path: root/drivers/char/nsc_gpio.c
2006-12-08[PATCH] struct path: convert char-driversJosef Sipek
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-07-14[PATCH] gpio: cosmetics: remove needless newlinesJim Cromie
- pure cosmetics: lose needless newlines. - rename EXPORTed gpio vtables from {scx200,pc8736x}_access to _gpio_ops new name is much closer to the vtable-name struct nsc_gpio_ops, should be clearer. Also rename the _fops vtable var to _fileops to better disambiguate it from the gpio vtable. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: display pin values in/out in ↵Jim Cromie
gpio_dump Add current pin settings to gpio_dump() output. This adds the last 'word' to the syslog lines, which displays the input and output values that the pin is set to. pc8736x_gpio.0: io00: 0x0044 TS OD PUE EDGE LO DEBOUNCE io:1/1 The 2 values may differ for a number of reasons: 1- the pin output circuitry is diaabled, (as the above 'TS' indicates) 2- it needs a pullup resistor to drive the attached circuit, 3- the external circuit needs a pullup so the open-drain has something to pull-down 4- the pin is wired to Vcc or Ground It might be appropriate to add a WARN for 2,3,4, since they could damage the chip and/or circuit, esp if misconfig goes unnoticed. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: use dev_dbg in common moduleJim Cromie
Use of dev_dbg() and friends is considered good practice. dev_dbg() needs a struct device *devp, but nsc_gpio is only a helper module, so it doesnt have/need its own. To provide devp to the user-modules (scx200 & pc8736x _gpio), we add it to the vtable, and set it during init. Also squeeze nsc_gpio_dump()'s format a little. [ 199.259879] pc8736x_gpio.0: io09: 0x0044 TS OD PUE EDGE LO DEBOUNCE Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: add new pc8736x_gpio moduleJim Cromie
Add the brand new pc8736x_gpio driver. This is mostly based upon scx200_gpio.c, but the platform_dev is treated separately, since its fairly big too. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: migrate gpio_dump to common moduleJim Cromie
Since the meaning of config-bits is the same for scx200 and pc8736x _gpios, we can share a function to deliver this to user. Since it is called via the vtable, its also completely replaceable. For now, we keep using printk... Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: migrate file-ops to common moduleJim Cromie
Now that the read(), write() file-ops are dispatching gpio-ops via the vtable, they are generic, and can be moved 'verbatim' to the nsc_gpio common-support module. After the move, various symbols are renamed to update 'scx200_' to 'nsc_', and headers are adjusted accordingly. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: add empty common-moduleJim Cromie
Add the nsc_gpio common-support module as an empty shell. Next patch starts the migration of the common gpio support routines. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
