path: root/drivers/char
2011-05-30virtio console: don't manually set or finalize VIRTIO_CONSOLE_F_MULTIPORT.Rusty Russell
That's already been done by the virtio infrastructure before the probe function is called. Reported-by: alexey.kardashevskiy@au1.ibm.com Acked-by: Amit Shah <amit.shah@redhat.com> Tested-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-26drivers/char/ppdev.c: put gotten port valueJulia Lawall
parport_find_number() calls parport_get_port() on its result, so there should be a corresponding call to parport_put_port() before dropping the reference. Similar code is found in the function register_device() in the same file. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ local idexpression struct parport * x; expression ra,rr; statement S1,S2; @@ x = parport_find_number(...) ... when != x = rr when any when != parport_put_port(x,...) when != if (...) { ... parport_put_port(x,...) ...} ( if(<+...x...+>) S1 else S2 | if(...) { ... when != x = ra when forall when != parport_put_port(x,...) *return...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26drivers/char/mspec.c: use {k,v}zalloc to allocate memoryRakib Mullick
Let memory allocator initialize the allocated memory as null, thus remove the use of memset. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26ipmi: convert to seq_file interfaceAlexey Dobriyan
The ->read_proc interface is going away, convert to seq_file. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc:Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25i8k: Integrate with the hwmon subsystemJean Delvare
Let i8k create an hwmon class device so that libsensors will expose the CPU temperature and fan speeds to monitoring applications. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Massimo Dal Zotto <dz@debian.org>
2011-05-25i8k: Avoid lahf in 64-bit codeLuca Tettamanti
i8k uses lahf to read the flag register in 64-bit code; early x86-64 CPUs, however, lack this instruction and we get an invalid opcode exception at runtime. Use pushf to load the flag register into the stack instead. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Reported-by: Jeff Rickman <jrickman@myamigos.us> Tested-by: Jeff Rickman <jrickman@myamigos.us> Tested-by: Harry G McGavran Jr <w5pny@arrl.net> Cc: stable@kernel.org Cc: Massimo Dal Zotto <dz@debian.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits) drivers/gpu/drm/radeon/atom.c: fix warning drm/radeon/kms: bump kms version number drm/radeon/kms: properly set num banks for fusion asics drm/radeon/kms/atom: move dig phy init out of modesetting drm/radeon/kms/cayman: fix typo in register mask drm/radeon/kms: fix typo in spread spectrum code drm/radeon/kms: fix tile_config value reported to userspace on cayman. drm/radeon/kms: fix incorrect comparison in cayman setup code. drm/radeon/kms: add wait idle ioctl for eg->cayman drm/radeon/cayman: setup hdp to invalidate and flush when asked drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked agp/uninorth: Fix lockups with radeon KMS and >1x. drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices drm/radeon/kms: fixup eDP connector handling drm/radeon/kms: bail early for eDP in hotplug callback drm/radeon/kms: simplify hotplug handler logic drm/radeon/kms: rewrite DP handling drm/radeon/kms/atom: add support for setting DP panel mode drm/radeon/kms: atombios.h updates for DP panel mode ...
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm: apm-emulation: apm_mutex breaks ACK; remove it APM: take over maintainership
2011-05-23apm-emulation: apm_mutex breaks ACK; remove itPaul Parsons
apm_mutex is locked by a process (e.g. apm -s) at the start of apm_ioctl() and remains locked while pm_suspend() is called. Any subsequent process trying to ACK the suspend (e.g. apmd) is then blocked at the start of apm_ioctl(), causing the suspend to be delayed for 5 seconds in apm_suspend_notifier() while the ACK times out. In short, ACKs don't work. The driver's data structures are sufficiently protected by assorted locks. And pm_suspend() has its own mutex to prevent reentrancy. Consequently there is no obvious requirement for apm_mutex, which evolved from earlier BKL calls. So let's remove it. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-22agp/uninorth: Fix lockups with radeon KMS and >1x.Michel Dänzer
This was based on a description by Ben Herrenschmidt: > I've removed that SBA reset from the normal TLB invalidation path and > left it only once after turning AGP on. About six months ago, he said: > I did it a bit differently, but yeah, you get the idea. I'm doing a > patch series so don't bother pushing things too hard yet. But I haven't seen anything from him about this since then, and people are regularly hitting these lockups, so here we are... Signed-off-by: Michel Dänzer <daenzer@vmware.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@gmail.com>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits) crypto: caam - add support for sha512 variants of existing AEAD algorithms crypto: caam - remove unused authkeylen from caam_ctx crypto: caam - fix decryption shared vs. non-shared key setting crypto: caam - platform_bus_type migration crypto: aesni-intel - fix aesni build on i386 crypto: aesni-intel - Merge with fpu.ko crypto: mv_cesa - make count_sgs() null-pointer proof crypto: mv_cesa - copy remaining bytes to SRAM only when needed crypto: mv_cesa - move digest state initialisation to a better place crypto: mv_cesa - fill inner/outer IV fields only in HMAC case crypto: mv_cesa - refactor copy_src_to_buf() crypto: mv_cesa - no need to save digest state after the last chunk crypto: mv_cesa - print a warning when registration of AES algos fail crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup crypto: mv_cesa - the descriptor pointer register needs to be set just once crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of crypto: caam - fix printk recursion for long error texts crypto: caam - remove unused keylen from session context hwrng: amd - enable AMD hw rnd driver for Maple PPC boards hwrng: amd - manage resource allocation ...
2011-05-20Merge remote branch 'origin/master' into mergeBenjamin Herrenschmidt
Manual merge of arch/powerpc/kernel/smp.c and add missing scheduler_ipi() call to arch/powerpc/platforms/cell/interrupt.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-19Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits) debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning sysfs: remove "last sysfs file:" line from the oops messages drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION" memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION SYSFS: Fix erroneous comments for sysfs_update_group(). driver core: remove the driver-model structures from the documentation driver core: Add the device driver-model structures to kerneldoc Translated Documentation/email-clients.txt RAW driver: Remove call to kobject_put(). reboot: disable usermodehelper to prevent fs access efivars: prevent oops on unload when efi is not enabled Allow setting of number of raw devices as a module parameter Introduce CONFIG_GOOGLE_FIRMWARE driver: Google Memory Console driver: Google EFI SMI x86: Better comments for get_bios_ebda() x86: get_bios_ebda_length() misc: fix ti-st build issues params.c: Use new strtobool function to process boolean inputs debugfs: move to new strtobool ... Fix up trivial conflicts in fs/debugfs/file.c due to the same patch being applied twice, and an unrelated cleanup nearby.
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19Merge branch 'merge' into nextBenjamin Herrenschmidt
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-13agp/intel: add Ivy Bridge supportJesse Barnes
Just use the Sandy Bridge routines. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-06RAW driver: Remove call to kobject_put().Robert P. J. Day
If cdev_add() fails, there is no justification for subsequently calling kobject_put(). Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-06Allow setting of number of raw devices as a module parameterJan Kara
Allow setting of maximal number of raw devices as a module parameter. This requires changing of static array into a vmalloced one (the array is going to be too large for kmalloc). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-05-04powerpc/pseries/bsr: Remove redundant initialization of bsr dev_t declaration.Robert P. J. Day
Remove the unnecessary initialization of "dev_t bsr_dev" since it's subsequently used in an "alloc_chrdev_region()" call which uses that variable in an output-only fashion. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04hwrng: amd - enable AMD hw rnd driver for Maple PPC boardsDmitry Eremin-Solenikov
PPC 970FX Evaluation kit (Maple) boards bear AMD8111 southbridge. Allow this driver to be compiled in if PPC_MAPLE is selected. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-04hwrng: amd - manage resource allocationDmitry Eremin-Solenikov
As amd driver doesn't bind to PCI device, we'd better manage reource allocation on our own to disallow (possible) conflicts. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: console: Enable call to hvc_remove() on console port remove virtio_pci: Prevent double-free of pci regions after device hot-unplug virtio: Decrement avail idx on buffer detach
2011-04-21virtio: console: Enable call to hvc_remove() on console port removeAmit Shah
This call was disabled as hot-unplugging one virtconsole port led to another virtconsole port freezing. Upon testing it again, this now works, so enable it. In addition, a bug was found in qemu wherein removing a port of one type caused the guest output from another port to stop working. I doubt it was just this bug that caused it (since disabling the hvc_remove() call did allow other ports to continue working), but since it's all solved now, we're fine with hot-unplugging of virtconsole ports. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21agp: fix arbitrary kernel memory writesVasiliy Kulikov
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND, and it is not checked at all in case of AGPIOC_UNBIND. As a result, user with sufficient privileges (usually "video" group) may generate either local DoS or privilege escalation. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix OOM and buffer overflowVasiliy Kulikov
page_count is copied from userspace. agp_allocate_memory() tries to check whether this number is too big, but doesn't take into account the wrap case. Also agp_create_user_memory() doesn't check whether alloc_size is calculated from num_agp_pages variable without overflow. This may lead to allocation of too small buffer with following buffer overflow. Another problem in agp code is not addressed in the patch - kernel memory exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()). Each allocation is limited to 16KB, though, there is no per-process limit. This might lead to OOM situation, which is not even solved in case of the caller death by OOM killer - the memory is allocated for another (faked) process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-19kmsg: properly support writev to avoid interleaved printk lines fixAndrew Morton
make `len' size_t, avoid multiple-assignments. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19printk: /dev/kmsg - properly support writev() to avoid interleaved printk() ↵Kay Sievers
lines printk: /dev/kmsg - properly support writev() to avoid interleaved printk lines We should avoid calling printk() in a loop, when we pass a single string to /dev/kmsg with writev(). Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-29char/tpm: Fix unitialized usage of data bufferPeter Huewe
This patch fixes information leakage to the userspace by initializing the data buffer to zero. Reported-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> [ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way deeper problems than a simple multiplication can fix. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23drivers/char/mem.c: clean up the codeChangli Gao
Reduce the lines of code and simplify the logic. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23drivers/char: add MSM smd_pkt driverNiranjana Vishwanathapura
Add smd_pkt driver which provides device interface to smd packet ports. Signed-off-by: Niranjana Vishwanathapura <nvishwan@codeaurora.org> Cc: Brian Swetland <swetland@google.com> Cc: Greg KH <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: David Brown <davidb@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23drivers/char/ipmi/ipmi_si_intf.c: fix cleanup_one_si section mismatchSergey Senozhatsky
commit d2478521afc2022 ("char/ipmi: fix OOPS caused by pnp_unregister_driver on unregistered driver") introduced a section mismatch by calling __exit cleanup_ipmi_si from __devinit init_ipmi_si. Remove __exit annotation from cleanup_ipmi_si. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17char: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: tcrypt - do not attempt to write to readonly variable random: update interface comments to reflect reality crypto: picoxcell - add support for the picoxcell crypto engines crypto: sha1 - Add test vector to test partial block processing hwrng: omap - Convert release_resource to release_region/release_mem_region crypto: aesni-intel - Fix remaining leak in rfc4106_set_hash_key crypto: omap-sham - don't treat NULL clk as an error crypto: omap-aes - don't treat NULL clk as an error crypto: testmgr - mark ghash as fips_allowed crypto: testmgr - mark xts(aes) as fips_allowed crypto: skcipher - remove redundant NULL check hwrng: pixocell - add support for picoxcell TRNG crypto: aesni-intel - Don't leak memory in rfc4106_set_hash_subkey
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-03-10ipmi: Fix IPMI errors due to timing problemsDoe, YiCheng
This patch fixes an issue in OpenIPMI module where sometimes an ABORT command is sent after sending an IPMI request to BMC causing the IPMI request to fail. Signed-off-by: YiCheng Doe <yicheng.doe@hp.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Acked-by: Tom Mingarelli <thomas.mingarelli@hp.com> Tested-by: Andy Cress <andy.cress@us.kontron.com> Tested-by: Mika Lansirine <Mika.Lansirinne@stonesoft.com> Tested-by: Brian De Wolf <bldewolf@csupomona.edu> Cc: Jean Michel Audet <Jean-Michel.Audet@ca.Kontron.com> Cc: Jozef Sudelsky <jozef.sudolsky@elbiahosting.sk> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-07tty: move cd1865.h to drivers/staging/tty/Arnd Bergmann
The file is required by the specialix driver, which was moved to drivers/staging/. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07Staging: tty: fix build with epca.c driverGreg Kroah-Hartman
I forgot to move the digi*.h files from drivers/char/ to drivers/staging/tty/ Thanks to Randy for pointing out the issue. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-06virtio: console: Don't access vqs if device was unpluggedAmit Shah
If a virtio-console device gets unplugged while a port is open, a subsequent close() call on the port accesses vqs to free up buffers. This can lead to a crash. The buffers are already freed up as a result of the call to unplug_ports() from virtcons_remove(). The fix is to simply not access vq information if port->portdev is NULL. Reported-by: juzhang <juzhang@redhat.com> CC: stable@kernel.org Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01Revert "TPM: Long default timeout fix"Linus Torvalds
This reverts commit c4ff4b829ef9e6353c0b133b7adb564a68054979. Ted Ts'o reports: "TPM is working for me so I can log into employer's network in 2.6.37. It broke when I tried 2.6.38-rc6, with the following relevant lines from my dmesg: [ 11.081627] tpm_tis 00:0b: 1.2 TPM (device-id 0x0, rev-id 78) [ 25.734114] tpm_tis 00:0b: Operation Timed out [ 78.040949] tpm_tis 00:0b: Operation Timed out This caused me to get suspicious, especially since the _other_ TPM commit in 2.6.38 had already been reverted, so I tried reverting commit c4ff4b829e: "TPM: Long default timeout fix". With this commit reverted, my TPM on my Lenovo T410 is once again working." Requested-and-tested-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()Axel Lin
The ioctl file pointer was removed in commit 6caa76 "tty: now phase out the ioctl file pointer for good". Thus fix the prototype for mgslpc_ioctl() and eliminate below warning: CC [M] drivers/char/pcmcia/synclink_cs.o drivers/char/pcmcia/synclink_cs.c:2787: warning: initialization from incompatible pointer type Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
