arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
When cpu runs at frequency not in cpufreq table (because of other
frequency governing mechanisms), bill time spent at that frequency to
next lower frequency in cpufreq stats table.
Original-Change-Id: I9cfda4e7a223ca3f773f1adb145d242483209799
Reviewed-on: http://git-master/r/47929
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Tested-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rd25650679bddec2837d92c75b18f8568c7569336
When cpu runs at a frequency not in cpufreq table (because of other
frequency governing mechanisms), freq_table_get_index() returns -1
which gets used as an array index.
Original-Change-Id: Id8fa5d5125c3cd1e2aad8b48ff7bd619f39c57d8
Reviewed-on: http://git-master/r/47887
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R032fc27d227d3308e5afa17d909f64d6925e05cc
Ensures that cpufreq_stats_free_table is called before
__cpufreq_remove_dev on cpu hotplug (which also occurs during
suspend on SMP systems) to make sure that sysfs_remove_group
can get called before the cpufreq kobj is freed. Otherwise,
the sysfs file structures are leaked.
Change-Id: I87e55277272f5cfad47e9e7c92630e990bb90069
Signed-off-by: Colin Cross <ccross@android.com>
If the driver submitted an non-existing pol>cur value (say it
used the default initialized value of zero), when the cpufreq
stats tries to setup its initial values it incorrectly sets
stat->last_index to -1 (or 0xfffff...). And cpufreq_stats_update
tries to update at that index location and fails.
This can be caused by:
stat->last_index = freq_table_get_index(stat, policy->cur);
not finding the appropiate frequency in the table (b/c the policy->cur
is wrong) and we end up crashing. The fix however is
concentrated in the 'cpufreq_stats_update' as the last_index
(and old_index) are updated there. Which means it can reset
the last_index to -1 again and on the next iteration cause a crash.
Without this patch, the following crash is observed:
powernow-k8: Found 1 AMD Athlon(tm) 64 Processor 3700+ (1 cpu cores) (version 2.20.00)
powernow-k8: fid 0x2 (1000 MHz), vid 0x12
powernow-k8: fid 0xa (1800 MHz), vid 0xa
powernow-k8: fid 0xc (2000 MHz), vid 0x8
powernow-k8: fid 0xe (2200 MHz), vid 0x8
Marking TSC unstable due to cpufreq changes
powernow-k8: fid trans failed, fid 0x2, curr 0x0
BUG: unable to handle kernel paging request at ffff880807e07b78
IP: [<ffffffff81479163>] cpufreq_stats_update+0x46/0x5b
.. snip..
Pid: 1, comm: swapper Not tainted 3.0.0-rc2 #45 MICRO-STAR INTERNATIONAL CO., LTD MS-7094/MS-7094
..snip..
Call Trace:
[<ffffffff81479248>] cpufreq_stat_notifier_trans+0x48/0x7c
[<ffffffff81095d68>] notifier_call_chain+0x32/0x5e
[<ffffffff81095e6b>] __srcu_notifier_call_chain+0x47/0x63
[<ffffffff81095e96>] srcu_notifier_call_chain+0xf/0x11
[<ffffffff81477e7a>] cpufreq_notify_transition+0x111/0x134
[<ffffffff8147b0d4>] powernowk8_target+0x53b/0x617
[<ffffffff8147723a>] __cpufreq_driver_target+0x2e/0x30
[<ffffffff8147a127>] cpufreq_governor_dbs+0x339/0x356
[<ffffffff81477394>] __cpufreq_governor+0xa8/0xe9
[<ffffffff81477525>] __cpufreq_set_policy+0x132/0x13e
[<ffffffff8147848d>] cpufreq_add_dev_interface+0x272/0x28c
Reported-by: Tobias Diedrich <ranma+xen@tdiedrich.de>
Tested-by: Tobias Diedrich <ranma+xen@tdiedrich.de>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Dave Jones <davej@redhat.com>
cpufreq_stats leaves behind its sysfs entries, which causes a panic
when something stumbled across them.
(Discovered by unloading cpufreq_stats while powertop was loaded).
Cc: stable@kernel.org
Fixed brace coding style issue.
Signed-off-by: Karthigan Srinivasan <karthigan.srinivasan@hp.com>
When a CPU is taken offline in an SMP system, cpufreq_remove_dev()
nulls out the per-cpu policy before cpufreq_stats_free_table() can
make use of it. cpufreq_stats_free_table() then skips the
call to sysfs_remove_group(), leaving about 100 bytes of sysfs-related
memory unclaimed each time a CPU-removal occurs. Break up
cpu_stats_free_table into sysfs and table portions, and
call the sysfs portion early.
Signed-off-by: Steven Finney <steven.finney@palm.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Change cpufreq_policy and cpufreq_governor pointer tables
from arrays to per_cpu variables in the cpufreq subsystem.
Also some minor complaints from checkpatch.pl fixed.
Based on:
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86.git
Signed-off-by: Mike Travis <travis@sgi.com>
Sometimes old_index != stat->last_index, see cpufreq_update_policy, bios can
change cpu setting in resume. In my test, after resume cpu is in lowest
speed, but the stat info shows cpu is in full speed. This patch makes the
stat info correct after a resume.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Fix show_trans_table when it overflows PAGE_SIZE.
* Not all snprintf calls were protected against being passed a negative
length.
* When show_trans_table overflows, len might be > PAGE_SIZE. In that case,
returns PAGE_SIZE.
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Signed-off-by: Dave Jones <davej@codemonkey.org.uk>
Fix the following warnings:
WARNING: vmlinux.o(.text+0xfe6711): Section mismatch in reference from the function cpufreq_unregister_driver() to the variable .cpuinit.data:cpufreq_cpu_notifier
WARNING: vmlinux.o(.text+0xfe68af): Section mismatch in reference from the function cpufreq_register_driver() to the variable .cpuinit.data:cpufreq_cpu_notifier
WARNING: vmlinux.o(.exit.text+0xc4fa): Section mismatch in reference from the function cpufreq_stats_exit() to the variable .cpuinit.data:cpufreq_stat_cpu_notifier
The warnings were casued by references to unregister_hotcpu_notifier()
from normal functions or exit functions.
This is flagged by modpost as a potential error because
it does not know that for the non HOTPLUG_CPU
scenario the unregister_hotcpu_notifier() is a nop.
Silence the warning by replacing the __initdata
annotation with a __refdata annotation.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
cpufreq_stats_free_table() mustn't be __cpuexit since it's called by the
__cpuinit cpufreq_stat_cpu_callback().
This patch fixes the following section mismatch reported by
Chris Clayton:
WARNING: vmlinux.o(.init.text+0x143dd): Section mismatch: reference to .exit.text:cpufreq_stats_free_table (between 'cpufreq_stat_cpu_callback' and 'cpufreq_stats_init')
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Chris Clayton <chris2553@googlemail.com>
Acked-by: Dave Jones <davej@codemonkey.org.uk>
* Stop referencing the callback directly from the __init and __exit
functions of this driver, and instead explicitly call
cpufreq_update_policy() et al. This enables the callback function
to be marked as __cpuinit (and the notifier_block __cpuinitdata),
thereby saving space when HOTPLUG_CPU=n. This also enables us to
use other tricks to replace __cpuinit{data} in future.
* cpufreq_stats_free_table() is only called from __cpuinit or __exit
marked functions, making it an ideal candidate for __cpuexit.
* Fix missing space in the module description
Signed-off-by: Satyam Sharma <satyam@infradead.org>
sysfs is now completely out of driver/module lifetime game. After
deletion, a sysfs node doesn't access anything outside sysfs proper,
so there's no reason to hold onto the attribute owners. Note that
often the wrong modules were accounted for as owners leading to
accessing removed modules.
This patch kills now unnecessary attribute->owner. Note that with
this change, userland holding a sysfs node does not prevent the
backing module from being unloaded.
For more info regarding lifetime rule cleanup, please read the
following message.
http://article.gmane.org/gmane.linux.kernel/510293
(tweaked by Greg to not delete the field just yet, to make it easier to
merge things properly.)
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
The hotplug CPU locking in cpufreq is horrendous. No-one seems to care
enough to fix it, so just remove it so that the 99.9% of the real world
users of this code can use cpufreq without being bothered by warnings.
change notification
Fixes the oops in cpufreq_stats with acpi_cpufreq driver. The issue was
that the frequency was reported as 0 in acpi-cpufreq.c. The bug is due to
different indicies for freq_table and ACPI perf table.
Also adds a check in cpufreq_stats to check for error return from
freq_table_get_index() and avoid using the error return value.
Patch fixes the issue reported at
http://www.ussg.iu.edu/hypermail/linux/kernel/0611.2/0629.html
and also other similar issue here
http://bugme.osdl.org/show_bug.cgi?id=7383 comment 53
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Clean up cpufreq subsystem to fix coding style issues and to improve
the readability.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Lukewarm IQ detected in hotplug locking
BUG: warning at kernel/cpu.c:38/lock_cpu_hotplug()
[<b0134a42>] lock_cpu_hotplug+0x42/0x65
[<b02f8af1>] cpufreq_update_policy+0x25/0xad
[<b0358756>] kprobe_flush_task+0x18/0x40
[<b0355aab>] schedule+0x63f/0x68b
[<b01377c2>] __link_module+0x0/0x1f
[<b0119e7d>] __cond_resched+0x16/0x34
[<b03560bf>] cond_resched+0x26/0x31
[<b0355b0e>] wait_for_completion+0x17/0xb1
[<f965c547>] cpufreq_stat_cpu_callback+0x13/0x20 [cpufreq_stats]
[<f9670074>] cpufreq_stats_init+0x74/0x8b [cpufreq_stats]
[<b0137872>] sys_init_module+0x91/0x174
[<b0102c81>] sysenter_past_esp+0x56/0x79
As there are other places that call cpufreq_update_policy without
the hotplug lock, it seems better to keep the hotplug locking
at the lower level for the time being until this is revamped.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
CPUs come online only at init time (unless CONFIG_HOTPLUG_CPU is defined).
So, cpu_notifier functionality need to be available only at init time.
This patch makes register_cpu_notifier() available only at init time, unless
CONFIG_HOTPLUG_CPU is defined.
This patch exports register_cpu_notifier() and unregister_cpu_notifier() only
if CONFIG_HOTPLUG_CPU is defined.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Ashok Raj <ashok.raj@intel.com>
cpufreq are the only remaining bit to be solved for me to have a modpost
clean build for sparc64 - so I took one more look at it.
changelog entry:
Fix section mismatch warnings in cpufreq:
WARNING: drivers/cpufreq/cpufreq_stats.o - Section mismatch: reference to .init.text: from .data between 'cpufreq_stat_cpu_notifier' (at offset 0xa8) and 'notifier_policy_block'
WARNING: drivers/cpufreq/cpufreq_stats.o - Section mismatch: reference to .init.text: from .exit.text after 'cleanup_module' (at offset 0x30)
The culprint is the function: cpufreq_stat_cpu_callback
It is marked __cpuinit which get's redefined to __init in case
HOTPLUG_CPU is not enabled as per. init.h:
#ifdef CONFIG_HOTPLUG_CPU
#define __cpuinit
#else
#define __cpuinit __init
#endif
$> grep HOTPLUG .config
CONFIG_HOTPLUG=y
But cpufreq_stat_cpu_callback() is used in:
__exit cpufreq_stats_exit()
static struct notifier_block cpufreq_stat_cpu_notifier
cpufreq_stat_cpu_notifier is again used in:
__init cpufreq_stats_init()
So in both cases used from both __init and __exit context.
Only solution seems to drop __cpuinit tag.
Whoops, I lost a hunk of the last patch somehow.
cpufreq entries in sysfs should only be populated when CPU is online state.
When we either boot with maxcpus=x and then boot the other cpus by echoing
to sysfs online file, these entries should be created and destroyed when
CPU_DEAD is notified. Same treatement as cache entries under sysfs.
We place the processor in the lowest frequency, so hw managed P-State
transitions can still work on the other threads to save power.
Primary goal was to just make these directories appear/disapper dynamically.
There is one in this patch i had to do, which i really dont like myself but
probably best if someone handling the cpufreq infrastructure could give
this code right treatment if this is not acceptable. I guess its probably
good for the first cut.
- Converting lock_cpu_hotplug()/unlock_cpu_hotplug() to disable/enable preempt.
The locking was smack in the middle of the notification path, when the
hotplug is already holding the lock. I tried another solution to avoid this
so avoid taking locks if we know we are from notification path. The solution
was getting very ugly and i decided this was probably good for this iteration
until someone who understands cpufreq could do a better job than me.
(akpm: export cpucontrol to GPL modules: drivers/cpufreq/cpufreq_stats.c now
does lock_cpu_hotplug())
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Zwane Mwaikambo <zwane@holomorphy.com>
Cc: Greg KH <greg@kroah.com>
This fixes an issue found in drivers/cpufreq/cpufreq_stats.c by Coverity.
Error reported:
CID: 2642
Checker: NULL_RETURNS (help)
File: /export2/p4-coverity/mc2/linux26/drivers/cpufreq/cpufreq_stats.c
Function: cpufreq_stats_create_table
Description: Dereferencing NULL value "data"
Patch description:
The return of cpufreq_cpu_get can be NULL, check return code and return
-EINVAL if it is NULL.
Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com>
Changes to the cpufreq stats driver:
* Changes the way P-state transition table looks in /sysfs providing more
clear output
* Changes the time unit in the output from HZ to clock_t
infrastructure for it.
Let it rip!
