Fix warnings caused by the unsigned long long usage in sparc
specific drivers.
The drivers were considered sparc specific more or less from the
filename alone.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
those two functions only used in that C file
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
* i8k-updates:
i8k: Add Dell Vostro systems
i8k: Enable i8k on Dell Precision Systems
This trivial patch adds support for i8k on the new Dell Vostro models.
I tested it on my Vostro 1400, and it works. It does print a warning
when loading the module:
i8k: unable to get SMM BIOS version
But I couldn't figure out how to fix that. The module seems to work fine,
anyway...
Signed-off-by: Federico Heinz <fheinz@vialibre.org.ar>
Signed-off-by: Alan Cox <alan@redhat.com>
Patch to enable i8k on Dell Precisions.
Signed-off-by: Andy Spencer <spenceal@rose-hulman.edu>
We forgot to release resources in one case.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12137
Reported-by: Florian Lohoff <flo@rfc822.org>
Use the tty port operations, add refcounting, and refactor a bit to make the
refcounting work cleanly.
Now we have our ducks in order we can begin switching to the port
operations
We will need this kref fitted to make full use of the port operations.
We need to this ready for using the standard helpers
Bring this driver into the port locking model
Now the locking is straight and the port kref usage is straight we can
replace lots of chunks of code with the standard port helpers
Bring epca into line with the port locking.
Update the nozomi driver to use krefs
disc_data and driver_data are void *
The write wakeup is done anyway for the poll while DO_WRITE_WAKUP is
cleared, set and managed by the ldisc layer and is no business of the pty
code.
The N_TTY ldisc layer does not send SIGIO POLL_OUTs correctly when output is
possible due to flawed handling of the TTY_DO_WRITE_WAKEUP bit. It will
either send no SIGIOs at all or on every tty wakeup.
The fix is to set the bit when the tty driver write would block and test
and clear it on write wakeup.
[Merged with existing N_TTY patches and a small buglet fixed -- Alan]
Signed-off-by: Thomas Pfaff <tpfaff@pcs.com>
Again this is a lot of common code we can unify
If we have no speed set at some point then we should not raise DTR/RTS at
that point when opening as the tty is not ready
Mark it broken
Start sucking more commonality out of the drivers into a single piece of
core code.
Normalise them so we can use the common helpers later on
Switch generic_serial to do port count locking via the tty_port structure
ready for moving to a common port wait routine. Keep the old driver lock for
internal calling so we don't risk messing up the drivers below until we
are ready.
Still needs kref conversions
This helps set the basis for moving block_til_ready into common code. We also
introduce a tty_port_hangup helper as this will also be generally needed.
This moves another per device special out of what should be shared open
wait paths into private methods
This was an alloc/clear wrapper but makes even less sense now it uses
kzalloc. Kill it off.
This is the first step to generalising the various pieces of waiting logic
duplicated in all sorts of serial drivers.
This patch causes "bell" (^G) characters (invoked when the input buffer
is full) to be immediately output rather than filling the echo buffer.
This is especially a problem when the tty is stopped and buffers fill, since
the bells do not serve their purpose of immediate notification that the
buffer cannot take further input, and they will flush all at once when the
tty is restarted.
Signed-off-by: Joe Peterson <joe@skyrush.com>
Fix the handling of input characters when the tty buffer is full or nearly
full. This includes tests that are done in n_tty_receive_char() and handling
of PARMRK.
Problems with the buffer-full tests done in receive_char() caused characters to
be lost at times when the buffer(s) filled. Also, these full conditions
would often only be detected with echo on, and PARMRK was not accounted for
properly in all cases. One symptom of these problems, in addition to lost
characters, was early termination from unix commands like tr and cat when
^Q was used to break from a stopped tty with full buffers (note that breaking
out was often previously not possible, due to the pty getting in "gridlock",
which will be addressed in another patch). Note space is always reserved
at the end of the buffer for a newline (or EOF/EOL) in canonical mode.
Fix process_output_block to detect continuation characters correctly
and to handle control characters even when O_OLCUC is enabled. Make
similar change to do_output_char().
We have special case logic for resizing pty/tty pairs. We also have a per
driver resize method so for the pty case we should use it.
Fixed sparse warning:
drivers/char/tty_io.c:1216:19: warning: symbol 'tty_driver_lookup_tty' was not declared. Should it be static?
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Now the main work is done its polishing time
Fixes the loss of echoed (and other ldisc-generated characters) when
the tty is stopped or when the driver output buffer is full (happens
frequently for input during continuous program output, such as ^C)
and removes the Big Kernel Lock from the N_TTY line discipline.
Adds an "echo buffer" to the N_TTY line discipline that handles all
ldisc-generated output (including echoed characters). Along with the
loss of characters, this also fixes the associated loss of sync between
tty output and the ldisc state when characters cannot be immediately
written to the tty driver.
The echo buffer stores (in addition to characters) state operations that need
to be done at the time of character output (like management of the column
position). This allows echo to cooperate correctly with program output,
since the ldisc state remains consistent with actual characters written.
Since the echo buffer code now isolates the tty column state code
to the process_out* and process_echoes functions, we can remove the
Big Kernel Lock (BKL) and replace it with mutex locks.
Highlights are:
* Handles echo (and other ldisc output) when tty driver buffer is full
- continuous program output can block echo
* Saves echo when tty is in stopped state (e.g. ^S)
- (e.g.: ^Q will correctly cause held characters to be released for output)
* Control character pairs (e.g. "^C") are treated atomically and not
split up by interleaved program output
* Line discipline state is kept consistent with characters sent to
the tty driver
* Remove the big kernel lock (BKL) from N_TTY line discipline
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
lguest: struct device - replace bus_id with dev_name()
lguest: move the initial guest page table creation code to the host
kvm-s390: implement config_changed for virtio on s390
virtio_console: support console resizing
virtio: add PCI device release() function
virtio_blk: fix type warning
virtio: block: dynamic maximum segments
virtio: set max_segment_size and max_sectors to infinite.
virtio: avoid implicit use of Linux page size in balloon interface
virtio: hand virtio ring alignment as argument to vring_new_virtqueue
virtio: use KVM_S390_VIRTIO_RING_ALIGN instead of relying on pagesize
virtio: use LGUEST_VRING_ALIGN instead of relying on pagesize
virtio: Don't use PAGE_SIZE for vring alignment in virtio_pci.
virtio: rename 'pagesize' arg to vring_init/vring_size
virtio: Don't use PAGE_SIZE in virtio_pci.c
virtio: struct device - replace bus_id with dev_name(), dev_set_name()
virtio-pci queue allocation not page-aligned
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits)
[ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices
[ARM] pxafb: cleanup of the timing checking code
[ARM] pxafb: cleanup of the color format manipulation code
[ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3
[ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching
[ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset
[ARM] pxafb: allow video memory size to be configurable
[ARM] pxa: add document on the MFP design and how to use it
[ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant
[ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant
[ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad)
[ARM] pxa: Update eseries defconfig
[ARM] 5352/1: add w90p910-plat config file
[ARM] s3c: S3C options should depend on PLAT_S3C
[ARM] mv78xx0: implement GPIO and GPIO interrupt support
[ARM] Kirkwood: implement GPIO and GPIO interrupt support
[ARM] Orion: share GPIO IRQ handling code
[ARM] Orion: share GPIO handling code
[ARM] s3c: define __io using the typesafe version
[ARM] S3C64XX: Ensure CPU_V6 is selected
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp/intel: Fix broken ® symbol in device name.
agp/intel: add support for G41 chipset
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, sparseirq: clean up Kconfig entry
x86: turn CONFIG_SPARSE_IRQ off by default
sparseirq: fix numa_migrate_irq_desc dependency and comments
sparseirq: add kernel-doc notation for new member in irq_desc, -v2
locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP
sparseirq, xen: make sure irq_desc is allocated for interrupts
sparseirq: fix !SMP building, #2
x86, sparseirq: move irq_desc according to smp_affinity, v7
proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ
sparse irqs: add irqnr.h to the user headers list
sparse irqs: handle !GENIRQ platforms
sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build
sparseirq: fix Alpha build failure
sparseirq: fix typo in !CONFIG_IO_APIC case
x86, MSI: pass irq_cfg and irq_desc
x86: MSI start irq numbering from nr_irqs_gsi
x86: use NR_IRQS_LEGACY
sparse irq_desc[] array: core kernel and x86 changes
genirq: record IRQ_LEVEL in irq_desc[]
irq.h: remove padding from irq_desc on 64bits
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
hrtimers: fix warning in kernel/hrtimer.c
x86: make sure we really have an hpet mapping before using it
x86: enable HPET on Fujitsu u9200
linux/timex.h: cleanup for userspace
posix-timers: simplify de_thread()->exit_itimers() path
posix-timers: check ->it_signal instead of ->it_pid to validate the timer
posix-timers: use "struct pid*" instead of "struct task_struct*"
nohz: suppress needless timer reprogramming
clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI
nohz: no softirq pending warnings for offline cpus
hrtimer: removing all ur callback modes, fix
hrtimer: removing all ur callback modes, fix hotplug
x86: correct link to HPET timer specification
rtc-cmos: export second NVRAM bank
Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c
manually.
this patch uses the new hvc callback hvc_resize to set the window size
which allows to change the tty size of hvc_console via a hvc_resize
function.
I have added a new feature bit VIRTIO_CONSOLE_F_SIZE. The driver will
change the window size on tty open and via the config_changed callback
of the transport. Currently lguest and kvm_s390 have not implemented this
callback, but the callback can be implemented at a later point in time.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (144 commits)
powerpc/44x: Support 16K/64K base page sizes on 44x
powerpc: Force memory size to be a multiple of PAGE_SIZE
powerpc/32: Wire up the trampoline code for kdump
powerpc/32: Add the ability for a classic ppc kernel to be loaded at 32M
powerpc/32: Allow __ioremap on RAM addresses for kdump kernel
powerpc/32: Setup OF properties for kdump
powerpc/32/kdump: Implement crash_setup_regs() using ppc_save_regs()
powerpc: Prepare xmon_save_regs for use with kdump
powerpc: Remove default kexec/crash_kernel ops assignments
powerpc: Make default kexec/crash_kernel ops implicit
powerpc: Setup OF properties for ppc32 kexec
powerpc/pseries: Fix cpu hotplug
powerpc: Fix KVM build on ppc440
powerpc/cell: add QPACE as a separate Cell platform
powerpc/cell: fix build breakage with CONFIG_SPUFS disabled
powerpc/mpc5200: fix error paths in PSC UART probe function
powerpc/mpc5200: add rts/cts handling in PSC UART driver
powerpc/mpc5200: Make PSC UART driver update serial errors counters
powerpc/mpc5200: Remove obsolete code from mpc5200 MDIO driver
powerpc/mpc5200: Add MDMA/UDMA support to MPC5200 ATA driver
Fix trivial conflict in drivers/char/Makefile as per Paul's directions
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Dave Airlie <airlied@linux.ie>
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
