* don't dump info which mcheck already does
* update to newest BKDG
* mv amd64_process_error_info -> amd64_decode_nb_mce
* shorten error struct names
* remove redundant info ptr in amd64_process_error_info
* remove unused ErrorCodeExt[19:16] (MCx_STATUS) defines
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
* mv amd64_error_info_regs -> err_regs
This is in preparation of adding AMD-specific MCE decoding functionality
to the EDAC core. The error decoding macros originate from the AMD64
EDAC driver albeit in a simplified and cleaned up version here.
While at it, add macros to generate the error description strings and
use them in the error type decoders directly which removes a bunch of
code and makes the decoding functions much more readable. Also, fix
strings and shorten macro names.
Remove superfluous htlink_msgs.
- cleanup debug calls
- shorten function names
- cleanup error exit paths
Also, link into Kbuild by adding Kconfig and Makefile entries.
Borislav:
- Kconfig/Makefile splitting
- use zero-sized arrays for the sysfs attrs if not enabled
- rename sysfs attrs to more conform values
- shorten CONFIG_ names
- make multiple structure members assignment vertically aligned
- fix/cleanup comments
- fix function return value patterns
- fix err labels
- fix a memleak bug caught by Ingo
- remove the NUMA dependency and use num_k8_northbrides for initializing
a driver instance per NB.
- do not copy the pvt contents into the mci struct in
amd64_init_2nd_stage() and save it in the mci->pvt_info void ptr
instead.
- simplify amd64_setup_pci_device()
Reviewed-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Doug Thompson <dougthompson@xmission.com>
Borislav:
- convert to the new {rd|wr}msr_on_cpus interfaces.
- convert pvt->old_mcgctl to a bitmask thus saving some bytes
- add a proper bugfix found by Doug to amd64_check_ecc_enabled where we
missed checking for the ECC enabled bit in NB CFG.
Borislav:
- remove register bit descriptions (complete text in BKDG)
- cleanup and remove excessive/superfluous comments
