NMI. Unfortunately, they trigger on events like DIE_NMI and DIE_NMI_IPI, which depending on when they registered may collide with other handlers that have the ability to determine if the NMI is theirs or not. The function unknown_nmi_error() makes one last effort to walk the die_chain when no one else has claimed the NMI before spitting out messages that the NMI is unknown. This is a better spot for these devices to execute any code without colliding with the other handlers. The two drivers modified are only compiled on x86 arches I believe, so they shouldn't be affected by other arches that may not have DIE_NMIUNKNOWN defined. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Russ Anderson <rja@sgi.com> Cc: Corey Minyard <minyard@acm.org> Cc: openipmi-developer@lists.sourceforge.net Cc: dann frazier <dannf@hp.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294348732-15030-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04ipmi: explicitly include of_address.h and of_irq.hRob Herring
of_address.h and of_irq.h are implicitly included on powerpc. Adding them fixes builds on non-powerpc platforms. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-03of: Fixes for OF probing on little endian systemsRob Herring
Fixes for sdhci-of and ipmi drivers. Auditing all drivers using of_get_property did not find other occurrences likely to be used on LE platforms. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-14IPMI: Add one interface to get more info of low-level IPMI deviceZhao Yakui
The IPMI smi_watcher will be used to catch the IPMI interface as they come or go. In order to communicate with the correct IPMI device, it should be confirmed whether it is what we wanted especially on the system with multiple IPMI devices. But the new_smi callback function of smi_watcher provides very limited info(only the interface number and dev pointer) and there is no detailed info about the low level interface. For example: which mechansim registers the IPMI interface(ACPI, PCI, DMI and so on). This is to add one interface that can get more info of low-level IPMI device. For example: the ACPI device handle will be returned for the pnp_acpi IPMI device. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-27drivers/char/ipmi/Makefile: replace the use of <module>-objs with <module>-yTracey Dent
Changed <module>-objs to <module>-y in Makefile. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ipmi: fix __init and __exit attribute locationsCorey Minyard
__init and __exit belong after the return type on functions, not before. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26ipmi: proper spinlock initializationEric Dumazet
Unloading ipmi module can trigger following error. (if CONFIG_DEBUG_SPINLOCK=y) [ 9633.779590] BUG: spinlock bad magic on CPU#1, rmmod/7170 [ 9633.779606] lock: f41f5414, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 [ 9633.779626] Pid: 7170, comm: rmmod Not tainted 2.6.36-rc7-11474-gb71eb1e-dirty #328 [ 9633.779644] Call Trace: [ 9633.779657] [<c13921cc>] ? printk+0x18/0x1c [ 9633.779672] [<c11a1f33>] spin_bug+0xa3/0xf0 [ 9633.779685] [<c11a1ffd>] do_raw_spin_lock+0x7d/0x160 [ 9633.779702] [<c1131537>] ? release_sysfs_dirent+0x47/0xb0 [ 9633.779718] [<c1131b78>] ? sysfs_addrm_finish+0xa8/0xd0 [ 9633.779734] [<c1394bac>] _raw_spin_lock_irqsave+0xc/0x20 [ 9633.779752] [<f99d93da>] cleanup_one_si+0x6a/0x200 [ipmi_si] [ 9633.779768] [<c11305b2>] ? sysfs_hash_and_remove+0x72/0x80 [ 9633.779786] [<f99dcf26>] ipmi_pnp_remove+0xd/0xf [ipmi_si] [ 9633.779802] [<c11f622b>] pnp_device_remove+0x1b/0x40 Fix this by initializing spinlocks in a smi_info_alloc() helper function, right after memory allocation and clearing. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Corey Minyard <cminyard@mvista.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: block: autoconvert trivial BKL users to private mutex drivers: autoconvert trivial BKL users to private mutex ipmi: autoconvert trivial BKL users to private mutex mac: autoconvert trivial BKL users to private mutex mtd: autoconvert trivial BKL users to private mutex scsi: autoconvert trivial BKL users to private mutex Fix up trivial conflicts (due to addition of private mutex right next to deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-22ipmi: fix hardcoded ipmi device exit path warningYinghai Lu
When modprobe.conf has options ipmi_si type="kcs" ports=0xCA2 regspacings="4" ipmi_si can be loaded properly, but when try to unload it get: Sep 20 15:00:27 xx abrt: Kerneloops: Reported 1 kernel oopses to Abrt Sep 20 15:00:27 xx abrtd: Directory 'kerneloops-1285020027-1' creation detected Sep 20 15:00:27 xx abrtd: New crash /var/spool/abrt/kerneloops-1285020027-1, processing Sep 20 15:01:09 xx kernel: ------------[ cut here ]------------ Sep 20 15:01:09 xx kernel: WARNING: at drivers/base/driver.c:262 driver_unregister+0x8a/0xa0() Sep 20 15:01:09 xx kernel: Hardware name: Sun Fire x4800 Sep 20 15:01:09 xx kernel: Unexpected driver unregister! Sep 20 15:01:09 xx kernel: Modules linked in: ipmi_si(-) ipmi_msghandler ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf xt_physdev be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb3i iw_cxgb3 cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun kvm_intel kvm uinput sg ses enclosure ahci libahci pcspkr i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support igb dca i7core_edac edac_core ext3 jbd mbcache sd_mod crc_t10dif megaraid_sas [last unloaded: ipmi_devintf] Sep 20 15:01:09 xx kernel: Pid: 10625, comm: modprobe Tainted: G W 2.6.36-rc5-tip+ #6 Sep 20 15:01:09 xx kernel: Call Trace: Sep 20 15:01:09 xx kernel: [<ffffffff810600df>] warn_slowpath_common+0x7f/0xc0 Sep 20 15:01:09 xx kernel: [<ffffffff810601d6>] warn_slowpath_fmt+0x46/0x50 Sep 20 15:01:09 xx kernel: [<ffffffff812ff60a>] driver_unregister+0x8a/0xa0 Sep 20 15:01:09 xx kernel: [<ffffffff812ae112>] pnp_unregister_driver+0x12/0x20 Sep 20 15:01:09 xx kernel: [<ffffffffa01d0327>] cleanup_ipmi_si+0x3c/0xa7 [ipmi_si] Sep 20 15:01:09 xx kernel: [<ffffffff81099a60>] sys_delete_module+0x1a0/0x270 Sep 20 15:01:09 xx kernel: [<ffffffff814b7070>] ? do_page_fault+0x150/0x320 Sep 20 15:01:09 xx kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b Sep 20 15:01:09 xx kernel: ---[ end trace 0d1967161adcee0d ]--- We need to check if ipmi_pnp_driver is loaded before we try to unload it. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22ipmi: fix acpi probe printYinghai Lu
After d9e1b6c45059ccf ("ipmi: fix ACPI detection with regspacing") we get [ 11.026326] ipmi_si: probing via ACPI [ 11.030019] ipmi_si 00:09: (null) regsize 1 spacing 1 irq 0 [ 11.035594] ipmi_si: Adding ACPI-specified kcs state machine on an old system with only one range for ipmi kcs range. Try to fix it by adding another res pointer. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-15ipmi: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Corey Minyard <cminyard@mvista.com> Cc: openipmi-developer@lists.sourceforge.net
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-11ipmi: print info for spmi and smbios paths like acpi and pciYinghai Lu
Print out the reg spacing and size for spmi and smbios so BIOS developers can make them consistent. Also remove extra PFX on the duplicating path. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Corey Minyard <minyard@acm.org> Cc: Matthew Garrett <mjg@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Myron Stowe <myron.stowe@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11ipmi: fix memleaking for add_smi when duplicating happenYinghai Lu
Free the temporary info struct when we have duplicated ones. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Corey Minyard <minyard@acm.org> Cc: Matthew Garrett <mjg@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Myron Stowe <myron.stowe@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/char/ipmi/ipmi_si_intf.c: fix warning: variable 'addr_space' set but ↵Justin P. Mattock
not used Fix a warning message generated by GCC, and also updates a web address pointing to a pdf containing information. CC [M] drivers/char/ipmi/ipmi_si_intf.o drivers/char/ipmi/ipmi_si_intf.c: In function 'try_init_spmi': drivers/char/ipmi/ipmi_si_intf.c:2016:8: warning: variable 'addr_space' set but not used Signed-off-by: Sergey V. <sftp.mtuci@gmail.com> Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11param: update drivers/char/ipmi/ipmi_watchdog.c to new schemeRusty Russell
This is one of the most interesting users of module parameters in the tree, so weaning it off the old-style non-const module_param_call scheme is a useful exercise. I was confused by set_param_int/get_param_int (vs. the normal param_set_int and param_get_int), so I renamed set_param_int to set_param_timeout, and re-used param_get_int directly instead of get_param_int. I also implemented param_check_wdog_ifnum and param_check_timeout, so now the ifnum_to_use and timeout/pretimeout parameters can just use plain module_param(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Corey Minyard <minyard@acm.org> Cc: openipmi-developer@lists.sourceforge.net
2010-08-09ipmi: fix ACPI detection with regspacingYinghai Lu
After the commit that changed ipmi_si detecting sequence from SMBIOS/ACPI to ACPI/SMBIOS, | commit 754d453185275951d39792865927ec494fa1ebd8 | Author: Matthew Garrett <mjg@redhat.com> | Date: Wed May 26 14:43:47 2010 -0700 | | ipmi: change device discovery order | | The ipmi spec provides an ordering for si discovery. Change the driver to | match, with the exception of preferring smbios to SPMI as HPs (at least) | contain accurate information in the former but not the latter. ipmi_si can not be initialized. [ 138.799739] calling init_ipmi_devintf+0x0/0x109 @ 1 [ 138.805050] ipmi device interface [ 138.818131] initcall init_ipmi_devintf+0x0/0x109 returned 0 after 12797 usecs [ 138.822998] calling init_ipmi_si+0x0/0xa90 @ 1 [ 138.840276] IPMI System Interface driver. [ 138.846137] ipmi_si: probing via ACPI [ 138.849225] ipmi_si 00:09: [io 0x0ca2] regsize 1 spacing 1 irq 0 [ 138.864438] ipmi_si: Adding ACPI-specified kcs state machine [ 138.870893] ipmi_si: probing via SMBIOS [ 138.880945] ipmi_si: Adding SMBIOS-specified kcs state machineipmi_si: duplicate interface [ 138.896511] ipmi_si: probing via SPMI [ 138.899861] ipmi_si: Adding SPMI-specified kcs state machineipmi_si: duplicate interface [ 138.917095] ipmi_si: Trying ACPI-specified kcs state machine at i/o address 0xca2, slave address 0x0, irq 0 [ 138.928658] ipmi_si: Interface detection failed [ 138.953411] initcall init_ipmi_si+0x0/0xa90 returned 0 after 110847 usecs in smbios has DMI/SMBIOS Handle 0x00C5, DMI type 38, 18 bytes IPMI Device Information Interface Type: KCS (Keyboard Control Style) Specification Version: 2.0 I2C Slave Address: 0x00 NV Storage Device: Not Present Base Address: 0x0000000000000CA2 (I/O) Register Spacing: 32-bit Boundaries in DSDT has Device (BMC) { Name (_HID, EisaId ("IPI0001")) Method (_STA, 0, NotSerialized) { If (LEqual (OSN, Zero)) { Return (Zero) } Return (0x0F) } Name (_STR, Unicode ("IPMI_KCS")) Name (_UID, Zero) Name (_CRS, ResourceTemplate () { IO (Decode16, 0x0CA2, // Range Minimum 0x0CA2, // Range Maximum 0x00, // Alignment 0x01, // Length ) IO (Decode16, 0x0CA6, // Range Minimum 0x0CA6, // Range Maximum 0x00, // Alignment 0x01, // Length ) }) Method (_IFT, 0, NotSerialized) { Return (One) } Method (_SRV, 0, NotSerialized) { Return (0x0200) } } so the reg spacing should be 4 instead of 1. Try to calculate regspacing for this kind of system. Observed on a Sun Fire X4800. Other OSes work and pass certification. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Matthew Garrett <mjg@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Myron Stowe <myron.stowe@hp.com> Cc: Corey Minyard <minyard@acm.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
