Provide a common function to initialize a channels cookie values.
Change-Id: Idc822d69971d7a6d26ffea8809df4825b87020e5
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Jassi Brar <jassisinghbrar@gmail.com>
[imx-sdma.c & mxs-dma.c]
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
(cherry picked from mainline commit
d3ee98cdcd6198ea1cf75c603178acc8a805b69b)
Change-Id: Id7d52f05b78d15b0c61cb04122b19810e78b9269
Reviewed-on: http://git-master/r/93783
Now that we have the completed cookie in the dma_chan structure, we
can consolidate the tx_status functions by providing a function to set
the txstate structure and returning the DMA status. We also provide
a separate helper to set the residue for cookies which are still in
progress.
Change-Id: I4b7672bbd17d072bfde348d04481c8db48e814c4
96a2af41c78b1fbb1f567a3486bdc63f7b31c5fd)
Change-Id: Ifdb55d85eb4789f221679f1f38f5566168e5c643
Reviewed-on: http://git-master/r/93782
Provide a common function to do the cookie mechanics for completing
a DMA descriptor.
Cherry-picked from mainline commit
f7fbce07c6ce26a25b4e0cb5f241c361fde87901
Change-Id: I0b0a9d4ad538db4fda227cc91436c44bc4a6f206
Reviewed-on: http://git-master/r/93781
Everyone deals with assigning DMA cookies in the same way (it's part of
the API so they should be), so lets consolidate the common code into a
helper function to avoid this duplication.
Change-Id: I730882ff0f84f9ae42dd137a8926b7ae10868370
(cherry picked from mainline commit 884485e1f12dcd39390f042e772cdbefc9ebb750)
Change-Id: Ifc4a395a5dbafad03f8b28e052ad0e7ea5d90163
Reviewed-on: http://git-master/r/93780
Add a local private header file to contain definitions and declarations
which should only be used by DMA engine drivers.
We also fix linux/dmaengine.h to use LINUX_DMAENGINE_H to guard against
multiple inclusion.
(cherry picked from mainline commit d2ebfb335b0426deb1a4fb14e4e926d81ecd8235)
Change-Id: I91b051537fa1890e2651ebe0409fa97cbc9191dd
Reviewed-on: http://git-master/r/93779
