commit 1b82feb6c5e1996513d0fb0bbb475417088b4954 upstream.
It seems that smp_processor_id() is only used for a best-effort
load-balancing, refer to qat_crypto_get_instance_node(). It's not feasible
to disable preemption for the duration of the crypto requests. Therefore,
just silence the warning. This commit is similar to e7a9b05ca4
("crypto: cavium - Fix smp_processor_id() warnings").
Silences the following splat:
BUG: using smp_processor_id() in preemptible [00000000] code: cryptomgr_test/2904
caller is qat_alg_ablkcipher_setkey+0x300/0x4a0 [intel_qat]
CPU: 1 PID: 2904 Comm: cryptomgr_test Tainted: P O 4.14.69 #1
Call Trace:
dump_stack+0x5f/0x86
check_preemption_disabled+0xd3/0xe0
skcipher_setkey_ablkcipher+0x2b/0x40
__test_skcipher+0x1f3/0xb20
? cpumask_next_and+0x26/0x40
? find_busiest_group+0x10e/0x9d0
? preempt_count_add+0x49/0xa0
? try_module_get+0x61/0xf0
? crypto_mod_get+0x15/0x30
? __kmalloc+0x1df/0x1f0
? __crypto_alloc_tfm+0x116/0x180
? crypto_skcipher_init_tfm+0xa6/0x180
? crypto_create_tfm+0x4b/0xf0
test_skcipher+0x21/0xa0
alg_test_skcipher+0x3f/0xa0
alg_test.part.6+0x126/0x2a0
? finish_task_switch+0x21b/0x260
? __schedule+0x1e9/0x800
? __wake_up_common+0x8d/0x140
cryptomgr_test+0x40/0x50
kthread+0xff/0x130
? cryptomgr_notify+0x540/0x540
? kthread_create_on_node+0x70/0x70
ret_from_fork+0x24/0x50
Fixes: ed8ccaef52 ("crypto: qat - Add support for SRIOV")
Cc: stable@vger.kernel.org
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
The unsigned long type for init_status and start_status in
service_hndl are not long enough to represent more than 64
acceleration devices. Use an array instead.
Signed-off-by: Xin Zeng <xin.zeng@intel.com>
Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com>
Different product families will use FLR or SBR.
Virtual Function devices have no reset method.
Signed-off-by: Conor McLoughlin <conor.mcloughlin@intel.com>
The adf_vf_isr.c should only be build if CONFIG_PCI_IOV is enabled
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Merge the crypto tree to pull in the qat adf_init_pf_wq fix.
Fix undefined reference issue reported by kbuild test robot.
Cc: <stable@vger.kernel.org>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Merge the crypto tree to pull in the qat adf_init_pf_wq change.
The pf2vf_resp_wq is a global so it has to be created at init
and destroyed at exit, instead of per device.
Tested-by: Suresh Marikkannu <sureshx.marikkannu@intel.com>
Before VF sends a signal to PF it should check if PF
is still running.
Tested-by: Suman Bangalore Sathyanarayana <sumanx.bangalore.sathyanarayana@intel.com>
The vf2pf_init and vf2pf_exit are exactly the same for all VFs
so move them to common and reuse.
VFs call adf_dev_stop() from a PF to VF interrupt bottom half.
This causes an oops "scheduling while atomic", because it tries
to acquire a mutex to un-register crypto algorithms.
This patch fixes the issue by calling adf_dev_stop() asynchronously.
Changes in v2:
- change kthread to a work queue.
It returns always zero anyway.
Move qat_isr.c and qat_isrvf.c files to qat_common dir
so that they can be reused by all devices.
Remove adf_drv.h files because thay are not longer needed.
Move adf_dev_configure() function to qat_common so it can be reused.
Also some minor updates to common code for multidevice.
FW loader updates for new qat devices
Some code cleanups after crypto API changes:
- Change qat_algs_unregister to a void function to keep it consistent
with qat_asym_algs_unregister.
- Remove empty functions qat_algs_init & qat_algs_exit.
We need to support legacy VFs as well as VFs running on different OSes.
To do so the compatibility check need needs to be relaxed.
This patch moves the logic responsible for VF to PF version and
compatibility checking from adfsriov.c to adf_pf2vf_msg.c,
where it belongs, and changes the logic enable legacy VFs.
Add code that enables SRIOV on dh895xcc devices.
Adf admin and HW arbiter function can be used by dh895xcc specific code
well as the new dh895xccvf and future devices so moving them to
qat_common so that they can be shared.
Add RSA support to QAT driver.
Removed unused RNG rings.
Load Modular Math Processor(MMP) firmware into QAT devices to support
public key algorithm acceleration.
Signed-off-by: Pingchao Yang <pingchao.yang@intel.com>
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
release_firmware was called twice on error path causing an Oops.
Reported-by: Ahsan Atta <ahsan.atta@intel.com>
When the device needs a reset, e.g. when an uncorrectable PCIe AER event
occurs, various services/data structures need to be cleaned up, the
hardware reset and the services/data structures initialized and started.
The code to perform the cleanup and initialization was not performed when
a device reset was done.
This patch moves some of the initialization code out of the .probe entry-
point into a separate function that is now called during probe as well as
after the hardware has been reset. Similarly, a new function is added for
first cleaning up these services/data structures prior to resetting. The
new functions are adf_dev_init() and adf_dev_shutdown(), respectively, for
which there are already prototypes but no actual functions just yet and are
now called when the device is reset and during probe/cleanup of the driver.
The down and up flows via ioctl calls has similarly been updated.
In addition, there are two other bugs in the reset flow - one in the logic
for determining whether to schedule a device reset upon receiving an
uncorrectable AER event which prevents the reset flow from being initiated,
and another with clearing the status bit indicating a device is configured
(when resetting the device the configuration remains across the reset so
the bit should not be cleared, otherwise, the necessary services will not
be re-started in adf_dev_start() after the reset - clear the bit only when
actually deleting the configuration).
Firmware loader crashes when no firmware file is present.
Reviewed-by: Bruce Allan <bruce.w.allan@intel.com>
This patch adds a common infractructure that will be used by all Intel(R)
QuickAssist Technology (QAT) devices.
v2 - added ./drivers/crypto/qat/Kconfig and ./drivers/crypto/qat/Makefile
v4 - splits common part into more, smaller patches
Acked-by: John Griffin <john.griffin@intel.com>
Reviewed-by: Bruce W. Allan <bruce.w.allan@intel.com>
