path: root/drivers/dca
2009-09-13dca: module load should not be an error messageStephen Hemminger
The message (if it must exist) should not be an error message. IMHO such messages are useless. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-09-10dca: registering requesters in multiple dca domainsMaciej Sosnowski
This patch enables DCA support on multiple-IOH/multiple-IIO architectures. It modifies dca module by replacing single dca_providers list with dca_domains list, each domain containing separate list of providers. This approach lets dca driver manage multiple domains, i.e. sets of providers and requesters mapped back to the same PCI root complex device. The driver takes care to register each requester to a provider from the same domain. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
2009-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) ucc_geth: Fix oops when using fixed-link support dm9000: locking bugfix net: update dnet.c for bus_id removal dnet: DNET should depend on HAS_IOMEM dca: add missing copyright/license headers nl80211: Check that function pointer != NULL before using it sungem: missing net_device_ops be2net: fix to restore vlan ids into BE2 during a IF DOWN->UP cycle be2net: replenish when posting to rx-queue is starved in out of mem conditions bas_gigaset: correctly allocate USB interrupt transfer buffer smsc911x: reset last known duplex and carrier on open sh_eth: Fix mistake of the address of SH7763 sh_eth: Change handling of IRQ netns: oops in ip[6]_frag_reasm incrementing stats net: kfree(napi->skb) => kfree_skb net: fix sctp breakage ipv6: fix display of local and remote sit endpoints net: Document /proc/sys/net/core/netdev_budget tulip: fix crash on iface up with shirq debug virtio_net: Make virtio_net support carrier detection ...
2009-03-21dca: add missing copyright/license headersMaciej Sosnowski
In two dca files copyright and license headers are missing. This patch adds them there. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04I/OAT: update driver version and copyright datesMaciej Sosnowski
Together with new fixes update driver version and extend copyright dates ranges. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-02-02dca: redesign locks to fix deadlocksMaciej Sosnowski
Change spin_locks to irqsave to prevent dead-locks. Protect adding and deleting to/from dca_providers list. Drop the lock during dca_sysfs_add_req() and dca_sysfs_remove_req() calls as they might sleep (use GFP_KERNEL allocation). Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06dmaengine: bump initcall level to arch_initcallDan Williams
There are dmaengine users that would like to register dma devices at subsys_initcall time to ensure channels are available by device_initcall time. Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-11-10[4/4] dca: fixup initialization dependencyDan Williams
Mark dca_init as a subsys_initcall since it needs to be ready to go before dependent drivers start registering themselves. Cc: <stable@kernel.org> Reported-and-tested-by: Mark Rustad <mark_rustad@Xiotech.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (24 commits) I/OAT: I/OAT version 3.0 support I/OAT: tcp_dma_copybreak default value dependent on I/OAT version I/OAT: Add watchdog/reset functionality to ioatdma iop_adma: cleanup iop_chan_xor_slot_count iop_adma: document how to calculate the minimum descriptor pool size iop_adma: directly reclaim descriptors on allocation failure async_tx: make async_tx_test_ack a boolean routine async_tx: remove depend_tx from async_tx_sync_epilog async_tx: export async_tx_quiesce async_tx: fix handling of the "out of descriptor" condition in async_xor async_tx: ensure the xor destination buffer remains dma-mapped async_tx: list_for_each_entry_rcu() cleanup dmaengine: Driver for the Synopsys DesignWare DMA controller dmaengine: Add slave DMA interface dmaengine: add DMA_COMPL_SKIP_{SRC,DEST}_UNMAP flags to control dma unmap dmaengine: Add dma_client parameter to device_alloc_chan_resources dmatest: Simple DMA memcpy test client dmaengine: DMA engine driver for Marvell XOR engine iop-adma: fix platform driver hotplug/coldplug dmaengine: track the number of clients using a channel ... Fixed up conflict in drivers/dca/dca-sysfs.c manually
2008-07-22I/OAT: I/OAT version 3.0 supportMaciej Sosnowski
This patch adds to ioatdma and dca modules support for Intel I/OAT DMA engine ver.3 (aka CB3 device). The main features of I/OAT ver.3 are: * 8 single channel DMA devices (8 channels total) * 8 DCA providers, each can accept 2 requesters * 8-bit TAG values and 32-bit extended APIC IDs Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-21device create: dca: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-08DCA: convert struct class_device to struct device.Kay Sievers
Thanks to Kay for keeping us honest. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Cc: "Williams, Dan J" <dan.j.williams@intel.com> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16I/OAT: Add DCA servicesShannon Nelson
Add code to connect to the DCA driver and provide cpu tags for use by drivers that would like to use Direct Cache Access hints. [Adrian Bunk] Several Kconfig cleanup items [Andrew Morten, Chris Leech] Fix for using cpu_physical_id() even when built for uni-processor Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16DCA: Add Direct Cache Access driverShannon Nelson
Direct Cache Access (DCA) is a method for warming the CPU cache before data is used, with the intent of lessening the impact of cache misses. This patch adds a manager and interface for matching up client requests for DCA services with devices that offer DCA services. In order to use DCA, a module must do bus writes with the appropriate tag bits set to trigger a cache read for a specific CPU. However, different CPUs and chipsets can require different sets of tag bits, and the methods for determining the correct bits may be simple hardcoding or may be a hardware specific magic incantation. This interface is a way for DCA clients to find the correct tag bits for the targeted CPU without needing to know the specifics. [Dave Miller] use DEFINE_SPINLOCK() Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
