Save the key in hardware when the key setting call comes. Currently it is
set at later time.
Bug 917607
Change-Id: Ibdacb07c16c161eeba00eda6716884518e40c40a
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/90072
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Added check for valid requested process buffer size.
Bug 928454
Change-Id: I2dc389af64cb3de2f0a0a3f0bbc5057dd9bd676c
Reviewed-on: http://git-master/r/89381
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Should have been "GPL v2", not "GPLv2".
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Change-Id: I7b4669c023c48e1080de7f87ed7166dc9b47884a
Reviewed-on: http://git-master/r/88101
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Bug 917607
Change-Id: I049ca03efe7953dc6a6c03eaa4acce85e15662d1
Reviewed-on: http://git-master/r/76154
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Bug 917607
Change-Id: I6036b12456d3b5fb22f479a9e0eefd500cb6c059
Reviewed-on: http://git-master/r/76153
Bug 917607
Change-Id: I7497411932b6ba8c155026f1662063e87c21eb40
Reviewed-on: http://git-master/r/74012
Fixed the case where SG buffer length is more than actual number
of bytes to process.
Bug 922857
Change-Id: I8445d8ae74b8fc6c964c19523fcd731f7ba4bd37
Reviewed-on: http://git-master/r/75701
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: http://git-master/r/75891
RNG support for less than 16 Bytes and or not a multiple of
16 Bytes.
Bug 893463
Change-Id: I37fff0f90004dd3116b621c5aa956cebbd6a085a
Reviewed-on: http://git-master/r/74263
Tested-by: Venkata Jagadish <vjagadish@nvidia.com>
Reviewed-on: http://git-master/r/74559
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Venkata Jagadish <vjagadish@nvidia.com>
- Workqueue of tegra-se does not need to be CPU bound
Bug 911397
Change-Id: I8786e8574cf3ec2e33b3869de8c8be3f0939e13f
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/71527
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Check for valid key size before setting the key.
Bug 915210
Change-Id: I081e2af9505ea89719d447b4b0ca2b0177860d09
Reviewed-on: http://git-master/r/70046
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
store the keys in the individual request context structure,
since there is no other way to manage keys across different
crypto operations. also retry requests thrice in case of
errors
Reviewed-on: http://git-master/r/40008
(cherry picked from commit 5437e3230679fbc6e342f7e6787e3cc1692e5df6)
Change-Id: Iba23e20371661c8732995d13774cf3dbba6e24b4
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit 274252862f386b7868f35bf5ceaa5391a8ccfdf3 upstream.
This was broken by commit 7759995c75ae0cbd4c861582908449f6b6208e7a (yes,
myself). The basic problem here is since the digest state is only saved
after the last chunk, the state array is only valid when handling the
first chunk of the next buffer. Broken since linux-3.0.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
In platform_pm_suspend, if there's a dev->driver->pm struct,
it expects the suspend routine to be filled in there.
With a pm struct, it won't use the platform_legacy_suspend
path, which is how tegra_se_suspend had been hooked up. This
change just moves suspend/resume into the pm ops struct.
Bug 883391
Change-Id: Iee8245676ba104d2e4cc0f2f2ffe406674cb1d5b
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/67989
Reviewed-by: Simone Willett <swillett@nvidia.com>
- Suspension of the device does not need to happen immediately
Bug 904152
Change-Id: I900f79faf85c5aca95b67b1284be18d89f36d3a9
Reviewed-on: http://git-master/r/68318
Problem description:
- runtime_idle is called even if the device is being used
as it is called without a lock
- This happens when power.usage_count is incremented during rpm_idle
- In case runtime_idle is called when the device is being used, write
to the bus can happen with clock disabled
Fix description:
- Instead of disabling clock on runtime_idle, disable on runtime_suspend
Bug 904152
Change-Id: I1489c62a0c8cfd84eca788d53d2013487fb7f737
Reviewed-on: http://git-master/r/68293
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Change-Id: I9d03b3a6876b858983739c5e8d8a166a08fb2d78
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/59170
Reviewed-by: Rakesh Iyer <riyer@nvidia.com>
Rebase-Id: R73da0f98f4e0d9912ff37cd9faebf06ef11e7bef
bug 886813
Change-Id: Ia016c0f783b0396d8433b202ccef1659d10085f5
Reviewed-on: http://git-master/r/57850
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R5a13865e200c1345bc30ab86b8d3286d47af5796
To prevent unauthorized access to keys loaded into key
slots in Security engine, disabled read access for all
key slots.
Bug 868040
Original-Change-Id: I01229ff9a523192a041b7fab94ed154a65ee15e5
Reviewed-on: http://git-master/r/48998
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: Rc625e9ea7b76ba35bfd1de30c1c2d800f93d9c93
tegra-aes driver can also be used on tegra3.
Original-Change-Id: Ic0d5e705abfefea9b43d64a9a85d748df189abc9
Reviewed-on: http://git-master/r/47720
Rebase-Id: R790a786e22b3c6a4d0339971419d2be03ed2e272
Added support for generating RNG for more than 16 bytes.
Bug 861777
Original-Change-Id: I414063378c1b7c31c9ef2ade950adcaa4e7db388
Reviewed-on: http://git-master/r/46066
Rebase-Id: Ra4ff01903b00f98b317606be3ffdfef58668aa92
Added LP context save support in Security Engine
Bug 855476
Original-Change-Id: I384f3adcacd9e94325d40cd98d1c96a98e01aee5
Reviewed-on: http://git-master/r/44810
Rebase-Id: R5d891e6908a2e5f6206c7c509d7d0585b1522aee
support to use ssk for some special encrypt
decrypt operations. algo names changed to match
the ones accessed by /dev/tegra-crypto
Bug 850434
Original-Change-Id: I8f13ae1fd15ffeae4aceee5799552d173560479a
Reviewed-on: http://git-master/r/41012
Rebase-Id: R86620bd834ae7740377f43c285ba86aee74bb4cc
Changed dev_err to pr_err because 'dd' can be NULL.
Added NULL checking before clock disable of engine->pclk
Reviewed-on: http://git-master/r/37857
(cherry picked from commit 851ffd0a30cbe67a5033a9792825b319f0bcd7ed)
Original-Change-Id: If5a2bbd550f3dc038b42d8a185647d02df9cb593
Reviewed-on: http://git-master/r/38446
Tested-by: Jubeom Kim <jubeomk@nvidia.com>
Rebase-Id: R57fa4ce4a2e95d80813448ad5234fb9bdf74faf1
instead of checking for NULL, IS_ERR() should
be used to check the validity of a clock handle
Reviewed-on: http://git-master/r/#change,35619
(cherry picked from commit cfb16f57d0a846dba4cd5d6a87c05dcb8efd188d)
Change-Id: If844a166deabc7e67c9af69e4d05f59757773895
Reviewed-on: http://git-master/r/36218
Rebase-Id: R9a6137402ee132e6b4c1a38ab5d51a3acb035a28
- get some basic struct definitions from the header to
the .c file
- read SE config register before disabling the clock.
there are scenarios seen where some write transactions
are not posted before we disable clock. a dummy SE
register read fixes that issue.
Bug 835859
Original-Change-Id: I5e09c13262dbc392cac233a1fb6d69240b3460f2
Reviewed-on: http://git-master/r/35636
Rebase-Id: R8a7380e843db8dd8fda379b9d0a2c4270d1bd40b
- reset intr_status if error occur while encrypt/decrypt
- rename iram variables to _phys and _virt
- use bsea for rng
- remove unwanted macros from the header file
Bug 833165
Reviewed-on: http://git-master/r/#change,34552
(cherry picked from commit 4f2f0431fe196829c8ec61ab10ed5cb2ea6b5038)
Original-Change-Id: I76f221bde1e5fdb331b9b75f826c822bd3246e14
Reviewed-on: http://git-master/r/35194
Rebase-Id: Ra044f128c66a8591c9d6ed29725c167334efd05d
* set bsea sclk to ulong_max
* use unbounded work queues with 1 max_active
work item on each of them
* clear INTR_STATUS per operation
* free nvmap handle after using it
Bug 803932
Reviewed-on: http://git-master/r/#change,30196
(cherry picked from commit b0f6c074aab8a9f3bddec4a204b618180df630db)
Original-Change-Id: Ica9d702db9a247110d0639c64ab65672f02d7451
Reviewed-on: http://git-master/r/31936
Rebase-Id: R5a51f9a8f7133a7e08f6544bbee581e30b46c6b5
Added support for Security Engine.
Following HW features are supported:
CBC,ECB,CTR,OFB,SHA1,SHA224,SHA384,SHA512 and AES-CMAC
Original-Change-Id: Ic45c29add689f55be68966d333d1cb7cdb378353
Reviewed-on: http://git-master/r/29950
Rebase-Id: R57f92020a7a713f624afe3b1d42da489bf89daba
* add bsea engine support for encryption and decryption
* add arbitration semaphore id for bsea
Bug 803932
Original change: http://git-master/r/#change,29672
(cherry picked from commit 0008cdb0f38d0cd0c074671fc067c4321f340b06)
Original-Change-Id: I59fcaab29c47a8b42e7470b30486851cfe90848f
Reviewed-on: http://git-master/r/30190
Rebase-Id: R6f1bf287860a24d0a535e49f516581b31092d182
Original-Change-Id: I158d2be97c795313e7e74ce9fb4ec0bdc7d95496
Reviewed-on: http://git-master/r/27559
Tested-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Original-Change-Id: I0ff198daa548ed2837f7fb1794013bf0adf7e5a1
Rebase-Id: R46eb4226a3d37331db92f05d1a6e1c8e45f682a2
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: Rb4bacf7db8c96e1865380466ef7eca71d72d08bc
Bug 787628
Original-Change-Id: I73c3b8f0b3e69f1c4bc13bdaea84b19b14eb73d1
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/28003
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rdf987e66c66135392489bd73ca16429d4d05d636
clients call the algorithm's close api, which
results in the algo's cra_exit getting called, when
they are done using the hardware. we need to free the
key slot which was being used by the client when its
cra_exit is called.
Original-Change-Id: Ib42d445f5068c4ea1ef6b3edbbc547fe9eeef583
Reviewed-on: http://git-master/r/24673
Rebase-Id: R8676bc01e6930c3164f8cc22d96023e0aeb44a3e
Original-Change-Id: I7d8fe24ab5aa914fc2753f256eec261fcbf746bc
Reviewed-on: http://git-master/r/22594
Rebase-Id: Re4de8ecdfd6507cad5e0196882326d00f5ae79e0
This reverts commit 8bc4f710e981d53a9bd161c6c054241231e09149.
Original-Change-Id: I0497afd3ec54e7b835de37e9941b2418e3dad4e3
Reviewed-on: http://git-master/r/22963
Rebase-Id: Rf393b9a6102e4550c44bc538ccc541879890f924
This reverts commit a8dbfda58a6980976de60ba46f22a5f0b2ecab5f.
Original-Change-Id: I70407c45cc5605ad9924a5a1145e18371dc9d2ef
Reviewed-on: http://git-master/r/22554
Rebase-Id: Rdfc2a43ce9137e1a7ff81b78868c2e48f91f1b02
- set the key only at the start of encrypt/decrypt operations
- avoid using mutex in handle_req, since it is already serialised
- sanity checks while setting the iv
Original-Change-Id: I026e138f59d661cd705db6820bed63e5e15f02c5
Reviewed-on: http://git-master/r/22162
Rebase-Id: R11bd949802ebf158b87b8705aab5271c27da844b
ssk slot is write-locked so the driver should not
track in its free slot pool.
Original-Change-Id: Ibf04a949a2894ef2c41851e7e92c13901c873bf2
Reviewed-on: http://git-master/r/22161
Rebase-Id: R7ae05f50294e8a7f0241296aee53cda57aa36a5f
Original-Change-Id: I41ba8dfc193b346eda522eadfb0f9035f4d838f8
Reviewed-on: http://git-master/r/22160
Rebase-Id: R8351adfba377ede436f101194551e8091aa5528b
Change-Id: I69731fcd50933ccea73542d046c3c5d86d03fcd9
The hardware aes engine is required for key management for
HDCP, but since it's performance is bad, we don't want it
enabled for dm-crypt. This hack changes the cra_name field
so dm-crypt won't find a match, but leaves the cra_driver_name
field unchanged to the device file interface will still find it.
Signed-off-by: Ken Sumrall <ksumrall@android.com>
- enable/disable clocks only once per request
- create a thread for handling the driver's work queue
- always set vde clocks to the max before processing a request
Change-Id: I935e5523e9e913c93705cc694f8a475d212c15ce
Change-Id: I368a9bf8aa1c311532e54d18a813b556576b8da1
avp does not use the crypto engine inside the vde block,
so it is ok if we do not reset the entire block before
any crypto operation. this would save more than 100us per crypto
operation.
Change-Id: I4e6f4940c5b6e95498b6f7a62498fbf956e25254
the encrypt/decrypt callbacks have to return with -EINPROGRESS
error code and the request complete callback needs to be
called from handle_req for aynchronous block ciphers. use
work queue to make the driver asynchronous.
Change-Id: I0dec1185c31e5de7ba039c39d6bd87c8b3487b2a
Change-Id: I6f5a7107d1140cf67f6029111cb4df312ac1183c
Change-Id: Iaddea9ba9d3bee9c987776f37225dee483684274
Change-Id: Ie5b98b705a7ec70782df5dc0aec69438b699661c
Signed-off-by: Colin Cross <ccross@android.com>
