path: root/drivers/edac/edac_pci.c
2011-05-26edac,rcu: use synchronize_rcu() instead of call_rcu()+rcu_barrier()Lai Jiangshan
synchronize_rcu() does the stuff as needed. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24edac: core: remove completion-wait for complete with rcu_barrierJesper Dangaard Brouer
Module edac_core.ko uses call_rcu() callbacks in edac_device.c, edac_mc.c and edac_pci.c. They all use a wait_for_completion() scheme, but this scheme it not 100% safe on multiple CPUs. See the _rcu_barrier() implementation which explains why extra precausion is needed. The patch adds a comment about rcu_barrier() and as a precausion calls rcu_barrier(). A maintainer needs to look at removing the wait_for_completion code. [dougthompson@xmission.com: remove the wait_for_completion code] Signed-off-by Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13edac: use to_delayed_work()Jean Delvare
The edac-core driver includes code which assumes that the work_struct which is included in every delayed_work is the first member of that structure. This is currently the case but might change in the future, so use to_delayed_work() instead, which doesn't make such an assumption. linux-2.6.30-rc1 has the to_delayed_work() function that will allow this patch to work Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02edac: Add edac_pci_alloc_index()Harry Ciao
Add edac_pci_alloc_index(), because for MAPLE platform there may exist several EDAC driver modules that could make use of edac_pci_ctl_info structure at the same time. The index allocation for these structures should be taken care of by EDAC core. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06edac: struct device: replace bus_id with dev_name(), dev_set_name()Kay Sievers
This patch is part of a larger patch series which will remove the "char bus_id[20]" name string from struct device. The device name is managed in the kobject anyway, and without any size limitation, and just needlessly copied into "struct device". [akpm@linux-foundation.org: coding-style fixes] Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05dev_name introduction fall out fixStephen Rothwell
Commit 06916639e2fed9ee475efef2747a1b7429f8fe76 ("driver-core: add dev_name() to help transition away from using bus_id") added a static inline dev_name() and used it in dev_printk. Unfortunately, drivers/edac/edac_core.h defines a macro called dev_name(). Rename the latter. Diagnosis by Tony Breeds and Michael Ellerman. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edac: remove unneeded functions and add static accessorAdrian Bunk
Collection of patches, merged into one, from Adrian that do the following: 1) This patch makes the following needlessly global functions static: - edac_pci_get_log_pe() - edac_pci_get_log_npe() - edac_pci_get_panic_on_pe() - edac_pci_unregister_sysfs_instance_kobj() - edac_pci_main_kobj_setup() 2) Remove unneeded function edac_device_find() 3) Added #if 0 around function edac_pci_find() 4) make the needlessly global edac_pci_generic_check() static 5) Removed function edac_check_mc_devices() Doug Thompson modified Adrian's patches, to bettern represent the direction of EDAC, and make them one patch. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edac: use the shorter LIST_HEAD for brevityRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07drivers-edac: use round_jiffies_relativeAnton Blanchard
When rounding a relative timeout we need to use round_jiffies_relative(). Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/edac/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-26drivers/edac: fix edac_pci sysfsDoug Thompson
This patch fixes sysfs exit code for the EDAC PCI device in a similiar manner and the previous fixes for EDAC_MC and EDAC_DEVICE. It removes the old (and incorrect) completion model and uses reference counts on per instance kobjects and on the edac core module. This pattern was applied to the edac_mc and edac_device code, but the EDAC PCI code was missed. In addition, this fixes a system hang after a low level driver was unloaded. (A cleanup function was called twice, which really screwed things up) Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod edac_opt_state_to_string functionDouglas Thompson
Refactored the function edac_op_state_toString() to be edac_op_state_to_string() for consistent style, and its callers Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: remove null from staticsDouglas Thompson
Patches to conform to coding style, namely static don't need to be initialized to NULL nor '0', as that is the default Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: cleanup spaces-gotos after Lindent messupDouglas Thompson
This patch fixes some remnant spaces inserted by the use of Lindent. Seems Lindent adds some spaces when it shoulded. These have been fixed. In addition, goto targets have issues, these have been fixed in this patch. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: cleanup workq ifdefsDouglas Thompson
The origin of this code comes from patches at sourceforge, that allow EDAC to be updated to various kernels. With kernel version 2.6.20 a new workq system was installed, thus the patches needed to be modified based on the kernel version. For submitting to the latest kernel.org those #ifdefs are removed Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: core Lindent cleanupDouglas Thompson
Run the EDAC CORE files through Lindent for cleanup Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod PCI poll namesDave Jiang
Fixup poll values for MC and PCI. Also make mc function names unique to mc. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmissin.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: updated PCI monitoringDave Jiang
Moving PCI to a per-instance device model This should include the correct sysfs setup as well. Please review. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
