[ Upstream commit ee678706e46d0d185c27cc214ad97828e0643159 ]
DSI DPHY gate bit on MIPI DSI clock register is bit 15
not bit 30.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Stephen Boyd <sboyd@kernel.org>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
[ Upstream commit 859783d1390035e29ba850963bded2b4ffdf43b5 ]
In the user manual of A64 SoC, the bit 22 and 23 of pll-mipi control
register is called "LDO{1,2}_EN", and according to the BSP source code
from Allwinner , the LDOs are enabled during the clock's enabling
process.
The clock failed to generate output if the two LDOs are not enabled.
Add the two bits to the clock's gate bits, so that the LDOs are enabled
when the PLL is enabled.
Fixes: c6a0637460c2 ("clk: sunxi-ng: Add A64 clocks")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
On the A83T, the AHB1 clock has a shared pre-divider on the two
PLL-PERIPH clock parents. To support such instances of shared
pre-dividers, this patch extends the mux clock type to support
multiple variable pre-dividers.
As the pre-dividers are only used to calculate the rate, but
do not participate in the factorization process, this is fairly
straightforward.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The mult/div for osc12M was previously backwards (giving a 48M rate
for osc12M). Fix it.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Tested-by: Christoph Muellner <christoph.muellner@theobroma-systems.com>
Some checkpatch warnings about spaces were missed and we didn't
mark two structs as static. Clean it up.
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Add the A64 CCU clocks set.
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
