path: root/drivers/char/vt.c
2010-11-05TTY: create drivers/tty/vt and move the vt code thereGreg Kroah-Hartman
The vt and other related code is moved into the drivers/tty/vt directory. Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22vcs: invoke the vt update callback when /dev/vcs* is written toNicolas Pitre
A notifier chain is called whenever the vt code modifies a terminal content, except for one case which is when the modification comes through writes to /dev/vcs* devices. Let's add the missing notifier invocation at the end of vcs_write() for that case too. Signed-off-by: Nicolas Pitre <nicolas.pitre@canonical.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-03vt: Fix console corruption on driver hand-over.Francisco Jerez
After 02f0777a0d6560eb995aade34a1b82f95c0452da "vc_origin" is no longer reset to the screen buffer before calling the con_init() hook of the new console driver. If the old driver wasn't using a fixed scanout buffer (e.g. the case of vgacon) "vc_origin" may be a pointer to a VRAM location, and its contents aren't guaranteed to be preserved after calling con_deinit() on the old driver and con_init() on the new driver, i.e. the subsequent console resize may fill the framebuffer with garbage. It can be reproduced in the transition from vgacon to the nouveau framebuffer driver: in that case the legacy VGA aperture "vc_origin" points to becomes unreadable after fbcon_init(). This patch reverts the mentioned commit. To avoid the problem it intended to fix, stop using "vc_scr_end" in vc_do_resize() to calculate how many rows we have to copy (actually the code looks simpler this way without the help of "vc_scr_end"). Signed-off-by: Francisco Jerez <currojerez@riseup.net> Cc: qiaochong <qiaochong@loongson.cn> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-16vt,console,kdb: preserve console_blanked while in kdbJason Wessel
Commit b45cfba4e9005d64d419718e7ff7f7cab44c1994 (vt,console,kdb: implement atomic console enter/leave functions) introduced the ability to atomically change the console mode with kernel mode setting but did not preserve the state of the console_blanked variable. The console_blanked variable must be restored when executing the con_debug_leave() or further kernel mode set changes (such as using chvt X) will fail to correctly set the state of console. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Andrew Morton <akpm@linux-foundation.org>
2010-08-16vt: fix regression warnings from KMS mergeJason Wessel
Fix the following new sparse warnings in vt.c introduced by the commit b45cfba4e9005d64d419718e7ff7f7cab44c1994 (vt,console,kdb: implement atomic console enter/leave functions): drivers/char/vt.c:197:5: warning: symbol 'saved_fg_console' was not declared. Should it be static? drivers/char/vt.c:198:5: warning: symbol 'saved_last_console' was not declared. Should it be static? drivers/char/vt.c:199:5: warning: symbol 'saved_want_console' was not declared. Should it be static? drivers/char/vt.c:200:5: warning: symbol 'saved_vc_mode' was not declared. Should it be static? Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Andrew Morton <akpm@linux-foundation.org>
2010-08-10tty: Move the vt_tty field from the vc_data into the standard tty_portAlan Cox
This takes all the tty references through the expected interface points so we can refcount them. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: Make vt's have a tty_portAlan Cox
The vt layer isn't safely handling reference counts to tty object on the input side. Add a tty port structure to the vt layer in order to implement this using the standard helpers. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10vc: Locking clean upAlan Cox
The virtual console layer uses the BKL for various things that don't really need it. Clean them out. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10vt/console: try harder to print output when panicingJesse Barnes
Jesse's initial patch commit said: "At panic time (i.e. when oops_in_progress is set) we should try a bit harder to update the screen and make sure output gets to the VT, since some drivers are capable of flipping back to it. So make sure we try to unblank and update the display if called from a panic context." I've enhanced this to add a flag to the vc that console layer can set to indicate they want this behaviour to occur. This also adds support to fbcon for that flag and adds an fb flag for drivers to indicate they want to use the support. It enables this for KMS drivers. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10vt: clean up the code - use kernel libraryAndy Shevchenko
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-09drivers/char/vt.c:vc_do_resize(): local var `end' should be unsigned longqiaochong
According include/linux/console_struct.h,vc_scr_end is unsigned long. struct vc_data { unsigned short vc_num; /* Console number */ unsigned int vc_cols; /* [#] Console size */ unsigned int vc_rows; unsigned int vc_size_row; /* Bytes per row */ unsigned int vc_scan_lines; /* # of scan lines */ unsigned long vc_origin; /* [!] Start of real screen */ unsigned long vc_scr_end; /* [!] End of real screen */ unsigned long vc_visible_origin; /* [!] Top of visible window */ unsigned int vc_top, vc_bottom; /* Scrolling region */ const struct consw *vc_sw; unsigned short *vc_screenbuf; ... } Signed-off-by: qiaochong <qiaochong@loongson.cn> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/char/vt.c: fix vc->vc_origin on take_over_console()qiaochong
kernel will die on some platform when switch from vga mode to framebuffer mode. The reason of this bug is that bind_con_driver reset vc->vc_origin to (unsigned long)vc->vc_screenbuf. On vgacon vc->vc_origin is not releated to vc->vc_screenbuf,if set vc->vc_origin to vc->vc_screenbuf,kernel will die on vc_do_resize. static int vc_do_resize(struct tty_struct *tty, struct tty_struct *real_tty, struct vc_data *vc, unsigned int cols, unsigned int lines) { unsigned long old_origin, new_origin, new_scr_end, rlth, rrem, err = 0; unsigned int old_cols, old_rows, old_row_size, old_screen_size; unsigned int new_cols, new_rows, new_row_size, new_screen_size; unsigned int end, user; ... end = (old_rows > new_rows) ? old_origin + (old_row_size * new_rows) : vc->vc_scr_end; ... /* here for a test from vgacon to framebuffer: old_origin=0x810814a0,end=0xb00b8fa0,vc->vc_origin=0x810814a0 the code bellow will copy memory from 0x810814a0 to 0xb00b8fa0, this will cover kernel code,kernel died here. */ while (old_origin < end) { scr_memcpyw((unsigned short *) new_origin, (unsigned short *) old_origin, rlth); if (rrem) scr_memsetw((void *)(new_origin + rlth), vc->vc_video_erase_char, rrem); old_origin += old_row_size; new_origin += new_row_size; } ... } [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: qiaochong <qiaochong@loongson.cn> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05vt,console,kdb: automatically set kdb LINES variableJason Wessel
The kernel console interface stores the number of lines it is configured to use. The kdb debugger can greatly benefit by knowing how many lines there are on the console for the pager functionality without having the end user compile in the setting or have to repeatedly change it at run time. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> CC: David Airlie <airlied@linux.ie> CC: Andrew Morton <akpm@linux-foundation.org>
2010-08-05vt,console,kdb: implement atomic console enter/leave functionsJesse Barnes
These functions allow the kernel debugger to save and restore the state of the system console. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: David Airlie <airlied@linux.ie> CC: Andrew Morton <akpm@linux-foundation.org>
2010-06-06Revert "tty: fix a little bug in scrup, vt.c"Linus Torvalds
This reverts commit 962400e8fd29981a7b166e463dd143b6ac6a3e76, which was entirely bogus. The code used to multiply the character offset by "vc->vc_cols", and that's actually correct, because 'd' itself is an 'unsigned short'. So the pointer arithmetic already takes the size of a VGA character into account. Changing it to use vc_size_row (which is just "vc_cols" shifted up to take the size of the character into account) ends up multiplying with the VGA character size twice. This got reported as bugs for various other subsystems, because what it actually results in is writing the 16-bit vc_video_erase_char pattern (usually 0x0720: 0x07 is the default attribute, 0x20 is ASCII space) into some random other allocation. So Markus ended up reporting this as a ext4 bug, while to Torsten Kaiser it looked like a problem with KMS or libata. Jeff Chua saw it in different places. And finally - Justin Mattock had slab poisoning enabled, and saw it as a slab poison overwritten. And bisected and reverted this to verify the buggy commit. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reported-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reported-by: Jeff Chua <jeff.chua.linux@gmail.com> Reported-by: Justin P. Mattock <justinmattock@gmail.com> Reported-bisected-and-tested-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Dave Airlie <airlied@redhat.com> Cc: Frank Pan <frankpzh@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04tty: fix a little bug in scrup, vt.cFrank Pan
The code uses vc->vc_cols instead of vc->vc_size_row by mistake, it will cause half of the region which is going to clear remain uncleared. The issue happens in background consoles, so it's hard to observe. Frank Pan Signed-off-by: Frank Pan <frankpzh@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-27drivers/char/vt.c: use memdup_userJulia Lawall
Use memdup_user when user data is immediately copied into the allocated region. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; position p; identifier l1,l2; @@ - to = \(kmalloc@p\|kzalloc@p\)(size,flag); + to = memdup_user(from,size); if ( - to==NULL + IS_ERR(to) || ...) { <+... when != goto l1; - -ENOMEM + PTR_ERR(to) ...+> } - if (copy_from_user(to, from, size) != 0) { - <+... when != goto l2; - -EFAULT - ...+> - } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-05vt: remove unused variablesShahar Havivi
Remove unused fields in drivers/char/vt.c variables orig_buf and orig_count are assigned but never used. Signed-off-by: Shahar Havivi <shaharh@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-16vt: make the default cursor shape configurableClemens Ladisch
For embedded systems, the blinking cursor at startup time can be annoying and unintended. Add a new kernel parameter to change the default cursor shape. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: David Newall <davidn@davidnewall.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vt: introduce and use vt_kmsg_redirect() functionBernhard Walle
The kernel offers with TIOCL_GETKMSGREDIRECT ioctl() the possibility to redirect the kernel messages to a specific console. However, since it's not possible to switch to the kernel message console after a panic(), it would be nice if the kernel would print the panic message on the current console. This patch series adds a new interface to access the global kmsg_redirect variable by a function to be able to use it in code where CONFIG_VT_CONSOLE is not set (kernel/panic.c). This patch: Instead of using and exporting a global value kmsg_redirect, introduce a function vt_kmsg_redirect() that both can set and return the console where messages are printed. Change all users of kmsg_redirect (the VT code itself and kernel/power.c) to the new interface. The main advantage is that vt_kmsg_redirect() can also be used when CONFIG_VT_CONSOLE is not set. Signed-off-by: Bernhard Walle <bernhard@bwalle.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-13vc: Add support for hiding the cursor when creating VTsMatthew Garrett
Add support for setting a global default for whether or not a visible cursor should be enabled when creating VCs. The default will be to do so, unless overridden by the user at boot time or by a driver. Signed-off-by: Matthew Garrett <mjg@redhat.com> LKML-Reference: <1258143251-5818-1-git-send-email-mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-09-19tty: vt: use printk_onceMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19tty: handle VT specific compat ioctls in vt driverArnd Bergmann
The VT specific compat_ioctl handlers are the only ones in common code that require the BKL. Moving them into the vt driver lets us remove the BKL from the other handlers and cleans up the code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19vt: add an event interfaceAlan Cox
This is needed and requested in various forms for ConsoleKit, screenblank handling and the like so do the job with a single interface. Also build the interface so that unlike VT_WAITACTIVE and friends it won't miss events. FIXME: Should this be a waitactive ioctl or a new device file you can poll and read events from. We need the code anyway to fix up the existing broken wait for console switch logic but the ConsoleKit people would prefer the new device to the ioctl we have here Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19tty: includecheck fix: drivers/char, vt.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/char/vt.c: linux/device.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15sparc: Kill PROM console driver.David S. Miller
Many years ago when this driver was written, it had a use, but these days it's nothing but trouble and distributions should not enable it in any situation. Pretty much every console device a sparc machine could see has a bonafide real driver, making the PROM console hack unnecessary. If any new device shows up, we should write a driver instead of depending upon this crutch to save us. We've been able to take care of this even when no chip documentation exists (sunxvr500, sunxvr2500) so there are no excuses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-16vt: drop bootmem/slab memory distinctionJohannes Weiner
Bootmem is not used for the vt screen buffer anymore as slab is now available at the time the console is initialized. Get rid of the now superfluous distinction between slab and bootmem, it's always slab. This also fixes a kmalloc leak which Catalin described thusly: Commit a5f4f52e ("vt: use kzalloc() instead of the bootmem allocator") replaced the alloc_bootmem() with kzalloc() but didn't set vc_kmalloced to 1 and the memory block is later leaked. The corresponding kmemleak trace: unreferenced object 0xdf828000 (size 8192): comm "swapper", pid 0, jiffies 4294937296 backtrace: [<c006d473>] __save_stack_trace+0x17/0x1c [<c000d869>] log_early+0x55/0x84 [<c01cfa4b>] kmemleak_alloc+0x33/0x3c [<c006c013>] __kmalloc+0xd7/0xe4 [<c00108c7>] con_init+0xbf/0x1b8 [<c0010149>] console_init+0x11/0x20 [<c0008797>] start_kernel+0x137/0x1e4 Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16console: make blank timeout value a boot optionDaniel Mack
The console blank timer is currently hardcoded to 10*60 seconds which might be annoying on systems with no input devices attached to wake up the console again. Especially during development, disabling the screen saver can be handy - for example when debugging the root fs mount mechanism or other scenarios where no userspace program could be started to do that at runtime from userspace. This patch defines a core_param for the variable in charge which allows users to entirely disable the blank feature at boot time by setting it 0. The value can still be overwritten at runtime using the standard ioctl call - this just allows to conditionally change the default. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12kmemleak: Remove the kmemleak.h include in drivers/char/vt.cCatalin Marinas
This file is no longer annotated for false positives but the kmemleak.h include was still present. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Alan Cox <alan.cox@linux.intel.com>
2009-06-11Merge branch 'for-linus' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'for-linus' of git://linux-arm.org/linux-2.6: kmemleak: Add the corresponding MAINTAINERS entry kmemleak: Simple testing module for kmemleak kmemleak: Enable the building of the memory leak detector kmemleak: Remove some of the kmemleak false positives kmemleak: Add modules support kmemleak: Add kmemleak_alloc callback from alloc_large_system_hash kmemleak: Add the vmalloc memory allocation/freeing hooks kmemleak: Add the slub memory allocation/freeing hooks kmemleak: Add the slob memory allocation/freeing hooks kmemleak: Add the slab memory allocation/freeing hooks kmemleak: Add documentation on the memory leak detector kmemleak: Add the base support Manual conflict resolution (with the slab/earlyboot changes) in: drivers/char/vt.c init/main.c mm/slab.c
2009-06-11vt: use kzalloc() instead of the bootmem allocatorPekka Enberg
Now that kmem_cache_init() happens before console_init(), we should use kzalloc() and not the bootmem allocator. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11kmemleak: Remove some of the kmemleak false positivesCatalin Marinas
There are allocations for which the main pointer cannot be found but they are not memory leaks. This patch fixes some of them. For more information on false positives, see Documentation/kmemleak.txt. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-04-19Revert "console ASCII glyph 1:1 mapping"Samuel Thibault
This reverts commit 1c55f18717304100a5f624c923f7cb6511b4116d. Ingo Brueckl was assuming that reverting to 1:1 mapping for chars >= 128 was not useful, but it happens to be: due to the limitations of the Linux console, when a blind user wants to read BIG5 on it, he has no other way than loading a font without SFM and let the 1:1 mapping permit the screen reader to get the BIG5 encoding. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24vcs: hook sysfs devices into object lifetime instead of "binding"Kay Sievers
During bootup performance tracing I noticed many occurrences of vca* device creation and removal, leading to the usual userspace uevent processing, which are, in this case, rather pointless. A simple test showing the kernel timing (not including all the work userspace has to do), gives us these numbers: $ time for i in `seq 1000`; do echo a > /dev/tty2; done real 0m1.142s user 0m0.015s sys 0m0.540s If we move the hook for the vcs* driver core devices from the tty "binding" to the vc allocation/deallocation, which is what the vcs* devices represent, we get the following numbers: $ time for i in `seq 1000`; do echo a > /dev/tty2; done real 0m0.152s user 0m0.030s sys 0m0.072s Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-08Make various things staticRoel Kluin
Building an allnoconfig kernel, sparse asked whether these could be static, so I checked, and they are only used in the file where they are declared. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02pty: simplify resizeAlan Cox
We have special case logic for resizing pty/tty pairs. We also have a per driver resize method so for the pty case we should use it. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02n_tty: Fix loss of echoed characters and remove bkl from n_ttyJoe Peterson
Fixes the loss of echoed (and other ldisc-generated characters) when the tty is stopped or when the driver output buffer is full (happens frequently for input during continuous program output, such as ^C) and removes the Big Kernel Lock from the N_TTY line discipline. Adds an "echo buffer" to the N_TTY line discipline that handles all ldisc-generated output (including echoed characters). Along with the loss of characters, this also fixes the associated loss of sync between tty output and the ldisc state when characters cannot be immediately written to the tty driver. The echo buffer stores (in addition to characters) state operations that need to be done at the time of character output (like management of the column position). This allows echo to cooperate correctly with program output, since the ldisc state remains consistent with actual characters written. Since the echo buffer code now isolates the tty column state code to the process_out* and process_echoes functions, we can remove the Big Kernel Lock (BKL) and replace it with mutex locks. Highlights are: * Handles echo (and other ldisc output) when tty driver buffer is full - continuous program output can block echo * Saves echo when tty is in stopped state (e.g. ^S) - (e.g.: ^Q will correctly cause held characters to be released for output) * Control character pairs (e.g. "^C") are treated atomically and not split up by interleaved program output * Line discipline state is kept consistent with characters sent to the tty driver * Remove the big kernel lock (BKL) from N_TTY line discipline Signed-off-by: Joe Peterson <joe@skyrush.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-13console ASCII glyph 1:1 mappingIngo Brueckl
For the console, there is a 1:1 mapping of glyphs which cannot be found in the current font. This seems to be meant as a kind of 'emergency fallback' for fonts without unicode mapping which otherwise would display nothing readable on the screen. At the moment it affects all chars for which no substitution character is defined. In particular this means that for all chars (>= 128) where there is no iso88591-1/unicode character (e.g. control character area) you'll get the very strange 1:1 mapping of the (cp437) graphics card glyphs. I'm pretty sure that the 1:1 mapping should only affect strict ASCII code characters, i.e. chars < 128. The patch limits the mapping as it probably was meant anyway. Signed-off-by: Ingo Brueckl <ib@wupperonline.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Egmont Koblinger <egmont@uhulinux.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06vt: incomplete initialization of vc_tab_stopWolfgang Kroworsch
Problem 1 (see patch below): vc_tab_stop is declared as an array of 8 unsigned ints in struct vc_data in include/linux/console_struct.h . In drivers/char/vt.c only 5 of these 8 unsigned ints get initialized leading to unintended tabulator placement on displays with more than 160 columns text. Problem 2 (open): Upcoming displays will have more than 256 columns of text leading to invalid memory access in drivers/char/vt.c during tabulator calculations: if (vc->vc_tab_stop[vc->vc_x >> 5] & (1 << (vc->vc_x & 31))) break; Signed-off-by: Wolfgang Kroworsch <wolfgang@kroworsch.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14Revert "vt: fix background color on line feed"Linus Torvalds
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the subsequent commits that fixed it up: - afa9b649 "fbcon: prevent cursor disappearance after switching to 512 character font" - d850a2fa "vt/fbcon: fix background color on line feed" - 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font switch" by request of Alan Cox. Quoth Alan: "Unfortunately it's wrong and its been causing breakages because various apps like ncurses expect our previous (and correct) behaviour." Alexander sent out a similar patch. Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Tested-by: Jan Engelhardt <jengelh@medozas.de> Cc: Alexander V. Lukyanov <lav@netis.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove more special casing and out of place codeAlan Cox
Carry on pushing code out of tty_io when it belongs to other drivers. I'm not 100% happy with some of this and it will be worth revisiting some of the exports later when the restructuring work is done. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: shutdown methodAlan Cox
Right now there are various drivers that try to use tty->count to know when they get the final close. Aristeau Rozanski showed while debugging the vt sysfs race that this isn't entirely safe. Instead of driver side tricks to work around this introduce a shutdown which is called when the tty is being destructed. This also means that the shutdown method is tied into the refcounting. Use this to rework the console close/sysfs logic. Remove lots of special case code from the tty core code. The pty code can now have a shutdown() method that replaces the special case hackery in the tree free up paths. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13vt: remove bogus lock droppingAlan Cox
For hysterical raisins the vt layer drops and retakes locks in the write method. This is a left over from the days when user/kernel data was passed directly to the tty not pre-buffered. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: move tioclinux from a special caseAlan Cox
Right now we have ifdefs and hooks in the core ioctl handler for TIOCLINUX and then test if its a console. This is brain dead. Instead call the tioclinux helper from the relevant driver ioctl methods. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15tty: remove resize window special caseAlan Cox
This moves it to being a tty operation. That removes special cases and now also means that resize can be picked up by um and other non vt consoles which may have a resize operation. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04vt: Deadlock workaroundAlan Cox
2.6.26 corrected the mutex locking on tty resizing to fix the case where you could get the tty/vt sizing out of sync. That turns out to have a deadlock. The actual fix is really major and I've got it lined up as part of the ops changes for 2.6.28 so for 2.6.26/2.6.27 it is safer to reintroduce this ages old minor bug. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Merge git://git.infradead.org/embedded-2.6Linus Torvalds
* git://git.infradead.org/embedded-2.6: Make console charset translation optional
