path: root/drivers/edac/edac_mce_amd.c
2010-10-21EDAC, MCE: Rename filesBorislav Petkov
Drop "edac_" string from the filenames since they're prefixed with edac/ in their pathname anyway. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21EDAC, MCE: Rework MCE injectionBorislav Petkov
Add sysfs injection facilities for testing of the MCE decoding code. Remove large parts of amd64_edac_dbg.c, as a result, which did only NB MCE injection anyway and the new injection code supports that functionality already. Add an injection module so that MCE decoding code in production kernels like those in RHEL and SLES can be tested. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21EDAC, MCE: Pass complete MCE info to decodersBorislav Petkov
... instead of the MCi_STATUS info only for improved handling of certain types of errors later. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21EDAC, MCE: Sanitize error codesBorislav Petkov
Clean up error codes names, shorten to mnemonics, add RRRR boundary checking. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21EDAC, MCE: Remove unused function parameterBorislav Petkov
Remove remains from previous functionality. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-10-21EDAC, MCE: Add HW_ERR prefixBorislav Petkov
.. so that the user knows what she's looking at there in dmesg. Also, fix a minor cosmetic output inconsistency. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-26amd64_edac: Do not report error overflow as a separate errorBorislav Petkov
When the Overflow MCi_STATUS bit is set, EDAC reports the lost error with a "no information available" message which often puzzles users parsing the dmesg. This doesn't make much sense since this error has been lost anyway so no need for reporting it separately. Thus, report the overflow bit setting in the MCE dump instead. While at it, remove reporting of MiscV and ErrorEnable (en) which are superfluous. Now it looks like this: [ 1501.650024] MC4_STATUS: Corrected error, other errors lost: yes, CPU context corrupt: no, CECC Error [ 1501.666887] Northbridge Error, node 2 Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-24MCE, AMD: Limit MCE decoding to current families for nowBorislav Petkov
Limit MCE error decoding to current and older families only (K8-F11h). Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-03amd64_edac: Remove polling mechanismBorislav Petkov
Switch to reusing the mcheck core's machine check polling mechanism instead of duplicating functionality by using the EDAC polling routine. Correct formatting while at it. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-04-30edac, mce: Fix wrong mask and macro usageBorislav Petkov
Correct two mishaps which prevented reporting error type (CECC vs UECC) and extended error description. Cc: <stable@kernel.org> # 32.x, 33.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-22edac, mce: Filter out invalid valuesBorislav Petkov
Print the CPU associated with the error only when the field is valid. Cc: <stable@kernel.org> # .32.x .33.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-12-16edac, mce, amd: silence GART TLB errorsBorislav Petkov
Although reporting of benign GART TLB errors is disabled in __mcheck_cpu_apply_quirks, those are still being logged, and, as a result, trip up amd64_edac. Pull up reporting check so that machines with loaded edac module bail out early and don't spit fragments into dmesg. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-12-15edac, mce: correct corenum reportingBorislav Petkov
Fix core number reporting with NB MCEs. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-12-07edac, mce: update AMD F10h revD checkBorislav Petkov
F10h revD start with model number 8. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-10-12mce, edac: Use an atomic notifier for MCEs decodingBorislav Petkov
Add an atomic notifier which ensures proper locking when conveying MCE info to EDAC for decoding. The actual notifier call overrides a default, negative priority notifier. Note: make sure we register the default decoder only once since mcheck_init() runs on each CPU. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> LKML-Reference: <20091003065752.GA8935@liondog.tnic> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-02x86: EDAC: carve out AMD MCE decoding logicBorislav Petkov
This converts the MCE decoding logic into a standalone config option which can be built-in or a module, the first one being the default for MCEs happening early on in the boot process. This, beyond being separated in a cleaner way, also saves RAM by making the decoding logic modular. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <20091002133148.GD28682@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-02x86: EDAC: MCE: Fix MCE decoding callback logicIngo Molnar
Make decoding of MCEs happen only on AMD hardware by registering a non-default callback only on CPU families which support it. While looking at the interaction of decode_mce() with the other MCE code i also noticed a few other things and made the following cleanups/fixes: - Fixed the mce_decode() weak alias - a weak alias is really not good here, it should be a proper callback. A weak alias will be overriden if a piece of code is built into the kernel - not good, obviously. - The patch initializes the callback on AMD family 10h and 11h. - Added the more correct fallback printk of: No support for human readable MCE decoding on this CPU type. Transcribe the message and run it through 'mcelog --ascii' to decode. On CPUs that dont have a decoder. - Made the surrounding code more readable. Note that the callback allows us to have a default fallback - without having to check the CPU versions during the printout itself. When an EDAC module registers itself, it can install the decode-print function. (there's no unregister needed as this is core code.) version -v2 by Borislav Petkov: - add K8 to the set of supported CPUs - always build in edac_mce_amd since we use an early_initcall now - fix checkpatch warnings Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <20091001141432.GA11410@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16x86, EDAC: Provide function to return NodeId of a CPUAndreas Herrmann
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: H. Peter Anvin <hpa@zytor.com>
2009-09-14EDAC, AMD: decode FR MCEsBorislav Petkov
See Fam10h BKDG (31116, rev. 3.28), Table 101. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: decode load store MCEsBorislav Petkov
See Fam10h BKDG (31116, rev. 3.28), Table 100. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: decode bus unit MCEsBorislav Petkov
... according to Table 69, Fam10h BKDG (31116, rev. 3.28). Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: decode instruction cache MCEsBorislav Petkov
See Fam10h BKDG (31116, rev. 3.28), Table 95 Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: decode data cache MCEsBorislav Petkov
Those get reported in MC0_STATUS, see Table 92, F10h BKDG (31116, rev. 3.28) for more details. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: carve out decoding of MCi_STATUS ErrorCodeBorislav Petkov
This is the MCE error code from the MCi_STATUS banks, bits [15:0] which describe what type of error was encountered: GART TLB, Memory or Bus error. The semantics of those bits are identical across all MCE banks so decode those separately, irrespectively of MCE type. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC, AMD: carve out MCi_STATUS decodingBorislav Petkov
The MCi_STATUS registers have most field definitions in common so decode them in the general path. Do not pass ecc_type along and compute it in __amd64_decode_bus_error instead. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14x86, mce: pass mce info to EDAC for decodingBorislav Petkov
Move NB decoder along with required defines to EDAC MCE core. Add registration routines for further decoding of the MCE info in the AMD64 EDAC module. CC: Andi Kleen <andi@firstfloor.org> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2009-09-14EDAC: beef up ErrorCodeExt error signaturesBorislav Petkov
2009-09-14EDAC: move MCE error descriptions to EDAC coreBorislav Petkov
This is in preparation of adding AMD-specific MCE decoding functionality to the EDAC core. The error decoding macros originate from the AMD64 EDAC driver albeit in a simplified and cleaned up version here. While at it, add macros to generate the error description strings and use them in the error type decoders directly which removes a bunch of code and makes the decoding functions much more readable. Also, fix strings and shorten macro names. Remove superfluous htlink_msgs. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
