commit 3836785a1bdcd6706c68ad46bf53adc0b057b310 upstream.
If there is a PM QoS latency limit and all of the sufficiently shallow
C-states are disabled, the cpuidle menu governor returns 0 which on
some systems is CPUIDLE_DRIVER_STATE_START and shouldn't be returned
if that C-state has been disabled.
Fix the issue by modifying the menu governor to return (-1) in such
situations.
[shilpab: Backport to 3.10.y
- adjust context
- add a check if 'next_state' is less than 0 in 'cpuidle_idle_call()',
this ensures that we exit 'cpuidle_idle_call()' if governor->select()
returns negative value]
Signed-off-by: Shilpasri G Bhat <shilpa.bhat@linux.vnet.ibm.com>
commit d75e4af14e228bbe3f86e29bcecb8e6be98d4e04 upstream.
Thomas Schlichter reports the following issue on his Samsung NC20:
"The C-states C1 and C2 to the OS when connected to AC, and additionally
provides the C3 C-state when disconnected from AC. However, the number
of C-states shown in sysfs is fixed to the number of C-states present
at boot.
If I boot with AC connected, I always only see the C-states up to C2
even if I disconnect AC.
The reason is commit 130a5f692425 (ACPI / cpuidle: remove dev->state_count
setting). It removes the update of dev->state_count, but sysfs uses
exactly this variable to show the C-states.
The fix is to use drv->state_count in sysfs. As this is currently the
last user of dev->state_count, this variable can be completely removed."
Remove dev->state_count as per the above.
Reported-by: Thomas Schlichter <thomas.schlichter@web.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
[ rjw: Changelog ]
If not, we could end up in the unfortunate situation where
we dereference a NULL pointer b/c we have cpuidle disabled.
This is the case when booting under Xen (which uses the
ACPI P/C states but disables the CPU idle driver) - and can
be easily reproduced when booting with cpuidle.off=1.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8156db4a>] cpuidle_unregister_device+0x2a/0x90
.. snip..
Call Trace:
[<ffffffff813b15b4>] acpi_processor_power_exit+0x3c/0x5c
[<ffffffff813af0a9>] acpi_processor_stop+0x61/0xb6
[<ffffffff814215bf>] __device_release_driver+0fffff81421653>] device_release_driver+0x23/0x30
[<ffffffff81420ed8>] bus_remove_device+0x108/0x180
[<ffffffff8141d9d9>] device_del+0x129/0x1c0
[<ffffffff813cb4b0>] ? unregister_xenbus_watch+0x1f0/0x1f0
[<ffffffff8141da8e>] device_unregister+0x1e/0x60
[<ffffffff814243e9>] unregister_cpu+0x39/0x60
[<ffffffff81019e03>] arch_unregister_cpu+0x23/0x30
[<ffffffff813c3c51>] handle_vcpu_hotplug_event+0xc1/0xe0
[<ffffffff813cb4f5>] xenwatch_thread+0x45/0x120
[<ffffffff810af010>] ? abort_exclusive_wait+0xb0/0xb0
[<ffffffff8108ec42>] kthread+0xd2/0xf0
[<ffffffff8108eb70>] ? kthread_create_on_node+0x180/0x180
[<ffffffff816ce17c>] ret_from_fork+0x7c/0xb0
This problem also appears in 3.12 and could be a candidate for backport.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: All applicable <stable@vger.kernel.org>
poll_idle_init() just initializes drv->states[0] and so that is
required to be done only once for each driver. Currently, it is
called from cpuidle_enable_device() which is called for every CPU
that the driver supports. That is not required, so move it to a
better place and call it from __cpuidle_register_driver() so that
the initialization is carried out only once.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Few statements in cpuidle_idle_call() are broken into multiple lines,
although that isn't really necessary. Convert those to single line.
We are doing this twice in cpuidle_idle_call() routine:
drv->states[next_state].flags & CPUIDLE_FLAG_TIMER_STOP
Would be better if we actually store this in a local variable and
use that. That reduces code duplication and likely makes this piece
of code run faster (in case the compiler wasn't able to optimize it
earlier)
[rjw: Cast the result of bitwise AND to bool explicitly using !!]
Two checks cpuidle_idle_call() cause the same error code to be
returned if they fail, so merge them for clarity.
[rjw: Changelog]
This patch rearranges __cpuidle_register_device() a bit in order to
reduce the number of exit points in that function.
The only value returned by __cpuidle_device_init() is 0, so it very
well may be a void function. Make that happen.
[rjw: Changelog]
Some comments in cpuidle core files contain trivial mistakes.
This patch fixes them.
Make __cpuidle_register_device() check whether or not the device has
been registered already and return -EBUSY immediately if that's the
case.
[rjw: Changelog]
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Add __cpuidle_device_init() for initializing the cpuidle_device
structure.
[rjw: Changelog]
To reduce code duplication related to the unregistration of cpuidle
devices, introduce __cpuidle_unregister_device() and move all of the
unregistration code to that function.
[rjw: Changelog]
We previously changed the ordering of the cpuidle framework
initialization so that the governors are registered before the
drivers which can register their devices right from the start.
Now, we can safely remove the __cpuidle_register_device() call hack
in cpuidle_enable_device() and check if the driver has been
registered before enabling it. Then, cpuidle_register_device() can
consistently check the cpuidle_enable_device() return value when
enabling the device.
[rjw: Changelog]
Commit bf4d1b5 (cpuidle: support multiple drivers) introduced support
for using multiple cpuidle drivers at the same time. It added a
couple of new APIs to register the driver per CPU, but that led to
some unnecessary code complexity related to the kernel config options
deciding whether or not the multiple driver support is enabled. The
code has to work as it did before when the multiple driver support is
not enabled and the multiple driver support has to be compatible with
the previously existing API.
Remove the new API, not used by any driver in the tree yet (but
needed for the HMP cpuidle drivers that will be submitted soon), and
add a new cpumask pointer to the cpuidle driver structure that will
point to the mask of CPUs handled by the given driver. That will
allow the cpuidle_[un]register_driver() API to be used for the
multiple driver support along with the cpuidle_[un]register()
functions added recently.
[rjw: Changelog]
Fix comment format for the kernel doc script.
The usual scheme to initialize a cpuidle driver on a SMP is:
cpuidle_register_driver(drv);
for_each_possible_cpu(cpu) {
device = &per_cpu(cpuidle_dev, cpu);
cpuidle_register_device(device);
This code is duplicated in each cpuidle driver.
On UP systems, it is done this way:
On UP, the macro 'for_each_cpu' does one iteration:
#define for_each_cpu(cpu, mask) \
for ((cpu) = 0; (cpu) < 1; (cpu)++, (void)mask)
Hence, the initialization loop is the same for UP than SMP.
Beside, we saw different bugs / mis-initialization / return code unchecked in
the different drivers, the code is duplicated including bugs. After fixing all
these ones, it appears the initialization pattern is the same for everyone.
Please note, some drivers are doing dev->state_count = drv->state_count. This is
not necessary because it is done by the cpuidle_enable_device function in the
cpuidle framework. This is true, until you have the same states for all your
devices. Otherwise, the 'low level' API should be used instead with the specific
initialization for the driver.
Let's add a wrapper function doing this initialization with a cpumask parameter
for the coupled idle states and use it for all the drivers.
That will save a lot of LOC, consolidate the code, and the modifications in the
future could be done in a single place. Another benefit is the consolidation of
the cpuidle_device variable which is now in the cpuidle framework and no longer
spread accross the different arch specific drivers.
The en_core_tk_irqen flag is set in all the cpuidle driver which
means it is not necessary to specify this flag.
Remove the flag and the code related to it.
Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/*
When a cpu enters a deep idle state, the local timers are stopped and
the time framework falls back to the timer device used as a broadcast
timer.
The different cpuidle drivers are calling clockevents_notify ENTER/EXIT
when the idle state stops the local timer.
Add a new flag CPUIDLE_FLAG_TIMER_STOP which can be set by the cpuidle
drivers. If the flag is set, the cpuidle core code takes care of the
notification on behalf of the driver to avoid pointless code duplication.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The text in Documentation said it would be removed in 2.6.41;
the text in the Kconfig said removal in the 3.1 release. Either
way you look at it, we are well past both, so push it off a cliff.
Note that the POWER_CSTATE and the POWER_PSTATE are part of the
legacy tracing API. Remove all tracepoints which use these flags.
As can be seen from context, most already have a trace entry via
trace_cpu_idle anyways.
Also, the cpufreq/cpufreq.c PSTATE one is actually unpaired, as
compared to the CSTATE ones which all have a clear start/stop.
As part of this, the trace_power_frequency also becomes orphaned,
so it too is deleted.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
We realized that the power usage field is never filled and when it
is filled for tegra, the power_specified flag is not set causing all
of these values to be reset when the driver is initialized with
set_power_state().
However, the power_specified flag can be simply removed under the
assumption that the states are always backward sorted, which is the
case with the current code.
This change allows the menu governor select function and the
cpuidle_play_dead() to be simplified. Moreover, the
set_power_states() function can removed as it does not make sense
any more.
Drop the power_specified flag from struct cpuidle_driver and make
the related changes as described above.
As a consequence, this also fixes the bug where on the dynamic
C-states system, the power fields are not initialized.
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=42870
References: https://bugzilla.kernel.org/show_bug.cgi?id=43349
References: https://lkml.org/lkml/2012/10/16/518
Since cpuidle_state.power_usage is a signed value, use INT_MAX (instead
of -1) to init the local copies so that functions that tries to find
cpuidle states with minimum power usage works correctly even if they use
non-negative values.
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Many cpuidle drivers measure their time spent in an idle state by
reading the wallclock time before and after idling and calculating the
difference. This leads to erroneous results when the wallclock time gets
updated by another processor in the meantime, adding that clock
adjustment to the idle state's time counter.
If the clock adjustment was negative, the result is even worse due to an
erroneous cast from int to unsigned long long of the last_residency
variable. The negative 32 bit integer will zero-extend and result in a
forward time jump of roughly four billion milliseconds or 1.3 hours on
the idle state residency counter.
This patch changes all affected cpuidle drivers to either use the
monotonic clock for their measurements or make use of the generic time
measurement wrapper in cpuidle.c, which was already working correctly.
Some superfluous CLIs/STIs in the ACPI code are removed (interrupts
should always already be disabled before entering the idle function, and
not get reenabled until the generic wrapper has performed its second
measurement). It also removes the erroneous cast, making sure that
negative residency values are applied correctly even though they should
not appear anymore.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Len Brown <len.brown@intel.com>
With the tegra3 and the big.LITTLE [1] new architectures, several cpus
with different characteristics (latencies and states) can co-exists on the
system.
The cpuidle framework has the limitation of handling only identical cpus.
This patch removes this limitation by introducing the multiple driver support
for cpuidle.
This option is configurable at compile time and should be enabled for the
architectures mentioned above. So there is no impact for the other platforms
if the option is disabled. The option defaults to 'n'. Note the multiple drivers
support is also compatible with the existing drivers, even if just one driver is
needed, all the cpu will be tied to this driver using an extra small chunk of
processor memory.
The multiple driver support use a per-cpu driver pointer instead of a global
variable and the accessor to this variable are done from a cpu context.
In order to keep the compatibility with the existing drivers, the function
'cpuidle_register_driver' and 'cpuidle_unregister_driver' will register
the specified driver for all the cpus.
The semantic for the output of /sys/devices/system/cpu/cpuidle/current_driver
remains the same except the driver name will be related to the current cpu.
The /sys/devices/system/cpu/cpu[0-9]/cpuidle/driver/name files are added
allowing to read the per cpu driver name.
[1] http://lwn.net/Articles/481055/
Acked-by: Peter De Schrijver <pdeschrijver@nvidia.com>
When cpuidle governor choose a C-state to enter for idle CPU, but it notice that
there is tasks request to be executed. So the idle CPU will not really enter
the target C-state and go to run task.
In this situation, it will use the residency of previous really entered target
C-states. Obviously, it is not reasonable.
So, this patch fix it by set the target C-state residency to 0.
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Youquan Song <youquan.song@intel.com>
Move the kobj initialization and completion in the sysfs.c
and encapsulate the code more.
The function needs the cpuidle_device which is initially passed to the
caller.
The current code gets the struct device from the struct cpuidle_device,
pass it the cpuidle_add_sysfs function. This function calls
per_cpu(cpuidle_devices, cpu) to get the cpuidle_device.
This patch pass the cpuidle_device instead and simplify the code.
On a KVM guest, when a CPU is taken offline and brought back online, we hit
the following NULL pointer dereference:
[ 45.400843] Unregister pv shared memory for cpu 1
[ 45.412331] smpboot: CPU 1 is now offline
[ 45.529894] SMP alternatives: lockdep: fixing up alternatives
[ 45.533472] smpboot: Booting Node 0 Processor 1 APIC 0x1
[ 45.411526] kvm-clock: cpu 1, msr 0:7d14601, secondary cpu clock
[ 45.571370] KVM setup async PF for cpu 1
[ 45.572331] kvm-stealtime: cpu 1, msr 7d0e040
[ 45.575031] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 45.576017] IP: [<ffffffff81519f98>] cpuidle_disable_device+0x18/0x80
[ 45.576017] PGD 5dfb067 PUD 5da8067 PMD 0
[ 45.576017] Oops: 0000 [#1] SMP
[ 45.576017] Modules linked in:
[ 45.576017] CPU 0
[ 45.576017] Pid: 607, comm: stress_cpu_hotp Not tainted 3.6.0-padata-tp-debug #3 Bochs Bochs
[ 45.576017] RIP: 0010:[<ffffffff81519f98>] [<ffffffff81519f98>] cpuidle_disable_device+0x18/0x80
[ 45.576017] RSP: 0018:ffff880005d93ce8 EFLAGS: 00010286
[ 45.576017] RAX: ffff880005d93fd8 RBX: 0000000000000000 RCX: 0000000000000006
[ 45.576017] RDX: 0000000000000006 RSI: 2222222222222222 RDI: 0000000000000000
[ 45.576017] RBP: ffff880005d93cf8 R08: 2222222222222222 R09: 2222222222222222
[ 45.576017] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 45.576017] R13: 0000000000000000 R14: ffffffff81c8cca0 R15: 0000000000000001
[ 45.576017] FS: 00007f91936ae700(0000) GS:ffff880007c00000(0000) knlGS:0000000000000000
[ 45.576017] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 45.576017] CR2: 0000000000000000 CR3: 0000000005db3000 CR4: 00000000000006f0
[ 45.576017] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 45.576017] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 45.576017] Process stress_cpu_hotp (pid: 607, threadinfo ffff880005d92000, task ffff8800066bbf40)
[ 45.576017] Stack:
[ 45.576017] ffff880007a96400 0000000000000000 ffff880005d93d28 ffffffff813ac689
[ 45.576017] ffff880007a96400 ffff880007a96400 0000000000000002 ffffffff81cd8d01
[ 45.576017] ffff880005d93d58 ffffffff813aa498 0000000000000001 00000000ffffffdd
[ 45.576017] Call Trace:
[ 45.576017] [<ffffffff813ac689>] acpi_processor_hotplug+0x55/0x97
[ 45.576017] [<ffffffff813aa498>] acpi_cpu_soft_notify+0x93/0xce
[ 45.576017] [<ffffffff816ae47d>] notifier_call_chain+0x5d/0x110
[ 45.576017] [<ffffffff8109730e>] __raw_notifier_call_chain+0xe/0x10
[ 45.576017] [<ffffffff81069050>] __cpu_notify+0x20/0x40
[ 45.576017] [<ffffffff81069085>] cpu_notify+0x15/0x20
[ 45.576017] [<ffffffff816978f1>] _cpu_up+0xee/0x137
[ 45.576017] [<ffffffff81697983>] cpu_up+0x49/0x59
[ 45.576017] [<ffffffff8168758d>] store_online+0x9d/0xe0
[ 45.576017] [<ffffffff8140a9f8>] dev_attr_store+0x18/0x30
[ 45.576017] [<ffffffff812322c0>] sysfs_write_file+0xe0/0x150
[ 45.576017] [<ffffffff811b389c>] vfs_write+0xac/0x180
[ 45.576017] [<ffffffff811b3be2>] sys_write+0x52/0xa0
[ 45.576017] [<ffffffff816b31e9>] system_call_fastpath+0x16/0x1b
[ 45.576017] Code: 48 c7 c7 40 e5 ca 81 e8 07 d0 18 00 5d c3 0f 1f 44 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 10 48 89 5d f0 4c 89 65 f8 48 89 fb <f6> 07 02 75 13 48 8b 5d f0 4c 8b 65 f8 c9 c3 66 0f 1f 84 00 00
[ 45.576017] RIP [<ffffffff81519f98>] cpuidle_disable_device+0x18/0x80
[ 45.576017] RSP <ffff880005d93ce8>
[ 45.656079] ---[ end trace 433d6c9ac0b02cef ]---
Analysis:
Commit 3d339dc (cpuidle / ACPI : move cpuidle_device field out of the
acpi_processor_power structure()) made the allocation of the dev structure
(struct cpuidle) of a CPU dynamic, whereas previously it was statically
allocated. And this dynamic allocation occurs in acpi_processor_power_init()
if pr->flags.power evaluates to non-zero.
On KVM guests, pr->flags.power evaluates to zero, hence dev is never
allocated. This causes the NULL pointer (dev) dereference in
cpuidle_disable_device() during a subsequent CPU online operation. Fix this
by ensuring that dev is non-NULL before dereferencing.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull ACPI & power management update from Len Brown:
"Re-write of the turbostat tool.
lower overhead was necessary for measuring very large system when
they are very idle.
IVB support in intel_idle
It's what I run on my IVB, others should be able to also:-)
ACPICA core update
We have found some bugs due to divergence between Linux and the
upstream ACPICA base. Most of these patches are to reduce that
divergence to reduce the risk of future bugs.
Some cpuidle updates, mostly for non-Intel
More will be coming, as they depend on this part.
Some thermal management changes needed by non-ACPI systems.
Some _OST (OS Status Indication) updates for hot ACPI hot-plug."
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (51 commits)
Thermal: Documentation update
Thermal: Add Hysteresis attributes
Thermal: Make Thermal trip points writeable
ACPI/AC: prevent OOPS on some boxes due to missing check power_supply_register() return value check
tools/power: turbostat: fix large c1% issue
tools/power: turbostat v2 - re-write for efficiency
ACPICA: Update to version 20120711
ACPICA: AcpiSrc: Fix some translation issues for Linux conversion
ACPICA: Update header files copyrights to 2012
ACPICA: Add new ACPI table load/unload external interfaces
ACPICA: Split file: tbxface.c -> tbxfload.c
ACPICA: Add PCC address space to space ID decode function
ACPICA: Fix some comment fields
ACPICA: Table manager: deploy new firmware error/warning interfaces
ACPICA: Add new interfaces for BIOS(firmware) errors and warnings
ACPICA: Split exception code utilities to a new file, utexcep.c
ACPI: acpi_pad: tune round_robin_time
ACPICA: Update to version 20120620
ACPICA: Add support for implicit notify on multiple devices
ACPICA: Update comments; no functional change
'cpuidle-coupled', 'cpuidle-tweaks', 'intel_idle-ivb', 'ost', 'red-hat-bz-772730', 'thermal', 'thermal-spear' and 'turbostat-v2' into release
* pm-domains:
PM / Domains: Fix build warning for CONFIG_PM_RUNTIME unset
PM / Domains: Replace plain integer with NULL pointer in domain.c file
PM / Domains: Add missing static storage class specifier in domain.c file
PM / Domains: Allow device callbacks to be added at any time
PM / Domains: Add device domain data reference counter
PM / Domains: Add preliminary support for cpuidle, v2
PM / Domains: Do not stop devices after restoring their states
PM / Domains: Use subsystem runtime suspend/resume callbacks by default
On certain bios, resume hangs if cpus are allowed to enter idle states
during suspend [1].
This was fixed in apci idle driver [2].But intel_idle driver does not
have this fix. Thus instead of replicating the fix in both the idle
drivers, or in more platform specific idle drivers if needed, the
more general cpuidle infrastructure could handle this.
A suspend callback in cpuidle_driver could handle this fix. But
a cpuidle_driver provides only basic functionalities like platform idle
state detection capability and mechanisms to support entry and exit
into CPU idle states. All other cpuidle functions are found in the
cpuidle generic infrastructure for good reason that all cpuidle
drivers, irrepective of their platforms will support these functions.
One option therefore would be to register a suspend callback in cpuidle
which handles this fix. This could be called through a PM_SUSPEND_PREPARE
notifier. But this is too generic a notfier for a driver to handle.
Also, ideally the job of cpuidle is not to handle side effects of suspend.
It should expose the interfaces which "handle cpuidle 'during' suspend"
or any other operation, which the subsystems call during that respective
operation.
The fix demands that during suspend, no cpus should be allowed to enter
deep C-states. The interface cpuidle_uninstall_idle_handler() in cpuidle
ensures that. Not just that it also kicks all the cpus which are already
in idle out of their idle states which was being done during cpu hotplug
through a CPU_DYING_FROZEN callbacks.
Now the question arises about when during suspend should
cpuidle_uninstall_idle_handler() be called. Since we are dealing with
drivers it seems best to call this function during dpm_suspend().
Delaying the call till dpm_suspend_noirq() does no harm, as long as it is
before cpu_hotplug_begin() to avoid race conditions with cpu hotpulg
operations. In dpm_suspend_noirq(), it would be wise to place this call
before suspend_device_irqs() to avoid ugly interactions with the same.
Ananlogously, during resume.
References:
[1] https://bugs.launchpad.net/ubuntu/+source/linux/+bug/674075.
[2] http://marc.info/?l=linux-pm&m=133958534231884&w=2
Reported-and-tested-by: Dave Hansen <dave@linux.vnet.ibm.com>
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
On some systems there are CPU cores located in the same power
domains as I/O devices. Then, power can only be removed from the
domain if all I/O devices in it are not in use and the CPU core
is idle. Add preliminary support for that to the generic PM domains
framework.
First, the platform is expected to provide a cpuidle driver with one
extra state designated for use with the generic PM domains code.
This state should be initially disabled and its exit_latency value
should be set to whatever time is needed to bring up the CPU core
itself after restoring power to it, not including the domain's
power on latency. Its .enter() callback should point to a procedure
that will remove power from the domain containing the CPU core at
the end of the CPU power transition.
The remaining characteristics of the extra cpuidle state, referred to
as the "domain" cpuidle state below, (e.g. power usage, target
residency) should be populated in accordance with the properties of
the hardware.
Next, the platform should execute genpd_attach_cpuidle() on the PM
domain containing the CPU core. That will cause the generic PM
domains framework to treat that domain in a special way such that:
* When all devices in the domain have been suspended and it is about
to be turned off, the states of the devices will be saved, but
power will not be removed from the domain. Instead, the "domain"
cpuidle state will be enabled so that power can be removed from
the domain when the CPU core is idle and the state has been chosen
as the target by the cpuidle governor.
* When the first I/O device in the domain is resumed and
__pm_genpd_poweron(() is called for the first time after
power has been removed from the domain, the "domain" cpuidle
state will be disabled to avoid subsequent surprise power removals
via cpuidle.
The effective exit_latency value of the "domain" cpuidle state
depends on the time needed to bring up the CPU core itself after
restoring power to it as well as on the power on latency of the
domain containing the CPU core. Thus the "domain" cpuidle state's
exit_latency has to be recomputed every time the domain's power on
latency is updated, which may happen every time power is restored
to the domain, if the measured power on latency is greater than
the latency stored in the corresponding generic_pm_domain structure.
Reviewed-by: Kevin Hilman <khilman@ti.com>
Andrew J.Schorr raises a question. When he changes the disable setting on
a single CPU, it affects all the other CPUs. Basically, currently, the
disable field is per-driver instead of per-cpu. All the C states of the
same driver are shared by all CPU in the same machine.
The patch changes the `disable' field to per-cpu, so we could set this
separately for each cpu.
Signed-off-by: ShuoX Liu <shuox.liu@intel.com>
Reported-by: Andrew J.Schorr <aschorr@telemetry-investments.com>
Reviewed-by: Yanmin Zhang <yanmin_zhang@intel.com>
On some ARM SMP SoCs (OMAP4460, Tegra 2, and probably more), the
cpus cannot be independently powered down, either due to
sequencing restrictions (on Tegra 2, cpu 0 must be the last to
power down), or due to HW bugs (on OMAP4460, a cpu powering up
will corrupt the gic state unless the other cpu runs a work
around). Each cpu has a power state that it can enter without
coordinating with the other cpu (usually Wait For Interrupt, or
WFI), and one or more "coupled" power states that affect blocks
shared between the cpus (L2 cache, interrupt controller, and
sometimes the whole SoC). Entering a coupled power state must
be tightly controlled on both cpus.
The easiest solution to implementing coupled cpu power states is
to hotplug all but one cpu whenever possible, usually using a
cpufreq governor that looks at cpu load to determine when to
enable the secondary cpus. This causes problems, as hotplug is an
expensive operation, so the number of hotplug transitions must be
minimized, leading to very slow response to loads, often on the
order of seconds.
This file implements an alternative solution, where each cpu will
wait in the WFI state until all cpus are ready to enter a coupled
state, at which point the coupled state function will be called
on all cpus at approximately the same time.
Once all cpus are ready to enter idle, they are woken by an smp
cross call. At this point, there is a chance that one of the
cpus will find work to do, and choose not to enter idle. A
final pass is needed to guarantee that all cpus will call the
power state enter function at the same time. During this pass,
each cpu will increment the ready counter, and continue once the
ready counter matches the number of online coupled cpus. If any
cpu exits idle, the other cpus will decrement their counter and
retry.
To use coupled cpuidle states, a cpuidle driver must:
Set struct cpuidle_device.coupled_cpus to the mask of all
coupled cpus, usually the same as cpu_possible_mask if all cpus
are part of the same cluster. The coupled_cpus mask must be
set in the struct cpuidle_device for each cpu.
Set struct cpuidle_device.safe_state to a state that is not a
coupled state. This is usually WFI.
Set CPUIDLE_FLAG_COUPLED in struct cpuidle_state.flags for each
state that affects multiple cpus.
Provide a struct cpuidle_state.enter function for each state
that affects multiple cpus. This function is guaranteed to be
called on all cpus at approximately the same time. The driver
should ensure that the cpus all abort together if any cpu tries
to abort once the function is called.
update1:
cpuidle: coupled: fix count of online cpus
online_count was never incremented on boot, and was also counting
cpus that were not part of the coupled set. Fix both issues by
introducting a new function that counts online coupled cpus, and
call it from register as well as the hotplug notifier.
update2:
cpuidle: coupled: fix decrementing ready count
cpuidle_coupled_set_not_ready sometimes refuses to decrement the
ready count in order to prevent a race condition. This makes it
unsuitable for use when finished with idle. Add a new function
cpuidle_coupled_set_done that decrements both the ready count and
waiting count, and call it after idle is complete.
Cc: Amit Kucheria <amit.kucheria@linaro.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Trinabh Gupta <g.trinabh@gmail.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Kevin Hilman <khilman@ti.com>
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Fix the error handling in __cpuidle_register_device to include
the missing list_del. Move it to a label, which will simplify
the error handling when coupled states are added.
Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
Split the code to enter a state and update the stats into a helper
function, cpuidle_enter_state, and export it. This function will
be called by the coupled state code to handle entering the safe
state and the final coupled state.
The existing check for dev == NULL in __cpuidle_register_device() is
rendered useless because dev is dereferenced before the check itself.
Moreover, correctly speaking, it is the job of the callers of this
function, i.e., cpuidle_register_device() & cpuidle_enable_device() (which
also happen to be exported functions) to ensure that
__cpuidle_register_device() is called with a non-NULL dev.
So add the necessary dev == NULL checks in the two callers and remove the
(useless) check from __cpuidle_register_device().
commit 9a6558371bcd01c2973b7638181db4ccc34eab4f
Author: Arjan van de Ven <arjan@linux.intel.com>
Date: Sun Nov 9 12:45:10 2008 -0800
regression: disable timer peek-ahead for 2.6.28
It's showing up as regressions; disabling it very likely just papers
over an underlying issue, but time is running out for 2.6.28, lets get
back to this for 2.6.29
Many years has passed since 2008, so it seems ok to remove whole `#if 0' block.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Arjan van de Ven <arjan@infradead.org>
kick_all_cpus_sync() is the core implementation of cpu_idle_wait()
which is copied all over the arch code.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20120507175652.119842173@linutronix.de
Fix a NULL pointer dereference panic in cpuidle_play_dead() during
CPU off-lining when no cpuidle driver is registered. A cpuidle
driver may be registered at boot-time based on CPU type. This patch
allows an off-lined CPU to enter HLT-based idle in this condition.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Boris Ostrovsky <boris.ostrovsky@amd.com>
Tested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Pull ACPI & Power Management changes from Len Brown:
- ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup
- cpuidle evolving, more ARM use
- thermal sub-system evolving, ditto
- assorted other PM bits
Fix up conflicts in various cpuidle implementations due to ARM cpuidle
cleanups (ARM at91 self-refresh and cpu idle code rewritten into
"standby" in asm conflicting with the consolidation of cpuidle time
keeping), trivial SH include file context conflict and RCU tracing fixes
in generic code.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits)
ACPI throttling: fix endian bug in acpi_read_throttling_status()
Disable MCP limit exceeded messages from Intel IPS driver
ACPI video: Don't start video device until its associated input device has been allocated
ACPI video: Harden video bus adding.
ACPI: Add support for exposing BGRT data
ACPI: export acpi_kobj
ACPI: Fix logic for removing mappings in 'acpi_unmap'
CPER failed to handle generic error records with multiple sections
ACPI: Clean redundant codes in scan.c
ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed()
ACPI: consistently use should_use_kmap()
PNPACPI: Fix device ref leaking in acpi_pnp_match
ACPI: Fix use-after-free in acpi_map_lsapic
ACPI: processor_driver: add missing kfree
ACPI, APEI: Fix incorrect APEI register bit width check and usage
Update documentation for parameter *notrigger* in einj.txt
ACPI, APEI, EINJ, new parameter to control trigger action
ACPI, APEI, EINJ, limit the range of einj_param
ACPI, APEI, Fix ERST header length check
cpuidle: power_usage should be declared signed integer
Currently when a CPU is off-lined it enters either MWAIT-based idle or,
if MWAIT is not desired or supported, HLT-based idle (which places the
processor in C1 state). This patch allows processors without MWAIT
support to stay in states deeper than C1.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
If the state_count is not initialized for the device use
the driver's state count as the default. That will prevent
to add it manually in the cpuidle driver initialization
routine and will save us from duplicate line of code.
Some C states of new CPU might be not good. One reason is BIOS might
configure them incorrectly. To help developers root cause it quickly, the
patch adds a new sysfs entry, so developers could disable specific C state
manually.
In addition, C state might have much impact on performance tuning, as it
takes much time to enter/exit C states, which might delay interrupt
processing. With the new debug option, developers could check if a deep C
state could impact performance and how much impact it could cause.
Also add this option in Documentation/cpuidle/sysfs.txt.
[akpm@linux-foundation.org: check kstrtol return value]
Reviewed-and-Tested-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Make necessary changes to implement time keeping and irq enabling
in the core cpuidle code. This will allow the removal of these
functionalities from various platform cpuidle implementations whose
timekeeping and irq enabling follows the form in this common code.
Signed-off-by: Robert Lee <rob.lee@linaro.org>
Tested-by: Jean Pihet <j-pihet@ti.com>
Tested-by: Amit Daniel <amit.kachhap@linaro.org>
Tested-by: Robert Lee <rob.lee@linaro.org>
Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Reviewed-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Acked-by: Jean Pihet <j-pihet@ti.com>
As the tracepoints in the cpuidle code are called when rcu_idle_exit() is in
effect, the _rcuidle() version must be used, otherwise the rcu_read_lock()s
that protect the tracepoint will not be honored.
Cc: Len Brown <len.brown@intel.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem
and converts the devices to regular devices. The sysdev drivers are
implemented as subsystem interfaces now.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Userspace relies on events and generic sysfs subsystem infrastructure
from sysdev devices, which are made available with this conversion.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Borislav Petkov <bp@amd64.org>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Len Brown <lenb@kernel.org>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
cpuidle: Single/Global registration of idle states
cpuidle: Split cpuidle_state structure and move per-cpu statistics fields
cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare()
cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state
ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning
ACPI: Export FADT pm_profile integer value to userspace
thermal: Prevent polling from happening during system suspend
ACPI: Drop ACPI_NO_HARDWARE_INIT
ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast()
PNPACPI: Simplify disabled resource registration
ACPI: Fix possible recursive locking in hwregs.c
ACPI: use kstrdup()
mrst pmu: update comment
tools/power turbostat: less verbose debugging
