Add context parameter to device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to allow passing client/target specific information associated
with the data transfer.
Modify all affected DMA engine drivers.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
Cherry-picked from mainline
185ecb5f4fd43911c35956d4cc7d94a1da30417f
Change-Id: Ief79d20f6e9d367ee2b530d08df72864fb16895a
Reviewed-on: http://git-master/r/94464
In S2R all DMA registers are reset by hardware and thus they are required to be
reprogrammed. The channels which aren't reprogrammed are channel configuration
and interrupt enable registers, which are currently programmed at chan_alloc
time.
This patch creates another routine to initialize a channel. It will try to
initialize channel on every dwc_dostart() call. If channel is already
initialised then it simply returns, otherwise it configures registers.
This routine will also initialize registers on wakeup from S2R, as we mark
channels as uninitialized on suspend.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
cherry-picked from mainline 61e183f8306934a9f66557f69f1f0f56f18dca06
Change-Id: I4ede3e1db8844533161bd4a836b1fece0d0ee716
Reviewed-on: http://git-master/r/93784
Provide a common function to initialize a channels cookie values.
Change-Id: Idc822d69971d7a6d26ffea8809df4825b87020e5
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Jassi Brar <jassisinghbrar@gmail.com>
[imx-sdma.c & mxs-dma.c]
Tested-by: Shawn Guo <shawn.guo@linaro.org>
(cherry picked from mainline commit
d3ee98cdcd6198ea1cf75c603178acc8a805b69b)
Change-Id: Id7d52f05b78d15b0c61cb04122b19810e78b9269
Reviewed-on: http://git-master/r/93783
Now that we have the completed cookie in the dma_chan structure, we
can consolidate the tx_status functions by providing a function to set
the txstate structure and returning the DMA status. We also provide
a separate helper to set the residue for cookies which are still in
progress.
Change-Id: I4b7672bbd17d072bfde348d04481c8db48e814c4
96a2af41c78b1fbb1f567a3486bdc63f7b31c5fd)
Change-Id: Ifdb55d85eb4789f221679f1f38f5566168e5c643
Reviewed-on: http://git-master/r/93782
Provide a common function to do the cookie mechanics for completing
a DMA descriptor.
Cherry-picked from mainline commit
f7fbce07c6ce26a25b4e0cb5f241c361fde87901
Change-Id: I0b0a9d4ad538db4fda227cc91436c44bc4a6f206
Reviewed-on: http://git-master/r/93781
Everyone deals with assigning DMA cookies in the same way (it's part of
the API so they should be), so lets consolidate the common code into a
helper function to avoid this duplication.
Change-Id: I730882ff0f84f9ae42dd137a8926b7ae10868370
(cherry picked from mainline commit 884485e1f12dcd39390f042e772cdbefc9ebb750)
Change-Id: Ifc4a395a5dbafad03f8b28e052ad0e7ea5d90163
Reviewed-on: http://git-master/r/93780
Add a local private header file to contain definitions and declarations
which should only be used by DMA engine drivers.
We also fix linux/dmaengine.h to use LINUX_DMAENGINE_H to guard against
multiple inclusion.
(cherry picked from mainline commit d2ebfb335b0426deb1a4fb14e4e926d81ecd8235)
Change-Id: I91b051537fa1890e2651ebe0409fa97cbc9191dd
Reviewed-on: http://git-master/r/93779
Every DMA engine implementation declares a last completed dma cookie
in their private dma channel structures. This is pointless, and
forces driver specific code. Move this out into the common dma_chan
structure.
4d4e58de32a192fea65ab84509d17d199bd291c8
Change-Id: Ib653bcfa5f492986946fd34006a8de3090db0441
Reviewed-on: http://git-master/r/93778
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits)
x86: poll waiting for I/OAT DMA channel status
maintainers: add dma engine tree details
dmaengine: add TODO items for future work on dma drivers
dmaengine: Add API documentation for slave dma usage
dmaengine/dw_dmac: Update maintainer-ship
dmaengine: move link order
dmaengine/dw_dmac: implement pause and resume in dwc_control
dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback
dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT
dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS
dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called
dmaengine: at_hdmac: pause: no need to wait for FIFO empty
pch_dma: modify pci device table definition
pch_dma: Support new device ML7223 IOH
pch_dma: Support I2S for ML7213 IOH
pch_dma: Fix DMA setting issue
pch_dma: modify for checkpatch
pch_dma: fix dma direction issue for ML7213 IOH video-in
dmaengine: at_hdmac: use descriptor chaining help function
dmaengine: at_hdmac: implement pause and resume in atc_control
Fix up trivial conflict in drivers/dma/dw_dmac.c
Nobody is currently maintaining dw_dmac. We are using dw_dmac for SPEAr13xx and
are currently maintaining it. After discussing with Vinod, sending this patch to
update maintainer-ship of dw_dmac.
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Haavard's e-mail address at Atmel is no longer valid.
Some peripherals like amba-pl011 needs pause to be implemented in DMA controller
drivers. This also returns correct status from dwc_tx_status() in case chan is
paused.
dmaengine routines can be called from interrupt context and with interrupts
disabled. Whereas spin_unlock_bh can't be called from such contexts. So this
patch converts all spin_*_bh routines to irqsave variants.
Also, spin_lock() used in tasklet is converted to irqsave variants, as tasklet
can be interrupted, and dma requests from such interruptions may also call
spin_lock.
Now, submission from callbacks are permitted as per dmaengine framework. So we
shouldn't hold any locks while calling callbacks. As locks were taken by parent
routines, so releasing them before calling callbacks doesn't look clean enough.
So, locks are taken inside all routine now, whereever they are required. And
dwc_descriptor_complete is always called without taking locks.
DWC_MAX_COUNT
If len passed in sg for slave_sg transfers is greater than DWC_MAX_COUNT, then
driver programmes controller incorrectly. This patch adds code to handle this
situation by allocation more than one desc for same sg.
!DMA_SUCCESS
If transfer status is !=DMA_SUCCESS, return total transfer len as residue,
instead of zero.
If dmaengine_terminate_all() is called for dma channel, then it doesn't make
much sense to call registered callback routine. While in case of success or
failure it must be called.
also with llp
dwc_scan_descriptors scans all descriptors from active_list in case transfer is
not completed. It compares first_desc->lli.llp, and then all childrens of its
tx_list. But it doesn't compare its own address, i.e. first_desc->txd.phys, as
this is what we have initially programmed into the controller register. So this
causes dma to stop and finish a transfer, which was never started. And thus
fail.
This patch sets default Burst length for all transfer to 16. This will
enhance performance when user doesn't have any chan->private data.
Msize or Burst Size is peripheral dependent in case of prep_slave_sg and
cyclic_prep transfers, and in case of memcpy transfers it is platform dependent.
So msize configuration must come from platform data.
Also some peripherals (ex: JPEG), need to be flow controller for dma transfers,
so this information in case of slave_sg & cyclic_prep transfers must come from
platform data.
In Synopsys designware, channel priority is programmable. This patch adds
support for passing channel priority through platform data. By default Ascending
channel priority will be followed, i.e. channel 0 will get highest priority and
channel 7 will get lowest.
In SPEAr Platform channels 4-7 have more Fifo depth. So we must get better
channel first. This patch introduces concept of channel allocation order in
dw_dmac. If user doesn't pass anything or 0, than normal (ascending) channel
allocation will follow, else channels will be allocated in descending order.
dwc_desc_get checks all descriptors for DMA_CTRL_ACK before allocating them for
transfers. And descriptors are not marked with DMA_CRTL_ACK after transfer
finishes. Thus descriptor once used is not usable again. This patch marks
descriptors with DMA_CRTL_ACK after dma xfer finishes
Every descriptor can transfer a maximum count of 4095 (12 bits, in control reg),
So we must have DWC_MAX_COUNT as 4095 instead of 2048.
Lock must be taken before calling dwc_scan_descriptors, as this may
access/modify shared data and queues. dwc_tx_status wasn't taking lock before
calling this routine. This patch add code that takes lock before calling
dwc_scan_descriptors.
dwc_complete_all
dwc_complete_all and other routines was removing all descriptors from dwc->queue
and pushing them to dwc->active_list. Only one was required to be removed. Also
we are calling dwc_dostart, once list is fixed.
In some cases users of dw_dmac are initialized before dw_dmac, and if they try
to use dw_dmac, they simply fail. So its better we register init() routine
of driver using subsys_initcall() instead of module_init(), so that dma driver
is available at the earliest possible.
Some platforms (e.g. Picochip PC3XX) have multiple DMA controllers
where some may be used for slave transfers and others for general
purpose memcpy type transfers. Add a .is_private boolean to the
platform data structure so that controllers can be marked as private
so that the DMA_PRIVATE capability will be set for that controller.
Signed-off-by: Jamie Iles <jamie.iles@picochip.com>
Some platforms have flexible mastering capabilities and this needs
to be selected at runtime. If the platform has specified private
data in the form of the dw_dma_slave then fetch the source and
destination masters from here. If this isn't present, default to
the previous of 0 and 1.
v2: cleanup whitespace
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Some hardware (picoChip picoXCell in particular) sometimes has
the block transfer complete bit being set for a channel after the
whole transfer has completed. If we don't have any transfers in the
active list then don't bother to scan the descriptors. This often
happens in normal operation and doesn't require the channel to be
reset.
This adds an argument to the DMAengine control function, so that
we can later provide control commands that need some external data
passed in through an argument akin to the ioctl() operation
prototype.
[dan.j.williams@intel.com: fix up some missed conversions]
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Simple conditional struct filler to cut out some duplicated code.
Convert the device_is_tx_complete() operation on the
DMA engine to a generic device_tx_status()operation which
can return three states, DMA_TX_RUNNING, DMA_TX_COMPLETE,
DMA_TX_PAUSED.
[dan.j.williams@intel.com: update for timberdale]
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Maciej Sosnowski <maciej.sosnowski@intel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Li Yang <leoli@freescale.com>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Magnus Damm <damm@opensource.se>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Joe Perches <joe@perches.com>
Cc: Roland Dreier <rdreier@cisco.com>
Convert the device_terminate_all() operation on the
DMA engine to a generic device_control() operation
which can now optionally support also pausing and
resuming DMA on a certain channel. Implemented for the
COH 901 318 DMAC as an example.
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
drivers/dma: Correct use after free
drivers/dma: drop unnecesary memset
ioat2,3: put channel hardware in known state at init
async_tx: expand async raid6 test to cover ioatdma corner case
ioat3: fix p-disabled q-continuation
sh: fix DMA driver's descriptor chaining and cookie assignment
dma: at_hdmac: correct incompatible type for argument 1 of 'spin_lock_bh'
memset of 0 is not needed after kzalloc
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x;
statement S;
x = kzalloc(...);
if (x == NULL) S
... when != x
-memset(x,0,...);// </smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
Dan Williams wrote:
... DMA-slave clients request specific channels and know the hardware
details at a low level, so it should not be too high an expectation to
push dma mapping responsibility to the client.
Also this patch includes DMA_COMPL_{SRC,DEST}_UNMAP_SINGLE support for
dw_dmac driver.
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Drop dw_dmac's use of tx_list from struct dma_async_tx_descriptor in
preparation for removal of this field.
This patch reworks platform driver power management code
for dw_dmac from legacy late/early callbacks to dev_pm_ops.
The callbacks are converted for CONFIG_SUSPEND like this:
suspend_late() -> suspend_noirq()
resume_early() -> resume_noirq()
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: Pavel Machek <pavel@ucw.cz>
dma: Add SoF and EoF debugging to ipu_idmac.c, minor cleanup
dw_dmac: add cyclic API to DW DMA driver
dmaengine: Add privatecnt to revert DMA_PRIVATE property
dmatest: add dma interrupts and callbacks
dmatest: add xor test
dmaengine: allow dma support for async_tx to be toggled
async_tx: provide __async_inline for HAS_DMA=n archs
dmaengine: kill some unused headers
dmaengine: initialize tx_list in dma_async_tx_descriptor_init
dma: i.MX31 IPU DMA robustness improvements
dma: improve section assignment in i.MX31 IPU DMA driver
dma: ipu_idmac driver cosmetic clean-up
dmaengine: fail device registration if channel registration fails
This patch adds a cyclic DMA interface to the DW DMA driver. This is
very useful if you want to use the DMA controller in combination with a
sound device which uses cyclic buffers.
Using a DMA channel for cyclic DMA will disable the possibility to use
it as a normal DMA engine until the user calls the cyclic free function
on the DMA channel. Also a cyclic DMA list can not be prepared if the
channel is already active.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Centralize this common initialization (and one case where ipu_idmac is
duplicating ->chan initialization).
Cc: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The conversion of atmel-mci to dma_request_channel missed the
initialization of the channel dma_slave information. The filter_fn passed
to dma_request_channel is responsible for initializing the channel's
private data. This implementation has the additional benefit of enabling
a generic client-channel data passing mechanism.
Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Resolves:
WARNING: at drivers/base/core.c:122 device_release+0x4d/0x52()
Device 'dma0chan0' does not have a release() function, it is broken and must be fixed.
The dma_chan_dev object is introduced to gear-match sysfs kobject and
dmaengine channel lifetimes. When a channel is removed access to the
sysfs entries return -ENODEV until the kobject can be released.
The bulk of the change is updates to existing code to handle the extra
layer of indirection between a dma_chan and its struct device.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
All users have been converted to either the general-purpose allocator,
dma_find_channel, or dma_request_channel.
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
dma_request_channel provides an exclusive channel, so we no longer need to
pass slave data through dmaengine.
Simply, if a client wants any dmaengine channel then prevent all dmaengine
modules from being removed. Once the clients are done re-enable module
removal.
Why?, beyond reducing complication:
1/ Tracking reference counts per-transaction in an efficient manner, as
is currently done, requires a complicated scheme to avoid cache-line
bouncing effects.
2/ Per-transaction ref-counting gives the false impression that a
dma-driver can be gracefully removed ahead of its user (net, md, or
dma-slave)
3/ None of the in-tree dma-drivers talk to hot pluggable hardware, but
if such an engine were built one day we still would not need to notify
clients of remove events. The driver can simply return NULL to a
->prep() request, something that is much easier for a client to handle.
