path: root/drivers/cpufreq
2011-07-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (135 commits) drm/radeon/kms: fix DP training for DPEncoderService revision bigger than 1.1 drm/radeon/kms: add missing vddci setting on NI+ drm/radeon: Add a rmb() in IH processing drm/radeon: ATOM Endian fix for atombios_crtc_program_pll() drm/radeon: Fix the definition of RADEON_BUF_SWAP_32BIT drm/radeon: Do an MMIO read on interrupts when not uisng MSIs drm/radeon: Writeback endian fixes drm/radeon: Remove a bunch of useless _iomem casts drm/gem: add support for private objects DRM: clean up and document parsing of video= parameter DRM: Radeon: Fix section mismatch. drm: really make debug levels match in edid failure code drm/radeon/kms: fix i2c map for rv250/280 drm/nouveau/gr: disable fifo access and idle before suspend ctx unload drm/nouveau: pass flag to engine fini() method on suspend drm/nouveau: replace nv04_graph_fifo_access() use with direct reg bashing drm/nv40/gr: rewrite/split context takedown functions drm/nouveau: detect disabled device in irq handler and return IRQ_NONE drm/nouveau: ignore connector type when deciding digital/analog on DVI-I drm/nouveau: Add a quirk for Gigabyte NX86T ...
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-19powerpc/cpufreq: Add cpufreq driver for Momentum Maple boardsDmitry Eremin-Solenikov
Add simple cpufreq driver for Maple-based boards (ppc970fx evaluation kit and others). Driver is based on a cpufreq driver for 64-bit powermac boxes with all pmac-dependant features removed and simple cleanup applied. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-14Merge branch 'drm-intel-next' of ↵Dave Airlie
ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 into drm-core-next * 'drm-intel-next' of ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: (52 commits) drm/i915: provide module parameter description drm/i915: add module parameter compiler hints drm/i915/bios: Avoid temporary allocation whilst searching for downclock drm/i915: Cache GT fifo count for SandyBridge i915: Fix opregion notifications drm/i915: TVDAC_STATE_CHG does not indicate successful load-detect drm/i915: Select correct pipe during TV detect drm/i915/ringbuffer: Idling requires waiting for the ring to be empty Revert "drm/i915: enable rc6 by default" drm/i915: Clean up i915_driver_load failure path drm/i915: Enable i915 frame buffer compression by default drm/i915: Share the common work of disabling active FBC before updating drm/i915: Perform intel_enable_fbc() from a delayed task drm/i915: Disable FBC across page-flipping drm/i915: Set persistent-mode for ILK/SNB framebuffer compression drm/i915: Use of a CPU fence is mandatory to update FBC regions upon CPU writes drm/i915: Remove vestigial pitch from post-gen2 FBC control routines drm/i915: Replace direct calls to vfunc.disable_fbc with intel_disable_fbc() drm/i915: Only export the generic intel_disable_fbc() interface drm/i915: Enable GPU reset on Ivybridge. ...
2011-07-13[CPUFREQ] s5pv210: make needlessly global symbols staticAxel Lin
The following symbols are needlessly defined global: s5pv210_verify_speed s5pv210_getspeed Make them static. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] exynos4210: make needlessly global symbols staticAxel Lin
The following symbols are needlessly defined global: exynos4_verify_speed exynos4_getspeed exynos4_set_clkdiv Make them static. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S3C6410: Add some lower frequencies for 800MHz base clock operationMark Brown
By extension from the 667MHz based clocks currently supported add 100MHz and 200MHz operating points. Due to a lack of documentation these have not been confirmed as supported but by extension from the existing frequencies they should be OK, and I've given them quite a bit of runtime testing. The major risk is synchronization with the non-ARM clocks but as we can't currently scale the ARM PLL the risk should be relatively low. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S5PV210: Add reboot notifier to prevent system hangHuisung Kang
When system reboot, the CPUFREQ level should be 800MHz to prevent system lockup. Signed-off-by: Huisung Kang <hs1218.kang@samsung.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S5PV210: Adjust udelay prior to voltage scaling downTodd Poynor
Voltage scaling accesses the MAX8998 regulators over bit-banged I2C with lots of udelays. In the case of decreasing CPU speed, the number of loops per us for udelay needs to be adjusted prior to decreasing voltage to avoid delaying for up to 10X too long. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S5PV210: Lock a mutex while changing the cpu frequencyArve Hjønnevåg
Without this lock the call to change the frequency for suspend could switch to a new frequency while another thread was still changing the cpu voltage. Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S5PV210: Add pm_notifier to prevent system unstableHuisung Kang
Minimum 800MHz is needed to enter/exit suspend mode due to voltage mismatch. Signed-off-by: Huisung Kang <hs1218.kang@samsung.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S5PV210: Add arm/int voltage control supportJonghwan Choi
2011-07-13[CPUFREQ] S5PV210: Add additional symantics for "relation" in cpufreq with pmHuisung Kang
Relation has an additional symantics other than standard. s5pv310_target funtion have below additional relation. - DISABLE_FURTHER_CPUFREQ : disable further access to target - ENABLE_FURTHER_CPUFRER : enable access to target Signed-off-by: Huisung Kang <hs1218.kang@samsung.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S3C64xx: Notify transition complete as soon as frequency changedMark Brown
The CPUFREQ_POSTCHANGE notification is used to update things that depend on the system clock rates. Since this may include the interfaces used to talk to the regulators do the notification before we try to update regulators to reflect lowered system clock rate. The voltage scaling is just a power optimisation and may not happen at all so there's no concern about it not having completed. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] S3C6410: Support 800MHz operation in cpufreqMark Brown
At least some newer S3C6410 silicon supports operation up to 800MHz rather than just 667MHz. Unfortunately I don't have access to any of documentation of this other than some running systems, add a new cpufreq table entry for this based on the behaviour of those systems. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] s5pv210-cpufreq.c: Add missing clk_putJulia Lawall
The successive calls to clk_get each call clk_put in the case of failure, but this is not done for subsequent error handling code. The calls to clk_get are moved to the end of the function, and appropriate gotos are added. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreqKukjin Kim
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] Remove some vi noise that escaped into the Makefile.Dave Jones
2011-07-13[CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/Kukjin Kim
According to discussion of the ARM arch subsystem migration, ARM cpufreq drivers move to drivers/cpufreq. So this patch adds Kconfig.arm for ARM like x86 and adds Samsung S5PV210 and EXYNOS4210 cpufreq driver compile in there. As a note, otherw will be moved. Cc: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ/S3C64xx] Move S3C64xx CPUfreq driver into drivers/cpufreqMark Brown
This is a straight code motion patch, there are no changes to the driver itself. The Kconfig is left untouched as the ARM CPUfreq Kconfig is all in one big block in arm/Kconfig and should be moved en masse rather than being done piecemeal. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] Handle CPUs with different capabilities in acpi-cpufreqMatthew Garrett
acpi-cpufreq checks each CPU for aperf/mperf support, but only sets a global flag. This will cause errors if some CPUs in the system don't support the feature. Check boot_cpu_has() instead in order to make sure that all CPUs support it. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-10[CPUFREQ] fix cpumask memory leak in acpi-cpufreq on cpu hotplug.Luming Yu
I came across a memory leak during a cyclic cpu-online-offline test. Signed-off-by: Yu Luming <luming.yu@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-28cpufreq: expose a cpufreq_quick_get_max routineJesse Barnes
This allows drivers and other code to get the max reported CPU frequency. Initial use is for scaling ring frequency with GPU frequency in the i915 driver. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-16[CPUFREQ] powernow-k8: Don't try to transition if the pstate is incorrectKonrad Rzeszutek Wilk
This patch augments the pstate transition code to error out (instead of returning 0) when an incorrect pstate is provided. Suggested-by: Borislav Petkov <bp@alien8.de> CC: andre.przywara@amd.com CC: Mark.Langsdorf@amd.com Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-16[CPUFREQ] powernow-k8: Don't notify of successful transition if we failed ↵Konrad Rzeszutek Wilk
(vid case). Before this patch if we failed the vid transition would still try to submit the "new" frequencies to cpufreq. That is incorrect - also we could submit a non-existing frequency value which would cause cpufreq to crash. The ultimate fix is in cpufreq to deal with incorrect values, but this patch improves the error recovery in the AMD powernowk8 driver. The failure that was reported was as follows: powernow-k8: Found 1 AMD Athlon(tm) 64 Processor 3700+ (1 cpu cores) (version 2.20.00) powernow-k8: fid 0x2 (1000 MHz), vid 0x12 powernow-k8: fid 0xa (1800 MHz), vid 0xa powernow-k8: fid 0xc (2000 MHz), vid 0x8 powernow-k8: fid 0xe (2200 MHz), vid 0x8 Marking TSC unstable due to cpufreq changes powernow-k8: fid trans failed, fid 0x2, curr 0x0 BUG: unable to handle kernel paging request at ffff880807e07b78 IP: [<ffffffff81479163>] cpufreq_stats_update+0x46/0x5b ... And transition fails and data->currfid ends up with 0. Since the machine does not support 800Mhz value when the calculation is done ('find_khz_freq_from_fid(data->currfid);') it reports the new frequency as 800000 which is bogus. This patch fixes the issue during target setting. The patch however does not fix the issue in 'powernowk8_cpu_init' where the pol->cur can also be set with the 800000 value: pol->cur = find_khz_freq_from_fid(data->currfid); dprintk("policy current frequency %d kHz\n", pol->cur); /* min/max the cpu is capable of */ if (cpufreq_frequency_table_cpuinfo(pol, data->powernow_table)) { The fix for that looks to update cpufreq_frequency_table_cpuinfo to check pol->cur.... but that would cause an regression in how the acpi-cpufreq driver works (it sets cpu->cur after calling cpufreq_frequency_table_cpuinfo). Instead the fix will be to let cpufreq gracefully handle bogus data (another patch). Acked-by: Borislav Petkov <bp@alien8.de> CC: andre.przywara@amd.com CC: Mark.Langsdorf@amd.com Reported-by: Tobias Diedrich <ranma+xen@tdiedrich.de> Tested-by: Tobias Diedrich <ranma+xen@tdiedrich.de> [v1: Rebased on v3.0-rc2, reduced patch to deal with vid case] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-16[CPUFREQ] Don't set stat->last_index to -1 if the pol->cur has incorrect value.Konrad Rzeszutek Wilk
If the driver submitted an non-existing pol>cur value (say it used the default initialized value of zero), when the cpufreq stats tries to setup its initial values it incorrectly sets stat->last_index to -1 (or 0xfffff...). And cpufreq_stats_update tries to update at that index location and fails. This can be caused by: stat->last_index = freq_table_get_index(stat, policy->cur); not finding the appropiate frequency in the table (b/c the policy->cur is wrong) and we end up crashing. The fix however is concentrated in the 'cpufreq_stats_update' as the last_index (and old_index) are updated there. Which means it can reset the last_index to -1 again and on the next iteration cause a crash. Without this patch, the following crash is observed: powernow-k8: Found 1 AMD Athlon(tm) 64 Processor 3700+ (1 cpu cores) (version 2.20.00) powernow-k8: fid 0x2 (1000 MHz), vid 0x12 powernow-k8: fid 0xa (1800 MHz), vid 0xa powernow-k8: fid 0xc (2000 MHz), vid 0x8 powernow-k8: fid 0xe (2200 MHz), vid 0x8 Marking TSC unstable due to cpufreq changes powernow-k8: fid trans failed, fid 0x2, curr 0x0 BUG: unable to handle kernel paging request at ffff880807e07b78 IP: [<ffffffff81479163>] cpufreq_stats_update+0x46/0x5b .. snip.. Pid: 1, comm: swapper Not tainted 3.0.0-rc2 #45 MICRO-STAR INTERNATIONAL CO., LTD MS-7094/MS-7094 ..snip.. Call Trace: [<ffffffff81479248>] cpufreq_stat_notifier_trans+0x48/0x7c [<ffffffff81095d68>] notifier_call_chain+0x32/0x5e [<ffffffff81095e6b>] __srcu_notifier_call_chain+0x47/0x63 [<ffffffff81095e96>] srcu_notifier_call_chain+0xf/0x11 [<ffffffff81477e7a>] cpufreq_notify_transition+0x111/0x134 [<ffffffff8147b0d4>] powernowk8_target+0x53b/0x617 [<ffffffff8147723a>] __cpufreq_driver_target+0x2e/0x30 [<ffffffff8147a127>] cpufreq_governor_dbs+0x339/0x356 [<ffffffff81477394>] __cpufreq_governor+0xa8/0xe9 [<ffffffff81477525>] __cpufreq_set_policy+0x132/0x13e [<ffffffff8147848d>] cpufreq_add_dev_interface+0x272/0x28c Reported-by: Tobias Diedrich <ranma+xen@tdiedrich.de> Tested-by: Tobias Diedrich <ranma+xen@tdiedrich.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-12[CPUFREQ] Remove cpufreq_stats sysfs entries on module unload.Dave Jones
cpufreq_stats leaves behind its sysfs entries, which causes a panic when something stumbled across them. (Discovered by unloading cpufreq_stats while powertop was loaded). Signed-off-by: Dave Jones <davej@redhat.com> Cc: stable@kernel.org
2011-05-24cpufreq: make DB8500 cpufreq driver compileLinus Walleij
Concluding interface update and movement of the driver by making the DB8500 cpufreq driver compile in the cpufreq subsystem. Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-05-24cpufreq: update DB8500 cpufreq driverLinus Walleij
This updates the ux500 cpufreq driver to the new interface from the updated DB8500 PRCMU Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-05-24mach-ux500: move CPUfreq driver to cpufreq subsystemLinus Walleij
As part of the ARM arch subsystem migration, move the DB8500 cpufreq driver to drivers/cpufreq as discussed with Dave Jones. The Makefile is not updated in order to avoid cross-subsystem conflicts for this file in merges. Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-05-19Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, cpu: Fix detection of Celeron Covington stepping A1 and B0 Documentation, ABI: Update L3 cache index disable text x86, AMD, cacheinfo: Fix L3 cache index disable checks x86, AMD, cacheinfo: Fix fallout caused by max3 conversion x86, cpu: Change NOP selection for certain Intel CPUs x86, cpu: Clean up and unify the NOP selection infrastructure x86, percpu: Use ASM_NOP4 instead of hardcoding P6_NOP4 x86, cpu: Move AMD Elan Kconfig under "Processor family" Fix up trivial conflicts in alternative handling (commit dc326fca2b64 "x86, cpu: Clean up and unify the NOP selection infrastructure" removed some hacky 5-byte instruction stuff, while commit d430d3d7e646 "jump label: Introduce static_branch() interface" renamed HAVE_JUMP_LABEL to CONFIG_JUMP_LABEL in the code that went away)
2011-05-19[CPUFREQ] Move x86 drivers to drivers/cpufreq/Dave Jones
2011-05-04[CPUFREQ] remove redundant sprintf from request_module call.Kees Cook
Since format string handling is part of request_module, there is no need to construct the module name. As such, drop the redundant sprintf and heap usage. Signed-off-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-04[CPUFREQ] cpufreq_stats.c: Fixed brace coding style issueKarthigan Srinivasan
Fixed brace coding style issue. Signed-off-by: Karthigan Srinivasan <karthigan.srinivasan@hp.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-04[CPUFREQ] Fix memory leak in cpufreq_statsteven finney
When a CPU is taken offline in an SMP system, cpufreq_remove_dev() nulls out the per-cpu policy before cpufreq_stats_free_table() can make use of it. cpufreq_stats_free_table() then skips the call to sysfs_remove_group(), leaving about 100 bytes of sysfs-related memory unclaimed each time a CPU-removal occurs. Break up cpu_stats_free_table into sysfs and table portions, and call the sysfs portion early. Signed-off-by: Steven Finney <steven.finney@palm.com> Signed-off-by: Dave Jones <davej@redhat.com> Cc: stable@kernel.org
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-04[CPUFREQ] CPU hotplug, re-create sysfs directory and symlinksJacob Shin
When we discover CPUs that are affected by each other's frequency/voltage transitions, the first CPU gets a sysfs directory created, and rest of the siblings get symlinks. Currently, when we hotplug off only the first CPU, all of the symlinks and the sysfs directory gets removed. Even though rest of the siblings are still online and functional, they are orphaned, and no longer governed by cpufreq. This patch, given the above scenario, creates a sysfs directory for the first sibling and symlinks for the rest of the siblings. Please note the recursive call, it was rather too ugly to roll it out. And the removal of redundant NULL setting (it is already taken care of near the top of the function). Signed-off-by: Jacob Shin <jacob.shin@amd.com> Acked-by: Mark Langsdorf <mark.langsdorf@amd.com> Reviewed-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com> Cc: stable@kernel.org
2011-03-23cpufreq: Use syscore_ops for boot CPU suspend/resume (v2)Rafael J. Wysocki
The cpufreq subsystem uses sysdev suspend and resume for executing cpufreq_suspend() and cpufreq_resume(), respectively, during system suspend, after interrupts have been switched off on the boot CPU, and during system resume, while interrupts are still off on the boot CPU. In both cases the other CPUs are off-line at the relevant point (either they have been switched off via CPU hotplug during suspend, or they haven't been switched on yet during resume). For this reason, although it may seem that cpufreq_suspend() and cpufreq_resume() are executed for all CPUs in the system, they are only called for the boot CPU in fact, which is quite confusing. To remove the confusion and to prepare for elimiating sysdev suspend and resume operations from the kernel enirely, convernt cpufreq to using a struct syscore_ops object for the boot CPU suspend and resume and rename the callbacks so that their names reflect their purpose. In addition, put some explanatory remarks into their kerneldoc comments. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-16[CPUFREQ] Remove the pm_message_t argument from driver suspendRafael J. Wysocki
None of the existing cpufreq drivers uses the second argument of its .suspend() callback (which isn't useful anyway), so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-16[CPUFREQ] Remove unneeded locksThomas Renninger
There cannot be any concurrent access to these through different cpu sysfs files anymore, because these tunables are now all global (not per cpu). I still have some doubts whether some of these locks were needed at all. Anyway, let's get rid of them. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com> CC: cpufreq@vger.kernel.org
2011-03-16[CPUFREQ] Remove old, deprecated per cpu ondemand/conservative sysfs filesThomas Renninger
Marked deprecated for quite a whilte now... Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com> CC: cpufreq@vger.kernel.org
2011-03-16[CPUFREQ] Remove deprecated sysfs file sampling_rate_maxThomas Renninger
Marked deprecated for quite a while now... Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com> CC: cpufreq@vger.kernel.org
2011-03-16[CPUFREQ] calculate delay after dbs_check_cpuVincent Guittot
calculate ondemand delay after dbs_check_cpu call because it can modify rate_mult value use freq_lo_jiffies value for the sub sample period of powersave_bias mode Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-16[CPUFREQ] drivers/cpufreq: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-01[CPUFREQ] fix BUG on cpufreq policy init failureJiri Slaby
cpufreq_register_driver sets cpufreq_driver to a structure owned (and placed) in the caller's memory. If cpufreq policy fails in its ->init function, sysdev_driver_register returns nonzero in cpufreq_register_driver. Now, cpufreq_register_driver returns an error without setting cpufreq_driver back to NULL. Usually cpufreq policy modules are unloaded because they propagate the error to the module init function and return that. So a later access to any member of cpufreq_driver causes bugs like: BUG: unable to handle kernel paging request at ffffffffa00270a0 IP: [<ffffffff8145eca3>] cpufreq_cpu_get+0x53/0xe0 PGD 1805067 PUD 1809063 PMD 1c3f90067 PTE 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/net/tun0/statistics/collisions CPU 0 Modules linked in: ... Pid: 5677, comm: thunderbird-bin Tainted: G W 2.6.38-rc4-mm1_64+ #1389 To be filled by O.E.M./To Be Filled By O.E.M. RIP: 0010:[<ffffffff8145eca3>] [<ffffffff8145eca3>] cpufreq_cpu_get+0x53/0xe0 RSP: 0018:ffff8801aec37d98 EFLAGS: 00010086 RAX: 0000000000000202 RBX: 0000000000000000 RCX: 0000000000000001 RDX: ffffffffa00270a0 RSI: 0000000000001000 RDI: ffffffff8199ece8 ... Call Trace: [<ffffffff8145f490>] cpufreq_quick_get+0x10/0x30 [<ffffffff8103f12b>] show_cpuinfo+0x2ab/0x300 [<ffffffff81136292>] seq_read+0xf2/0x3f0 [<ffffffff8126c5d3>] ? __strncpy_from_user+0x33/0x60 [<ffffffff8116850d>] proc_reg_read+0x6d/0xa0 [<ffffffff81116e53>] vfs_read+0xc3/0x180 [<ffffffff81116f5c>] sys_read+0x4c/0x90 [<ffffffff81030dbb>] system_call_fastpath+0x16/0x1b ... It's all cause by weird fail path handling in cpufreq_register_driver. To fix that, shuffle the code to do proper handling with gotos. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Dave Jones <davej@redhat.com>
2011-01-26cpufreq: use system_wq instead of dedicated workqueuesTejun Heo
With cmwq, there's no reason for cpufreq drivers to use separate workqueues. Remove the dedicated workqueues from cpufreq_conservative and cpufreq_ondemand and use system_wq instead. The work items are already sync canceled on stop, so it's already guaranteed that no work is running on module exit. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Dave Jones <davej@redhat.com> Cc: cpufreq@vger.kernel.org
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-04perf: Clean up power events by introducing new, more generic onesThomas Renninger
Add these new power trace events: power:cpu_idle power:cpu_frequency power:machine_suspend The old C-state/idle accounting events: power:power_start power:power_end Have now a replacement (but we are still keeping the old tracepoints for compatibility): power:cpu_idle and power:power_frequency is replaced with: power:cpu_frequency power:machine_suspend is newly introduced. Jean Pihet has a patch integrated into the generic layer (kernel/power/suspend.c) which will make use of it. the type= field got removed from both, it was never used and the type is differed by the event type itself. perf timechart userspace tool gets adjusted in a separate patch. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Jean Pihet <jean.pihet@newoldbits.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: rjw@sisk.pl LKML-Reference: <1294073445-14812-3-git-send-email-trenn@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1290072314-31155-2-git-send-email-trenn@suse.de>
