path: root/drivers/edac/i7300_edac.c
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-04-19edac: Drop __DATE__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Doug Thompson <dougthompson@xmission.com> Cc: bluesmoke-devel@lists.sourceforge.net Cc: linux-edac@vger.kernel.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-19Kill off warning: ‘inline’ is not at beginning of declarationJesper Juhl
Fix a bunch of warning: ‘inline’ is not at beginning of declaration messages when building a 'make allyesconfig' kernel with -Wextra. These warnings are trivial to kill, yet rather annoying when building with -Wextra. The more we can cut down on pointless crap like this the better (IMHO). A previous patch to do this for a 'allnoconfig' build has already been merged. This just takes the cleanup a little further. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-24i7300_edac: Properly initialize per-csrow memory sizeMauro Carvalho Chehab
Due to the current edac-core limits, we cannot represent a per-channel memory size, for FB-DIMM drivers. So, we need to sum-up all values for each slot, in order to properly represent the total amount of memory found by the i7300 driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-24V4L/DVB: i7300_edac: better initialize page countsMauro Carvalho Chehab
It is still somewhat fake, as the pages may not be on this exact order, and may even be used in mirror mode, but this is a best guess than the other random fake values. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300-edac: CodingStyle cleanupMauro Carvalho Chehab
2010-08-30i7300_edac: Improve commentsMauro Carvalho Chehab
This is basically a cleanup patch, improving the comments for each function. While here, do a few cleanups. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Cleanup: reorganize the file contentsMauro Carvalho Chehab
This change should do no functional change. It just rearranges the contents of the c file, in order to make easier to understand and maintain it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Properly detect channel on CE errorsMauro Carvalho Chehab
2010-08-30i7300_edac: enrich FBD error info for corrected errorsMauro Carvalho Chehab
2010-08-30i7300_edac: enrich FBD error info for fatal errorsMauro Carvalho Chehab
2010-08-30i7300_edac: pre-allocate a buffer used to prepare err messagesMauro Carvalho Chehab
Instead of dynamically allocating a buffer for it where needed, just allocate it once. As we'll use the same buffer also during fatal and non-fatal errors, is is very risky to dynamically allocate it during an error. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Fix MTR x4/x8 detection logicMauro Carvalho Chehab
2010-08-30i7300_edac: Make the debug messages coherent with the othersMauro Carvalho Chehab
2010-08-30i7300_edac: Cleanup: remove get_error_info logicMauro Carvalho Chehab
As the error logic in this driver came from i5400 driver, it were using one function to get errors, and another to display. Let's make it simpler and avoid doing it into two steps. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Add a code to cleanup error registersMauro Carvalho Chehab
2010-08-30i7300_edac: Add support for reporting FBD errorsMauro Carvalho Chehab
2010-08-30i7300_edac: Properly detect the type of error correctionMauro Carvalho Chehab
2010-08-30i7300_edac: Detect if the device is on single modeMauro Carvalho Chehab
2010-08-30i7300_edac: Adds detection for enhanced scrub mode on x8Mauro Carvalho Chehab
While here, do some cleanup by adding some macros to check for device features. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Clear the error bit after readingMauro Carvalho Chehab
2010-08-30i7300_edac: Add error detection code for global errorsMauro Carvalho Chehab
There's no mention at the datasheet about how to enable global error reporting. So, I'm assuming that those errors are always enabled. Maybe I'm plain wrong about that ;) Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-30i7300_edac: Better name PCI devicesMauro Carvalho Chehab
2010-08-30i7300_edac: Add a FIXME note about the error correction typeMauro Carvalho Chehab
2010-08-30i7300_edac: add global error registersMauro Carvalho Chehab
2010-08-30i7300_edac: display info if ECC is enabled or notMauro Carvalho Chehab
2010-08-30i7300_edac: start a driver for i7300 chipset (Clarksboro)Mauro Carvalho Chehab
