path: root/drivers/dca/dca-core.c
2008-11-10[4/4] dca: fixup initialization dependencyDan Williams
Mark dca_init as a subsys_initcall since it needs to be ready to go before dependent drivers start registering themselves. Cc: <stable@kernel.org> Reported-and-tested-by: Mark Rustad <mark_rustad@Xiotech.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22I/OAT: I/OAT version 3.0 supportMaciej Sosnowski
This patch adds to ioatdma and dca modules support for Intel I/OAT DMA engine ver.3 (aka CB3 device). The main features of I/OAT ver.3 are: * 8 single channel DMA devices (8 channels total) * 8 DCA providers, each can accept 2 requesters * 8-bit TAG values and 32-bit extended APIC IDs Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2007-10-16DCA: Add Direct Cache Access driverShannon Nelson
Direct Cache Access (DCA) is a method for warming the CPU cache before data is used, with the intent of lessening the impact of cache misses. This patch adds a manager and interface for matching up client requests for DCA services with devices that offer DCA services. In order to use DCA, a module must do bus writes with the appropriate tag bits set to trigger a cache read for a specific CPU. However, different CPUs and chipsets can require different sets of tag bits, and the methods for determining the correct bits may be simple hardcoding or may be a hardware specific magic incantation. This interface is a way for DCA clients to find the correct tag bits for the targeted CPU without needing to know the specifics. [Dave Miller] use DEFINE_SPINLOCK() Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
