commit f87dfcabc6f173cc811d185d33327f50a8c88399 upstream.
The mdp_lut_clk isn't a child of the mdp_clk. Instead it's the
child of the mdp_src clock. Fix it.
Fixes: 6d00b56fe "clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)"
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit ff20783f7b9f35b29e768d8ecc7076c1ca1a60ca upstream.
Clocks that don't have a pre-divider don't list any pre-divider
in their frequency tables, but their tables are initialized using
aggregate initializers. Use tagged initializers so we properly
assign the m and n values for each frequency. Furthermore, the
mmcc_pxo_pll8_pll2_pll3 array improperly mapped the second
element to pll2 instead of pll8, causing the clock driver to
recalculate the wrong rate for any clocks using this array along
with a rate that uses pll2. Plus the .num_parents field is 3
instead of 4 so you can't even switch the parent to pll3. Finally
I noticed that the jpegd clock improperly indicates that the
pre-divider width is only 2, when it's actually 4 bits wide.
Tested-by: Rob Clark <robdclark@gmail.com>
commit 067bb1741c27c8d3b74ac98c0b8fc12b31e67005 upstream.
In some cases, clocks can switch their parent with clk_set_rate, for
example clk_mux can do this in some cases. Current implementation of
clk_change_rate uses un-safe list iteration on the clock children, which
will cause wrong clocks to be parsed in case any of the clock children
change their parents during the change rate operation. Fixed by using
the safe list iterator instead.
The problem was detected due to some divide by zero errors generated
by clock init on dra7-evm board, see discussion under
http://article.gmane.org/gmane.linux.ports.arm.kernel/349180 for details.
Fixes: 71472c0c06cf ("clk: add support for clock reparent on set_rate")
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Reported-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
commit c556bcddc78096caeb46dbe3ad0314dd951f1665 upstream.
The HDMI PLL input to the tv mux is supposed to be 3, not 2. Fix
the code so that we can properly select the HDMI PLL.
Reported-by: Rob Clark <robdclark@gmail.com>
commit 2a96dfa49c83a2a7cbdb11382976aaa6b2636764 upstream.
After unbinding the driver memory was corrupted by double free of
clk_lookup structure. This lead to OOPS when re-binding the driver
again.
The driver allocated memory for 'clk_lookup' with devm_kzalloc. During
driver removal this memory was freed twice: once by clkdev_drop() and
second by devm code.
Kernel panic log:
[ 30.839284] Unable to handle kernel paging request at virtual address 5f343173
[ 30.846476] pgd = dee14000
[ 30.849165] [5f343173] *pgd=00000000
[ 30.852703] Internal error: Oops: 805 [#1] PREEMPT SMP ARM
[ 30.858166] Modules linked in:
[ 30.861208] CPU: 0 PID: 1 Comm: bash Not tainted 3.16.0-rc2-00239-g94bdf617b07e-dirty #40
[ 30.869364] task: df478000 ti: df480000 task.ti: df480000
[ 30.874752] PC is at clkdev_add+0x2c/0x38
[ 30.878738] LR is at clkdev_add+0x18/0x38
[ 30.882732] pc : [<c0350908>] lr : [<c03508f4>] psr: 60000013
[ 30.882732] sp : df481e78 ip : 00000001 fp : c0700ed8
[ 30.894187] r10: 0000000c r9 : 00000000 r8 : c07b0e3c
[ 30.899396] r7 : 00000002 r6 : df45f9d0 r5 : df421390 r4 : c0700d6c
[ 30.905906] r3 : 5f343173 r2 : c0700d84 r1 : 60000013 r0 : c0700d6c
[ 30.912417] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 30.919534] Control: 10c53c7d Table: 5ee1406a DAC: 00000015
[ 30.925262] Process bash (pid: 1, stack limit = 0xdf480240)
[ 30.930817] Stack: (0xdf481e78 to 0xdf482000)
[ 30.935159] 1e60: 00001000 df6de610
[ 30.943321] 1e80: df7f4558 c0355650 c05ec6ec c0700eb0 df6de600 df7f4510 dec9d69c 00000014
[ 30.951480] 1ea0: 00167b48 df6de610 c0700e30 c0713518 00000000 c0700e30 dec9d69c 00000006
[ 30.959639] 1ec0: 00167b48 c02c1b7c c02c1b64 df6de610 c07aff48 c02c0420 c06fb150 c047cc20
[ 30.967798] 1ee0: df6de610 df6de610 c0700e30 df6de644 c06fb150 0000000c dec9d690 c02bef90
[ 30.975957] 1f00: dec9c6c0 dece4c00 df481f80 dece4c00 0000000c c02be73c 0000000c c016ca8c
[ 30.984116] 1f20: c016ca48 00000000 00000000 c016c1f4 00000000 00000000 b6f18000 df481f80
[ 30.992276] 1f40: df7f66c0 0000000c df480000 df480000 b6f18000 c011094c df47839c 60000013
[ 31.000435] 1f60: 00000000 00000000 df7f66c0 df7f66c0 0000000c df480000 b6f18000 c0110dd4
[ 31.008594] 1f80: 00000000 00000000 0000000c b6ec05d8 0000000c b6f18000 00000004 c000f2a8
[ 31.016753] 1fa0: 00001000 c000f0e0 b6ec05d8 0000000c 00000001 b6f18000 0000000c 00000000
[ 31.024912] 1fc0: b6ec05d8 0000000c b6f18000 00000004 0000000c 00000001 00000000 00167b48
[ 31.033071] 1fe0: 00000000 bed83a80 b6e004f0 b6e5122c 60000010 00000001 ffffffff ffffffff
[ 31.041248] [<c0350908>] (clkdev_add) from [<c0355650>] (s2mps11_clk_probe+0x2b4/0x3b4)
[ 31.049223] [<c0355650>] (s2mps11_clk_probe) from [<c02c1b7c>] (platform_drv_probe+0x18/0x48)
[ 31.057728] [<c02c1b7c>] (platform_drv_probe) from [<c02c0420>] (driver_probe_device+0x13c/0x384)
[ 31.066579] [<c02c0420>] (driver_probe_device) from [<c02bef90>] (bind_store+0x88/0xd8)
[ 31.074564] [<c02bef90>] (bind_store) from [<c02be73c>] (drv_attr_store+0x20/0x2c)
[ 31.082118] [<c02be73c>] (drv_attr_store) from [<c016ca8c>] (sysfs_kf_write+0x44/0x48)
[ 31.090016] [<c016ca8c>] (sysfs_kf_write) from [<c016c1f4>] (kernfs_fop_write+0xc0/0x17c)
[ 31.098176] [<c016c1f4>] (kernfs_fop_write) from [<c011094c>] (vfs_write+0xa0/0x1c4)
[ 31.105899] [<c011094c>] (vfs_write) from [<c0110dd4>] (SyS_write+0x40/0x8c)
[ 31.112931] [<c0110dd4>] (SyS_write) from [<c000f0e0>] (ret_fast_syscall+0x0/0x3c)
[ 31.120481] Code: e2842018 e584501c e1a00004 e885000c (e5835000)
[ 31.126596] ---[ end trace efad45bfa3a61b05 ]---
[ 31.131181] Kernel panic - not syncing: Fatal exception
[ 31.136368] CPU1: stopping
[ 31.139054] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 3.16.0-rc2-00239-g94bdf617b07e-dirty #40
[ 31.148697] [<c0016480>] (unwind_backtrace) from [<c0012950>] (show_stack+0x10/0x14)
[ 31.156419] [<c0012950>] (show_stack) from [<c0480db8>] (dump_stack+0x80/0xcc)
[ 31.163622] [<c0480db8>] (dump_stack) from [<c001499c>] (handle_IPI+0x130/0x15c)
[ 31.170998] [<c001499c>] (handle_IPI) from [<c000862c>] (gic_handle_irq+0x60/0x68)
[ 31.178549] [<c000862c>] (gic_handle_irq) from [<c0013480>] (__irq_svc+0x40/0x70)
[ 31.186009] Exception stack(0xdf4bdf88 to 0xdf4bdfd0)
[ 31.191046] df80: ffffffed 00000000 00000000 00000000 df4bc000 c06d042c
[ 31.199207] dfa0: 00000000 ffffffed c06d03c0 00000000 c070c288 00000000 00000000 df4bdfd0
[ 31.207363] dfc0: c0010324 c0010328 60000013 ffffffff
[ 31.212402] [<c0013480>] (__irq_svc) from [<c0010328>] (arch_cpu_idle+0x28/0x30)
[ 31.219783] [<c0010328>] (arch_cpu_idle) from [<c005f150>] (cpu_startup_entry+0x2c4/0x3f0)
[ 31.228027] [<c005f150>] (cpu_startup_entry) from [<400086c4>] (0x400086c4)
[ 31.234968] ---[ end Kernel panic - not syncing: Fatal exception
Fixes: 7cc560dea415 ("clk: s2mps11: Add support for s2mps11")
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Yadwinder Singh Brar <yadi.brar@samsung.com>
commit 15ebb05248d025534773c9ef64915bd888f04e4b upstream.
The control register is at offset 0x10, not 0x0. This is wreckaged
since commit 5df33a62c (SPEAr: Switch to common clock framework).
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 437ae6a1b8f2eedebfbf0f6572e19ca5c58a3f71 upstream.
We forgot to add the status bit for the PLLs and we were using
the wrong register and masks for configuration, leading to
unexpected PLL configurations. Fix this.
Fixes: d8b212014e69 (clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC))
commit aa014149ba002155a084ec1e9328e95b70167cbb upstream.
If the bit is set the clock is off so we should be checking for
a clear bit, not a set bit. Invert the logic.
Fixes: bcd61c0f535a (clk: qcom: Add support for root clock generators (RCGs))
commit 874f224cc52d64c912087e68e3724be95ad80ee7 upstream.
When a clock is unregsitered, we iterate over the list of
children and reparent them to NULL (i.e. orphan list). While
iterating the list, we should use the safe iterators because the
children list for this clock is changing when we reparent the
children to NULL. Failure to iterate safely can lead to slab
corruption like this:
BUG kmalloc-128 (Not tainted): Poison overwritten
Disabling lock debugging due to kernel taint
INFO: 0xed0c4900-0xed0c4903. First byte 0x0 instead of 0x6b
INFO: Allocated in clk_register+0x20/0x1bc age=297 cpu=2 pid=70
__slab_alloc.isra.39.constprop.42+0x410/0x454
kmem_cache_alloc_trace+0x200/0x24c
devm_clk_register+0x34/0x68
0xbf0000f0
driver_probe_device+0x94/0x360
__driver_attach+0x94/0x98
bus_for_each_dev+0x54/0x88
bus_add_driver+0xe8/0x204
driver_register+0x78/0xf4
do_one_initcall+0xc4/0x17c
load_module+0x19ac/0x2294
SyS_init_module+0xa4/0x110
ret_fast_syscall+0x0/0x48
INFO: Freed in clk_unregister+0xd4/0x140 age=23 cpu=2 pid=73
__slab_free+0x38/0x41c
release_nodes+0x164/0x1d8
__device_release_driver+0x60/0xb0
driver_detach+0xb4/0xb8
bus_remove_driver+0x5c/0xc4
SyS_delete_module+0x148/0x1d8
INFO: Slab 0xeec50b90 objects=25 used=0 fp=0xed0c5400 flags=0x4080
INFO: Object 0xed0c48c0 @offset=2240 fp=0xed0c4a00
Bytes b4 ed0c48b0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Object ed0c48c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c48d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c48e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c48f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c4900: 00 00 00 00 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b ....kkkkkkkkkkkk
Object ed0c4910: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c4920: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object ed0c4930: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkkkkkkkkkk.
Redzone ed0c4940: bb bb bb bb ....
Padding ed0c49e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Padding ed0c49f8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
CPU: 3 PID: 75 Comm: mdev Tainted: G B 3.14.0-11033-g2054ba5ca781 #35
[<c0014be0>] (unwind_backtrace) from [<c0012240>] (show_stack+0x10/0x14)
[<c0012240>] (show_stack) from [<c04b74a0>] (dump_stack+0x70/0xbc)
[<c04b74a0>] (dump_stack) from [<c00f7a78>] (check_bytes_and_report+0xbc/0x100)
[<c00f7a78>] (check_bytes_and_report) from [<c00f7c48>] (check_object+0x18c/0x218)
[<c00f7c48>] (check_object) from [<c00f7efc>] (__free_slab+0x104/0x144)
[<c00f7efc>] (__free_slab) from [<c04b6668>] (__slab_free+0x3dc/0x41c)
[<c04b6668>] (__slab_free) from [<c014c008>] (load_elf_binary+0x88/0x12b4)
[<c014c008>] (load_elf_binary) from [<c0105a44>] (search_binary_handler+0x78/0x18c)
[<c0105a44>] (search_binary_handler) from [<c0106fc0>] (do_execve+0x490/0x5dc)
[<c0106fc0>] (do_execve) from [<c0036b8c>] (____call_usermodehelper+0x134/0x168)
[<c0036b8c>] (____call_usermodehelper) from [<c000f048>] (ret_from_fork+0x14/0x2c)
FIX kmalloc-128: Restoring 0xed0c4900-0xed0c4903=0x6b
Fixes: fcb0ee6a3d33 (clk: Implement clk_unregister)
Cc: Jiada Wang <jiada_wang@mentor.com>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
commit 293ba3b4a4fd54891b900f2911d1a57e1ed4a843 upstream.
Now that clk_unregister() frees the struct clk we're
unregistering we'll free memory twice: first we'll call kfree()
in __clk_release() with an address kmalloc doesn't know about and
second we'll call kfree() in the devres layer. Remove the
allocation of struct clk in devm_clk_register() and let
clk_release() handle it. This fixes slab errors like:
BUG kmalloc-128 (Not tainted): Invalid object pointer 0xed08e8d0
INFO: Slab 0xeec503f8 objects=25 used=15 fp=0xed08ea00 flags=0x4081
CPU: 2 PID: 73 Comm: rmmod Tainted: G B 3.14.0-11032-g526e9c764381 #34
[<c0012240>] (show_stack) from [<c04b74dc>] (dump_stack+0x70/0xbc)
[<c04b74dc>] (dump_stack) from [<c00f6778>] (slab_err+0x74/0x84)
[<c00f6778>] (slab_err) from [<c04b6278>] (free_debug_processing+0x2cc/0x31c)
[<c04b6278>] (free_debug_processing) from [<c04b6300>] (__slab_free+0x38/0x41c)
[<c04b6300>] (__slab_free) from [<c03931bc>] (clk_unregister+0xd4/0x140)
[<c03931bc>] (clk_unregister) from [<c02fb774>] (release_nodes+0x164/0x1d8)
[<c02fb774>] (release_nodes) from [<c02f8698>] (__device_release_driver+0x60/0xb0)
[<c02f8698>] (__device_release_driver) from [<c02f9080>] (driver_detach+0xb4/0xb8)
[<c02f9080>] (driver_detach) from [<c02f8480>] (bus_remove_driver+0x5c/0xc4)
[<c02f8480>] (bus_remove_driver) from [<c008c9b8>] (SyS_delete_module+0x148/0x1d8)
[<c008c9b8>] (SyS_delete_module) from [<c000ef80>] (ret_fast_syscall+0x0/0x48)
FIX kmalloc-128: Object at 0xed08e8d0 not freed
commit 6b4ed8b00e93bd31f24a25f59ed8d1b808d0cc00 upstream.
If the allocation fails then we dereference the NULL in the error path.
Just return directly.
Fixes: ed27ff1db869 ('clk: Versatile Express clock generators ("osc") driver')
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
commit d2c834abe2b39a2d5a6c38ef44de87c97cbb34b4 upstream.
The value written to PLLE_AUX was incorrect due to a wrong variable
being used. Without this fix SATA does not work.
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Tested-by: Mikko Perttunen <mperttunen@nvidia.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Tested-by: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
[mturquette@linaro.org: improved changelog]
commit 9ba71705706aa83bcd7f9b74ae2d167da934c951 upstream.
The Tegra124 clock driver currently provides 3 clocks that don't actually
exist; 2 for NAND and one for UART5/UARTE. Delete these.
commit 238e14055da87d0d012257788e39fe0df3a82226 upstream.
If parent device does not have of_node set the s2mps11_clk_parse_dt()
returned NULL. This NULL was later passed to of_clk_add_provider() which
dereferenced it in pr_debug() call.
commit 8559087f0e9722a95df43fa5968bd1ee42bcf540 upstream.
When arch/arm/mach-omap2/gpmc.c calls clk_get(..., "fck"), it will
get a dummy clock and try to use it. As the rate is configured to zero,
this will result in several divisions by zero, and misconfigured
timings, with devices on the bus being lost in the La La Land.
It is better to remove gpmc_fck from the dummy clocks, so that gpmc.c
can fail gracefully.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Tero Kristo <t-kristo@ti.com>
git://git.linaro.org/people/mike.turquette/linux
Pull clk driver fix from Mike Turquette:
"Single fix for a clock driver merged in 3.14-rc1. Without this fix
the CPU frequency cannot be scaled"
* tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux:
clk: shmobile: rcar-gen2: Use kick bit to allow Z clock frequency change
The Z clock frequency change is effective only after setting the kick
bit located in the FRQCRB register.
Without that, the CA15 CPUs clock rate will never change.
Fix that by checking if the kick bit is cleared and enable it to make
the clock rate change effective. The bit is cleared automatically upon
completion.
Signed-off-by: Benoit Cousson <bcousson+renesas@baylibre.com>
Acked-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
cppcheck detected following error
[clk-master.c:245]: (error) Memory leak: characteristics
The original code forgot to free characteristics when
irq_of_parse_and_map() failed.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by Boris BREZILLON <b.brezillon@overkiz.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The Nomadik debugfs screws up multiplatform boots if debugfs
is enabled on the multiplatform image, since it's a simple
initcall that is unconditionally executed and reads from certain
memory locations.
Fix this by checking that the driver has been properly
initialized, so a base offset to the Nomadik SRC controller
exists, before proceeding to register debugfs files.
Reported-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Ensure clk->kref is dereferenced only when clk is not NULL.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Tested-by: Sachin Kamat <sachin.kamat@linaro.org>
git://nv-tegra.nvidia.com/user/pdeschrijver/linux into clk-fixes
Fixes stray access to undefined registers, use of wrong clock parents &
running clocks at wrong rates. All of these issues cause regressions in
the form of boards that are unable to boot or crash and die horrible
deaths.
Tegra124 does not have gr2d and gr3d clocks. They have been replaced by the
vic03 and gpu clocks respectively.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
The vic03 mux uses a linear mapping.
git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into clk-fixes
clk-fixes
mvebu clock fixes for v3.14
- kirkwood, dove, armada-xp, armada-370
- force clock init order broken by sorting DT ocp nodes by address
- fixes boot failures on affected platforms
The qspi clock divisor is incorrectly set to twice the value it should
have, possibly because it has been computed based on PLL1 as the clock
parent instead of PLL1 / 2 (the datasheets specifies the qspi nominal
frequencies, not the divisor values). Fix it.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
The lb, qspi, sdh, sd0 and sd1 clocks have the PLL1 (divided by 2) as
their parent, not the main clock. Fix it.
When requesting a rate less than the minimum clock rate for a divider,
use the maximum divider value instead of bailing out with an error.
This matches the behavior of the generic clock divider.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
When pll_x is the parent of cclk_lp, PLLX_DIV2_BYPASS_LP determines
whether cclk_lp output is divided by 2. Set TEGRA_DIVIDER_2 so that
the clk_super driver is aware of this.
The sdmmc clocks on Tegra114 and Tegra124 are 3-bit wide muxes with
6 parents. Add support for tegra_clk_sdmmc*_8 and switch Tegra114
and Tegra124 to use these clocks instead.
The host1x clock on Tegra124 is a 3-bit wide mux with 6 parents.
Change thte id to tegra_clk_host1x_8 so that the correct clock gets
registered.
Signed-off-by: Mark Zhang <markz@nvidia.com>
Set correct pll_d2_out0 divider and correct the p div values for pll_d2.
Signed-off-by: David Ung <davidu@nvidia.com>
PLLD was using the same mnp table as PLLP. Fix it to use its own
table which is different from PLLP's.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
This table had settings for 216MHz, but PLLP is (and is supposed to be)
configured at 408MHz. If that table is used and PLLP_BASE_OVRRIDE is
not set, the kernel will panic in clk_pll_recalc_rate().
Signed-off-by: Gabe Black <gabeblack@google.com>
UARTE has clock number 66. Number 65 is the right one for UARTD.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add clocks required for accessing fuses on Tegra20.
The clk_init_data struct is allocated in the stack. All members of
this struct should be initialized before using otherwise it will
lead to unpredictable situation as it can contain garbage.
Ultimately the clk->flag field contains garbage. In my case it leads
that flag CLK_IGNORE_UNUSED is set for most of clocks. As result a
bunch of unused clocks cannot be disabled.
So initialize flags in this structure too.
Cc: Mike Turquette <mturquette@linaro.org>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Init order of CLK_OF_DECLARE'd drivers depends on compile order.
Unfortunately, clk_of_init does not allow drivers to return errors,
e.g. -EPROBE_DEFER if parent clocks have not been registered, yet.
To avoid init order woes for MVEBU clock drivers, we take care of
proper init order ourselves. This patch joins core-clk and gating-clk
init to maintain proper init order.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
Currently, we are allocating space for two pointers, when we actually
may need to store three of them (two divisors plus the original clock).
Fix this, and change sizeof(type) to sizeof(*var) to keep checkpatch.pl
happy.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Allow drivers to be compiled as modules by exporting more clock
provider functions.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Commit 9807362bfe1748d9bb48eecb9261f1b1aaafea1c
"clk: si5351: declare all device IDs for module loading"
removed the common i2c_device_id and introduced new ones for each variant
of the clock generator. Instead of exploiting that information in the driver,
it still depends on platform_data passing the chips .variant.
This removes the now redundant .variant from the platform_data and puts it in
i2c_device_id's .driver_data instead.
Pull clk framework changes from Mike Turquette:
"The first half of the clk framework pull request is made up almost
entirely of new platform/driver support. There are some conversions
of existing drivers to the common-clock Device Tree binding, and a few
non-critical fixes to the framework.
Due to an entirely unnecessary cyclical dependency with the arm-soc
tree this pull request is broken into two pieces. The second piece
will be sent out after arm-soc sends you the pull request that merged
in core support for the HiSilicon 3620 platform. That same pull
request from arm-soc depends on this pull request to merge in those
HiSilicon bits without causing build failures"
[ Just did the ARM SoC merges, so getting ready for the second clk tree
pull request - Linus ]
* tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits)
devicetree: bindings: Document qcom,mmcc
devicetree: bindings: Document qcom,gcc
clk: qcom: Add support for MSM8660's global clock controller (GCC)
clk: qcom: Add support for MSM8974's global clock controller (GCC)
clk: qcom: Add support for MSM8960's global clock controller (GCC)
clk: qcom: Add reset controller support
clk: qcom: Add support for branches/gate clocks
clk: qcom: Add support for phase locked loops (PLLs)
clk: qcom: Add a regmap type clock struct
clk: Add set_rate_and_parent() op
reset: Silence warning in reset-controller.h
clk: sirf: re-arch to make the codes support both prima2 and atlas6
clk: composite: pass mux_hw into determine_rate
clk: shmobile: Fix MSTP clock array initialization
clk: shmobile: Fix MSTP clock index
ARM: dts: Add clock provider specific properties to max77686 node
clk: max77686: Register OF clock provider
Pull ARM driver updates from Olof Johansson:
"Updates of SoC-near drivers and other driver updates that makes more
sense to take through our tree.
The largest part of this is a conversion of device registration for
some renesas shmobile/sh devices over to use resources. This has
required coordination with the corresponding arch/sh changes, and
we've agreed to merge the arch/sh changes through our tree.
Added in this branch is support for Trusted Foundations secure
firmware, which is what is used on many of the commercial Nvidia Tegra
products that are in the market, including the Nvidia Shield. The
code is local to arch/arm at this time since it's uncertain whether it
will be shared with arm64 longer-term, if needed we will refactor
later.
A couple of new RTC drivers used on ARM boards, merged through our
tree on request by the RTC maintainer.
... plus a bunch of smaller updates across the board, gpio conversions
for davinci, etc"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits)
watchdog: davinci: rename platform driver to davinci-wdt
tty: serial: Limit msm_serial_hs driver to platforms that use it
mmc: msm_sdcc: Limit driver to platforms that use it
usb: phy: msm: Move mach dependent code to platform data
clk: versatile: fixup IM-PD1 clock implementation
clk: versatile: pass a name to ICST clock provider
ARM: integrator: pass parent IRQ to the SIC
irqchip: versatile FPGA: support cascaded interrupts from DT
gpio: davinci: don't create irq_domain in case of unbanked irqs
gpio: davinci: use chained_irq_enter/chained_irq_exit API
gpio: davinci: add OF support
gpio: davinci: remove unused variable intc_irq_num
gpio: davinci: convert to use irqdomain support.
gpio: introduce GPIO_DAVINCI kconfig option
gpio: davinci: get rid of DAVINCI_N_GPIO
gpio: davinci: use {readl|writel}_relaxed() instead of __raw_*
serial: sh-sci: Add OF support
serial: sh-sci: Add device tree bindings documentation
serial: sh-sci: Remove platform data mapbase and irqs fields
serial: sh-sci: Remove platform data scbrr_algo_id field
Pull ARM SoC DT updates from Olof Johansson:
"DT and DT-conversion-related changes for various ARM platforms. Most
of these are to enable various devices on various boards, etc, and not
necessarily worth enumerating.
New boards and systems continue to come in as new devicetree files
that don't require corresponding C changes any more, which is
indicating that the system is starting to work fairly well.
A few things worth pointing out:
* ST Ericsson ux500 platforms have made the major push to move over
to fully support the platform with DT
* Renesas platforms continue their conversion over from legacy
platform devices to DT-based for hardware description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (327 commits)
ARM: dts: SiRF: add pin group for USP0 with only RX or TX frame sync
ARM: dts: SiRF: add lost usp1_uart_nostreamctrl pin group for atlas6
ARM: dts: sirf: add lost minigpsrtc device node
ARM: dts: sirf: add clock, frequence-voltage table for CPU0
ARM: dts: sirf: add lost bus_width, clock and status for sdhci
ARM: dts: sirf: add lost clocks for cphifbg
ARM: dts: socfpga: add pl330 clock
ARM: dts: socfpga: update L2 tag and data latency
arm: sun7i: cubietruck: Enable the i2c controllers
ARM: dts: add support for EXYNOS4412 based TINY4412 board
ARM: dts: Add initial support for Arndale Octa board
ARM: bcm2835: add USB controller to device tree
ARM: dts: MSM8974: Add MMIO architected timer node
ARM: dts: MSM8974: Add restart node
ARM: dts: sun7i: external clock outputs
ARM: dts: sun7i: Change 32768 Hz oscillator node name to clk@N style
ARM: dts: sun7i: Add pin muxing options for clock outputs
ARM: dts: sun7i: Add rtp controller node
ARM: dts: sun5i: Add rtp controller node
ARM: dts: sun4i: Add rtp controller node
Pull ARM SoC cleanups from Olof Johansson:
"This is the branch where we usually queue up cleanup efforts, moving
drivers out of the architecture directory, header file restructuring,
etc. Sometimes they tangle with new development so it's hard to keep
it strictly to cleanups.
Some of the things included in this branch are:
* Atmel SAMA5 conversion to common clock
* Reset framework conversion for tegra platforms
- Some of this depends on tegra clock driver reworks that are shared
with Mike Turquette's clk tree.
* Tegra DMA refactoring, which are shared branches with the DMA tree.
* Removal of some header files on exynos to prepare for
multiplatform"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: mvebu: move Armada 370/XP specific definitions to armada-370-xp.h
ARM: mvebu: remove prototypes of non-existing functions from common.h
ARM: mvebu: move ARMADA_XP_MAX_CPUS to armada-370-xp.h
serial: sh-sci: Rework baud rate calculation
serial: sh-sci: Compute overrun_bit without using baud rate algo
serial: sh-sci: Remove unused GPIO request code
serial: sh-sci: Move overrun_bit and error_mask fields out of pdata
serial: sh-sci: Support resources passed through platform resources
serial: sh-sci: Don't check IRQ in verify port operation
serial: sh-sci: Set the UPF_FIXED_PORT flag
serial: sh-sci: Remove duplicate interrupt check in verify port op
serial: sh-sci: Simplify baud rate calculation algorithms
serial: sh-sci: Remove baud rate calculation algorithm 5
serial: sh-sci: Sort headers alphabetically
ARM: EXYNOS: Kill exynos_pm_late_initcall()
ARM: EXYNOS: Consolidate selection of PM_GENERIC_DOMAINS for Exynos4
ARM: at91: switch Calao QIL-A9260 board to DT
clk: at91: fix pmc_clk_ids data type attriubte
PM / devfreq: use inclusion <mach/map.h> instead of <plat/map-s5p.h>
ARM: EXYNOS: remove <mach/regs-clock.h> for exynos
