path: root/drivers/dma
2015-10-02Merge tag 'dmaengine-fix-4.3-rc4' of ↵Linus Torvalds
git://git.infradead.org/users/vkoul/slave-dma Pull dmaengine fixes from Vinod Koul: "This contains fixes spread throughout the drivers, and also fixes one more instance of privatecnt in dmaengine. Driver fixes summary: - bunch of pxa_dma fixes for reuse of descriptor issue, residue and no-requestor - odd fixes in xgene, idma, sun4i and zxdma - at_xdmac fixes for cleaning descriptor and block addr mode" * tag 'dmaengine-fix-4.3-rc4' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: pxa_dma: fix residue corner case dmaengine: pxa_dma: fix the no-requestor case dmaengine: zxdma: Fix off-by-one for testing valid pchan request dmaengine: at_xdmac: clean used descriptor dmaengine: at_xdmac: change block increment addressing mode dmaengine: dw: properly read DWC_PARAMS register dmaengine: xgene-dma: Fix overwritting DMA tx ring dmaengine: fix balance of privatecnt dmaengine: sun4i: fix unsafe list iteration dmaengine: idma64: improve residue estimation dmaengine: xgene-dma: fix handling xgene_dma_get_ring_size result dmaengine: pxa_dma: fix initial list move
2015-10-01dmaengine: pxa_dma: fix residue corner caseRobert Jarzmik
A very tiny temporal window exists in the residue calculation where : - upon entering residue calculation, the transfer is ongoing - when reading the current transfer pointer, it just changed to the "finisher/linker" descriptor In this case, the residue returned is the whole transfer length instead of 0. Fix it. This appears almost in one extreme case, where the driver is used by older clients which inquire for residue in interrupt context, such as the smsc91x ethernet driver, in a tight loop : interrupt_handler() dmaengine_submit() do { dmaengine_tx_status() } while (residue > 0 || status != DMA_ERROR) Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-10-01dmaengine: pxa_dma: fix the no-requestor caseRobert Jarzmik
A very small number of devices don't use the flow control offered by requestor lines. In these specific cases, the pxa dma driver should be aware of that and not try to use a requestor line. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-10-01dmaengine: zxdma: Fix off-by-one for testing valid pchan requestAxel Lin
The valid pchan range is 0 ~ d->dma_requests - 1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Jun Nie <jun.nie@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-10-01dmaengine: at_xdmac: clean used descriptorLudovic Desroches
When putting back a descriptor to the free descs list, some fields are not set to 0, it can cause bugs if someone uses it without having this in mind. Descriptor are not put back one by one so it is easier to clean descriptors when we request them. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: stable@vger.kernel.org #4.2 Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-10-01dmaengine: at_xdmac: change block increment addressing modeMaxime Ripard
The addressing mode we were using was not only incrementing the address at each microblock, but also at each data boundary, which was severely slowing the transfer, without any benefit since we were not using the data stride. Switch to the micro block increment only in order to get back to an acceptable performance level. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Fixes: 6007ccb57744 ("dmaengine: xdmac: Add interleaved transfer support") Cc: stable@vger.kernel.org #4.2 Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-30dmaengine: dw: properly read DWC_PARAMS registerAndy Shevchenko
In case we have less than maximum allowed channels (8) and autoconfiguration is enabled the DWC_PARAMS read is wrong because it uses different arithmetic to what is needed for channel priority setup. Re-do the caclulations properly. This now works on AVR32 board well. Fixes: fed2574b3c9f (dw_dmac: introduce software emulation of LLP transfers) Cc: yitian.bu@tangramtek.com Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-30dmaengine: xgene-dma: Fix overwritting DMA tx ringRameshwar Prasad Sahu
This patch fixes an over flow issue with the TX ring descriptor. Each descriptor is 32B in size and an operation requires 2 of these descriptors. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-30dmaengine: fix balance of privatecntPeter Ujfalusi
dma_release_channel() decrements privatecnt counter and almost all dma_get* function increments it with the exception of dma_get_slave_channel(). In most cases this does not cause issue since normally the channel is not requested and released, but if a driver requests DMA channel via dma_get_slave_channel() and releases the channel the privatecnt will be unbalanced and this will prevent for example getting channel for memcpy. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-30dmaengine: sun4i: fix unsafe list iterationEmilio López
Currently, sun4i_dma_free_contract iterates over lists and frees memory as it goes through them, causing reads to recently freed memory to be performed. Fix this by using the safe version of the iterator, so freed memory is not referenced at all. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Emilio López <emilio@elopez.com.ar> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-25dmaengine: idma64: improve residue estimationAndy Shevchenko
The residue calculation may provide a wrong estimation when the transfer is started. There are possible scenarios we have to separate: 1) the transfer is not started yet; residue is equal to the total length; 2) the transfer is just started (first chunk is ongoing); residue is equal to the total length without already transfered bytes; 3) the transfer is ongoing and we already sent few chunks of data; residue is equal to the total length without fully transfered chunks and already sent bytes. Mistakenly the calculation in cases 2) and 3) was done in the similar way and the result is equal to -bytes that have been transfered, i.e. quite big since size_t type can't keep negative values. Rewrite the calculation algorithm to be one pass and have a correct result. Besides above in case user asks for a status of the active DMA descriptor without pausing an ongoing transfer the residue will be estimated based on the register value, though it's still racy. Since the transfer is active the value is continuously being changed. Here we have to read two registers at a time. To minimize an error make those reads close to each other. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-25dmaengine: xgene-dma: fix handling xgene_dma_get_ring_size resultAndrzej Hajda
The function can return negative value. The problem has been detected using proposed semantic patch scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2046107 Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-25dmaengine: pxa_dma: fix initial list moveRobert Jarzmik
Since the commit to have an allocated list of virtual descriptors was reverted, the pxa_dma driver is broken, as it assumes the descriptor is placed on the allocated list upon allocation. Fix the issue in pxa_dma by making an allocated virtual descriptor a singleton. Fixes: 8c8fe97b2b8a ("Revert "dmaengine: virt-dma: don't always free descriptor upon completion"") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-04Merge tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have aded a new capability for scatter-gathered memset using dmaengine APIs. This is supported in xdmac & hdmac drivers We have added support for reusing descriptors for examples like video buffers etc. Driver will follow The behaviour of descriptor ack has been clarified and documented New devices added are: - dma controller in sun[457]i SoCs - lpc18xx dmamux - ZTE ZX296702 dma controller - Analog Devices AXI-DMAC DMA controller - eDMA support for dma-crossbar - imx6sx support in imx-sdma driver - imx-sdma device to device support Other: - jz4780 fixes - ioatdma large refactor and cleanup for removal of ioat v1 and v2 which is deprecated and fixes - ACPI support in X-Gene DMA engine driver - ipu irq fixes - mvxor fixes - minor fixes spread thru drivers" [ The Kconfig and Makefile entries got re-sorted alphabetically, and I handled the conflict with the new Intel integrated IDMA driver by slightly mis-sorting it on purpose: "IDMA64" got sorted after "IMX" in order to keep the Intel entries together. I think it might be a good idea to just rename the IDMA64 config entry to INTEL_IDMA64 to make the sorting be a true sort, not this mismash. Also, this merge disables the COMPILE_TEST for the sun4i DMA controller, because it does not compile cleanly at all. - Linus ] * tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (89 commits) dmaengine: ioatdma: add Broadwell EP ioatdma PCI dev IDs dmaengine :ipu: change ipu_irq_handler() to remove compile warning dmaengine: ioatdma: Fix variable array length dmaengine: ioatdma: fix sparse "error" with prep lock dmaengine: hdmac: Add memset capabilities dmaengine: sort the sh Makefile dmaengine: sort the sh Kconfig dmaengine: sort the dw Kconfig dmaengine: sort the Kconfig dmaengine: sort the makefile drivers/dma: make mv_xor.c driver explicitly non-modular dmaengine: Add support for the Analog Devices AXI-DMAC DMA controller devicetree: Add bindings documentation for Analog Devices AXI-DMAC dmaengine: xgene-dma: Fix the lock to allow client for further submission of requests dmaengine: ioatdma: fix coccinelle warning dmaengine: ioatdma: fix zero day warning on incompatible pointer type dmaengine: tegra-apb: Simplify locking for device using global pause dmaengine: tegra-apb: Remove unnecessary return statements and variables dmaengine: tegra-apb: Avoid unnecessary channel base address calculation dmaengine: tegra-apb: Remove unused variables ...
2015-09-01Merge tag 'pm+acpi-4.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "From the number of commits perspective, the biggest items are ACPICA and cpufreq changes with the latter taking the lead (over 50 commits). On the cpufreq front, there are many cleanups and minor fixes in the core and governors, driver updates etc. We also have a new cpufreq driver for Mediatek MT8173 chips. ACPICA mostly updates its debug infrastructure and adds a number of fixes and cleanups for a good measure. The Operating Performance Points (OPP) framework is updated with new DT bindings and support for them among other things. We have a few updates of the generic power domains framework and a reorganization of the ACPI device enumeration code and bus type operations. And a lot of fixes and cleanups all over. Included is one branch from the MFD tree as it contains some PM-related driver core and ACPI PM changes a few other commits are based on. Specifics: - ACPICA update to upstream revision 20150818 including method tracing extensions to allow more in-depth AML debugging in the kernel and a number of assorted fixes and cleanups (Bob Moore, Lv Zheng, Markus Elfring). - ACPI sysfs code updates and a documentation update related to AML method tracing (Lv Zheng). - ACPI EC driver fix related to serialized evaluations of _Qxx methods and ACPI tools updates allowing the EC userspace tool to be built from the kernel source (Lv Zheng). - ACPI processor driver updates preparing it for future introduction of CPPC support and ACPI PCC mailbox driver updates (Ashwin Chaugule). - ACPI interrupts enumeration fix for a regression related to the handling of IRQ attribute conflicts between MADT and the ACPI namespace (Jiang Liu). - Fixes related to ACPI device PM (Mika Westerberg, Srinidhi Kasagar). - ACPI device registration code reorganization to separate the sysfs-related code and bus type operations from the rest (Rafael J Wysocki). - Assorted cleanups in the ACPI core (Jarkko Nikula, Mathias Krause, Andy Shevchenko, Rafael J Wysocki, Nicolas Iooss). - ACPI cpufreq driver and ia64 cpufreq driver fixes and cleanups (Pan Xinhui, Rafael J Wysocki). - cpufreq core cleanups on top of the previous changes allowing it to preseve its sysfs directories over system suspend/resume (Viresh Kumar, Rafael J Wysocki, Sebastian Andrzej Siewior). - cpufreq fixes and cleanups related to governors (Viresh Kumar). - cpufreq updates (core and the cpufreq-dt driver) related to the turbo/boost mode support (Viresh Kumar, Bartlomiej Zolnierkiewicz). - New DT bindings for Operating Performance Points (OPP), support for them in the OPP framework and in the cpufreq-dt driver plus related OPP framework fixes and cleanups (Viresh Kumar). - cpufreq powernv driver updates (Shilpasri G Bhat). - New cpufreq driver for Mediatek MT8173 (Pi-Cheng Chen). - Assorted cpufreq driver (speedstep-lib, sfi, integrator) cleanups and fixes (Abhilash Jindal, Andrzej Hajda, Cristian Ardelean). - intel_pstate driver updates including Skylake-S support, support for enabling HW P-states per CPU and an additional vendor bypass list entry (Kristen Carlson Accardi, Chen Yu, Ethan Zhao). - cpuidle core fixes related to the handling of coupled idle states (Xunlei Pang). - intel_idle driver updates including Skylake Client support and support for freeze-mode-specific idle states (Len Brown). - Driver core updates related to power management (Andy Shevchenko, Rafael J Wysocki). - Generic power domains framework fixes and cleanups (Jon Hunter, Geert Uytterhoeven, Rajendra Nayak, Ulf Hansson). - Device PM QoS framework update to allow the latency tolerance setting to be exposed to user space via sysfs (Mika Westerberg). - devfreq support for PPMUv2 in Exynos5433 and a fix for an incorrect exynos-ppmu DT binding (Chanwoo Choi, Javier Martinez Canillas). - System sleep support updates (Alan Stern, Len Brown, SungEun Kim). - rockchip-io AVS support updates (Heiko Stuebner). - PM core clocks support fixup (Colin Ian King). - Power capping RAPL driver update including support for Skylake H/S and Broadwell-H (Radivoje Jovanovic, Seiichi Ikarashi). - Generic device properties framework fixes related to the handling of static (driver-provided) property sets (Andy Shevchenko). - turbostat and cpupower updates (Len Brown, Shilpasri G Bhat, Shreyas B Prabhu)" * tag 'pm+acpi-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (180 commits) cpufreq: speedstep-lib: Use monotonic clock cpufreq: powernv: Increase the verbosity of OCC console messages cpufreq: sfi: use kmemdup rather than duplicating its implementation cpufreq: drop !cpufreq_driver check from cpufreq_parse_governor() cpufreq: rename cpufreq_real_policy as cpufreq_user_policy cpufreq: remove redundant 'policy' field from user_policy cpufreq: remove redundant 'governor' field from user_policy cpufreq: update user_policy.* on success cpufreq: use memcpy() to copy policy cpufreq: remove redundant CPUFREQ_INCOMPATIBLE notifier event cpufreq: mediatek: Add MT8173 cpufreq driver dt-bindings: mediatek: Add MT8173 CPU DVFS clock bindings PM / Domains: Fix typo in description of genpd_dev_pm_detach() PM / Domains: Remove unusable governor dummies PM / Domains: Make pm_genpd_init() available to modules PM / domains: Align column headers and data in pm_genpd_summary output powercap / RAPL: disable the 2nd power limit properly tools: cpupower: Fix error when running cpupower monitor PM / OPP: Drop unlikely before IS_ERR(_OR_NULL) PM / OPP: Fix static checker warning (broken 64bit big endian systems) ...
2015-09-01Merge branch 'acpi-pm'Rafael J. Wysocki
* acpi-pm: ACPI / bus: Move duplicate code to a separate new function mfd: Add support for Intel Sunrisepoint LPSS devices dmaengine: add a driver for Intel integrated DMA 64-bit mfd: make mfd_remove_devices() iterate in reverse order driver core: implement device_for_each_child_reverse() klist: implement klist_prev() Driver core: wakeup the parent device before trying probe ACPI / PM: Attach ACPI power domain only once PM / QoS: Make it possible to expose device latency tolerance to userspace ACPI / PM: Update the copyright notice and description of power.c
2015-08-28dmaengine: ioatdma: add Broadwell EP ioatdma PCI dev IDsDave Jiang
Adding the Broadwell Xeon ioatdma PCI device IDs and related bits. This is still IOATDMA 3.2 based hw. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-28dmaengine :ipu: change ipu_irq_handler() to remove compile warningyalin wang
Change ipu_irq_handler() to avoid gcc warning: drivers/dma/ipu/ipu_irq.c:305:4: warning: 'irq' may be used uninitialized in this function [-Wmaybe-uninitialized] generic_handle_irq(irq); Signed-off-by: yalin wang <yalin.wang2010@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-26dmaengine: ioatdma: Fix variable array lengthDave Jiang
Sparse reported: drivers/dma/ioat/prep.c:637:27: sparse: Variable length array is used. Assigning a static value for the array. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-26dmaengine: ioatdma: fix sparse "error" with prep lockDave Jiang
The prep lock gets acquired in ioat_check_space_lock and released in ioat_tx_submit_unlock. Setting the annotations so sparse does not freak out. drivers/dma/ioat/dma.c:273:30: sparse: context imbalance in 'ioat_tx_submit_unlock' - unexpected unlock drivers/dma/ioat/dma.c:476:5: sparse: context imbalance in 'ioat_check_space_lock' - wrong count at exit Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-26dmaengine: hdmac: Add memset capabilitiesMaxime Ripard
Just like for the XDMAC, the SoCs that embed the HDMAC don't have any kind of GPU, and need to accelerate a few framebuffer-related operations through their DMA controller. However, unlike the XDMAC, the HDMAC doesn't have the memset capability built-in. That can be easily emulated though, by doing a transfer with a fixed address on the variable that holds the value we want to set. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-26dmaengine: sort the sh MakefileVinod Koul
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-26dmaengine: sort the sh KconfigVinod Koul
2015-08-25drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-styleLuis R. Rodriguez
dma_alloc_writecombine()'s call and return value check is tangled in all in one call. Untangle both calls according to kernel coding style. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: benh@kernel.crashing.org Cc: bhelgaas@google.com Cc: daniel.vetter@ffwll.ch Cc: dmaengine@vger.kernel.org Cc: konrad.wilk@oracle.com Cc: luto@amacapital.net Cc: mst@redhat.com Cc: tomi.valkeinen@ti.com Cc: toshi.kani@hp.com Cc: xen-devel@lists.xensource.com Link: http://lkml.kernel.org/r/1440443613-13696-10-git-send-email-mcgrof@do-not-panic.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-24dmaengine: sort the dw KconfigVinod Koul
2015-08-24dmaengine: sort the KconfigVinod Koul
dmaengine Kconfig grew over the years, unfortunately without any order to it. So order by core, driver and client sections, and sort these sections alphabetically Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-24dmaengine: sort the makefileVinod Koul
dmaengine makefile grew over the years, unfortunately without any order to it. So order by core, dmatest and driver sections and sort these sections alphabetically Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-23drivers/dma: make mv_xor.c driver explicitly non-modularPaul Gortmaker
The Kconfig for this driver is currently: config MV_XOR bool "Marvell XOR engine support" ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. We leave some tags like MODULE_AUTHOR for documentation purposes. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: dmaengine@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-23dmaengine: Add support for the Analog Devices AXI-DMAC DMA controllerLars-Peter Clausen
Add support for the Analog Devices AXI-DMAC DMA controller. This controller is a soft peripheral that can be instantiated in a FPGA and is often used in Analog Devices' reference designs for FPGA platforms. The peripheral has various configuration options that can be selected at synthesis time and influence the supported features of the instantiated peripheral, those options are represented as device-tree properties to allow the driver to behave accordingly. The peripheral has a zero latency architecture, which means it is possible to switch from one to the next descriptor without any delay. This is archived by having a internal queue which can hold multiple descriptors. The driver supports this, which means it will submit new descriptors directly to the hardware until the queue is full and not wait for a descriptor to complete before the next one is submitted. Interrupts are used for the descriptor queue flow control. Currently the driver supports SG, cyclic and interleaved slave DMA. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-23Merge branch 'topic/zxdma' into for-linusVinod Koul
2015-08-23Merge branch 'topic/ti-xbar' into for-linusVinod Koul
2015-08-23Merge branch 'topic/at_xdmac' into for-linusVinod Koul
2015-08-21dmaengine: xgene-dma: Fix the lock to allow client for further submission of ↵Rameshwar Prasad Sahu
requests This patch provides the fix in the cleanup routing such that client can perform further submission by releasing the lock before calling client's callback function. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-21dmaengine: ioatdma: fix coccinelle warningDave Jiang
Simplifying the end return. This existed in the original code but was flagged when refactoring of the code made it appear it's new. coccinelle warnings: (new ones prefixed by >>) >> drivers/dma/ioat/init.c:1018:1-3: WARNING: end returns can be simpified Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-21dmaengine: ioatdma: fix zero day warning on incompatible pointer typeDave Jiang
The 32bit build is creating this warning. Since we don't expect anyone actually use this on 32bit, restrict ioatdma to be built only on x86_64. This issue has long existed and only reason it's surfacing due to code refactoring. drivers/dma/ioat/dma.c: In function 'ioat_timer_event': >> drivers/dma/ioat/dma.c:870:39: warning: passing argument 2 of 'ioat_cleanup_preamble' from incompatible pointer type if (ioat_cleanup_preamble(ioat_chan, &phys_complete)) ^ drivers/dma/ioat/dma.c:577:13: note: expected 'u64 *' but argument is of type 'dma_addr_t *' static bool ioat_cleanup_preamble(struct ioatdma_chan *ioat_chan, ^ Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: tegra-apb: Simplify locking for device using global pauseJon Hunter
Sparse reports the following with regard to locking in the tegra_dma_global_pause() and tegra_dma_global_resume() functions: drivers/dma/tegra20-apb-dma.c:362:9: warning: context imbalance in 'tegra_dma_global_pause' - wrong count at exit drivers/dma/tegra20-apb-dma.c:366:13: warning: context imbalance in 'tegra_dma_global_resume' - unexpected unlock The warning is caused because tegra_dma_global_pause() acquires a lock but does not release it. However, the lock is released by tegra_dma_global_resume(). These pause/resume functions are called in pairs and so it does appear to work. This global pause is used on early tegra devices that do not have an individual pause for each channel. The lock appears to be used to ensure that multiple channels do not attempt to assert/de-assert the global pause at the same time which could cause the DMA controller to be in the wrong paused state. Rather than locking around the entire code between the pause and resume, employ a simple counter to keep track of the global pause requests. By using a counter, it is only necessary to hold the lock when pausing and unpausing the DMA controller and hence, fixes the sparse warning. Please note that for devices that support individual channel pausing, the DMA controller lock is not held between pausing and unpausing the channel. Hence, this change will make the devices that use the global pause behave in the same way, with regard to locking, as those that don't. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: tegra-apb: Remove unnecessary return statements and variablesJon Hunter
Some void functions have unnecessary return statements at the end (reported by sparse) and so remove these. Also remove the return variables from functions tegra_dma_prep_slave_sg() and tegra_dma_prep_slave_cyclic() because the value is not used. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: tegra-apb: Avoid unnecessary channel base address calculationJon Hunter
Everytime a DMA channel register is accessed, the channel base address is calculated by adding the DMA base address and the channel register offset. Avoid this calculation and simply calculate the channel base address once at probe time for each DMA channel. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: tegra-apb: Remove unused variablesJon Hunter
The callback and callback_param members of the tegra_dma_sg_req structure are never used. The dma-engine structure, dma_async_tx_descriptor, defines the same members and these are the ones used by the driver. Therefore, remove the unused versions from the tegra_dma_sg_req structure. The half_done member of tegra_dma_channel structure is configured but never used and so remove it. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: xgene-dma: Add ACPI support for X-Gene DMA engine driverRameshwar Prasad Sahu
This patch adds ACPI support for the APM X-Gene DMA engine driver. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: imx-sdma: Check for clk_enable() errorsFabio Estevam
clk_enable() may fail, so we should better check the return value and propagate it in the case of error. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-20dmaengine: sun4i: Add support for the DMA engine on sun[457]i SoCsEmilio López
This patch adds support for the DMA engine present on Allwinner A10, A13, A10S and A20 SoCs. This engine has two kinds of channels: normal and dedicated. The main difference is in the mode of operation; while a single normal channel may be operating at any given time, dedicated channels may operate simultaneously provided there is no overlap of source or destination. Hardware documentation can be found on A10 User Manual (section 12), A13 User Manual (section 14) and A20 User Manual (section 1.12) Signed-off-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: mv_xor: optimize performance by using a subset of the XOR channelsThomas Petazzoni
Due to how async_tx behaves internally, having more XOR channels than CPUs is actually hurting performance more than it improves it, because memcpy requests get scheduled on a different channel than the XOR requests, but async_tx will still wait for the completion of the memcpy requests before scheduling the XOR requests. It is in fact more efficient to have at most one channel per CPU, which this patch implements by limiting the number of channels per engine, and the number of engines registered depending on the number of availables CPUs. Marvell platforms are currently available in one CPU, two CPUs and four CPUs configurations: - in the configurations with one CPU, only one channel from one engine is used. - in the configurations with two CPUs, only one channel from each engine is used (they are two XOR engines) - in the configurations with four CPUs, both channels of both engines are used. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: mv_xor: remove support for dmacap,* DT propertiesThomas Petazzoni
The only reason why we had dmacap,* properties is because back when DMA_MEMSET was supported, only one out of the two channels per engine could do a memset operation. But this is something that the driver already knows anyway, and since then, the DMA_MEMSET support has been removed. The driver is already well aware of what each channel supports and the one to one mapping between Linux specific implementation details (such as dmacap,interrupt enabling DMA_INTERRUPT) and DT properties is a good indication that these DT properties are wrong. Therefore, this commit simply gets rid of these dmacap,* properties, they are now ignored, and the driver is responsible for knowing the capabilities of the hardware with regard to the dmaengine subsystem expectations. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: pl330: do not emit loop for 1 byte transfer.Michal Suchanek
When there is only one burst required do not emit loop instructions to loop exactly once. Emit just the body of the loop. Signed-off-by: Michal Suchanek <hramrach@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: dmaengine@vger.kernel.org Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: imx-sdma: Add imx6sx platform supportZidan Wang
The new Solo X has more requirements for SDMA events. So it creates a event mux to remap most of event numbers in GPR (General Purpose Register). If we want to use SDMA support for those module who do not get the even number as default, we need to configure GPR first. Thus this patch adds this support of GPR event remapping configuration to the SDMA driver. Signed-off-by: Zidan Wang <zidan.wang@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-19dmaengine: at_xdmac: fix bug in prep_dma_cyclicLudovic Desroches
In cyclic mode, the round chaining has been broken by the introduction of at_xdmac_queue_desc(): AT_XDMAC_MBR_UBC_NDE is set for all descriptors excepted for the last one. at_xdmac_queue_desc() has to be called one more time to chain the last and the first descriptors. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Fixes: 0d0ee751f7f7 ("dmaengine: xdmac: Rework the chaining logic") Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-08-18dmaengine: jz4780: Kill tasklets before unregistering the deviceAlex Smith
Tasklets may have been scheduled as a result of an earlier interrupt that could still be running. Kill them before unregistering the device. Signed-off-by: Alex Smith <alex.smith@imgtec.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Cc: dmaengine@vger.kernel.org Signed-off-by: Vinod Koul <vinod.koul@intel.com>
