Add support for new PLL-type for stih418 A9-PLL.
Currently the 407_A9_PLL type being used, it is corrected with this patch
4600c28 PLL allows to reach higher frequencies
so its programming algorithm is extended.
Signed-off-by: Pankaj Dev <pankaj.dev@st.com>
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Change A9 PLL rate, as per requirement from the cpufreq framework,
for DVFS. For rate change, the A9 clock needs to be temporarily sourced
from PLL external to A9 and then sourced back to A9-PLL
The patch adds support for enable/disable of the Clockgen PLLs.
clkgen_pll_enable/clkgen_pll_disable added as generic function for all PLLs.
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Use a generic name for this kind of PLL
Correction in dts files are already done here:
commit 5eb26c605909 ("ARM: STi: DT: Rename st_pll3200c32_407_c0_x into st_pll3200c32_cx_x")
Use the provider based method to get a clock's name so that we
can get rid of the clk member in struct clk_hw one day. Mostly
converted with the following coccinelle script.
struct clk_hw *E;
-__clk_get_name(E->clk)
+clk_hw_get_name(E)
Acked-by: Heiko Stuebner <heiko@sntech.de>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Peter De Schrijver <pdeschrijver@nvidia.com>
Cc: Prashant Gaikwad <pgaikwad@nvidia.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Thierry Reding <treding@nvidia.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
Cc: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Cc: Kevin Cernekee <cernekee@chromium.org>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Cc: linux-rockchip@lists.infradead.org
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Mostly converted with the following snippet:
struct clk_hw *E;
-__clk_get_flags(E->clk)
+clk_hw_get_flags(E)
Acked-by: Tero Kristo <t-kristo@ti.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Coquelin <mcoquelin.stm32@gmail.com>
* cleanup-clk-h-includes: (62 commits)
clk: Remove clk.h from clk-provider.h
clk: h8300: Remove clk.h and clkdev.h includes
clk: at91: Include clk.h and slab.h
clk: ti: Switch clk-provider.h include to clk.h
clk: pistachio: Include clk.h
clk: ingenic: Include clk.h
clk: si570: Include clk.h
clk: moxart: Include clk.h
clk: cdce925: Include clk.h
clk: Include clk.h in clk.c
clk: zynq: Include clk.h
clk: ti: Include clk.h
clk: sunxi: Include clk.h and remove unused clkdev.h includes
clk: st: Include clk.h
clk: qcom: Include clk.h
clk: highbank: Include clk.h
clk: bcm: Include clk.h
clk: versatile: Remove clk.h and clkdev.h includes
clk: ux500: Remove clk.h and clkdev.h includes
clk: tegra: Properly include clk.h
Use of_clk_parent_fill to fill in the parent clock names' array.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Tested-by Gabriel Fernandez <gabriel.fernandez@st.com>
Cc: Peter Griffin <peter.griffin@linaro.org>
This clock provider uses the consumer API, so include clk.h
explicitly.
Cc: Gabriel Fernandez <gabriel.fernandez@st.com>
The error paths in this file leak memory and mappings and test
for pointers being valid after dereferencing them. Fix these
problems and properly free resources on errors. Fix some
stylistic things too like using sizeof(*ptr) and fitting more
code on a single line. Note that we don't unregister clocks here.
That needs a clk_composite_unregister() API that we don't have
right now.
Acked-by: Gabriel Fernandez <gabriel.fernandez@linaro.org>
Cc: Pankaj Dev <pankaj.dev@st.com>
Incorrect register offset used for sthi407 clockgenC
Fixes: 51306d56ba81 ("clk: st: STiH407: Support for clockgenC0")
This patch fixes the mux bit-setting for ClockgenA9.
Fixes: 13e6f2da1ddf ("clk: st: STiH407: Support for A9 MUX Clocks")
Add the CLK_GET_RATE_NOCACHE flag to all the clocks with recalc ops,
so that they reflect Hw rate after CPS wake-up when a clk_get_rate()
is called
While proving lock, the following warning happens
and it is fixed after initializing lock in the setup
function
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.27-02861-g39df285-dirty #33
[<c00154ac>] (unwind_backtrace+0x0/0xf4) from [<c0011b50>] (show_stack+0x10/0x14)
[<c0011b50>] (show_stack+0x10/0x14) from [<c00689ac>] (__lock_acquire+0x900/0xb14)
[<c00689ac>] (__lock_acquire+0x900/0xb14) from [<c0069394>] (lock_acquire+0x68/0x7c)
[<c0069394>] (lock_acquire+0x68/0x7c) from [<c04958f8>] (_raw_spin_lock_irqsave+0x48/0x5c)
[<c04958f8>] (_raw_spin_lock_irqsave+0x48/0x5c) from [<c0381e6c>] (clk_gate_endisable+0x28/0x88)
[<c0381e6c>] (clk_gate_endisable+0x28/0x88) from [<c0381ee0>] (clk_gate_enable+0xc/0x14)
[<c0381ee0>] (clk_gate_enable+0xc/0x14) from [<c0386c68>] (flexgen_enable+0x28/0x40)
[<c0386c68>] (flexgen_enable+0x28/0x40) from [<c037f260>] (__clk_enable+0x5c/0x9c)
[<c037f260>] (__clk_enable+0x5c/0x9c) from [<c037f558>] (clk_enable+0x18/0x2c)
[<c037f558>] (clk_enable+0x18/0x2c) from [<c064a1dc>] (st_lpc_of_register+0xc0/0x248)
[<c064a1dc>] (st_lpc_of_register+0xc0/0x248) from [<c0649e44>] (clocksource_of_init+0x34/0x58)
[<c0649e44>] (clocksource_of_init+0x34/0x58) from [<c0637ddc>] (sti_timer_init+0x10/0x18)
[<c0637ddc>] (sti_timer_init+0x10/0x18) from [<c06343f8>] (time_init+0x20/0x30)
[<c06343f8>] (time_init+0x20/0x30) from [<c0632984>] (start_kernel+0x20c/0x2e8)
[<c0632984>] (start_kernel+0x20c/0x2e8) from [<40008074>] (0x40008074)
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Fixes: b116517055b7 ("clk: st: STiH407: Support for Flexgen Clocks")
This patch fixes the value for disabling the FSYN channel clock.
The 'is_enabled' returned value is also fixed.
Remove this duplicated code due to a bad copy / paste.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
drivers/clk/st/clkgen-mux.c:134:4: warning: symbol 'clkgena_divmux_get_parent' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:171:15: warning: symbol 'clkgena_divmux_recalc_rate' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:218:12: warning: symbol 'clk_register_genamux' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:388:13: warning: symbol 'st_of_clkgena_divmux_setup' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:488:13: warning: symbol 'st_of_clkgena_prediv_setup' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:625:13: warning: symbol 'st_of_clkgen_mux_setup' was not declared. Should it be static?
drivers/clk/st/clkgen-mux.c:702:13: warning: symbol 'st_of_clkgen_vcc_setup' was not declared. Should it be static?
drivers/clk/st/clkgen-pll.c:273:15: warning: symbol 'recalc_stm_pll800c65' was not declared. Should it be static?
drivers/clk/st/clkgen-pll.c:300:15: warning: symbol 'recalc_stm_pll1600c65' was not declared. Should it be static?
drivers/clk/st/clkgen-pll.c:324:15: warning: symbol 'recalc_stm_pll3200c32' was not declared. Should it be static?
drivers/clk/st/clkgen-pll.c:346:15: warning: symbol 'recalc_stm_pll1200c32' was not declared. Should it be static?
drivers/clk/st/clkgen-pll.c:565:19: warning: incorrect type in assignment (different address spaces)
drivers/clk/st/clkgen-pll.c:565:19: expected void [noderef] <asn:2>*reg
drivers/clk/st/clkgen-pll.c:565:19: got void *
drivers/clk/st/clkgen-pll.c:576:18: warning: incorrect type in assignment (different address spaces)
drivers/clk/st/clkgen-pll.c:576:18: expected void [noderef] <asn:2>*reg
drivers/clk/st/clkgen-pll.c:576:18: got void *
drivers/clk/st/clkgen-pll.c:693:53: warning: incorrect type in argument 2 (different address spaces)
drivers/clk/st/clkgen-pll.c:693:53: expected void *[noderef] <asn:2>reg
drivers/clk/st/clkgen-pll.c:693:53: got void [noderef] <asn:2>*[assigned] pll_base
drivers/clk/st/clkgen-fsyn.c:495:5: warning: symbol 'clk_fs660c32_vco_get_rate' was not declared. Should it be static?
drivers/clk/st/clkgen-fsyn.c:522:5: warning: symbol 'clk_fs660c32_vco_get_params' was not declared. Should it be static?
drivers/clk/st/clk-flexgen.c:119:15: warning: symbol 'flexgen_recalc_rate' was not declared. Should it be static?
drivers/clk/st/clk-flexgen.c:177:12: warning: symbol 'clk_register_flexgen' was not declared. Should it be static?
drivers/clk/st/clk-flexgen.c:263:13: warning: symbol 'st_of_flexgen_setup' was not declared. Should it be static?
of_device_id is always used as const.
(See driver.of_match_table and open firmware functions)
__initdata updated to __initconst for
static const struct of_device_id ti_clkdm_match_table[]
Signed-off-by: Fabian Frederick <fabf@skynet.be>
The change in the clk API to return a per-user clock instance, moved
the clock state to struct clk_core so now the struct clk_hw .core field
is used instead of .clk for most operations.
So for hardware clocks that needs to share the same clock state, both
the .core and .clk pointers have to be assigned but currently only the
.clk is set. This leads to NULL pointer dereference when the operations
try to access the hw clock .core. For example, the composite clock rate
and mux components didn't have a .core set which leads to this error:
Unable to handle kernel NULL pointer dereference at virtual address 00000034
pgd = c0004000
[00000034] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.19.0-next-20150211-00002-g1fb7f0e1150d #423
Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
task: ee480000 ti: ee488000 task.ti: ee488000
PC is at clk_mux_determine_rate_flags+0x14/0x19c
LR is at __clk_mux_determine_rate+0x24/0x2c
pc : [<c03a355c>] lr : [<c03a3734>] psr: a0000113
sp : ee489ce8 ip : ee489d84 fp : ee489d84
r10: 0000005c r9 : 00000001 r8 : 016e3600
r7 : 00000000 r6 : 00000000 r5 : ee442200 r4 : ee440c98
r3 : ffffffff r2 : 00000000 r1 : 016e3600 r0 : ee440c98
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 4000406a DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xee488210)
Stack: (0xee489ce8 to 0xee48a000)
9ce0: 00000000 ffffffff 60000113 ee440c98 ee442200 00000000
9d00: 016e3600 ffffffff 00000001 0000005c ee489d84 c03a3734 ee489d80 ee489d84
9d20: 00000000 c048b130 00000400 c03a5798 ee489d80 ee489d84 c0607f60 ffffffea
9d40: 00000001 00000001 ee489d5c c003f844 c06e3340 ee402680 ee440d0c ed935000
9d60: 016e3600 00000003 00000001 0000005c eded3700 c03a11a0 ee489d80 ee489d84
9d80: 016e3600 ee402680 c05b413a eddc9900 016e3600 c03a1228 00000000 ffffffff
9da0: ffffffff eddc9900 016e3600 c03a1c1c ffffffff 016e3600 ed8c6710 c03d6ce4
9dc0: eded3400 00000000 00000000 c03c797c 00000001 0000005c eded3700 eded3700
9de0: 000005e0 00000001 0000005c c03db8ac c06e7e54 c03c8f08 00000000 c06e7e64
9e00: c06b6e74 c06e7f64 000005e0 c06e7df8 c06e5100 00000000 c06e7e6c c06e7f54
9e20: 00000000 00000000 eebd9550 00000000 c06e7da0 c06e7e54 ee7b5010 c06e7da0
9e40: eddc9690 c06e7db4 c06b6e74 00000097 00000000 c03d4398 00000000 ee7b5010
9e60: eebd9550 c06e7da0 00000000 c03db824 ee7b5010 fffffffe c06e7db4 c0299c7c
9e80: ee7b5010 c072a05c 00000000 c0298858 ee7b5010 c06e7db4 ee7b5044 00000000
9ea0: eddc9580 c0298a04 c06e7db4 00000000 c0298978 c02971d4 ee405c78 ee732b40
9ec0: c06e7db4 eded3800 c06d6738 c0298044 c0608300 c06e7db4 00000000 c06e7db4
9ee0: 00000000 c06beb58 c06beb58 c0299024 00000000 c068dd00 00000000 c0008944
9f00: 00000038 c049013c ee462200 c0711920 ee480000 60000113 c06c2cb0 00000000
9f20: 00000000 c06c2cb0 60000113 00000000 ef7fcafc 00000000 c0640194 c00389ec
9f40: c05ec3a8 c063f824 00000006 00000006 c06c2c50 c0696444 00000006 c0696424
9f60: c06ee1c0 c066b588 c06b6e74 00000097 00000000 c066bd44 00000006 00000006
9f80: c066b588 c003d684 00000000 c0481938 00000000 00000000 00000000 00000000
9fa0: 00000000 c0481940 00000000 c000e680 00000000 00000000 00000000 00000000
9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[<c03a355c>] (clk_mux_determine_rate_flags) from [<c03a3734>] (__clk_mux_determine_rate+0x24/0x2c)
[<c03a3734>] (__clk_mux_determine_rate) from [<c03a5798>] (clk_composite_determine_rate+0xbc/0x238)
[<c03a5798>] (clk_composite_determine_rate) from [<c03a11a0>] (clk_core_round_rate_nolock+0x5c/0x9c)
[<c03a11a0>] (clk_core_round_rate_nolock) from [<c03a1228>] (__clk_round_rate+0x38/0x40)
[<c03a1228>] (__clk_round_rate) from [<c03a1c1c>] (clk_round_rate+0x20/0x38)
[<c03a1c1c>] (clk_round_rate) from [<c03d6ce4>] (max98090_dai_set_sysclk+0x34/0x118)
[<c03d6ce4>] (max98090_dai_set_sysclk) from [<c03c797c>] (snd_soc_dai_set_sysclk+0x38/0x80)
[<c03c797c>] (snd_soc_dai_set_sysclk) from [<c03db8ac>] (snow_late_probe+0x24/0x48)
[<c03db8ac>] (snow_late_probe) from [<c03c8f08>] (snd_soc_register_card+0xf04/0x1070)
[<c03c8f08>] (snd_soc_register_card) from [<c03d4398>] (devm_snd_soc_register_card+0x30/0x64)
[<c03d4398>] (devm_snd_soc_register_card) from [<c03db824>] (snow_probe+0x68/0xcc)
[<c03db824>] (snow_probe) from [<c0299c7c>] (platform_drv_probe+0x48/0x98)
[<c0299c7c>] (platform_drv_probe) from [<c0298858>] (driver_probe_device+0x114/0x234)
[<c0298858>] (driver_probe_device) from [<c0298a04>] (__driver_attach+0x8c/0x90)
[<c0298a04>] (__driver_attach) from [<c02971d4>] (bus_for_each_dev+0x54/0x88)
[<c02971d4>] (bus_for_each_dev) from [<c0298044>] (bus_add_driver+0xd8/0x1cc)
[<c0298044>] (bus_add_driver) from [<c0299024>] (driver_register+0x78/0xf4)
[<c0299024>] (driver_register) from [<c0008944>] (do_one_initcall+0x80/0x1d0)
[<c0008944>] (do_one_initcall) from [<c066bd44>] (kernel_init_freeable+0x10c/0x1d8)
[<c066bd44>] (kernel_init_freeable) from [<c0481940>] (kernel_init+0x8/0xe4)
[<c0481940>] (kernel_init) from [<c000e680>] (ret_from_fork+0x14/0x34)
Code: e24dd00c e5907000 e1a08001 e88d000c (e5970034)
The changes were made using the following cocinelle semantic patch:
@i@
@depends on i@
identifier dst;
- dst->clk = hw->clk;
+ __clk_hw_set_clk(dst, hw);
@depends on i@
identifier dst;
- dst->hw.clk = hw->clk;
+ __clk_hw_set_clk(&dst->hw, hw);
Fixes: 035a61c314eb3 ("clk: Make clk API return per-user struct clk instances")
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
Debugging eMMC on upstream kernels it has been noticed that when the
targetpack configures MMC0 clock to 200Mhz (required to switch to
HS200) then everything works OK. However if the kernel sets the
clock rate using clk_set_rate, then the eMMC card initialisation
fails with timeouts. Lower clock speeds (the default being 50Mhz)
work ok, but they we fail to get good eMMC transfer rates.
Looking through the vendor kernel clock driver reveals Giuseppe
had already fixed this issue, but the patch hasn't made its way
upstream.
The issue is fixed by changing the logic to manage the pdiv and
fdiv divisors used for setting the rate inside the flexgen driver code.
Pdiv is mainly targeted for low freq results, while fdiv should be
used for divs =< 64. The other way can lead to 'duty cycle'
issues.
I have changed the original patch to keep the original behaviour
in cases where the div is >64 which matches the original comment
and patch description more closely. Although no clocks appear to hit
this case currently when booting an upstream kernel.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
This patch uses CLK_DIVIDER_ROUND_CLOSEST flag to specify
the divider has to round to closest div.
Acked-by: Peter Griffin <peter.griffin@linaro.org>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
This patch extend the range of possible frequencies of the fs432c65
and fs660c32 Quad frequency synthesizers.
The patch added support for DT registration of ClockGenA9
It includes c32 type PLL.
Signed-off-by: Olivier Bideau <olivier.bideau@st.com>
The patch added support for ClockGenD0/D2/D3
It includes one 660 Quadfs.
The patch added support for DT registration of ClockGenC0
It includes 2 c32 type PLL and a 660 Quadfs.
This patch adds the support of quadfs reset handling.
This patch introduces polarity indication for pll power up bit
and for standby bit in order to have same code between stih416
and stih407 boards.
The patch added support for DT registration of ClockGenA0
The patch supports the A9-mux clocks used by ClockGenA9
This patch is the Flexgen implementation reusing as much as possible
of Common Clock Framework functions.
The idea is to have an instance of "struct flexgen" per output clock.
It represents the clock cross bar (by a mux element), and the pre and final dividers
(using dividers and gates elements).
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
converts clkgen_pll_data tables into static const
converts stm_fs tables into static const
Failure to terminate this match table can lead to boot failures
depending on where the compiler places the match table.
Cc: Gabriel FERNANDEZ <gabriel.fernandez@st.com>
When it fails to allocate div, gate should be free'd before return
Signed-off-by: Valentin Ilie <valentin.ilie@gmail.com>
A9-mux clock : Multiplexer inside ClockGenA9. A9 clock can be driven by
either PLL or External clock (with an optional divide-by-2). This is
implemented as 3-parent clock : PLL, Ext-clk OR Ext-clk/2
The patch added support for DT registration of ClockGenA9/DDR/GPU
ClockgenA9/DDR : It includes c32 type PLL (also in ClockgenA1x), hence
only CLK_OF_DECLARE implementation is required.
ClockgenGPU : It includes c65 type PLL (also in ClockgenAx), hence
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
The patch supports the 216/432/660 type Quad Frequency Synthesizers
used by ClockGenB/C/D/E/F
QUADFS clock : It includes support for all 216/432/660 type Quad
Frequency Synthesizers : implemented as Fixed Parent / Rate / Gate clock,
with clock rate calculated reading H/w settings done at BOOT.
QuadFS have 4 outputs : chan0 chan1 chan2 chan3
The patch supports the VCC-mux and MUX clocks used by ClockGenC/F
VCC-mux clock : Divider-Multiplexer-Gate inside ClockGenC/F
It includes support for each channel : 4-parent Multiplexer, Post Divide
by 1, 2, 4 or 8, Gate to switch OFF the output channel. The clock is
implemented using generic clocks implemented in the kernel clk_divider, clk_mux,
clk_gate and clk_composite (to combine all)
MUX clock : 2-parent clock used inside ClockGenC/F. The clock is implemented
using generic clocks implemented in the kernel clk_mux.
The patch supports the c65/c32 type PLLs used by ClockGenA(s)
PLL clock : It includes support for all c65/c32 type PLLs
inside ClockGenA(s) : implemented as Fixed Parent / Fixed Rate clock,
c65 PLLs have 2 outputs : HS and LS
c32 PLLs have 1-4 outputs : ODFx
The patch supports the DIVMUX and PreDiv clocks used by ClockGenA(s)
DIVMUX clock : Divider-Multiplexer-Gate inside ClockGenA(s)
It includes support for each channel : 3-parent Multiplexer,
Divider for each Parent, Gate to switch OFF the output channel. The
clock is implemented using generic clocks implemented in the kernel
clk_divider and clk_mux.
PreDiv clock : Fixed Divider Clock used inside ClockGenA(s) to divide
the oscillator clock by factor-of-16. The clock is implemented using
generic clocks implemented in the kernel clk_divider.
