path: root/drivers/devfreq
2014-07-10devfreq: Account only powered time in trans_statArto Merilainen
This patch modifies devfreq to account only the time a device is powered in trans_stat. In addition, this patch also fixes a race in trans_stat maintenance in cases where the node is readed at the same time the transition table is being updated by frequency re-estimation. Change-Id: I6e4341317b6dda88d69028c9f67785400e5a7a65 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/435174 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com> Reviewed-by: Samuel Russell <samuelr@nvidia.com> Tested-by: Samuel Russell <samuelr@nvidia.com> Reviewed-by: Ilan Aelion <iaelion@nvidia.com>
2014-01-22devfreq: Fix type of frequency tableTerje Bergstrom
Frequencies are always expressed as ulong, but devfreq's table is of type uint *. Fix the mismatch. Change-Id: I0ed6b43f397331d1940c7f573d37796e50e8ac58 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/352720 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2014-01-03devfreq: Fix transition table countingArto Merilainen
The code double counted transitions in cases where the new frequency was non-standard (i.e. not available in tables) due to invalid check in transition table maintenance. This patch fixes double counting by using always frequency levels in comparison. Change-Id: Ie4d4d91b5e6410494366cea28ef0ee5d84d66bee Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/351022 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2013-09-16devfreq: Round frequencies in transition statsArto Merilainen
Transition statistics required that the new frequency was *exactly* as it was in the table. However, we may unexpectedly select a frequency that is not in the table (i.e. thermal limit forces us to select a bit lower frequency, the original DVFS table does not hold for the current PLL for some reason, etc.) This patch modifies transition table to select the best candidate from the frequency table. Bug 1366760 Change-Id: I4329f77e733f5f1d39b9d9c3aebe3681a0760d90 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/273596 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2013-09-14fixup! devfreq: Add stub functions to governor.hDan Willemsen
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com> Change-Id: I0c7f47cb3c57636154b2bd1478387d29ad02feaf Reviewed-on: http://git-master/r/269998
2013-09-14devfreq: Export profile frequency table to sysfsArto Merilainen
devfreq exported the frequencies based that were available from OPP, however, some devices that use devfreq do not utilise OPP, but they give the list of supported frequencies separately for devfreq. This patch makes devfreq use the given table (if available) and fallback to OPP. Bug 1330780 Change-Id: I60ec2eade6066b0c3520f7e372384f0a42734048 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/256695 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2013-09-14devfreq: Add stub functions to governor.hArto Merilainen
Due to the kernel update we lost devfreq stub functions from governor.h which effectively prevents compilation of the kernel when devfreq is disabled. This patch adds stub functions to governor.h to allow the kernel to compile when there are devfreq users and devfreq is disabled. Change-Id: Ica543ef05ffeb0ba0258363087f9427d871f8e1f Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/244668 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-09-14drivers: devfreq: Fix devfreq stub functionsArto Merilainen
This patch allows the kernel to build even if devfreq.h is included when devfreq support is not available. Change-Id: I01f1bdd9dda755f86255e5609c2a5411cfb64480 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/132557 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Rebase-Id: R346b3b9ea9d3dd27487fe893795b7684dcd8be27
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-22PM / devfreq: exynos4_bus: honor RCU lock usageNishanth Menon
OPP pointers cannot be expected to be valid beyond the boundary of rcu_read_lock and rcu_read_unlock. Unfortunately, the current exynos4 busfreq driver does not honor the usage constraint and stores the OPP pointer in struct busfreq_data. This could potentially become invalid later such as: across devfreq opp change decisions, resulting in unpredictable behavior. To fix this, we introduce a busfreq specific busfreq_opp_info structure which is used to handle OPP information. OPP information is de-referenced to voltage and frequency pairs as needed into busfreq_opp_info structure and used as needed. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-22PM / devfreq: add locking documentation for recommended_oppNishanth Menon
OPP pointers are protected by RCU locks, the pointer validity is permissible only under the section of rcu_read_lock to rcu_read_unlock Add documentation to the effect. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-09treewide: Fix typo in various driversMasanari Iida
Correct spelling typo in printk within various drivers. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03Drivers: misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-07Merge branch 'pm-devfreq'Rafael J. Wysocki
* pm-devfreq: (23 commits) PM / devfreq: remove compiler error with module governors (2) PM / devfreq: Fix return value in devfreq_remove_governor() PM / devfreq: Fix incorrect argument in error message PM / devfreq: missing rcu_read_lock() added for find_device_opp() PM / devfreq: remove compiler error when a governor is module PM / devfreq: exynos4_bus.c: Fixed an alignment of the func call args. PM / devfreq: Add sysfs node to expose available governors PM / devfreq: allow sysfs governor node to switch governor PM / devfreq: governors: add GPL module license and allow module build PM / devfreq: map devfreq drivers to governor using name PM / devfreq: register governors with devfreq framework PM / devfreq: provide hooks for governors to be registered PM / devfreq: export update_devfreq PM / devfreq: Add sysfs node for representing frequency transition information. PM / devfreq: Add sysfs node to expose available frequencies PM / devfreq: documentation cleanups for devfreq header PM / devfreq: Use devm_* functions in exynos4_bus.c PM / devfreq: make devfreq_class static PM / devfreq: fix sscanf handling for writable sysfs entries PM / devfreq: kernel-doc typo corrections ...
2012-11-28PM / devfreq: remove compiler error with module governors (2)MyungJoo Ham
Governors compiled as modules may use these functions. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-26PM / devfreq: Fix return value in devfreq_remove_governor()Sachin Kamat
Use the value obtained from the function instead of -EINVAL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-26PM / devfreq: Fix incorrect argument in error messageSachin Kamat
'g' is cast to the error return code. Hence gives the following error which is fixed by this patch. drivers/devfreq/devfreq.c:645 devfreq_remove_governor() error: 'g' dereferencing possible ERR_PTR() Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-26PM / devfreq: missing rcu_read_lock() added for find_device_opp()MyungJoo Ham
opp_get_notifier() uses find_device_opp(), which requires to held rcu_read_lock. In order to keep the notifier-header valid, we have added rcu_read_lock(). Reported-by: Kees Cook <keescook@chromium.org> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: exynos4_bus.c: Fixed an alignment of the func call args.Sangho Yi
I fixed the following check item (via checkpatch.pl --strict option): CHECK: Alignment should match open parenthesis Signed-off-by: Sangho Yi <antiroot@gmail.com> [Merge conflict resolved] Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: Add sysfs node to expose available governorsNishanth Menon
Now that governor list can be variable, knowing the available governors is useful to be able to select a governor using relevant sysfs node. Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: allow sysfs governor node to switch governorNishanth Menon
This allows us to select governor runtime from the default configuration without having to rebuild kernel or the devfreq driver using the sysfs node: /sys/class/devfreq/.../governor cat of the governor will return valid governor and an echo 'governor_name'>governor will switch governor Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: governors: add GPL module license and allow module buildNishanth Menon
Add GPL module license and remove the static build restrictions for building governors. This allows governors now to be loaded on a need basis and reloaded independently of kernel build Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: map devfreq drivers to governor using nameNishanth Menon
Allow devfreq drivers to register a preferred governor name and when the devfreq governor loads itself at a later point required drivers are managed appropriately, at the time of unload of a devfreq governor, stop managing those drivers as well. Since the governor structures do not need to be exposed anymore, remove the definitions and make them static NOTE: devfreq_list_lock is now used to protect governor start and stop - as this allows us to protect governors and devfreq with the proper dependencies as needed. As part of this change, change the registration of exynos bus driver to request for ondemand using the governor name. Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> [Merge conflict resolved by MyungJoo Ham] Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: register governors with devfreq frameworkNishanth Menon
With the new registration functions, governors can be now registered with devfreq framework. NOTE: generates 'discards qualifiers from pointer target type' build warnings, which the next patche in this series fixes Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: provide hooks for governors to be registeredNishanth Menon
Add devfreq_add_governor and devfreq_remove_governor which can be invoked by governors to register with devfreq. This sets up the stage to dynamically switch governors and allow governors to be dynamically loaded as well. Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: export update_devfreqNishanth Menon
Allow update_devfreq to be used by devfreq governor built as modules Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: Add sysfs node for representing frequency transition information.Jonghwa Lee
This patch adds sysfs node which can be used to get information of frequency transition. It represents transition table which contains total number of transition of each freqeuncy state and time spent. It is inspired CPUFREQ's status driver. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> [Added Documentation/ABI entry, updated kernel-doc, and resolved merge conflict] Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: Add sysfs node to expose available frequenciesNishanth Menon
devfreq governors such as ondemand are controlled by a min and max frequency, while governors like userspace governor allow us to set a specific frequency. However, for the same specific device, depending on the SoC, the available frequencies can vary. So expose the available frequencies as a snapshot over sysfs to allow informed decisions. This was inspired by cpufreq framework's equivalent for similar usage sysfs node: scaling_available_frequencies. Cc: Rajagopal Venkat <rajagopal.venkat@linaro.org> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kevin Hilman <khilman@ti.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-20PM / devfreq: Use devm_* functions in exynos4_bus.cSachin Kamat
devm_* functions are device managed functions and make cleanup code simpler and smaller. devm_kzalloc and devm_regulator_get functions are used. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> [renamed the patch title by MyungJoo Ham] Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-11-15PM / OPP: predictable fail results for opp_find* functions, v2Nishanth Menon
Currently the opp_find* functions return -ENODEV when: a) it cant find a device (e.g. request for an OPP search on device which was not registered) b) When it cant find a match for the search strategy used This makes life a little in-efficient for users such as devfreq to make reasonable judgement before switching search strategies. So, standardize the return results as following: -EINVAL for bad pointer parameters -ENODEV when device cannot be found -ERANGE when search fails This has the following benefit for devfreq implementation: The search fails when an unregistered device pointer is provided. This is a trigger to change the search direction and search for a better fit, however, if we cannot differentiate between a valid search range failure Vs an unregistered device, second search goes through the same fail return condition. This can be avoided by appropriate handling of error return code. With this change, we also fix devfreq for the improved search strategy with updated error code. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: make devfreq_class staticNishanth Menon
devfreq_class is used internally by devfreq and has no need to be globally available. This also fixes the following sparse warning: drivers/devfreq/devfreq.c:30:14: warning: symbol 'devfreq_class' was not declared. Should it be static? Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: fix sscanf handling for writable sysfs entriesNishanth Menon
sscanf returns 0 when an invalid parameter like: echo -n "a">min_freq is attempted. Returning back the return result(0) will cause the command not to return back to command prompt. Instead, just return -EINVAL when sscanf does not return 1. This is done for min_freq, max_freq and polling_interval Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: kernel-doc typo correctionsNishanth Menon
Parameter documentation needs a ':' for scripts/kernel-doc to parse properly. Minor fixes for ones warned by: ./scripts/kernel-doc -text drivers/devfreq/devfreq.c>/dev/null Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: Add current freq callback in device profileRajagopal Venkat
Devfreq returns governor predicted frequency as current frequency via sysfs interface. But device may not support all frequencies that governor predicts. So add a callback in device profile to get current freq from driver. Also add a new sysfs node to expose governor predicted next target frequency. Signed-off-by: Rajagopal Venkat <rajagopal.venkat@linaro.org> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: Add suspend and resume apisRajagopal Venkat
Add devfreq suspend/resume apis for devfreq users. This patch supports suspend and resume of devfreq load monitoring, required for devices which can idle. Signed-off-by: Rajagopal Venkat <rajagopal.venkat@linaro.org> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15PM / devfreq: Core updates to support devices which can idleRajagopal Venkat
Prepare devfreq core framework to support devices which can idle. When device idleness is detected perhaps through runtime-pm, need some mechanism to suspend devfreq load monitoring and resume back when device is online. Present code continues monitoring unless device is removed from devfreq core. This patch introduces following design changes, - use per device work instead of global work to monitor device load. This enables suspend/resume of device devfreq and reduces monitoring code complexity. - decouple delayed work based load monitoring logic from core by introducing helpers functions to be used by governors. This provides flexibility for governors either to use delayed work based monitoring functions or to implement their own mechanism. - devfreq core interacts with governors via events to perform specific actions. These events include start/stop devfreq. This sets ground for adding suspend/resume events. The devfreq apis are not modified and are kept intact. Signed-off-by: Rajagopal Venkat <rajagopal.venkat@linaro.org> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-08-21workqueue: make deferrable delayed_work initializer names consistentTejun Heo
Initalizers for deferrable delayed_work are confused. * __DEFERRED_WORK_INITIALIZER() * DECLARE_DEFERRED_WORK() * INIT_DELAYED_WORK_DEFERRABLE() Rename them to * __DEFERRABLE_WORK_INITIALIZER() * DECLARE_DEFERRABLE_WORK() * INIT_DEFERRABLE_WORK() This patch doesn't cause any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-05-23Merge tag 'pm-for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: - Implementation of opportunistic suspend (autosleep) and user space interface for manipulating wakeup sources. - Hibernate updates from Bojan Smojver and Minho Ban. - Updates of the runtime PM core and generic PM domains framework related to PM QoS. - Assorted fixes. * tag 'pm-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (25 commits) epoll: Fix user space breakage related to EPOLLWAKEUP PM / Domains: Make it possible to add devices to inactive domains PM / Hibernate: Use get_gendisk to verify partition if resume_file is integer format PM / Domains: Fix computation of maximum domain off time PM / Domains: Fix link checking when add subdomain PM / Sleep: User space wakeup sources garbage collector Kconfig option PM / Sleep: Make the limit of user space wakeup sources configurable PM / Documentation: suspend-and-cpuhotplug.txt: Fix typo PM / Domains: Cache device stop and domain power off governor results, v3 PM / Domains: Make device removal more straightforward PM / Sleep: Fix a mistake in a conditional in autosleep_store() epoll: Add a flag, EPOLLWAKEUP, to prevent suspend while epoll events are ready PM / QoS: Create device constraints objects on notifier registration PM / Runtime: Remove device fields related to suspend time, v2 PM / Domains: Rework default domain power off governor function, v2 PM / Domains: Rework default device stop governor function, v2 PM / Sleep: Add user space interface for manipulating wakeup sources, v3 PM / Sleep: Add "prevent autosleep time" statistics to wakeup sources PM / Sleep: Implement opportunistic sleep, v2 PM / Sleep: Add wakeup_source_activate and wakeup_source_deactivate tracepoints ...
2012-05-01PM: devfreq: init performance/powersave governorXiaoguang Chen
Performance and powersave governor's get_target_freq is not called if driver chooses one of these two governors. Add init function in governor profile to call update_devfreq which will call get_target_freq subsequently. Signed-off-by: Xiaoguang Chen <chenxg@marvell.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-04-16Fix typo in various Kconfig fileMasanari Iida
Correct spelling typo in various Kconfig file. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-17PM / devfreq: add relation of recommended frequency.MyungJoo Ham
The semantics of "target frequency" given to devfreq driver from devfreq framework has always been interpretted as "at least" or GLB (greatest lower bound). However, the framework might want the device driver to limit its max frequency (LUB: least upper bound), especially if it is given by thermal framework (it's too hot). Thus, the target fuction should have another parameter to express whether the framework wants GLB or LUB. And, the additional parameter, "u32 flags", does it. With the update, devfreq_recommended_opp() is also updated. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mike Turquette <mturquette@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-10PM / devfreq: update the name of EXYNOS clock registers that were omittedMyungJoo Ham
In the commit, "PM / devfreq: update the name of EXYNOS clock register" ommitted one register. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-10PM / devfreq: update the name of EXYNOS clock registerKukjin Kim
According to replacing the name of EXYNOS clock registers, this patch updates exynos4_bus.c file where it is used. Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-01-20PM / devfreq: add min/max_freq limit requested by users.MyungJoo Ham
The frequency requested to devfreq device driver from devfreq governors is restricted by min_freq and max_freq input. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-01-20devfreq: Remove MODULE_ALIAS for exynos4 busfreq driverAxel Lin
This driver can only be built-in, it does not make sense to add modalias for it (in addition to being incorrect, the platform modalias needs to be prefixed with "platform:"). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
2012-01-20devfreq: exynos4_bus: Use dev_get_drvdata at appropriate placesAxel Lin
2011-12-21Merge branch 'devfreq-for-next' of ↵Rafael J. Wysocki
git://git.infradead.org/users/kmpark/linux-samsung into pm-devfreq * 'devfreq-for-next' of git://git.infradead.org/users/kmpark/linux-samsung: (765 commits) PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412. pci: Fix hotplug of Express Module with pci bridges i2c-eg20t: correct the driver init order of pch_i2c_probe() I2C: OMAP: fix FIFO usage for OMAP4 i2c-s3c2410: Fix return code of s3c24xx_i2c_parse_dt_gpio i2c: i2c-s3c2410: Add a cpu_relax() to busy wait for bus idle Linux 3.2-rc6 Revert "drm/i915: fix infinite recursion on unbind due to ilk vt-d w/a" btrfs: lower the dirty balance poll interval drm/i915/dp: Dither down to 6bpc if it makes the mode fit drm/i915: enable semaphores on per-device defaults drm/i915: don't set unpin_work if vblank_get fails drm/i915: By default, enable RC6 on IVB and SNB when reasonable iommu: Export intel_iommu_enabled to signal when iommu is in use drm/i915/sdvo: Include LVDS panels for the IS_DIGITAL check drm/i915: prevent division by zero when asking for chipset power drm/i915: add PCH info to i915_capabilities drm/i915: set the right SDVO transcoder for CPT drm/i915: no-lvds quirk for ASUS AT5NM10T-I sched: Fix select_idle_sibling() regression in selecting an idle SMT sibling ...
2011-12-20PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412.MyungJoo Ham
Exynos4-bus device devfreq driver add DVFS capability for Exynos4210/4212/4412-Bus (memory). The driver monitors PPMU counters of memory controllers and adjusts operating frequencies and voltages with OPP. For Exynos4210, vdd_int is controlled. For exynos4412/4212, vdd_mif and vdd_int are controlled. Dependency (CONFIG_EXYNOS_ASV): Exynos4 ASV driver has been posted in the mailing list; however, it si not yet upstreamed. Although the current revision of Exynos4 ASV patch does not contain "CONFIG_EXYNOS_ASV", we have added the symbol to hide the dependent from compilers for now. As soon as Exynos4 ASV drivers are merged, the #ifdef statement will be removed or the name will be changed. However, enabling ASV is essential in most Exynos4 chips to reduce the power consumption of Exynos4210 because without ASV, this Devfreq driver assumes the worst case scenario, which consumes more power. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> --- Changes from v1 - Support 4212 and 4412 as well as 4210.
2011-11-23PM / devfreq: separate error paths from successful pathAxel Lin
I think this change improves code readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
