commit 9505b98ccddc454008ca7efff90044e3e857c827 upstream.
pxa_cpufreq_init_voltages() is marked __init but usually inlined into
the non-__init pxa_cpufreq_init() function. When building with clang,
it can stay as a standalone function in a discarded section, and produce
this warning:
WARNING: vmlinux.o(.text+0x616a00): Section mismatch in reference from the function pxa_cpufreq_init() to the function .init.text:pxa_cpufreq_init_voltages()
The function pxa_cpufreq_init() references
the function __init pxa_cpufreq_init_voltages().
This is often because pxa_cpufreq_init lacks a __init
annotation or the annotation of pxa_cpufreq_init_voltages is wrong.
Fixes: 50e77fcd790e ("ARM: pxa: remove __init from cpufreq_driver->init()")
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: All applicable <stable@vger.kernel.org>
commit fb2a24a1c6457d21df9fae0dd66b20c63ba56077 upstream.
There are two definitions of pxa_cpufreq_change_voltage, with slightly
different prototypes after one of them had its argument marked 'const'.
Now the other one (for !CONFIG_REGULATOR) produces a harmless warning:
drivers/cpufreq/pxa2xx-cpufreq.c: In function 'pxa_set_target':
drivers/cpufreq/pxa2xx-cpufreq.c:291:36: warning: passing argument 1 of 'pxa_cpufreq_change_voltage' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
ret = pxa_cpufreq_change_voltage(&pxa_freq_settings[idx]);
drivers/cpufreq/pxa2xx-cpufreq.c:205:12: note: expected 'struct pxa_freqs *' but argument is of type 'const struct pxa_freqs *'
static int pxa_cpufreq_change_voltage(struct pxa_freqs *pxa_freq)
This changes the prototype in the same way as the other, which
avoids the warning.
Fixes: 03c229906311 (cpufreq: pxa: make pxa_freqs arrays const)
pxa255_run_freqs and pxa255_turbo_freqs are only read.
This patch updates arrays declaration, find_freq_tables()
and its callsites.
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
typedef is not really useful here. Replace it by structure
to improve readability. typedef should only be used in some cases.
(See Documentation/CodingStyle Chapter 5 for details).
cpufreq_generic_exit() is empty now and can be deleted.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Sometimes boot loaders set CPU frequency to a value outside of frequency table
present with cpufreq core. In such cases CPU might be unstable if it has to run
on that frequency for long duration of time and so its better to set it to a
frequency which is specified in frequency table.
On some systems we can't really say what frequency we're running at the moment
and so for these we shouldn't check if we are running at a frequency present in
frequency table. And so we really can't force this for all the cpufreq drivers.
Hence we are created another flag here: CPUFREQ_NEED_INITIAL_FREQ_CHECK that
will be marked by platforms which want to go for this check at boot time.
Initially this is done for all ARM platforms but others may follow if required.
Most of the drivers do following in their ->target_index() routines:
struct cpufreq_freqs freqs;
freqs.old = old freq...
freqs.new = new freq...
cpufreq_notify_transition(policy, &freqs, CPUFREQ_PRECHANGE);
/* Change rate here */
cpufreq_notify_transition(policy, &freqs, CPUFREQ_POSTCHANGE);
This is replicated over all cpufreq drivers today and there doesn't exists a
good enough reason why this shouldn't be moved to cpufreq core instead.
There are few special cases though, like exynos5440, which doesn't do everything
on the call to ->target_index() routine and call some kind of bottom halves for
doing this work, work/tasklet/etc..
They may continue doing notification from their own code as flag:
CPUFREQ_ASYNC_NOTIFICATION is already set for them.
All drivers are also modified in this patch to avoid breaking 'git bisect', as
double notification would happen otherwise.
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <linux@arm.linux.org.uk>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Lan Tianyu <tianyu.lan@intel.com>
Currently, the prototype of cpufreq_drivers target routines is:
int target(struct cpufreq_policy *policy, unsigned int target_freq,
unsigned int relation);
And most of the drivers call cpufreq_frequency_table_target() to get a valid
index of their frequency table which is closest to the target_freq. And they
don't use target_freq and relation after that.
So, it makes sense to just do this work in cpufreq core before calling
cpufreq_frequency_table_target() and simply pass index instead. But this can be
done only with drivers which expose their frequency table with cpufreq core. For
others we need to stick with the old prototype of target() until those drivers
are converted to expose frequency tables.
This patch implements the new light weight prototype for target_index() routine.
It looks like this:
int target_index(struct cpufreq_policy *policy, unsigned int index);
CPUFreq core will call cpufreq_frequency_table_target() before calling this
routine and pass index to it. Because CPUFreq core now requires to call routines
present in freq_table.c CONFIG_CPU_FREQ_TABLE must be enabled all the time.
This also marks target() interface as deprecated. So, that new drivers avoid
using it. And Documentation is updated accordingly.
It also converts existing .target() to newly defined light weight
.target_index() routine for many driver.
Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Many common initializations of struct policy are moved to core now and hence
this driver doesn't need to do it. This patch removes such code.
Most recent of those changes is to call ->get() in the core after calling
->init().
Cc: Eric Miao <eric.y.miao@gmail.com>
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines
and .attr. So its better if we have generic routines for them which can be used
by cpufreq drivers then.
This patch uses these generic routines in the PXA driver.
Lets use cpufreq_table_validate_and_show() instead of calling
cpufreq_frequency_table_cpuinfo() and cpufreq_frequency_table_get_attr().
This exposes frequency table of driver to cpufreq core and is required for core
to guess what the index for a target frequency is, when it calls
cpufreq_frequency_table_target(). And so this driver needs to expose it.
__init belongs after the return type on functions, not before it.
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
The "index" field of struct cpufreq_frequency_table was never an
index and isn't used at all by the cpufreq core. It only is useful
for cpufreq drivers for their internal purposes.
Many people nowadays blindly set it in ascending order with the
assumption that the core will use it, which is a mistake.
Rename it to "driver_data" as that's what its purpose is. All of its
users are updated accordingly.
[rjw: Changelog]
Acked-by: Simon Horman <horms+renesas@verge.net.au>
gcc-3.8 correctly found that the variables set by find_freq_tables()
are not initialized if this function is called on something other
than a pxa2xx or pxa3xx:
pxa2xx-cpufreq.c: In function 'pxa_verify_policy':
pxa2xx-cpufreq.c:272:6: warning: 'pxa_freqs_table' may be used uninitialized in this function [-Wmaybe-uninitialized]
pxa2xx-cpufreq.c:345:23: warning: 'pxa_freq_settings' may be used uninitialized in this function [-Wmaybe-uninitialized]
Rather than adding a bogus initialization that would let us
get a little further before crashing, add an explicit BUG().
We know that this code is designed to run on only these cpus,
so this will fix the build warning and give a more helpful
diagnostic if the code ever changes to run on other machines.
This patch moves cpufreq driver of ARM based pxa2xx platform to drivers/cpufreq.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
