path: root/drivers/crypto/caam/key_gen.c
2014-11-06crypto: caam - fix missing dma unmap on error pathCristian Stoica
If dma mapping for dma_addr_out fails, the descriptor memory is freed but the previous dma mapping for dma_addr_in remains. This patch resolves the missing dma unmap and groups resource allocations at function start. Cc: <stable@vger.kernel.org> # 3.13+ Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-05-08crypto: caam - Contain caam_jr_strstatus() uglinessMarek Vasut
The tentacles of this function were firmly attached to various places in the CAAM code. Just cut them, or this cthulhu function will sprout them anew. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-21crypto: caam - replace xstr macro with __stringifyAlex Porosanu
CAAM driver contains one macro (xstr) used for printing the line location in a file where a memdump is done. This patch replaces the xstr macro with the already existing __stringify macro that performs the same function. Signed-off-by: Alex Porosanu <alexandru.porosanu@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: caam - change key gen functions to return signed intKim Phillips
commit 2af8f4a "crypto: caam - coccicheck fixes" added error return values yet neglected to change the type from unsigned. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Optimised AES/SHA1 for ARM. - IPsec ESN support in talitos and caam. - x86_64/avx implementation of cast5/cast6. - Add/use multi-algorithm registration helpers where possible. - Added IBM Power7+ in-Nest support. - Misc fixes. Fix up trivial conflicts in crypto/Kconfig due to the sparc64 crypto config options being added next to the new ARM ones. [ Side note: cut-and-paste duplicate help texts make those conflicts harder to read than necessary, thanks to git being smart about minimizing conflicts and maximizing the common parts... ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits) crypto: x86/glue_helper - fix storing of new IV in CBC encryption crypto: cast5/avx - fix storing of new IV in CBC encryption crypto: tcrypt - add missing tests for camellia and ghash crypto: testmgr - make test_aead also test 'dst != src' code paths crypto: testmgr - make test_skcipher also test 'dst != src' code paths crypto: testmgr - add test vectors for CTR mode IV increasement crypto: testmgr - add test vectors for partial ctr(cast5) and ctr(cast6) crypto: testmgr - allow non-multi page and multi page skcipher tests from same test template crypto: caam - increase TRNG clocks per sample crypto, tcrypt: remove local_bh_disable/enable() around local_irq_disable/enable() crypto: tegra-aes - fix error return code crypto: crypto4xx - fix error return code crypto: hifn_795x - fix error return code crypto: ux500 - fix error return code crypto: caam - fix error IDs for SEC v5.x RNG4 hwrng: mxc-rnga - Access data via structure hwrng: mxc-rnga - Adapt clocks to new i.mx clock framework crypto: caam - add IPsec ESN support crypto: 842 - remove .cra_list initialization Revert "[CRYPTO] cast6: inline bloat--" ...
2012-09-07crypto: caam - coccicheck fixesKim Phillips
use true/false for bool, fix code alignment, and fix two allocs with no test. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07crypto/caam: Export gen_split_key symbol for other modulesBen Collins
In 3.6-rc3, without this patch, the following error occurs with a modular build: ERROR: "gen_split_key" [drivers/crypto/caam/caamhash.ko] undefined! ERROR: "gen_split_key" [drivers/crypto/caam/caamalg.ko] undefined! Signed-off-by: Ben Collins <ben.c@servergy.com> Cc: Yuan Kang <Yuan.Kang@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-27crypto: caam - refactor key_gen, sgYuan Kang
create separate files for split key generation and scatterlist functions. Signed-off-by: Yuan Kang <Yuan.Kang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
