path: root/drivers/edac/i82443bxgx_edac.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27drivers/edac: convert logging messages direct uses of __FILE__ to %s, __FILEJoe Perches
Reduces text by eliminating multiple __FILE__ uses. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Tim Small <tim@buttersideup.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-18PCI: fix typos pci_device_dis/enable to pci_dis/enable_device in commentsRoman Fietze
This fixes all occurrences of pci_enable_device and pci_disable_device in all comments. There are no code changes involved. Signed-off-by: Roman Fietze <roman.fietze@telemotive.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-10-16edac: make i82443bxgx_edac coexist with intel_agpVladislav Bogdanov
Fix 443BX/GX MCH suppport in a EDAC. It makes i82443bxgx_edac coexist with intel_agp using the same approach as several other EDAC drivers. Tested on Intel's L443GX with redhat's 2.6.18 with whole EDAC subsystem backported a while ago. [root@host ~]# dmesg|grep -iE '(AGP|EDAC)' Linux agpgart interface v0.101 (c) Dave Jones agpgart: Detected an Intel 440GX Chipset. agpgart: AGP aperture is 64M @ 0xf8000000 EDAC MC: Ver: 2.1.0 Jun 27 2008 EDAC MC0: Giving out device to 'i82443bxgx_edac' 'I82443BXGX': DEV 0000:00:00.0 EDAC PCI0: Giving out device to module 'i82443bxgx_edac' controller 'EDAC PCI controller': DEV '0000:00:00.0' (POLLED) Signed-off-by: Vladislav Bogdanov <slava@nsys.by> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edac: fix module initialization on several modules 2nd timeHitoshi Mitake
I implemented opstate_init() as a inline function in linux/edac.h. added calling opstate_init() to: i82443bxgx_edac.c i82860_edac.c i82875p_edac.c i82975x_edac.c I wrote a fixed patch of edac-fix-module-initialization-on-several-modules.patch, and tested building 2.6.25-rc7 with applying this. It was succeed. I think the patch is now correct. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: fix edac_mc init apisDoug Thompson
Refactoring of sysfs code necessitated the refactoring of the edac_mc_alloc() and edac_mc_add_mc() apis, of moving the index value to the alloc() function. This patch alters the in tree drivers to utilize this new api signature. Having the index value performed later created a chicken-and-the-egg issue. Moving it to the alloc() function allows for creating the necessary sysfs entries with the proper index number Cc: Alan Cox alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: cleanup spaces-gotos after Lindent messupDouglas Thompson
This patch fixes some remnant spaces inserted by the use of Lindent. Seems Lindent adds some spaces when it shoulded. These have been fixed. In addition, goto targets have issues, these have been fixed in this patch. Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: drivers to use new PCI operationDave Jiang
Move x86 drivers to new pci controller setup Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: Lindent i82443bxgxDouglas Thompson
Run i82443bxgx.c file through Lindent for cleanup Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add dev_name getter functionDave Jiang
Move dev_name() macro to a more generic interface since it's not possible to determine whether a device is pci, platform, or of_device easily. Now each low level driver sets the name into the control structure, and the EDAC core references the control structure for the information. Better abstraction. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: mod use edac_core.hDouglas Thompson
In the refactoring of edac_mc.c into several subsystem files, the header file edac_mc.h became meaningless. A new header file edac_core.h was created. All the files that previously included "edac_mc.h" are changed to include "edac_core.h". Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: new i82443bxgz MC driverTim Small
This is a NEW EDAC Memory Controller driver for the 440BX chipset (I82443BXGX) created and submitted by Timm Small Signed-off-by: Tim Small <tim@buttersideup.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
