path: root/drivers/char/sysrq.c
2010-11-05TTY: create drivers/tty and move the tty core files thereGreg Kroah-Hartman
The tty code should be in its own subdirectory and not in the char driver with all of the cruft that is currently there. Based on work done by Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits) Input: wacom - specify Cinitq supported tools Input: ab8500-ponkey - fix IRQ freeing in error path Input: adp5588-keys - use more obvious i2c_device_id name string Input: ad7877 - switch to using threaded IRQ Input: ad7877 - use attribute group to control visibility of attributes Input: serio - add support for PS2Mult multiplexer protocol Input: wacom - properly enable runtime PM Input: ad7877 - filter events where pressure is beyond the maximum Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting Input: ad7877 - implement specified chip select behavior Input: hp680_ts_input - use cancel_delayed_work_sync() Input: mousedev - correct lockdep annotation Input: ads7846 - switch to using threaded IRQ Input: serio - support multiple child devices per single parent Input: synaptics - simplify pass-through port handling Input: add ROHM BU21013 touch panel controller support Input: omap4-keypad - wake-up on events & long presses Input: omap4-keypad - fix interrupt line configuration Input: omap4-keypad - SYSCONFIG register configuration Input: omap4-keypad - use platform device helpers ...
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-29Input: sysrq - add locking to sysrq_filter()Dmitry Torokhov
Similarly to the keyboard handler, we are called by different input devices and thus need to add spinlock if we want to maintain our state properly. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-21Input: sysrq - drop tty argument form handle_sysrq()Dmitry Torokhov
Sysrq operations do not accept tty argument anymore so no need to pass it to us. [Stephen Rothwell <sfr@canb.auug.org.au>: fix build breakage in drm code caused by sysrq using bool but not including linux/types.h] [Sachin Sant <sachinp@in.ibm.com>: fix build breakage in s390 keyboadr driver] Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-19Input: sysrq - drop tty argument from sysrq ops handlersDmitry Torokhov
Noone is using tty argument so let's get rid of it. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-21sysrq,kdb: Use __handle_sysrq() for kdb's sysrq functionJason Wessel
The kdb code should not toggle the sysrq state in case an end user wants to try and resume the normal kernel execution. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2010-06-09Input: sysrq - fix "stuck" SysRq modeDmitry Torokhov
This shoud fix the problem with SysRq mode staying half-way enabled and interfereing with normal PrtScrn operation after user presses ALT for the first time. Reported-and-tested-by: Éric Piel <E.A.B.Piel@tudelft.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: psmouse - small formatting changes to better follow coding style Input: synaptics - set dimensions as reported by firmware Input: elantech - relax signature checks Input: elantech - enforce common prefix on messages Input: wistron_btns - switch to using kmemdup() Input: usbtouchscreen - switch to using kmemdup() Input: do not force selecting i8042 on Moorestown Input: Documentation/sysrq.txt - update KEY_SYSRQ info Input: 88pm860x_onkey - remove invalid irq number assignment Input: i8042 - add a PNP entry to the aux device list Input: i8042 - add some extra PNP keyboard types Input: wm9712 - fix wm97xx_set_gpio() logic Input: add keypad driver for keys interfaced to TCA6416 Input: remove obsolete {corgi,spitz,tosa}kbd.c Input: kbtab - do not advertise unsupported events Input: kbtab - simplify kbtab_disconnect() Input: kbtab - fix incorrect size parameter in usb_buffer_free Input: acecad - don't advertise mouse events Input: acecad - fix some formatting issues Input: acecad - simplify usb_acecad_disconnect() ... Trivial conflict in Documentation/feature-removal-schedule.txt
2010-04-21tracing: Dump either the oops's cpu source or all cpus buffersFrederic Weisbecker
The ftrace_dump_on_oops kernel parameter, sysctl and sysrq let one dump every cpu buffers when an oops or panic happens. It's nice when you have few cpus but it may take ages if have many, plus you miss the real origin of the problem in all the cpu traces. Sometimes, all you need is to dump the cpu buffer that triggered the opps, most of the time it is our main interest. This patch modifies ftrace_dump_on_oops to handle this choice. The ftrace_dump_on_oops kernel parameter, when it comes alone, has the same behaviour than before. But ftrace_dump_on_oops=orig_cpu will only dump the buffer of the cpu that oops'ed. Similarly, sysctl kernel.ftrace_dump_on_oops=1 and echo 1 > /proc/sys/kernel/ftrace_dump_on_oops keep their previous behaviour. But setting 2 jumps into cpu origin dump mode. v2: Fix double setup v3: Fix spelling issues reported by Randy Dunlap v4: Also update __ftrace_dump in the selftests Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-04-13Input: implement SysRq as a separate input handlerDmitry Torokhov
Instead of keeping SysRq support inside of legacy keyboard driver split it out into a separate input handler (filter). This stops most SysRq input events from leaking into evdev clients (some events, such as first SysRq scancode - not keycode - event, are still leaked into both legacy keyboard and evdev). [martinez.javier@gmail.com: fix compile error when CONFIG_MAGIC_SYSRQ is not defined] Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16oom-kill: fix NUMA constraint check with nodemaskKAMEZAWA Hiroyuki
Fix node-oriented allocation handling in oom-kill.c I myself think of this as a bugfix not as an ehnancement. In these days, things are changed as - alloc_pages() eats nodemask as its arguments, __alloc_pages_nodemask(). - mempolicy don't maintain its own private zonelists. (And cpuset doesn't use nodemask for __alloc_pages_nodemask()) So, current oom-killer's check function is wrong. This patch does - check nodemask, if nodemask && nodemask doesn't cover all node_states[N_HIGH_MEMORY], this is CONSTRAINT_MEMORY_POLICY. - Scan all zonelist under nodemask, if it hits cpuset's wall this faiulre is from cpuset. And - modifies the caller of out_of_memory not to call oom if __GFP_THISNODE. This doesn't change "current" behavior. If callers use __GFP_THISNODE it should handle "page allocation failure" by itself. - handle __GFP_NOFAIL+__GFP_THISNODE path. This is something like a FIXME but this gfpmask is not used now. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-03debug lockups: Improve lockup detection, fix generic arch fallbackIngo Molnar
As Andrew noted, my previous patch ("debug lockups: Improve lockup detection") broke/removed SysRq-L support from architecture that do not provide a __trigger_all_cpu_backtrace implementation. Restore a fallback path and clean up the SysRq-L machinery a bit: - Rename the arch method to arch_trigger_all_cpu_backtrace() - Simplify the define - Document the method a bit - in the hope of more architectures adding support for it. [ The patch touches Sparc code for the rename. ] Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: "David S. Miller" <davem@davemloft.net> LKML-Reference: <20090802140809.7ec4bb6b.akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02debug lockups: Improve lockup detectionIngo Molnar
When debugging a recent lockup bug i found various deficiencies in how our current lockup detection helpers work: - SysRq-L is not very efficient as it uses a workqueue, hence it cannot punch through hard lockups and cannot see through most soft lockups either. - The SysRq-L code depends on the NMI watchdog - which is off by default. - We dont print backtraces from the RCU code's built-in 'RCU state machine is stuck' debug code. This debug code tends to be one of the first (and only) mechanisms that show that a lockup has occured. This patch changes the code so taht we: - Trigger the NMI backtrace code from SysRq-L instead of using a workqueue (which cannot punch through hard lockups) - Trigger print-all-CPU-backtraces from the RCU lockup detection code Also decouple the backtrace printing code from the NMI watchdog: - Dont use variable size cpumasks (it might not be initialized and they are a bit more fragile anyway) - Trigger an NMI immediately via an IPI, instead of waiting for the NMI tick to occur. This is a lot faster and can produce more relevant backtraces. It will also work if the NMI watchdog is disabled. - Dont print the 'dazed and confused' message when we print a backtrace from the NMI - Do a show_regs() plus a dump_stack() to get maximum info out of the dump. Worst-case we get two stacktraces - which is not a big deal. Sometimes, if register content is corrupted, the precise stack walker in show_regs() wont give us a full backtrace - in this case dump_stack() will do it. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-29sysrq, kdump: make sysrq-c consistentHidetoshi Seto
commit d6580a9f15238b87e618310c862231ae3f352d2d ("kexec: sysrq: simplify sysrq-c handler") changed the behavior of sysrq-c to unconditional dereference of NULL pointer. So in cases with CONFIG_KEXEC, where crash_kexec() was directly called from sysrq-c before, now it can be said that a step of "real oops" was inserted before starting kdump. However, in contrast to oops via SysRq-c from keyboard which results in panic due to in_interrupt(), oops via "echo c > /proc/sysrq-trigger" will not become panic unless panic_on_oops=1. It means that even if dump is properly configured to be taken on panic, the sysrq-c from proc interface might not start crashdump while the sysrq-c from keyboard can start crashdump. This confuses traditional users of kdump, i.e. people who expect sysrq-c to do common behavior in both of the keyboard and proc interface. This patch brings the keyboard and proc interface behavior of sysrq-c in line, by forcing panic_on_oops=1 before oops in sysrq-c handler. And some updates in documentation are included, to clarify that there is no longer dependency with CONFIG_KEXEC, and that now the system can just crash by sysrq-c if no dump mechanism is configured. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Brayan Arraes <brayan@yack.com.br> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18kexec: sysrq: simplify sysrq-c handlerNeil Horman
Currently the sysrq-c handler is bit over-engineered. Its behavior is dependent on a few compile time and run time factors that alter its behavior which is really unnecessecary. If CONFIG_KEXEC is not configured, sysrq-c, crashes the system with a NULL pointer dereference. If CONFIG_KEXEC is configured, it calls crash_kexec directly, which implies that the kexec kernel will either be booted (if its been previously loaded), or it will simply do nothing (the no kexec kernel has been loaded). It would be much easier to just simplify the whole thing to dereference a NULL pointer all the time regardless of configuration. That way, it will always try to crash the system, and if a kexec kernel has been loaded into reserved space, it will still boot from the page fault trap handler (assuming panic_on_oops is set appropriately). [akpm@linux-foundation.org: build fix] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Brayan Arraes <brayan@yack.com.br> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-18Merge commit 'v2.6.30-rc6' into perfcounters/coreIngo Molnar
Merge reason: this branch was on an -rc4 base, merge it up to -rc6 to get the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-15sysrq, intel_fb: fix sysrq g collisionJason Wessel
Commit 79e539453b34e35f39299a899d263b0a1f1670bd introduced a regression where you cannot use sysrq 'g' to enter kgdb. The solution is to move the intel fb sysrq over to V for video instead of G for graphics. The SMP VOYAGER code to register for the sysrq-v is not anywhere to be found in the mainline kernel, so the comments in the code were cleaned up as well. This patch also cleans up the sysrq definitions for kgdb to make it generic for the kernel debugger, such that the sysrq 'g' can be used in the future to enter a gdbstub or another kernel debugger. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13sysrq: remove duplicated #includeHuang Weiyi
Remove duplicated #include in drivers/char/sysrq.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] cio: online_store - trigger recognition for boxed devices [S390] cio: disallow online setting of device in transient state [S390] cio: introduce notifier for boxed state [S390] cio: introduce ccw_device_schedule_sch_unregister [S390] cio: wake up on failed recognition [S390] fix hypfs build failure [PATCH] sysrq: include interrupt.h instead of irq.h
2009-04-01filesystem freeze: allow SysRq emergency thaw to thaw frozen filesystemsEric Sandeen
Now that the filesystem freeze operation has been elevated to the VFS, and is just an ioctl away, some sort of safety net for unintentionally frozen root filesystems may be in order. The timeout thaw originally proposed did not get merged, but perhaps something like this would be useful in emergencies. For example, freeze /path/to/mountpoint may freeze your root filesystem if you forgot that you had that unmounted. I chose 'j' as the last remaining character other than 'h' which is sort of reserved for help (because help is generated on any unknown character). I've tested this on a non-root fs with multiple (nested) freezers, as well as on a system rendered unresponsive due to a frozen root fs. [randy.dunlap@oracle.com: emergency thaw only if CONFIG_BLOCK enabled] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31[PATCH] sysrq: include interrupt.h instead of irq.hHeiko Carstens
With "cpumask: update irq_desc to use cpumask_var_t" we get this build failure on s390: CC drivers/char/sysrq.o In file included from drivers/char/sysrq.c:38: include/linux/irq.h: In function 'init_alloc_desc_masks': include/linux/irq.h:442: error: dereferencing pointer to incomplete type drivers/char/sysrq.c should include interrupt.h instead of irq.h. Cc: Mike Travis <travis@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-21Merge commit 'v2.6.29-rc2' into perfcounters/coreIngo Molnar
Conflicts: include/linux/syscalls.h
2009-01-18Merge branch 'tracing/ftrace'; commit 'v2.6.29-rc2' into tracing/coreIngo Molnar
2009-01-15sysrq: add commentary on why we use the console loglevel over using KERN_EMERGAndy Whitcroft
Add an explanitory comment as to why we modify the kernel console loglevel rather than simply moving sysrq messages to KERN_EMERG level. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-11Merge commit 'v2.6.29-rc1' into tracing/urgentIngo Molnar
2009-01-11Merge commit 'v2.6.29-rc1' into perfcounters/coreIngo Molnar
Conflicts: include/linux/kernel_stat.h
2009-01-06sysrq: more explicit, less terse help messagesRandy Dunlap
Eliminate sysrq terse help mode; make sysrq help messages more meaningful (more explicit/verbose). Make the sysrq action letter clearer by listing it explicitly in more sysrq help messages (when it is not simple/clear). The SysRq help message now looks like this: SysRq : HELP : loglevel(0-9) reBoot terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) saK show-backtrace-all-active-cpus(L) show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W) Addresses http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=330403. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <jidanni@jidanni.org> Cc: <330403@bugs.debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: fs/exec.c include/linux/init_task.h Simple context conflicts.
2008-12-26sysrq: fix ftrace help msg & doc.Randy Dunlap
Impact: update documentation and help messages We have a conventional method of explicitly stating the sysrq action key in a sysrq help message, so change dump-ftrace-buffer to use that method and add it to Documentation/sysrq.txt. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-08performance counters: core codeThomas Gleixner
Implement the core kernel bits of Performance Counters subsystem. The Linux Performance Counter subsystem provides an abstraction of performance counter hardware capabilities. It provides per task and per CPU counters, and it provides event capabilities on top of those. Performance counters are accessed via special file descriptors. There's one file descriptor per virtual counter used. The special file descriptor is opened via the perf_counter_open() system call: int perf_counter_open(u32 hw_event_type, u32 hw_event_period, u32 record_type, pid_t pid, int cpu); The syscall returns the new fd. The fd can be used via the normal VFS system calls: read() can be used to read the counter, fcntl() can be used to set the blocking mode, etc. Multiple counters can be kept open at a time, and the counters can be poll()ed. See more details in Documentation/perf-counters.txt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04ftrace: sysrq-z to dump the buffersPeter Zijlstra
Impact: add SysRq-z support to dump trace buffers Allows one to force an ftrace dump from sysrq Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20fix documentation of sysrq-q reallyThomas Gleixner
SysRq-Q also dumps information about the clockevent devices. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-20Fix documentation of sysrq-qAndi Kleen
I fell into the trap recently that it only dumps hrtimers instead of all timers. Fix the documentation. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: torvalds@linux-foundation.org Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-16proc: move sysrq-trigger out of fs/proc/Alexey Dobriyan
Move it into sysrq.c, along with the rest of the sysrq implementation. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysrq: add enable_mask in sysrq_moom_opNaohiro Ooiwa
It is written in the Documentation/sysrq.txt that oom-killer is enabled when we set "64" in /proc/sys/kernel/sysrq: <Documentation/sysrq.txt> Here is the list of possible values in /proc/sys/kernel/sysrq: 64 - enable signalling of processes (term, kill, oom-kill) ^^^^^^^^ but enable_mask is not set in sysrq_moom_op. Signed-off-by: Naohiro Ooiwa <nooiwa@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-27fix: "smp_call_function: get rid of the unused nonatomic/retry argument"Ingo Molnar
drivers/char/sysrq.c: In function 'sysrq_showregs_othercpus': drivers/char/sysrq.c:218: error: too many arguments to function 'smp_call_function' Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-20sparc64: Add global register dumping facility.David S. Miller
When a cpu really is stuck in the kernel, it can be often impossible to figure out which cpu is stuck where. The worst case is when the stuck cpu has interrupts disabled. Therefore, implement a global cpu state capture that uses SMP message interrupts which are not disabled by the normal IRQ enable/disable APIs of the kernel. As long as we can get a sysrq 'y' to the kernel, we can get a dump. Even if the console interrupt cpu is wedged, we can trigger it from userspace using /proc/sysrq-trigger The output is made compact so that this facility is more useful on high cpu count systems, which is where this facility will likely find itself the most useful :) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29sysrq: add show-backtrace-on-all-cpus functionRik van Riel
SysRQ-P is not always useful on SMP systems, since it usually ends up showing the backtrace of a CPU that is doing just fine, instead of the backtrace of the CPU that is having problems. This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every active CPU in the system. It skips idle CPUs because some SMP systems are just too large and we already know what the backtrace of the idle task looks like. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Rik van Riel <riel@redhat.com> Randy Dunlap <randy.dunlap@oracle.com> Cc: <lwoodman@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce node_zonelist() for accessing the zonelist for a GFP maskMel Gorman
Introduce a node_zonelist() helper function. It is used to lookup the appropriate zonelist given a node and a GFP mask. The patch on its own is a cleanup but it helps clarify parts of the two-zonelist-per-node patchset. If necessary, it can be merged with the next patch in this set without problems. Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17add CONFIG_VT_UNICODEBill Nottingham
As of now, the kernel defaults to non-unicode and XLATE for the keyboard. We've been changing this in Fedora, but that requires patching the defaults in the kernel. The attached introduces CONFIG_VT_UNICODE, which sets the console in unicode mode by default on boot, including both the virtual terminal and the keyboard driver. Signed-off-by: Bill Nottingham <notting@redhat.com> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: move prototypes to appropriate header fileDavid Rientjes
Move the OOM killer's extern function prototypes to include/linux/oom.h and include it where necessary. [clg@fr.ibm.com: build fix] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add SysRq-Q to print timer_list debug infoIngo Molnar
Add SysRq-Q to print pending timers and other timer info. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
