Allocate a descriptor for each period of a cyclic transfer, not just the first.
Also since the callback needs to be called for each finished period make sure to
initialize the callback and callback_param fields of each descriptor in a cyclic
transfer.
Cc: stable@vger.kernel.org
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Fix to return -ENODEV when no proper base address found error
handling case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The recent "drivers/dma: remove unused support for MEMSET operations"
change has fallout from lack of build testing by the author. This
fixes:
drivers/dma/iop-adma.c:1020:13: warning: unused variable 'dma_addr' [-Wunused-variable]
drivers/dma/iop-adma.c:1519:2: warning: format '%s' expects a matching 'char *' argument [-Wformat=]
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Pull slave-dmaengine updates from Vinod Koul:
"Once you have some time from extended weekend celebrations please
consider pulling the following to get:
- Various fixes and PCI driver for dw_dmac by Andy
- DT binding for imx-dma by Markus & imx-sdma by Shawn
- DT fixes for dmaengine by Lars
- jz4740 dmac driver by Lars
- and various fixes across the drivers"
What "extended weekend celebrations"? I'm in the merge window, who has
time for extended celebrations..
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (40 commits)
DMA: shdma: add DT support
DMA: shdma: shdma_chan_filter() has to be in shdma-base.h
DMA: shdma: (cosmetic) don't re-calculate a pointer
dmaengine: at_hdmac: prepare clk before calling enable
dmaengine/trivial: at_hdmac: add curly brackets to if/else expressions
dmaengine: at_hdmac: remove unsuded atc_cleanup_descriptors()
dmaengine: at_hdmac: add FIFO configuration parameter to DMA DT binding
ARM: at91: dt: add header to define at_hdmac configuration
MIPS: jz4740: Correct clock gate bit for DMA controller
MIPS: jz4740: Remove custom DMA API
MIPS: jz4740: Register jz4740 DMA device
dma: Add a jz4740 dmaengine driver
MIPS: jz4740: Acquire and enable DMA controller clock
dma: mmp_tdma: disable irq when disabling dma channel
dmaengine: PL08x: Avoid collisions with get_signal() macro
dmaengine: dw: select DW_DMAC_BIG_ENDIAN_IO automagically
dma: dw: add PCI part of the driver
dma: dw: split driver to library part and platform code
dma: move dw_dmac driver to an own directory
dw_dmac: don't check resource with devm_ioremap_resource
This patch adds Device Tree support to the shdma driver. No special DT
properties are used, only standard DMA DT bindings are implemented. Since
shdma controllers reside on SoCs, their configuration is SoC-specific and
shall be passed to the driver from the SoC platform data, using the
auxdata procedure.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
Use an existing pointer instead of retrieving it again.
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
[nicolas.ferre@atmel.com: remove return code checking in at_dma_resume_noirq()]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Correct coding style following the patch:
7c407d3e54dcc0c79119553c8d5ef176c1d5bc3a (DMA: AT91:
Get residual bytes in dma buffer).
Since patch 7c407d3e54dcc0c79119553c8d5ef176c1d5bc3a (DMA: AT91:
Get residual bytes in dma buffer), the function
atc_cleanup_descriptors() is not used anymore. We remove it to prevent
warnings.
For most devices the FIFO configuration is the same i.e. when half FIFO size is
available/filled, a source/destination request is serviced. But USART devices
have to do it when there is enough space/data available to perform a single
AHB access so the ASAP configuration.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Now that all users of the custom jz4740 DMA API have been converted to use
the dmaengine API instead we can remove the custom API and move all the code
talking to the hardware to the dmaengine driver.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
This patch adds dmaengine support for the JZ4740 DMA controller. For now the
driver will be a wrapper around the custom JZ4740 DMA API. Once all users of the
custom JZ4740 DMA API have been converted to the dmaengine API the custom API
will be removed and direct hardware access will be added to the dmaengine
driver.
mask dma irq when disabling dma channel, so that interrupt status
will not be set and interrupt won't come again.
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
Acked-by: Zhangfei Gao <zhangfei.gao@gmail.com>
As pointed out by Arnd Bergmann there is a get_signal macro definied in
linux/signal.h which can conflict with the platform data callback
function of the same name leading to confusing errors from the compiler
(especially if signal.h manages to get pulled into the driver itself due
to header dependencies). Avoid such errors by renaming get_signal and
put_signal in the platform data to get_xfer_signal and put_xfer_signal.
Signed-off-by: Mark Brown <broonie@linaro.org>
This is the PCI part of the DesignWare DMAC driver. The controller is usually
used in the Intel hardware such as Intel Medfield.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
To simplify the driver development let's split driver to library and platform
code parts. It helps us to add PCI driver in future.
[Fixed compile error and few checkpatch issues]
The dw_dmac driver is going to be split into multiple files. To make this more
convenient move it to an own directory.
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
The microcode bus address (pl330_dmac.mcode_bus) is currently a u32,
which fails to compile when building on a system with 64-bit bus
addresses.
This patch uses dma_addr_t to represent the address instead.
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Vinod Koul <vinod.koul@intel.com>
Acked-by: Jassi Brar <jaswinder.singh@linaro.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
The PL330 driver probes the peripheral and primecell IDs of the device to
make sure that it is indeed an AMBA PL330. However, it does this by
making byte accesses to a device mapping of the word-aligned ID
registers, which is either UNPREDICTABLE or generates an alignment fault
(depending on the presence of the virtualisation extensions).
Rather than fix this code, we can actually rip most of it out and let
the AMBA bus driver correctly do the probing for us.
Update imx-sdma driver to adopt generic DMA device tree bindings. It
calls of_dma_controller_register() with imx-sdma specific of_dma_xlate
to get the generic DMA device tree helper support. The #dma-cells for
imx-sdma must be 3, which includes request ID, peripheral type and
priority.
The existing way of requesting channel, clients directly call
dma_request_channel(), still work there, and will be removed after
all imx-sdma clients get converted to generic DMA device tree helper.
read SIRFSOC_DMA_CH_ADDR register to get current dma transfer position, then
update dma residue so that things like ALSA drivers work as ALSA drivers need
the right residue value.
Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Lock scenario: Channel 1 was allocated and prepared as slave_sg, used and freed.
Now preparation of cyclic dma on channel 1 will fail with err "DMA configuration
conflict" because tdc->isr_handler still setted to handle_once_dma_done.
This happens because tegra_dma_abort_all() won't be called on channel freeing
if pending list is empty and channel not busy. We need to clear isr_handler
on channel freeing to avoid locking.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
Fixed err msg params order on irq request fail.
EXPORT_SYMBOL and inline directives are contradictory to each other.
The patch fixes this inconsistency.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Denis Efremov <yefremov.denis@gmail.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Fix the following sparse warning:
drivers/dma/mxs-dma.c:696:17: warning: symbol 'mxs_dma_xlate' was not declared. Should it be static?
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Also, unnecessary dev_set_drvdata() is removed, because the driver core
clears the driver data to NULL after device_release or on probe failure.
Add support for returning the residue for current transfer cookie by
reading the transfered buffer size(BTSIZE) in CTRLA register.
For a single buffer cookie, the descriptor length minus BTSIZE
can get the residue.
For a lli cookie, remain_desc will record remain descriptor length
when last descriptor finish, the remain_desc minus BTSIZE can get the
current residue.
If the cookie has completed successfully, the residue will be zero.
If the cookie is in progress, it will be the number of bytes yet to be transferred.
If get residue error, the cookie will be turn into error status.
Check dma fifo to see if data remain, let issue pending finish remain work if there is.
Signed-off-by: Elen Song <elen.song@atmel.com>
In one dma transfer, the data transfer width can be configured and it is limited by source or destination peripheral width,
tx_width will save the transfer width, but for memcpy, either source or destination transfer width is taken as tx_width.
No modification in CFG register configuration, just rearrange
bits directives to group logically and make it more readable.
Peripheral handshaking identification numbers can be bigger than 15, so new
fields have been created in the CFG register.
Add macros to take this modification into account and use them in
at_dma_xlate() function.
imxdma->dev is used for dev_warn before it was set.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Adding devicetree support for imx-dma driver. Use driver name for
function 'imx_dma_is_general_purpose' because the devicename for
devicetree initialized devices is different.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
There have never been any real users of MEMSET operations since they
have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine:
refactor dmaengine around dma_async_tx_descriptor"). Therefore remove
support for them for now, it can be always brought back when needed.
[sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Dan Williams <djbw@fb.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@linaro.org>
tasklet_kill() may sleep so call it before taking pch->lock.
Fixes following lockup:
BUG: scheduling while atomic: cat/2383/0x00000002
Modules linked in:
unwind_backtrace+0x0/0xfc
__schedule_bug+0x4c/0x58
__schedule+0x690/0x6e0
sys_sched_yield+0x70/0x78
tasklet_kill+0x34/0x8c
pl330_free_chan_resources+0x24/0x88
dma_chan_put+0x4c/0x50
BUG: spinlock lockup suspected on CPU#0, swapper/0/0
lock: 0xe52aa04c, .magic: dead4ead, .owner: cat/2383, .owner_cpu: 1
do_raw_spin_lock+0x194/0x204
_raw_spin_lock_irqsave+0x20/0x28
pl330_tasklet+0x2c/0x5a8
tasklet_action+0xfc/0x114
__do_softirq+0xe4/0x19c
irq_exit+0x98/0x9c
handle_IPI+0x124/0x16c
gic_handle_irq+0x64/0x68
__irq_svc+0x40/0x70
cpuidle_wrap_enter+0x4c/0xa0
cpuidle_enter_state+0x18/0x68
cpuidle_idle_call+0xac/0xe0
cpu_idle+0xac/0xf0
Acked-by: Jassi Brar <jassisinghbrar@gmail.com>
Cc: Vinod Koul <vinod.koul@linux.intel.com>
Cc: <stable@vger.kernel.org>
Pull power management and ACPI updates from Rafael Wysocki:
"This time the total number of ACPI commits is slightly greater than
the number of cpufreq commits, but Viresh Kumar (who works on cpufreq)
remains the most active patch submitter.
To me, the most significant change is the addition of offline/online
device operations to the driver core (with the Greg's blessing) and
the related modifications of the ACPI core hotplug code. Next are the
freezer updates from Colin Cross that should make the freezing of
tasks a bit less heavy weight.
We also have a couple of regression fixes, a number of fixes for
issues that have not been identified as regressions, two new drivers
and a bunch of cleanups all over.
Highlights:
- Hotplug changes to support graceful hot-removal failures.
It sometimes is necessary to fail device hot-removal operations
gracefully if they cannot be carried out completely. For example,
if memory from a memory module being hot-removed has been allocated
for the kernel's own use and cannot be moved elsewhere, it's
desirable to fail the hot-removal operation in a graceful way
rather than to crash the kernel, but currenty a success or a kernel
crash are the only possible outcomes of an attempted memory
hot-removal. Needless to say, that is not a very attractive
alternative and it had to be addressed.
However, in order to make it work for memory, I first had to make
it work for CPUs and for this purpose I needed to modify the ACPI
processor driver. It's been split into two parts, a resident one
handling the low-level initialization/cleanup and a modular one
playing the actual driver's role (but it binds to the CPU system
device objects rather than to the ACPI device objects representing
processors). That's been sort of like a live brain surgery on a
patient who's riding a bike.
So this is a little scary, but since we found and fixed a couple of
regressions it caused to happen during the early linux-next testing
(a month ago), nobody has complained.
As a bonus we remove some duplicated ACPI hotplug code, because the
ACPI-based CPU hotplug is now going to use the common ACPI hotplug
code.
- Lighter weight freezing of tasks.
These changes from Colin Cross and Mandeep Singh Baines are
targeted at making the freezing of tasks a bit less heavy weight
operation. They reduce the number of tasks woken up every time
during the freezing, by using the observation that the freezer
simply doesn't need to wake up some of them and wait for them all
to call refrigerator(). The time needed for the freezer to decide
to report a failure is reduced too.
Also reintroduced is the check causing a lockdep warining to
trigger when try_to_freeze() is called with locks held (which is
generally unsafe and shouldn't happen).
- cpufreq updates
First off, a commit from Srivatsa S Bhat fixes a resume regression
introduced during the 3.10 cycle causing some cpufreq sysfs
attributes to return wrong values to user space after resume. The
fix is kind of fresh, but also it's pretty obvious once Srivatsa
has identified the root cause.
Second, we have a new freqdomain_cpus sysfs attribute for the
acpi-cpufreq driver to provide information previously available via
related_cpus. From Lan Tianyu.
Finally, we fix a number of issues, mostly related to the
CPUFREQ_POSTCHANGE notifier and cpufreq Kconfig options and clean
up some code. The majority of changes from Viresh Kumar with bits
from Jacob Shin, Heiko Stübner, Xiaoguang Chen, Ezequiel Garcia,
Arnd Bergmann, and Tang Yuantian.
- ACPICA update
A usual bunch of updates from the ACPICA upstream.
During the 3.4 cycle we introduced support for ACPI 5 extended
sleep registers, but they are only supposed to be used if the
HW-reduced mode bit is set in the FADT flags and the code attempted
to use them without checking that bit. That caused suspend/resume
regressions to happen on some systems. Fix from Lv Zheng causes
those registers to be used only if the HW-reduced mode bit is set.
Apart from this some other ACPICA bugs are fixed and code cleanups
are made by Bob Moore, Tomasz Nowicki, Lv Zheng, Chao Guan, and
Zhang Rui.
- cpuidle updates
New driver for Xilinx Zynq processors is added by Michal Simek.
Multidriver support simplification, addition of some missing
kerneldoc comments and Kconfig-related fixes come from Daniel
Lezcano.
- ACPI power management updates
Changes to make suspend/resume work correctly in Xen guests from
Konrad Rzeszutek Wilk, sparse warning fix from Fengguang Wu and
cleanups and fixes of the ACPI device power state selection
routine.
- ACPI documentation updates
Some previously missing pieces of ACPI documentation are added by
Lv Zheng and Aaron Lu (hopefully, that will help people to
uderstand how the ACPI subsystem works) and one outdated doc is
updated by Hanjun Guo.
- Assorted ACPI updates
We finally nailed down the IA-64 issue that was the reason for
reverting commit 9f29ab11ddbf ("ACPI / scan: do not match drivers
against objects having scan handlers"), so we can fix it and move
the ACPI scan handler check added to the ACPI video driver back to
the core.
A mechanism for adding CMOS RTC address space handlers is
introduced by Lan Tianyu to allow some EC-related breakage to be
fixed on some systems.
A spec-compliant implementation of acpi_os_get_timer() is added by
Mika Westerberg.
The evaluation of _STA is added to do_acpi_find_child() to avoid
situations in which a pointer to a disabled device object is
returned instead of an enabled one with the same _ADR value. From
Jeff Wu.
Intel BayTrail PCH (Platform Controller Hub) support is added to
the ACPI driver for Intel Low-Power Subsystems (LPSS) and that
driver is modified to work around a couple of known BIOS issues.
Changes from Mika Westerberg and Heikki Krogerus.
The EC driver is fixed by Vasiliy Kulikov to use get_user() and
put_user() instead of dereferencing user space pointers blindly.
Code cleanups are made by Bjorn Helgaas, Nicholas Mazzuca and Toshi
Kani.
- Assorted power management updates
The "runtime idle" helper routine is changed to take the return
values of the callbacks executed by it into account and to call
rpm_suspend() if they return 0, which allows us to reduce the
overall code bloat a bit (by dropping some code that's not
necessary any more after that modification).
The runtime PM documentation is updated by Alan Stern (to reflect
the "runtime idle" behavior change).
New trace points for PM QoS are added by Sahara
(<keun-o.park@windriver.com>).
PM QoS documentation is updated by Lan Tianyu.
Code cleanups are made and minor issues are addressed by Bernie
Thompson, Bjorn Helgaas, Julius Werner, and Shuah Khan.
- devfreq updates
New driver for the Exynos5-bus device from Abhilash Kesavan.
Minor cleanups, fixes and MAINTAINERS update from MyungJoo Ham,
Abhilash Kesavan, Paul Bolle, Rajagopal Venkat, and Wei Yongjun.
- OMAP power management updates
Adaptive Voltage Scaling (AVS) SmartReflex voltage control driver
updates from Andrii Tseglytskyi and Nishanth Menon."
* tag 'pm+acpi-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
cpufreq: Fix cpufreq regression after suspend/resume
ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state()
PM / Sleep: Warn about system time after resume with pm_trace
cpufreq: don't leave stale policy pointer in cdbs->cur_policy
acpi-cpufreq: Add new sysfs attribute freqdomain_cpus
cpufreq: make sure frequency transitions are serialized
ACPI: implement acpi_os_get_timer() according the spec
ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan
ACPI: Add CMOS RTC Operation Region handler support
ACPI / processor: Drop unused variable from processor_perflib.c
cpufreq: tegra: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: s3c64xx: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: omap: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: imx6q: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: exynos: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: dbx500: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: davinci: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: arm-big-little: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: powernow-k8: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: pcc: call CPUFREQ_POSTCHANGE notfier in error cases
Pull ARM SoC driver specific changes from Arnd Bergmann:
"These changes are all driver specific and cross over between arm-soc
contents and some other subsystem, in these cases cpufreq, crypto,
dma, pinctrl, mailbox and usb, and the subsystem owners agreed to have
these changes merged through arm-soc.
As we proceed to untangle the dependencies between platform code and
driver code, the amount of changes in this category is fortunately
shrinking, for 3.11 we have 16 branches here and 101 non-merge
changesets, the majority of which are for the stedma40 dma engine
driver used in the ux500 platform. Cleaning up that code touches
multiple subsystems, but gets rid of the dependency in the end.
The mailbox code moved out from mach-omap2 to drivers/mailbox is an
intermediate step and is still omap specific at the moment. Patches
exist to generalize the subsystem and add other drivers with the same
API, but those did not make it for 3.11."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits)
crypto: ux500: use dmaengine_submit API
crypto: ux500: use dmaengine_prep_slave_sg API
crypto: ux500: use dmaengine_device_control API
crypto: ux500/crypt: add missing __iomem qualifiers
crypto: ux500/hash: add missing static qualifiers
crypto: ux500/hash: use readl on iomem addresses
dmaengine: ste_dma40: Declare memcpy config as static
ARM: ux500: Remove mop500_snowball_ethernet_clock_enable()
ARM: ux500: Correct the EN_3v3 regulator's on/off GPIO
ARM: ux500: Provide a AB8500 GPIO Device Tree node
gpio: rcar: fix gpio_rcar_of_table
gpio-rcar: Remove #ifdef CONFIG_OF around OF-specific sections
gpio-rcar: Reference core gpio documentation in the DT bindings
clk: exynos5250: Add enum entries for divider clock of i2s1 and i2s2
ARM: dts: Update Samsung I2S documentation
ARM: dts: add clock provider information for i2s controllers in Exynos5250
ARM: dts: add Exynos audio subsystem clock controller node
clk: samsung: register audio subsystem clocks using common clock framework
ARM: dts: use #include for all device trees for Samsung
pinctrl: s3c24xx: use correct header for chained_irq functions
* pm-assorted:
PM / QoS: Add pm_qos and dev_pm_qos to events-power.txt
PM / QoS: Add dev_pm_qos_request tracepoints
PM / QoS: Add pm_qos_request tracepoints
PM / QoS: Add pm_qos_update_target/flags tracepoints
PM / QoS: Update Documentation/power/pm_qos_interface.txt
PM / Sleep: Print last wakeup source on failed wakeup_count write
PM / QoS: correct the valid range of pm_qos_class
PM / wakeup: Adjust messaging for wake events during suspend
PM / Runtime: Update .runtime_idle() callback documentation
PM / Runtime: Rework the "runtime idle" helper routine
PM / Hibernate: print physical addresses consistently with other parts of kernel
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/drivers
From Linus Walleij:
DMA40 fixes for earlier submitted driver patches:
- Fix various error path and sparse bugs in the DMA40 driver
- Fix various compile errors in the ux500 crypto driver
(dependent on the DMA40 changes).
* tag 'ux500-dma40-for-arm-soc-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
dmaengine: ste_dma40: fix error return code in d40_probe()
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
From Sekhar Nori:
DaVinci SoC updates for v3.11 - part 2
This pull request adds DT and runtime PM to
EDMA ARM private API so it can be used on
DT enabled DaVinci and OMAP platforms.
Also adds DMA channel crossbar mapping
support to be used by DT-enabled platforms
which use it.
* tag 'davinci-for-v3.11/soc-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
dmaengine: edma: enable build for AM33XX
ARM: edma: Add EDMA crossbar event mux support
ARM: edma: Add DT and runtime PM support to the private EDMA API
dmaengine: edma: Add TI EDMA device tree binding
ARM: edma: Convert to devm_* api
Fix sparse warnings:
drivers/dma/ste_dma40.c:81:26: warning: symbol 'dma40_memcpy_conf_phy' was not declared. Should it be static?
drivers/dma/ste_dma40.c:95:26: warning: symbol 'dma40_memcpy_conf_log' was not declared. Should it be static?
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Enable TI EDMA option on OMAP and TI_PRIV_EDMA
Signed-off-by: Matt Porter <mporter@ti.com>
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
From Sekhar Nori:
DaVinci SoC changes for v3.11
This pull request moves DaVinci EDMA library to
arch/arm/common so it can be used by OMAP based AM335x.
This is a temporary step until all drivers are converted
to use the dmaengine driver in drivers/dma/edma.c.
Several drivers like SPI, MMC/SD have already been converted.
Some like audio are pending.
The other two patches in the pull request are cleanup in nature.
* tag 'davinci-for-v3.11/soc-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: edma: remove unused transfer controller handlers
ARM: davinci: move private EDMA API to arm/common
ARM: davinci: remove __init atrribute from function declaration
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/soc
From Linus Walleij:
Device Tree and Multiplatform support for U300:
- Add devicetree support to timer, pinctrl (probe), I2C block,
watchdog, DMA controller and clocks.
- Piecewise add a device tree containing all peripherals.
- Delete the ATAG boot path.
- Delete redundant platform data and board files.
- Convert to multiplatform.
* tag 'u300-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: (40 commits)
ARM: u300: switch to using syscon regmap for board
ARM: u300: Update MMC configs for u300 defconfig
spi: pl022: use DMA by default when probing from DT
pinctrl: get rid of all platform data for coh901
ARM: u300: convert MMC/SD clock to device tree
ARM: u300: move the gated system controller clocks to DT
i2c: stu300: do not request a specific clock name
clk: move the U300 fixed and fixed-factor to DT
ARM: u300: remove register definition file
ARM: u300: add syscon node
ARM: u300 use module_spi_driver to register driver
ARM: u300: delete remnant machine headers
ARM: u300: convert to multiplatform
ARM: u300: localize <mach/u300-regs.h>
ARM: u300: delete <mach/irqs.h>
ARM: u300: delete <mach/hardware.h>
ARM: u300: push down syscon registers
ARM: u300: remove deps from debug macro
ARM: u300: move debugmacro to debug includes
ARM: u300: delete all static board data
Move mach-davinci/dma.c to common/edma.c so it can be used
by OMAP (specifically AM33xx) as well.
Acked-by: Chris Ball <cjb@laptop.org> # davinci_mmc.c
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
[nsekhar@ti.com: dropped davinci sffsdr changes]
