2020-10-01 | clk/ti/adpll: allocate room for terminating null | Stephen Kitt | |
[ Upstream commit 7f6ac72946b88b89ee44c1c527aa8591ac5ffcbe ] The buffer allocated in ti_adpll_clk_get_name doesn't account for the terminating null. This patch switches to devm_kasprintf to avoid overflowing. Signed-off-by: Stephen Kitt <steve@sk2.org> Link: https://lkml.kernel.org/r/20191019140634.15596-1-steve@sk2.org Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Stephen Boyd <sboyd@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org> | |||
2019-05-15 | clk: Remove io.h from clk-provider.h | Stephen Boyd | |
Now that we've gotten rid of clk_readl() we can remove io.h from the clk-provider header and push out the io.h include to any code that isn't already including the io.h header but using things like readl/writel, etc. Found with this grep: git grep -l clk-provider.h | grep '.c$' | xargs git grep -L 'linux/io.h' | \ xargs git grep -l \ -e '\<__iowrite32_copy\>' --or \ -e '\<__ioread32_copy\>' --or \ -e '\<__iowrite64_copy\>' --or \ -e '\<ioremap_page_range\>' --or \ -e '\<ioremap_huge_init\>' --or \ -e '\<arch_ioremap_pud_supported\>' --or \ -e '\<arch_ioremap_pmd_supported\>' --or \ -e '\<devm_ioport_map\>' --or \ -e '\<devm_ioport_unmap\>' --or \ -e '\<IOMEM_ERR_PTR\>' --or \ -e '\<devm_ioremap\>' --or \ -e '\<devm_ioremap_nocache\>' --or \ -e '\<devm_ioremap_wc\>' --or \ -e '\<devm_iounmap\>' --or \ -e '\<devm_ioremap_release\>' --or \ -e '\<devm_memremap\>' --or \ -e '\<devm_memunmap\>' --or \ -e '\<__devm_memremap_pages\>' --or \ -e '\<pci_remap_cfgspace\>' --or \ -e '\<arch_has_dev_port\>' --or \ -e '\<arch_phys_wc_add\>' --or \ -e '\<arch_phys_wc_del\>' --or \ -e '\<memremap\>' --or \ -e '\<memunmap\>' --or \ -e '\<arch_io_reserve_memtype_wc\>' --or \ -e '\<arch_io_free_memtype_wc\>' --or \ -e '\<__io_aw\>' --or \ -e '\<__io_pbw\>' --or \ -e '\<__io_paw\>' --or \ -e '\<__io_pbr\>' --or \ -e '\<__io_par\>' --or \ -e '\<__raw_readb\>' --or \ -e '\<__raw_readw\>' --or \ -e '\<__raw_readl\>' --or \ -e '\<__raw_readq\>' --or \ -e '\<__raw_writeb\>' --or \ -e '\<__raw_writew\>' --or \ -e '\<__raw_writel\>' --or \ -e '\<__raw_writeq\>' --or \ -e '\<readb\>' --or \ -e '\<readw\>' --or \ -e '\<readl\>' --or \ -e '\<readq\>' --or \ -e '\<writeb\>' --or \ -e '\<writew\>' --or \ -e '\<writel\>' --or \ -e '\<writeq\>' --or \ -e '\<readb_relaxed\>' --or \ -e '\<readw_relaxed\>' --or \ -e '\<readl_relaxed\>' --or \ -e '\<readq_relaxed\>' --or \ -e '\<writeb_relaxed\>' --or \ -e '\<writew_relaxed\>' --or \ -e '\<writel_relaxed\>' --or \ -e '\<writeq_relaxed\>' --or \ -e '\<readsb\>' --or \ -e '\<readsw\>' --or \ -e '\<readsl\>' --or \ -e '\<readsq\>' --or \ -e '\<writesb\>' --or \ -e '\<writesw\>' --or \ -e '\<writesl\>' --or \ -e '\<writesq\>' --or \ -e '\<inb\>' --or \ -e '\<inw\>' --or \ -e '\<inl\>' --or \ -e '\<outb\>' --or \ -e '\<outw\>' --or \ -e '\<outl\>' --or \ -e '\<inb_p\>' --or \ -e '\<inw_p\>' --or \ -e '\<inl_p\>' --or \ -e '\<outb_p\>' --or \ -e '\<outw_p\>' --or \ -e '\<outl_p\>' --or \ -e '\<insb\>' --or \ -e '\<insw\>' --or \ -e '\<insl\>' --or \ -e '\<outsb\>' --or \ -e '\<outsw\>' --or \ -e '\<outsl\>' --or \ -e '\<insb_p\>' --or \ -e '\<insw_p\>' --or \ -e '\<insl_p\>' --or \ -e '\<outsb_p\>' --or \ -e '\<outsw_p\>' --or \ -e '\<outsl_p\>' --or \ -e '\<ioread8\>' --or \ -e '\<ioread16\>' --or \ -e '\<ioread32\>' --or \ -e '\<ioread64\>' --or \ -e '\<iowrite8\>' --or \ -e '\<iowrite16\>' --or \ -e '\<iowrite32\>' --or \ -e '\<iowrite64\>' --or \ -e '\<ioread16be\>' --or \ -e '\<ioread32be\>' --or \ -e '\<ioread64be\>' --or \ -e '\<iowrite16be\>' --or \ -e '\<iowrite32be\>' --or \ -e '\<iowrite64be\>' --or \ -e '\<ioread8_rep\>' --or \ -e '\<ioread16_rep\>' --or \ -e '\<ioread32_rep\>' --or \ -e '\<ioread64_rep\>' --or \ -e '\<iowrite8_rep\>' --or \ -e '\<iowrite16_rep\>' --or \ -e '\<iowrite32_rep\>' --or \ -e '\<iowrite64_rep\>' --or \ -e '\<__io_virt\>' --or \ -e '\<pci_iounmap\>' --or \ -e '\<virt_to_phys\>' --or \ -e '\<phys_to_virt\>' --or \ -e '\<ioremap_uc\>' --or \ -e '\<ioremap\>' --or \ -e '\<__ioremap\>' --or \ -e '\<iounmap\>' --or \ -e '\<ioremap\>' --or \ -e '\<ioremap_nocache\>' --or \ -e '\<ioremap_uc\>' --or \ -e '\<ioremap_wc\>' --or \ -e '\<ioremap_wc\>' --or \ -e '\<ioremap_wt\>' --or \ -e '\<ioport_map\>' --or \ -e '\<ioport_unmap\>' --or \ -e '\<ioport_map\>' --or \ -e '\<ioport_unmap\>' --or \ -e '\<xlate_dev_kmem_ptr\>' --or \ -e '\<xlate_dev_mem_ptr\>' --or \ -e '\<unxlate_dev_mem_ptr\>' --or \ -e '\<virt_to_bus\>' --or \ -e '\<bus_to_virt\>' --or \ -e '\<memset_io\>' --or \ -e '\<memcpy_fromio\>' --or \ -e '\<memcpy_toio\>' I also reordered a couple includes when they weren't alphabetical and removed clk.h from kona, replacing it with clk-provider.h because that driver doesn't use clk consumer APIs. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Tero Kristo <t-kristo@ti.com> Acked-by: Sekhar Nori <nsekhar@ti.com> Cc: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Mark Brown <broonie@kernel.org> Cc: Chris Zankel <chris@zankel.net> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: John Crispin <john@phrozen.org> Acked-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Stephen Boyd <sboyd@kernel.org> | |||
2019-02-15 | clk: ti: remove usage of CLK_IS_BASIC | Tero Kristo | |
Remove the usage of CLK_IS_BASIC flag completely from TI clock driver. In most cases, the use is completely redundant, but in some cases we need to use the new API to check if the clock is an OMAP clock or not. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Tested-by: Keerthy <j-keerthy@ti.com> | |||
2018-06-12 | treewide: devm_kzalloc() -> devm_kcalloc() | Kees Cook | |
The devm_kzalloc() function has a 2-factor argument form, devm_kcalloc(). This patch replaces cases of: devm_kzalloc(handle, a * b, gfp) with: devm_kcalloc(handle, a * b, gfp) as well as handling cases of: devm_kzalloc(handle, a * b * c, gfp) with: devm_kzalloc(handle, array3_size(a, b, c), gfp) as it's slightly less ugly than: devm_kcalloc(handle, array_size(a, b), c, gfp) This does, however, attempt to ignore constant size factors like: devm_kzalloc(handle, 4 * 1024, gfp) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. Some manual whitespace fixes were needed in this patch, as Coccinelle really liked to write "=devm_kcalloc..." instead of "= devm_kcalloc...". The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ expression HANDLE; type TYPE; expression THING, E; @@ ( devm_kzalloc(HANDLE, - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | devm_kzalloc(HANDLE, - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression HANDLE; expression COUNT; typedef u8; typedef __u8; @@ ( devm_kzalloc(HANDLE, - sizeof(u8) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(__u8) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(char) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(unsigned char) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(u8) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(__u8) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(char) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ expression HANDLE; type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (COUNT_ID) + COUNT_ID, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * COUNT_ID + COUNT_ID, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (COUNT_CONST) + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * COUNT_CONST + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (COUNT_ID) + COUNT_ID, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * COUNT_ID + COUNT_ID, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (COUNT_CONST) + COUNT_CONST, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * COUNT_CONST + COUNT_CONST, sizeof(THING) , ...) ) // 2-factor product, only identifiers. @@ expression HANDLE; identifier SIZE, COUNT; @@ - devm_kzalloc + devm_kcalloc (HANDLE, - SIZE * COUNT + COUNT, SIZE , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression HANDLE; expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( devm_kzalloc(HANDLE, - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression HANDLE; expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ expression HANDLE; identifier STRIDE, SIZE, COUNT; @@ ( devm_kzalloc(HANDLE, - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products, // when they're not all constants... @@ expression HANDLE; expression E1, E2, E3; constant C1, C2, C3; @@ ( devm_kzalloc(HANDLE, C1 * C2 * C3, ...) | devm_kzalloc(HANDLE, - (E1) * E2 * E3 + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - (E1) * (E2) * E3 + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - (E1) * (E2) * (E3) + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants, // keeping sizeof() as the second factor argument. @@ expression HANDLE; expression THING, E1, E2; type TYPE; constant C1, C2, C3; @@ ( devm_kzalloc(HANDLE, sizeof(THING) * C2, ...) | devm_kzalloc(HANDLE, sizeof(TYPE) * C2, ...) | devm_kzalloc(HANDLE, C1 * C2 * C3, ...) | devm_kzalloc(HANDLE, C1 * C2, ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (E2) + E2, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * E2 + E2, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (E2) + E2, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * E2 + E2, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - (E1) * E2 + E1, E2 , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - (E1) * (E2) + E1, E2 , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - E1 * E2 + E1, E2 , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org> | |||
2017-08-31 | clk: ti: check for null return in strrchr to avoid null dereferencing | Colin Ian King | |
strrchr can potentially return a null so the following strlen on the null pointer can cause a null dereference. Add a check to see if the string postfix is not null before calling strlen. Detected by CoverityScan, CID#1452039 ("Dereference null return") Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> | |||
2017-08-23 | clk: ti: make clk_ops const | Bhumika Goyal | |
Make these const as they are only stored in the const field of a clk_init_data structure. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> | |||
2016-03-01 | clk: ti: Fix some errors found by static checkers | Stephen Boyd | |
drivers/clk/ti/clk-814x.c:34:12: warning: symbol 'dm814x_adpll_early_init' was not declared. Should it be static? drivers/clk/ti/clk-814x.c:58:12: warning: symbol 'dm814x_adpll_enable_init_clocks' was not declared. Should it be static? drivers/clk/ti/adpll.c:465 ti_adpll_recalc_rate() warn: should '__readw(d->regs + 20) << 18' be a 64 bit type? drivers/clk/ti/adpll.c:945 ti_adpll_probe() error: we previously assumed 'd->clocks' could be null (see line 921) The last one looks like a real bug because we don't return an error on allocation failure. Cc: Tero Kristo <t-kristo@ti.com> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> | |||
2016-03-01 | clk: ti: Add support for dm814x ADPLL | Tony Lindgren | |
On dm814x we have 13 ADPLLs with 3 to 4 outputs on each. The ADPLLs have several dividers and muxes controlled by a shared control register for each PLL. Note that for the clocks to work as device drivers for booting on dm814x, this patch depends on "ARM: OMAP2+: Change core_initcall levels to postcore_initcall" that has already been merged. Also note that this patch does not implement clk_set_rate for the PLL, that will be posted later on when available. Cc: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Michael Turquette <mturquette@baylibre.com> |
